PDA
View Full Version : Engine Mechanical Topics
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 117 M-8 to 131
  2. Four drain plugs...??
  3. Cam Plate Bolt #1 stripped,Stud or Helicoil fix? I'm stuck here.
  4. SE 211 replacement cam
  5. '89 Sportster Cam Bearings
  6. is it okay to mix mineral and synthetic oil??
  7. New lifters needed ? Stage 2
  8. Base gasket question
  9. Head bolt over torque
  10. 2007 96 twin cam dyna top end damage, sumping
  11. 2006 FXSTD Engine Swap
  12. 124” or 117” build on a 04 fxdx 88”
  13. 2006 softail fuel pump installation questions
  14. Engine break-in insight
  15. 24 Center cooled heads
  16. Pistons and cylinders
  17. Pinion Gear nightmare
  18. Loctite on engine bolts? (09 sportster)
  19. Scavenge oil change with DK Custom Oil relocation kit
  20. UPDATE
  21. To change inner TC cam bearings or not
  22. Cold Start Lifter Tick
  23. Stock bore 96 with 10.5:1 piston ?
  24. CAM INSTALL ISSUES
  25. Time to rebuild a fxr
  26. What epoxy for new SE compensator install
  27. Piston to Valve Clearance
  28. request for clear close up photos of knuckle rocker boxes
  29. 114 m8 Dip stick shows no oil on jiffy stand. Just did an oil change.
  30. 107 winter warm up
  31. Opinion on dyno
  32. Cams
  33. 2009 Sportster 883c Rocker Box Question
  34. High compression
  35. Shovelhead cam replacement
  36. StarRacing 30/30
  37. Cam opinions 447 or....
  38. 2015 FLHXS Camchest
  39. Road King flooded in hurricane "won't start"
  40. Starting issue on my night train 09
  41. 107 twin cam rattle/tapping
  42. Frustrated
  43. Diving into 1999 TC88 Tensioner Replacement
  44. S&S 91CC Super Stock heads flw numbes
  45. Best Twin Cam cylinder base O-Ring?
  46. 135 service manual question
  47. Se 135 rattle noise
  48. CR483 vs 22XD vs RS472
  49. Cams
  50. Driven Chain Master link 90 sportster
  51. 90 Sportster Fuel Petcock
  52. My 2018 upgrade project - cam, oil pump, compensator, exhaust
  53. 98 evo build
  54. 1996 Road King FI leaking fuel line
  55. Looking for EVO cam specs - Carl's Speed Shop CM8
  56. 90 Sportster Spacers Rear Tire
  57. 2015 CVO Twin Cooled Head removal
  58. TC Valve Stem Protrusion Measurement...
  59. 2019 Triglide cam choice
  60. Cam chain tensioner life span / age ?
  61. Milling TC heads
  62. Oil temp sensor location on an S&S T124 motor
  63. Engine whining noise
  64. External oil catch can report
  65. Reusing stock pushrod tubes with adjustable pushrods?CVO with scortched chrome color tubes
  66. What was the "SE stage II kit" for the early TC88 motors?
  67. Flooding at high rpms
  68. ??? Replacing Cylinder Base Gaskets on a 87 Evo
  69. Porting S&S super stock heads?
  70. M8 smoke on decel
  71. 90 Sportster Rear Sprocket
  72. M8 compression static vs corrected cam and piston specs?
  73. Engine swap
  74. 90 Sportster Cable to Carb Connection
  75. 98 evo randomly loses power
  76. 2007 road glide starts and shuts off immediately
  77. Spring replacement help
  78. Updating My 107 Twincam Build
  79. Rear cylinder misfire
  80. Cam choice for stock 96”
  81. Lots of Oil in the Intake After a ~Long Ride
  82. Clacking after rocker lockers
  83. Fat Bob Throttle cable and Return line
  84. Oil pump seal
  85. 90 Sportster Oil Lines
  86. 05 TC88 into 02 FLHTC
  87. HELP! will 2004 flywheel fit my 99
  88. 2021 M8 114 w/53K - Borescope
  89. scored cylinders new 131 crate motor.
  90. Cylinder studs??
  91. Se 135 engine
  92. 88b S&S 509
  93. Hard starting
  94. 2017 107 Cam Upgrade Thoughts
  95. Engine Tapping Sound
  96. Cylinder bore out of square
  97. push rod adjustment and heat.
  98. Adjusting lifters Help!!!
  99. Adjustable push rods
  100. Oil change after lifter and cam failure.
  101. Lubrication problem .
  102. Winter Storage coming up soon Time for Engine oil, should I do all 3 holes?
  103. Gear Drive Cams
  104. De-Tuning My Dyna...
  105. 2014 103" ticking noise on cold startup
  106. Flow bench guys, I need advice
  107. spark plug reading..
  108. Stroke or not to stroke, that is the question.
  109. 47t sproket upgrade
  110. Cam change and head work
  111. HPI 51mm sportster throttle body
  112. What do you guys think?
  113. advance timing gear
  114. S&S 635 cams, extreme exhaust duration?
  115. Cam comparison question for Evo motor
  116. Hard Start After 883 --> 1200 Upgrade
  117. 99 FLHTCUI Primary Shoe
  118. 90 Sportster1200 Rear Sprocket
  119. Pinging or compensator noice or..?
  120. Lost
  121. Cam chain tensioner question
  122. 90 Sportster Leaking Seal
  123. Engine oil fill spouts
  124. Anyone ever broken internals of an efi sportster throttle body?
  125. Rear cylinder not producing power
  126. Kick back when cranking
  127. Compression
  128. Burning down pistons
  129. S&S Crank for 88" Twin Cam - will it work in a 96"
  130. 2008 Dyna Engine Build Questions
  131. Help! Weird engine sound 883 iron 2021
  132. Sifton oil pump 12-0859
  133. Who knows how to burn a piston blow the rings
  134. Quick hiss sound and cutting out.
  135. Ultima 120” debris in rocker box
  136. Lifter Bore Scoring
  137. Cuts Out When Left in Hot Sun
  138. The old spinning starter gig
  139. Excess oil from air intake
  140. Drag Specialties motor oil
  141. Chirping
  142. 02 Twin Cam FLHRI Oil Cooler, Is it necessary?
  143. Miss loss of power and backfire at 3200 rpm’s
  144. Twin cam valve spring
  145. Evo switch to synthetic oil?
  146. M-6 motor "jingles"
  147. 90 Sportster Engine Reval
  148. Bad mileage… I think.
  149. Shovelhead crank pin
  150. Tappets ????
  151. Road king problem
  152. 90 sportster 1200 fluids
  153. So I did the unthinkable today-
  154. Idle reving up at stops
  155. Need input on my first performance build. High comp. 95
  156. Code on 2014 FLHX
  157. milwalkee8 in a TC frame
  158. 117 crank in 107 cases? and heads
  159. Gas Lank Sealer
  160. Tapping sounds when accelerating 2008 roadglide
  161. Star racing tork star 577 cam
  162. Twin Cam 88 rear cylinder running lean
  163. Fxr oil pumping but not returning
  164. Engine/drivetrain noise?
  165. Hard to find neutral
  166. 60 pan breather
  167. Valve clatter
  168. Engine making a new noise
  169. Crankshaft roller bearing tool
  170. 95ci compression question
  171. 2015 FLHXS - Thottle body gear shaft wear?
  172. Who can assign the sound ? 99 FXDX Sport
  173. Engine stamp
  174. S&S Pushrods - Reg Adjustable or quickee
  175. Tappet bled down. Why do we do this
  176. Help needed with adjustable pushrods
  177. 2014 FLHXS Rocker Box Gasket Help and Tips
  178. Replace cam bearings?
  179. Oil Leak Rear Cylinder Head
  180. Nice Vid of Noise That Has been Tormenting Me
  181. Is my sportster 1200 blown up?
  182. PLEASE! Help ran low on oil.
  183. Motor Tick and Oil light
  184. DIY job gone wrong
  185. 4.125" cylinder height question
  186. Raising the seat on my 2023 heritage classic
  187. Found This in Filter
  188. Wanting more out of my 122ci
  189. FuelMoto Adjustable Pushrods
  190. Do I have pinging?
  191. Please help with the noise!
  192. Proactive lifter change-
  193. Twin Cam vibration 1000-1500rpm only
  194. sweating foot of cylinder
  195. Lifter noise.
  196. Screaming Eagle 113 CI Piston Rings
  197. Having issues, need help
  198. Oil Filter Relocation
  199. M8 engine noises
  200. I'm not sure which way to go on cams...lol
  201. 124TC Build starting issues
  202. Flex fuel
  203. Engine swap
  204. 2006 Cam Chain Tensioners
  205. Starting bike after 5 years - sumped?
  206. 128 build problems.
  207. Will a lifter bleed down?
  208. 98 Road King EFI - Engine Build
  209. Twin cam cylinders - how to measure deck height?
  210. Let's Talk Lifters...
  211. flutter
  212. break in on crate motor
  213. How to choose a camshaft
  214. New Build Oil Problems
  215. Performance question about exhaust manifold route for 2-1 exhausts
  216. Used cam plate and oil pump.
  217. scorched ! !
  218. Engine sucking air sound at idle
  219. Lifters test.
  220. identify my pushrod covers?
  221. Throttle vibration/rear motor mount?
  222. Oil leak from push rod covers?
  223. 60K miles on Evo motor what to look for?
  224. 110 Build
  225. 2008 cam chain noise
  226. Sportster Electrical Issues (Stator?)
  227. Air Intake Upgrades
  228. 2023 Ultra Limited SE8-447 torque cam impressions
  229. Loud engine knock after cam change
  230. '85 Ironhead Crankshaft & full rebuild
  231. 2024 114
  232. Help with vibration of engine Fat Boy Lo 2015
  233. Star Racing 30-30 or S&S 475 cam?
  234. Cam Plate and Oil Pump Confusion
  235. Dynatek 2000I
  236. Rockers and Valve Springs
  237. Found very small flanged sleeve or bushing?
  238. XLX case question
  239. Engine replacement
  240. Breather Assembly - new vs old style
  241. Valve To Piston Clearance...
  242. Oil issue with 2006 RK Classic
  243. What hose is this?
  244. 2017 m8 107ci oil light and bad fuel mileage
  245. Oil Blow-By/Cylinder, Pistons and Rings Question
  246. Woods 22XD vs 22XE vs SE498 Tuning Concerns
  247. 132 big bore sumping
  248. Interesting cooling system issue
  249. Evo Cam to Crank distance / drawing
  250. High Oil Pressure?
