- Rocket 574 cams
- head gasket replacement, alternator cover - issues and questions
- Gaterman or S&S Lifters
- Torque specs
- rear cylinder squeak
- Cam replacement recommedations
- Gear oil smell
- Spun rod bushing ?
- 110 to 117 head work question.
- Factory heads... true quality
- chipped sleeve on big bore kit
- same ol' questions, probably
- 96 heads on 88
- Cam replacement with adjustable push rods
- Gear Drive
- Wood cam install problem
- Engine noise...
- 2016 cylinders fit my 2010
- charging 2020 RG battery
- Oil Pump Failure questions
- Slight rust at the base of the spark plug
- 2019 Ultra Limited
- 2016 lowrider wont start
- Starter Issue?
- 103 heads on a 88 inch, will they work
- Flywheels
- 1992 1340cc full rebuild
- Cam replacement questions
- Piston Question
- cv carb jetting
- Need Engine Mod Advise 2001 Dyna Low Rider 88"
- 120R breather bolts. Cant find correct length
- 2010 fxdwg stalling at idle and surging.
- Cat food in exhaust port
- Primary Belt When to Replace
- Started popping bad
- Is it necessary to replace the oil pump on 2020 when doing cam?
- Cam alignment question
- S&S heads and winter power package
- Which adjustable pushrods for my Heritage?
- I found this very interesting...Read A Spark Plug
- Running Rough
- Help ID my Air Cleaner ('04 TC88 EFI)
- opinions on STOCK 88ci refresh
- TC 88 to 98 upgrade with S&S .510 cam
- I'm dumb!? What the heck did I leave out of this cylinder head?
- Oil leak fron pushrod cover
- Is the FM 107 kit worth it or just stick to cams and a good tune?
- 1999 FLHR skips and pops
- Need feedback on the DME 500 evo cam
- Problem with sputtering and air intake popping. Please read
- Evo push rod noise
- Rocker Assembly Plate Issue - 07 Elec. Glide
- Which inner cam bearing?
- Question about bent push rods
- Another cam selection help thread
- Another top end noice thread - sorry 🙈
- Piston selection
- 09 fat bob wont start any help?
- Andrews 48H vs TW48 Cams
- Oiling issue?
- Need some advice on 107 build.
- Andrews gear drive cam question for TC 88
- 2001 Dyna 95" SE203 Cam Opinion
- Oil line help
- Changed cam cover and oil light stays on
- ignition/charging system
- Streetglide 103 heads
- Is it time for a top end rebuild?
- Star Racing 126
- indentify camshaft
- Loud Metal Clanging
- Top End Gasket Kits
- Inner cam bearing woes
- Not a big M8 problem but....
- Hot Yikes
- Trouble shooting
- putting a 1995 crank in a 1990 case 82ci
- 96ci Top End Noise
- Oil pump compatibility
- Old bike, new problem
- Cruise Control
- Help Identify Gasket
- Cam recommendation for a 2019 M8 114 to 117 Stage IV?
- 1200 conversion head gasket
- Engine Light ON and Engine Cut-Off
- 02 sportster 883xl mikuni hsr 42mm
- Social Distancing Lifter Swap
- Comp cams
- 10.2:1 to 10.5:1 compression
- Rockerbox gaskets
- Re-Shaping Oil Vent Line?
- Piston size for a stock 2005 Sportster 883
- Resleeving an OEM cylinder
- Why does the cam have to be be on the flat part when doing a top end dissassembly?
- 2006 dyna 88TC heat issue
- 2002 Heritage Engine Backfire Issue
- Low mileage used 103 for sale
- Torque dip .. suggestions?
- Help identify broken parts in cam chest
- Cracked case repair Input please !!
- '09 FLHT SE 58mm throttle body
- Getting new engine to turn
- 96ci Build question
- New direction for motor build
- Early TC88 cam plate question
- oil tank routing
- intake manifold 99flstf
- no more power
- Front cylinder runs too cold, rear too hot...
- 79 shovelhead rod end play
- Can anyone help me identify this engine?
- Gasket question
- Time for an upgrade, CAMs, tensioners, pump, etc...?
- Cam issue, lifter issue, now pinion issue?!
- Perfect Fit Pushrods or or use the OEM ones?
- When to upgrade oil pump?
- I have no power to the fuel pump, Sportster
- Evo Mild build confusion!
- 1992 fxdc cylinder distinction
- High idle
- Stock cam alignment issue
- 110 build
- Looking for Cometic MLS Head Gasket Part Number
- Twin cam upgrade compatibility question
- 10k needed new upper, 20k another issue?
- Breather timing "73 xlch 34 years, bushes"
- Rounded manifold bolts -help
- Need some motor advice - 2013 103ci Street Glide
- Push rod bend tolerances
- twin cam tensioner Question
- How to rotate tri glide engine by hand?
- 103 cam and head upgrades
- 01 RK TC-88 surging and coughing
- Anyone use these lifters?
- Rocker assemble removal and cam tensioner questions
- S&S and Zippers Cam chain tensioners comparison
- 2019 Heritage / Engine? vibration
- Remove and then re-install this bolt?
- '96 flhtcui engine swap ??
- TC88 cam lobe damage
- James Head Gasket - Help
- S&S east start cams
- Oil Flow Issue
- Engine build question
- 2016 1200 catastrophe
- 110 head torquing issue
- Cam chain followers
- What year twin cam engine ?
- Ticking noise what the hell?
- oil temp sensor touring 2002
- M8 447 Torque cam
- Hot Rod Cams
- Best cam for stock 110" cam-only upgrade?
- loud bouncers
- 114 heads and parts
- 03 Heritage Softail EFI - S&S 124 build
- Cam bearing surface question
- Torquing head gaskets
- Replacing stock cylinder studs on 2009 crossbones w/ SE solid steel studs
- Question on Heads
- Budget 88 horsepower question
- Knocking noise
- Replace breathers or add external?
- Exhaust and Cams: Stock Compression on a 103
- 106* S&S kit with stage V
- Leak help / torque specs
- HD Specialty Tool resources
- What newer bigger engines will fit the 2009 Low Rider?
- Prime Oiling System After Rebuild?
- Externally Vented Breather SE Stage 1
- Leading Edge billet cylinders
- Cam chain off
- 120r ccp
- conversion cams
- Help with weird code display
- Wood TW-222 or S&S 583
- 88 ci tc big bore questions
- M8 Engine in Pre-M8 Bike
- Bike dies on season's first long ride
- Harbor Freight Motorcycle Lift Table
- Screwed up cam plate
- How do I remove Oilpump Driveshaft Bushing??
- Unknown engine noise in Iron 883
- Street/Strip 124" Build
- 88 TC heat issues
- 58mm throttle body kit
- Engine builder/tuner - Palm Beach County?
- Cam install what are the necessary parts?
- Needing some help, may have fubar'd myself.
- Motor to far back
- T/C 103 Max bore?
- Lifter size and id
- Twin Cam 88 bottom end issues?
- Fatboy stalling and breakdown
- Hey Kirby
- Abnormally loud "tapping" noise post oil/filter change
- Ultima 96 shovelhead engine
- Possible cross threaded spark plug
- 08 TC96 ultra starter leaking oil, aftermarket starter with HD O ring
- 08 TC96 ultra starter leaking oil, aftermarket O ring
- 2009 HD VRod Muscle
- My engine build
- S&S 509 cam question
- Issue with smoke and oil?
- Cams
- Carbon build up/gasket removal
- 103 to 110. Throttle body?
- Shovelhead flywheel part identification
- Upgrading 96 Twin Cam
- M8 107 Smokes after Cam swap
- FXDB Hillside 117”
- S&S cam plate upgrade
- 02 Electra Glide will not power up
- Got Engine Codes
- Help identify engine noise
- Minor cylinder scratches--normal @ 7000 miles?
- 03 road king with 88
- Piston height for squish adjustment on Twinkie
- 107 to 114 oem top end "stage 3"
- 2010 streetglide build
- 2009 VRod - Oil / Exhaust
- 06 vs 99 TC Heads
- 2002 FLHTC Engine Upgrde
- HELP PLEASE! tan goo leaking out of cam position sensor
- Cylinder scoring + gunk on guide
- piston, cam upgrades?
- S&S timesaver pushrods input
- 96in motor?
- 2016 flss .006 crankshaft runout
- So cal machine shops
- 88" Cam Opinions
- Engine swap
- check engine light on
- Kit stage III (29893-07B) with cnc ported heads
- Procedure for installing exhaust stud in M8 head
- 200 hp 88".
- lifter axle shifted
- Jims 131 single cylinder firing, compression diagnosis?
- Crankcase vent to air cleaner
- Thread lock
- Lost power and loud sewing noise
- Perfect fit pushrods
- Twin cam crank and rods
- harley 117 engine
- Early 2000's twin cam valve train noise
- Calling all gear heads
- Kit 92500033 se 110
- Manual compression releases
- Replacing cams/ fuel moto b heads replace c/basket ?
