PDA
View Full Version : Engine Mechanical Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Can FXDLS 110ci barrels be bored to 177ci ?
  2. inspection scope pic of cylinder wall and piston
  3. Cyco cam chain tensioners
  4. TC oil Pump alignment
  5. cam support plate #1 hole
  6. 88 heads on a 96ci
  7. 2018 road king
  8. Fuel moto 107 kit
  9. Rough cost for crank repair?
  10. 15' 103 HO top end on an 07' 96"
  11. m8 S&S cam install...are lifters needed????
  12. Determining cams from a dyno sheet?
  13. Darkhorse/S&S 117 build questions
  14. No fire in front cylinder, need help
  15. Can the Average Joe install big bore kits?
  16. 113 woods 9b power off?
  17. 883 sportster engine swap
  18. Engine ID.
  19. inner cam bearings TC 88
  20. Leading Edge 151's update
  21. S&S Adjustable Pushrods with FuelMoto kits
  22. Twin cam. Cam alignment
  23. TMan Cams
  24. Questions about rebuild
  25. Cam Plate Question
  26. Front cylinder jug stuck
  27. Spare pro pipe baffle?
  28. Should I vent crankcase breathers?
  29. Screaming Eagle Pushrods
  30. S&s 143 engine
  31. What does it take to hit 120hp
  32. Cam Timing
  33. acr valvue
  34. Glide Pro Motor Mounts
  35. Routing clutch cable behind downtubes
  36. '09 flhtcu kept shutting down
  37. 2006 Roadking Heads Part number
  38. T-Man Performance 124 Pro Series Kit
  39. why cant i put a 4 5/8" crank into a '17 FXSE 117
  40. Throttle body for build
  41. inner cam bearing pull/install tool
  42. Mileage to replace cam chain tensioners
  43. Stage 1 heads vs bigger displacement
  44. 100 CI S&S in a Buell
  45. Built 98ci wont make power past 5300rpm
  46. Engine noise during start upLook
  47. compression relief valvue
  48. Lifters Brand vs stock HD?
  49. 2014 uLTRA 103" TORQUE SPECS ?
  50. Cam chain tensioner twin cam
  51. Interchageable cylinder heads
  52. Softail Billet engine
  53. loss of compression on rear cylinder...
  54. 2004 Road King Cam Tensioner whine
  55. push rod adjustment
  56. 96" Build researching but still unsure
  57. 1340 EVO Adj Pushrod hitting the cover
  58. Maxi Pads and Galled Pistons
  59. Read this plug
  60. How does the Mighty-Might compare with full size Love Jugs?
  61. Blown Head Gasket Symptons ?
  62. Cylinder Head Temperature Gauge: Do you run one?
  63. TC88B Inner Cam bearing replacement
  64. Cam Plate Troubles
  65. 97 Custom Softail Random misfire and not hot starting
  66. Long Block Program
  67. Harley Said $6500!!!
  68. Still Chasing a Noise-The Final Chapter.
  69. 107 M8, Stage II torture
  70. 09 sumping and hot
  71. Deceleration noise
  72. Starting issue after lifter swap.
  73. Surprise! A "name that sound in my TC" thread
  74. cams for 96ci
  75. AFR and timing advance opinions
  76. Engine Whine After Oil Change
  77. A little help needed
  78. Primary chain specs
  79. what air cleaner is this??
  80. Flush engine after piston galling?
  81. After new cams, I get a small "chirp" when I accelerate hard
  82. One loud click while trying to start
  83. Gear Drive CAM whine
  84. Carbon build up on pistons
  85. S&s adjustable pushrods
  86. Panhead S&S 450s cam?33-5062
  87. oil on spark plug threads
  88. Bike sounds like it might die when stopping
  89. Can this crank be salvaged?
  90. Is 124 or 131 possible next step?
  91. What is the difference?
  92. Hd tc 2007 +valve lifters ok for stock motor?
  93. Am I interpreting this dyno sheet right?
  94. EITMS temp question
  95. Looking for more
  96. Leaking from what looks like under the starter?
  97. Oil in Intake
  98. SE 211 and a Wood 4* gear
  99. Shout-out to Scott at Hillside, 11 year old build report
  100. 95ci upgrade for 2006 88ci
  101. Air Filter Life Extension Project Report
  102. Worth it to swap TW555 to TW777?
  103. Cam for 2014 Dyna
  104. Loud knock and severe piston galling after 500 miles on rebuilt motor
  105. Excessive Tappet Noise
  106. Supercharged shovelhead toasted clutch
  107. S&S lifters, HL2T limiters, SE tapered adj p/rods
  108. Not happy with results
  109. clearanced rocker boxes?
  110. Andrews V2 in a Hammer 1275 '88 Evo Sporty
  111. 01 Dyna Oil Leak from "Points cover"
  112. Shovelhead whine. Sounds like cam and pinion
  113. Is there a difference between these two CVO 110 heads?
  114. 2017 Road Glide Ultra M8 cooling fans
  115. 1984 Irondhead valve train ?
  116. Re surfacing heads on a twin cam
  117. Tire Shredder Kit
  118. Adjustable pushrods locative removal
  119. Squish measurement
  120. Oil pressure
  121. Torque plates or not fore machining
  122. TC cam bearing replacement
  123. 2010 96 CI (Road Glide) engine with lower left side knock
  124. milwaukee 8 114 vibration issues
  125. lifters swapped out
  126. Cam Chain and Oil Pump Upgrade TC 103
  127. EVO heads rebuild - High or low compression?
  128. 117 Refinement
  129. Angry Birds from 2300 - 3200 RPM: Exhaust leak?
  130. Loose head bolt
  131. '04 Road King Classic Motor Upgrades
  132. identification #on shovel flywheel??
  133. Noise After Cam Change
  134. Camshaft noise
  135. I think too much - Breather system question
  136. rebuild advise
  137. Twin cam Engine squeal
  138. Checked cam tension shoes @38k
  139. M8 114 to 124 stage 4 kit
  140. Mechanical help
  141. 110" Dyna big bore kit
  142. Harley softail 2009 - not starting
  143. Oil on rear plug need some help
  144. Cam chain tensioner inspection
  145. 07 Ultra update.
  146. White smoke after top end rebuild
  147. Loss of Power and High Oil Temp
  148. 4000 RPM high pitched tick
  149. Cam selection
  150. Any way to help weeping seals?
  151. Custom 124" build questions
  152. 03 Dyna Randomly dies at highway speed
  153. My 2008 Dyna Super Glide dies after a while of riding fast
  154. Old skool rebuild and retro conversion for FLHTCU
  155. I have 2015 roadglde special with 65000 miles
  156. Twin cam top end tick
  157. Loud Fan Type Noise after a long ride
  158. 2008 96 I ch motor?
  159. 2004 twin cam back cylinder is making noise
  160. Broken cam plate bolt. 07 ultra
  161. 2011 road glide fltru backfire
  162. S&S cams - NOT de-burred??
  163. Lifter Advice....
  164. 1993 FXR sp con won't start
  165. Throttle loss
  166. Wet and Dry Compression Results
  167. Compensator sprocket inspection procedure: Cant find it anywhere!
  168. TW-222 or SE-585 cams for stage II?
  169. Andrews Conversion Cams Checklist
  170. Engine swap
  171. Starting issue
  172. Worth it to do TB/injectors on 107?
  173. Top End rebuild - question about assembly lube & pre-oiling.
  174. aftermarket O2 sensors for 2009 heritage softail
  175. Replacing lifters in 117 kit, push rod length?
  176. 2014 CVO Ultra Limited Overheating
  177. Question on gear cams & big bore kit
  178. Hammer Performance 120hp 1275
  179. 2018 CVO Hot Engine
  180. Fat Boy S 117 install, now not starting.
  181. Maint issues after 267000kms
  182. Evo cam favorite pick?
  183. Oil coming out of the air filter housing
  184. Ping ...... on a harley
  185. 2015 limited lugging at stop - idle
  186. M8 Cam Install
  187. 2016 fatboy s cam swap thrust washer backwards
  188. The "new" wide glide
  189. The "new" wide glide
  190. 1999 dyna super glide sport engine upgrade
  191. what cams
  192. Dropping 2014 FLHX 103, 6 speed, and complete primary into a 05 Roadking
  193. ??? Mixture problem??? or???
  194. Engine pings when i take off
  195. 2007 96” to 110”?
  196. air temp sensor
  197. Cam/LIfter/Pushrod Kit for 2014 Stock 103HO
  198. Different Kind of Valve Damage
  199. New rocker cover gasket, leaks.. re-torque or replace?
  200. Over heating
  201. FM 107 outlaw?
  202. 2017 Dyna 103 and 2012 ultra limited 103 comparison?
  203. Pushrod length
  204. Fuel Moto pushrods and Woods Alpha Directional Lifter
  205. 103 stroker numbers!
  206. Need help with adapter
  207. What exactly is lifter bleeddown?
  208. Stripped Stud - Softail
  209. Loud ticking noise
  210. Engine heat
  211. Engin won't turn over
  212. Cracked case by inner cam bearings?
  213. 107 with TW555 low CCP
  214. 103 heads and jugs
  215. High idle question
  216. Woods 222 or Andrews 48H for '09 Road King
  217. low CCP: poor ring sealing?
  218. 88TC and TW26A install questions.....
  219. Lifter cover oil leak
  220. Power upgrade
  221. 883 into 1200
  222. Broke exhaust stud and had to remove front head
  223. Fresh build with mystery tick. Any ideas?
  224. What Smartphone Boroscope is best?
  225. Ultima performance clutch
  226. Revtech
  227. 103 upgrade kit in dyna
  228. Mild tc88b
  229. SE Hydraulic Cam Chain Tensioner Kit
  230. Random Evo knock, not consistent
  231. 2000 FLHT coughing unless choke is on.
  232. Fueling Camplate 8015/8033 Question
  233. Well trying to get ready for dyno tune...
  234. Lifter issues...
  235. 97 EVO fluttering sound
  236. Need info on Baisley porting etc
  237. Harley oil pump seal# 26227-58 replacement
  238. 883-1200 help
  239. Derby Covers
  240. Lifter tap/knock? and oil leak
  241. New rear sprocket
  242. All bore 107
  243. Question for the experts
  244. Cam question
  245. low lift headflow figures and how they relate to streetable performance
  246. Breather bolt/cylinder head issue
  247. Piece of rag in crank case
  248. Rough running after engine upgrades.
  249. Adjustable pushrods ?
  250. Crank Runout Help Please
