PDA
View Full Version : Engine Mechanical Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31
  1. 09 Electr Glide starter locked up??
  2. What should High-flow oil pump oil pressure be?
  3. Compression for a stock TC88
  4. 88 to 107 zipper big bore stock crank
  5. 88 to 107 stock crank
  6. 1995 Dyna FXDS rear cyl smoke at idle consuming oil
  7. ticking/rattle from engine
  8. Hq 0034 ??
  9. Mostly stock 88TC cam choices
  10. 2008 nightster engine noise loud
  11. Low RPM missfire Help
  12. Cam removal and install using autozone tool
  13. Help with hyd tensioner upgrade and cam sugestions
  14. Engine Light flashes on and off
  15. Dyna Motor combo HILLSIDE HELP!!
  16. What to update in a 2009 FLHTC To bring it to the 21st centry
  17. Spuratic idling please help
  18. 98 or 117 or ??
  19. feuling hp+ 525 camchest kit
  20. 95/98 or all bore 107
  21. 1996 Wide Glide noise got questions
  22. Final 103" Engine Build Results
  23. Manufacturer dyno claims, dyno tests, tuning, seat of the pants feel, & questions
  24. evo top end noise when warmed up
  25. EVO Wrist pin Bushings
  26. S&S heads super sports heads question?
  27. Stage 1 103" kit on my 08 RK - whats the compression
  28. Roadking cvo FLHRSE4 -08 110cui upgrade
  29. Twin Cam 88 engine miss between 1/8 - 1/4 throttle
  30. Push Rods
  31. oil pump centering question.
  32. Valve train noise ??
  33. Road Iron Magazine Build
  34. tensioner spring mix up
  35. To BEE or not ?
  36. 107" Build ... your thoughts?
  37. NOT SO GOOD Experience w/ Vee Twin Performance
  38. rockerarm/pushrod concern
  39. Oil cap blows off
  40. 110" case bore
  41. 2009 FLHP (Police Road King) cams?
  42. Turns over, won't start
  43. Rattle/Vibration in the throttle..Help!
  44. 110 heads
  45. need info from cam chain to gear drive
  46. Hillside Cycle 107" build
  47. 1994 Softail Custom Problems
  48. need to pin a new cam bushing?
  49. Crankcase Breather vent pressure
  50. Longer rods and cylinders: working combination?
  51. 2005 xl1200c TICKING SOUND
  52. new head casting
  53. 1990 FXR Lowrider Oil Light On
  54. 103 upgrade from 96 info
  55. Which calibration file should be used with a 103 Stage 4 Race kit?
  56. oil circulating problem
  57. 2008 Street Bob is stalling
  58. New Lifters
  59. Another cam bearing story & a question or 2
  60. Circlips
  61. top end noise
  62. pusbrod tube spring cap retainer
  63. Lifters & Cam questions
  64. piston
  65. Woods 777s Beware of Stock Springs And his BS
  66. 1997 Softail Custom forward cylinder cuts out
  67. Need specs
  68. Old one lung
  69. intake options
  70. 124" Sumping/
  71. Do u use thread locker on rocker arms
  72. 06 street glide cams, power, and probems
  73. Opinions on s&s 510c cam
  74. Cam advice needed
  75. More 96 to 103 questions
  76. Ran good then ?
  77. 07 and later what changes to cam chest.
  78. 96 to 103" conversion info please
  79. Harley 1200 rear pipe fire
  80. Jims Forceflow Cylinder Head Cooler
  81. 95 Electra glide overheating
  82. Not good!
  83. 2012 107" build numbers seem low
  84. 65 Pan Head oil leak
  85. Stage 3 Big Bore 103" kit for my 96" TwinCam FatBoy 2011
  86. Problems after cam install
  87. Tpi
  88. Evo Upgrade Challenge
  89. 1550 Big Bore Kit
  90. Oil on front of engine ....
  91. TC88B tuning and longevity
  92. Help!! Engine smoking after FM 107 install. Need ideas.
  93. 88" case mods for SE 103"
  94. Drag oil pump
  95. Need some gearhead opinions....
  96. is it the starter solenoid or what?
  97. Confused
  98. Stock valve stem hardness?
  99. Ok, here we go again... 80 inches of Evo whoop ass!
  100. Warm/hot start clunk, cough & spit.
  101. How's that supposed to work?
  102. Compensator upgrade?
  103. Oil return oring on lower jug falling in moter
  104. Backfire problem
  105. Oil pressure dropping
  106. Cam upgrade stock engine
  107. 1999 Dyna 1450cc Engine problems - Spitting oil out the carb
  108. HD 10mm SE spark plug wires
  109. Vibrations when I come off the throttle
  110. Base Gasket??
  111. 88" upgrade
  112. Was a drip, now it's blowing
  113. Cam cover
  114. another 'help me choose' thread - cams… 583/574/555
  115. 07 cam tensioner shoes
  116. New Build - Compression Test Question
  117. Smoke coming out of engine after installing stage 4
  118. Heavy Breather?
  119. Screaming Eagle piston rings
  120. cam change
  121. engine guru's
  122. 44 to 37
  123. Question About 88 c.i. upgrade
  124. Homemade ACR Socket
  125. Top end overhaul break in period
  126. 95 dyna heads
  127. Oil cooler?
  128. Cylinder dowel question
  129. Filter backing question
  130. Dying on De-cel
  131. s.e. cylinder studs
  132. Andrews N cam conversion
  133. Head problems
  134. 06 and earlier cam bearing tool
  135. Tappet cover and lifter ?'s
  136. S&S 583 vs. Andrews 26
  137. Ring gap for 95ci
  138. Can you bolt the se 110 heads up to a 95 inch motor
  139. Should you wait so many miles before installing a stage I on a new engine.
  140. Evo cylinder stud?
  141. Lifter
  142. oil return pressure
  143. vp c-10 and compression.
  144. installing new cam issues
  145. Any experience with Zippers Performance?
  146. Screamin' Eagle 103 ci Street Performance Stage 4 Kit
  147. 107" upgrade = slight oil seepage?
  148. Missing and Back fire
  149. High Compression 95" Help!
  150. Better head or bigger jugs?
  151. On the right track ??
  152. Stock 88 twin cam 45 mik jetting
  153. Options for tc88 rebuild?
  154. Evo 1340 rocker cover question
  155. Stock pushrod use for SE254E cam
  156. Question for the experts
  157. 120R: High Performance Mods
  158. too much warm up??
  159. 97 Heritage Springer Motor Build Advice
  160. Is this anything of concern? Engine block
  161. Cam help for 2009 street glide
  162. Andrews 57h with headwork?
  163. Carb Fuelling/Tune Issues
  164. Manley Valves for 95" 10.5:1
  165. Cleaning cylinder fins
  166. 94 Evo blowing oil out vent, lots! but not consistent
  167. Jim G’s Breakout Stage 4 project
  168. disconnect acr for manual ones
  169. perfect fit push rods... need advice
  170. Beather & air filter mounting options
  171. this combo sound ok?
  172. New guy - big problem
  173. Push Rod seals VS. Dirt
  174. cam chain tensioner change = oil in crank case
  175. Launching Oil Cap?
  176. Xied
  177. Which cylinder head for my 05?
  178. 400 hp Street Glide
  179. OEM cam chain tensioner hr charge
  180. Breather Bolts holding air breather bracket
  181. Rocker Box Removal Question
  182. Opinions 98 or 107
  183. sportster crank and rods
  184. Frustration builds on my 107 build!
  185. 2006 steetglide oil leak
  186. Genuine James' Gaskets
  187. Performance shop
  188. need help identifing heads
  189. Whats a good low to mid range cam for an old Evo?
  190. engine stall w/ low fuel
  191. New breathers and oil drain size
  192. Build results
  193. HD Street Stage IV Kit - Anyone Installed One?
  194. Need to run wires into gas tank.
  195. Oil not reaching the heads
  196. Bottom end / connecting rod limits
  197. regulator and stator
  198. Any way to tell if cam tensioners are original?
  199. Rocker arm assembly support bolts
  200. Motor Bearing upgrade
  201. Cam Chest questions
  202. Another 88-to-95 build thread w some pics...
  203. "Hard start" question
  204. Anybody have a build sheet template?
  205. 87 fxrs
  206. Help!!! Rocker Arm Support Plate
  207. Engine Vibrations/Runout check with pics
  208. Distributor drive gear
  209. engine and speedo problems
  210. 1988 1340 evo backfirer
  211. EZ Start cams and high compression
  212. Evo VOES Test
  213. My experience installing the SE 25284-11 cam kit
  214. Should I replace the Gaskets?
  215. Funny noise on start up
  216. Sporadic Missfire at High Speed - 1992 FXRS
  217. I need your help....
  218. Cam tensioner check
  219. Exhaust torque specs for a 2014 SG
  220. Exhaust questions
  221. Stripped spark plug hole
  222. .030 Cometic heat gaskets
  223. Se cam plate upgrade for '03 88"
  224. cam bearing tools
  225. 2013 True Dual Header Pipe
  226. my fix to oil out of A/C.
  227. engine/clutch noise
  228. Tune question
  229. Aluminum fine shavings probably in spark plug hole
  230. Big Bore Overhaul and Cam Replacement Tools
  231. Slip ons screamin eagle mods?
  232. Revtech 110 questions
  233. Replacing stock 96 with SE 120R crate engine
  234. new stage 1 air filter
  235. Scissored Flywheels '03 Twin Cam
  236. 2013 103 Ultra Classic DIY Breather, Pipes and Tuner
  237. Slip on exhaust needs
  238. Hard to start with compression releases
  239. Shovelhead crank bearing replacement
  240. Piston cleaning
  241. '88 Softail Problems
  242. 97 EVO will not start
  243. D & D Exhaust
  244. drive belt
  245. Gaskets for 103 big bore
  246. My little twinkie just keeps on pissing off people
  247. 2012 Harley engine ticking at warm up
  248. Bad Gasket problem
  249. 2007 FLSTC Primary Noise
  250. Replacing rocker cover
