- non hydraulic cam follower for Evo (weight of)
- Skipping '03 TC After Tensioner/Bearing Replacement
- Straight edge tool
- manifold gaskets
- 98 build throttle body
- Are these acr heads?
- 00' ultra revs up when clutch engaged!
- Crankcase breather for Marelli EFI??
- New Cam & Lifters / Old Tick Tick
- lifter noise
- HELP! Cracked head and on the road
- Can someone help me identify this sound?
- Western New York
- head surface
- New S&S TC 3 oil pump and cam support plate
- Baisley oil pressure spring
- Lefty Bearing
- 107 with Woods TW7H cams
- 84 flhtc knock
- Unidentified substance, need help
- Where to get my Bike Dyno'd in Illinois
- Honest Questions
- Weak Throttle
- Cam Change Laboring motor
- Trailer pulling beast! Wrong gearing though.....
- Freshening Up 2002 Road King Police
- Plug thread size different on same engine
- 05 Electra-Glide going to be changing cam tensioners - ??? on pushrods and cams
- HELP!!!!! problems with starting!
- Fm 107 vs stage 4 103 (no brainer right?)
- Feuling Cams for 103 build, opinions?
- Engine builders chime in..
- Diagnosing sumping
- I checked my CCP after my cam install and...
- how to tell if the compensator is going bad?
- Torrington Cam Bearing Part Number?
- Run out on 2001 Electra Glide
- 2001 Ultra Classic Issue
- 08 Nightster XL 1200 air filter bolt destroyed engine
- Engine Leak on my 2003 Road King
- Speed Sensor Problem
- Critique this build
- Best bang for the buck single mod?
- want to rent/borrow cam puller tool
- Confusion on motor
- Top engine builders on the west coast
- Engine noise
- 103 swap
- Bike started but now won't start after Cam install
- outer cam bearings
- 08 Touring: RPM Gauge Accuracy & Calibration?
- Twin Cam Rocker arm question.
- Cam Replacement Cost
- Shovelhead Rebuild Coming Up
- MPG with cam upgrade ?? Just out of curiosity.
- multiple engine failures
- 2000 ultra classic, help?
- Air Filter sucked dry
- Please read this plug
- Need Help Twin cam Rocker noise
- Questions on running True Duals and CFR's on 107 build.
- Performance shops in South Central PA?
- milling heads to reduce cc's
- Build thread from the Dyna Forum....
- Possibly a Bearing? Cannot figure out what the problem is
- Buddie broke down in Albuquerque needing help
- leaking Pushrod Tube
- How long/difficult to change primary cover
- Please help a new member get to 100hp /100 lbs tq
- Primary chain and compensating sprocket help
- 09 Harley Electra Glide won't start
- Splitting a Harley sportster 883 engine
- Replacing base o-rings, Do I need anything else?
- Engine knock
- H2LT Added to S&S Premium Lifters
- I'm lost
- advice to do a mild sporty engine build
- se 204 vs andrews 21 or 26 for softail
- Head valve seal????
- oil pan removal
- Rear cylinder cuts out
- Work Around for Dog Bones
- Kompressor heads
- Engine pinging
- Exhaust stud torque
- backfiring, jerking, stalling
- Strange engine noises
- Revtech 125" tappet screen
- Sportster won't start!!
- Bike idles and drives like it has an intake leak......
- 2001 Fat Boy Engine Upgrades?
- 2010 103 cams 96 caMS
- EVO engine noise.
- Help with top end assembly
- new guy project qustion 77 ironhead
- 130" Harley motor?
- 89 softail cranks but wont start
- Poor throttle response
- 06 88" tc tensioner question
- Not Again Cam Questions\Confusion
- Bruce Jenner Engine Combo?
- Another Oil Pressure Question
- motor swap night train
- Second oddity with the Fat Bob today.
- Has anybody used this big bore cylinder piston set?
- Cleaning engine/Decarb while running
- 91 ultra glide oil leak
- Newb Cam question...
- Removing heads question
- Woods Directionals
- Broken Oil pressure fitting in block!
- High compression engine failure
- Engine compression test results
- oil pump failure, now noise 98" build
- 100hp out of a twin cam efi 96"
- Roller Rockers
- Knock knock- FM 107 noises
- New to me bike with engine noise. HELP
- Help Needed on engine build
- Baisley Oil Pressure Spring
- Maybe a bad crank??
- Differences between 96 and 103?
- 2006 Dyna cam chain tensioners
- '02 Dyna codes ... reading them wrong?
- cams....
- 2004 road king noise
- Thinner head gaskets on 120R
- Ready for Summer: Jim's Forceflow Cylinder Head Cooler
- cylinder knock HELP!?
- New engine "break in"
- Clunk from primary when turning off
- Cam Choices
- Build under way, how do these figures look?
- more power please
- Thoughts on dyno numbers
- Swapping a stock 80ci with a stock 103ci
- EVO Bagger Cam
- lets talk about 117 inches
- Tappet question
- how many discs to run, 48h cams 96"
- Head porting a stock 103"
- Engine Swap
- 2009 Softail heads on 2007 Touring
- Oil Pressure Questions
- V Rod Rear Rocker Box Gasket
- 80" shovel with Delkron cases.
- TC Heads
- 2011 110 cvo ultra
- 88" to 97" Build on 2001 FXDXT
- 106" Head Gaskets
- Best guesses on dyno #s
- curious 103ho cams for 96
- engine paint?
- 2003 88 jugs
- Axtell Oil By-Pass Valve. How High is your presssure?
- woods TW-999-6 or TW999-6a cams
- MR103 guys.. Upgraded Throttle Body?
- Is this EVO motor worth it?
- Re Advice Building a 2000 Road King Engine
- Idle Issue
- Engine knocking/rattling noise
- 103 inch heads
- New guy questions about built TC88
- Custom throttle racket
- ultima 127 build
- Adjustable Pushrod choices
- 2009 Twin Cam 96 which lifters are stock? A?B?
- TC88 (1999 FLHTC) Motor Noise *VIDEO INSIDE*
- 05 sportster cutting out at highway speeds
- Oil leak question
- 2014 limited high idle
- 883 iron stock air intake
- Fuel Injected EVO reliability????
- Old Style Engines
- S&s 106 / 107
- 1340 Evo Engine
- 100" twin cam
- cams vs 103 kit
- rocker box gasket leak. advice needed
- Burst air cleaner?
- Compression testing
- S&S 'Standard Adjustable with keepers'....which parts do I re-use??
- Question on genniss cam
- 88" rear cylinder head oil leak
- 06 Fatboy feels as though it's missing / misfiring
- 2004 ultra EFI lost rear cyclinder
- Too Rich or A More Serious Problem?
- Finally dyno'd my 95" build...
- Cam/piston question
- Loud Rocker box
- Motor issues- maybe major
- Broken Motor mounts = Blown Motor?????
- hp103 cam
- S&S 106 piston valve relief volume cc's
- Evo rattling noise
- Another Cam Question
- Do I have the 1250?
- Stage 3 upgrade
- DK Breather Install on Heavy Breather Intake
- 103" engine decel noise
- Which performance Valves to use....???
- Big Bore gaskets
- EVO Top End rebuild
- Torquester cams and funny noise
- Engine ping
- SE heads
- '03 TC88 Cam Selection help please
- Help! Oil spewed everywhere!!
- Engine serial #
- OddBall Dyno Sheet
- Engine Re-Assembly...cleaning threads.
- Excessive heat - is there a solution?
- Lifter Rant..........
- Cam Tensioner Upgrade 95"
- Bottom end rebuild? Maybe? Input appreciated
- Will a 2013 103" Top end fit in my 07 flhx
- Observation About Rings
- T-man 555 torqster ,TW222 or SE 204
- Will a 110 fit in my 01 Exlectra Glide Classic
- Turn signals start flashing sporadically when ignition is turned on. 02 road king
- Lost my rear cylinder, oil on spark plug
- soft tail deluxe
- Bad hard starting...
- Need Advice
- Valve train/lifter noise after top end put back together
- S&S Lifter Install orientation
- 2010 FLHX Starter Issue
- SE204's in a 103" softail install questions?
- Considering fuelmoto 107" conversion
- Lengthy Servicing Dilemma?
- possible 88 to 124 build
- Shorter rocker arm support plate bolt
- Technical questions on intake and suspention
- 1947 servi car ?
- Piston/Head build up
- Lifter question
- Black smoke, rough idle, stalls, need help
- Cam recommendations.
- 2012 street glide 103 cam?
- Valve train noise
- Questions on resealing my evo motor
- F/S: K&N Air Intake Kit RK-3910-1
- Throttle body info required
- My first cam install....
- Need help guys. Washer fell into spark plug hole
- another cam question for 98" build
- missing on front cylinder
- 88CI to 103CI carby
- Petcock panic
