- S&S Cams and Cam Plate
- Crank adjustment after assembly?
- 1996 Sportster with oil around bolt???
- S&S 100" drop in?
- Can It Be Done
- Shovelhead cams and such
- S&S 111 with rear cyl piston failure
- 103 HO Compression and head questions
- Road Glide motor build
- Piston/Cylinder clearance Specs.....
- 09 electra glide starter issues??
- Tc88 upgrade help!
- Compatible motors for 2003 revtech 100
- Big bore and carb question
- Lifter blocks evo
- Identify pistons?
- Brass in oil.
- change valve springs?
- Special tools for Rocker Base upgrade & Lifter Replacement
- I need clarification on bore size...
- Coin Flip For Cams
- Gaskets
- Rockouts and Lifter Change
- inquiry
- S&s 110 kit
- SE heads on 08 SG
- B lifters..Keep or swap?
- Can't leave well enough alone...
- I May Have Screwed the Pooch
- What ever happened to all of LA Harleys Videos?
- Oil line mod on 1983 Shovel
- Fuel pump question
- Help- cylinder wall marks- is it a problem?
- Fuelmoto wood 222 cams install review
- Dyna 96 to a 103 upgrade questions
- Reusing adjustable pushrods on 103
- Scott @ Hillsidecycle
- MILD work on 2015
- Andrews TW21 Cam question
- Woods 555 optimum compression
- Andrews 57H cams in a 2016 stage 1 Ultra Limited?
- Ordered a 110 kit foe my 2012 Road glide
- External Breather Set up.
- cylinder studs
- Soak your new S&S standard lifters or no?
- Ironhead / Evo swap in an Amen Savior frame
- What specialty tools are needed for the M8 107 to 114 upgrade?
- Is the cam support plate a wear item
- oil relief spring
- Milwaukee 8 stall problem
- Milwaukee Eight Power Upgrades
- Crank runout
- 06 FXDBI Big Bore Kit
- What Size?
- Drilling rocker support drain holes
- Cam chain life
- Oil for break in
- Valve Springs at Cam Change Question
- 01 Road Glide TC88
- CAM only for a stock 103
- What else needed for 96 to 103 Softail Conversion
- Lifter confusion
- S&S Standard Lifters and Stock Pushrods
- Metal chipped off cylinder head combustion chamber
- Sumax billet pushrod covers
- Cam chain tensioner shoe replacement.
- 99 dyna
- Oil pump draining - Anyone know for certain which setup the 87 has?
- Bent crank and dealer warranty
- 2010 Harley Streetglide FLHX Leak on the backside underside of the primary.
- Fuelpack FP3 with a stage 4?
- When to Beef Up Clutch?
- Couple questions regarding evo rebuild, dyno readings, and v111 specs
- Engine Question
- Screaming Eagle Stage III Valves Rocker
- Front motor mount ?
- Another 110 drop in kit vendor option
- M8 107-117" pistons
- Are there any good lifters? Doesn't seem so.
- 2004 FLHTCUI will not start
- 88 to 98 Big Bore Conversion
- Engine (re)build time
- Se203
- Anybody have some big bore torque plates I can use?
- 103 to 110 question
- S&S 509G's in 88CI Fatboy
- 2001 FXSTDI Erratic Idle, Cough and Dies
- Harley & Revtech parts interchange
- Chamber Volume Increase From MCR Addition?
- Is there anymore Torque to be Gained?
- Anything else while heads are off?
- First time on
- S&S lifters oil hole orientation
- Scored Pinion Shaft & Bushing
- If you're looking for a big conversion cam
- Head Question
- 2004 Road King Cam chain tensioners.
- Rushmore 103
- how to diagnose lifters noise?
- S&S Lifters
- Does this Sound Right? "Power and Efficiency"
- Is this a legit Amsoil filter?
- Deciding on Cams
- DIY Throttle body honing?
- Anyone attempt to port and polish your own heads?
- oil blowing out intake,2016 fltrxs
- Lifter Going? Does My Thinking Track?
- Need Help with TDC and Cam Timing for 77 Sportster
- how to figure Compression ratio
- Torquing the intake manifold
- Quick question for cam re&re tool.
- Why swap out oem lifters?
- Big bore kit
- Is this Crank Bent?
- oil backing up in oil bag ?
- Thinking of new slip ons
- Cam Gear Alignment Issue
- Heads up.. HPi annual black Friday sale tomorrow
- Twin Cam lower end noise
- Why do I want oil going into the intake from the engine?
- How to install rocker shaft so it lines up properly?
- Installing new lifters - adjustment question
- Stock chamber volumes
- Valve Noise?
- motor misfires on a bump/ speedo drops out
- Can it be the ACR ?
- Bilt bottom end south dakota?
- 96 Cu in twin cam heads. ported/polished/flowed/upsize valves.
- My 103" to 110" build with dyno
- 88 Oil Pressure
- VEE TWIN runs fastest pass in P/F history
- From TW777 to S&S 625
- Train
- 06 night train
- Estimated HP/TQ
- Used pistons
- 2003 road king sputtering
- S&S vs. HD 110 kit(s)
- Bearing questions..
- 80" EVO burning oil from one cylinder
- S/E Big Bore Cylinders
- 103 to 110ci kit questions
- Valve Question
- 1983 Shovel top end r&r
- Starter setup for 1982 ironhead
- 95ci build. 06a heads and andrews tw21 advice?
- Evo top end cam advice
- build 107 or stick with 96" and Andrews 48's?
- 2016 Limited PV Autotune
- Compression with Stock Heads
- disabling factory set speed limiter
- Air cleaner
- Head Gasket diameter.
- Tire Shredder Heads
- 107 Winter upgrade anything I'm forgetting?
- From 88 to 95, 97 or 98
- Dimensions of tappets/lifters needed please
- S&S 110 Kit
- How important is this tool?
- Twin Cooled cylinder differences?
- really confusing START, but wont stay running....
- Screaming eagle kits for 89 Evo 1340
- fuelmoto or screamin eagle pro kompressor heads
- Tell me what you think of this upgrade idea
- 107 to 120 build.
- Looking for advice my bike idles at 2500 RPMs and 1400 with no air filter
- Twin Cam 103?
- Aftermarket a/c noise
- SE lifters
- `94 FXDS has an Issue, Your Help; Appreciated
- Comp sprocket torque check
- Swapping 103" tope end to my Wide Glide
- Looking for more, no idea where to begin.
- Start up noise "bang"
- Gear Drive Cams
- Flywheel markings
- Weird exhaust note after se255 cams
- Build concerns
- Boring vs Piston Cyl. Kit
- S&S 551 Cams
- Question: Are there two different 110 Shredder kits?
- Woods 777 with stage 5 kit
- Fxst tc88b cam tensioner job
- Just installed 255s. Starting sucks
- Low - Mid Cam Choice for 103
- Cam install Fail!
- Engine rattle!!!!!
- Big bore kit 106
- Crank to CAM timing
- Harley vs. S&S Motor
- My Hillside Motorcycle & Machine experience
- Cylinder studs?
- Hillside heads And 575 cycle cams
- @005 RK needs a new crank- reason for the brass dust found.
- 117 or 113 or 124
- What xould be causing this leak?
- Rear Cam / Crank sprocket alignmnet
- 2012 103 C.I. Hot start Fart (sounds bad)
- Used 120R or New 120 ST? Any advice?
- Yellow metal dust in the drain pan.
- FXDCI 2007 Super Glide Crankshaft Parts
- 03 oil pump replace or not?
- S&S 124 displacement
- S&S 551 vs TTS-100
- S&S v96 vs v111 Pros and Cons
- Losing voltage and power!!!!!!!
- oil expansion ring end gap
- How to remove shaft from rocker assembly
- Engine stammer
- 103HO to 110 upgrade
- 204's in bigger motor
- 110" Street kit with more compression.
- 01 Ultra with intermittent Stumble
- 96" cams / oil upgrades
- EVO breather questions, run both bottom and top?
- 96" to 107" build
- 13 Street Glide Oil Leak - Again!!
- Fluttering Noise in Engine ???
- Sparking late
- 96" upgrade questions
- 58mm Throttle body required??
- TwinCam 88 - Engine Knock
- Barn find sportster. Function tests?
- Re-use orings/packings on Breather Baffles??
- Challenge, neither Harley mechanic or I can figure this out.
- MAKE IT STOP!!!...(rocker box tap)
- Engine cuts out
- Are the CNC 110" Tire Shredder Heads badged?
- 11:1 Pistons in 107
- 2017 airbox (intake) question.
- CVO oil system
- Best shop to get engine work done in Houston
- Getting walked on
- gaskets required for cam change ?
- My 08 eg 96 grinds and knocks upon hot restart
- Cam for 2012 Heritage
- Front Engine mount Bolts
- 96 tc bud get build
- 2015 SG cam change Zippers 525
- CVO103 heads
- Oil Leak
- Quieting a Twin Cam 88
- 143" Build
- 117 Upgrade - 103 Upgrade with removed parts
- Bigger injectors=new tune?
- Really need help
- Head hurter
- Engine clatter
- Cam Changeout '14 Limited Second Thoughts
