PDA
View Full Version : Engine Mechanical Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31
  1. Hpi throttle body fitment issue , somebody please help me figure this out .
  2. Oil Cooler Recommendation
  3. 96 to a 103
  4. S&S Indy dealers around Sac ?
  5. Help !
  6. Camshaft
  7. Should I be pi$$ed or am I making something out of nothing?
  8. Throttle and clutch cable
  9. Premium gas?
  10. 103 heads on a 95" build
  11. oil leak again
  12. 96 CI Heads vs. 103 CI Heads
  13. What are the "real world" power gains with mild cams in a 103?
  14. How you can tell
  15. 96 to 103 and New Deck Heigth
  16. Cam plate upgrade on 03 dyna
  17. Polygon Crankpin technology for Twin Cam Flywheels
  18. Cam plate differences
  19. what's need to wake up there 110SE
  20. Can somebody tell me what collection this is
  21. Re-using lifters on cam install
  22. rod bearing question
  23. crank runout
  24. cylinder cutting out
  25. Rocker box changeover
  26. .030 gasket ok to use stock pushrods?
  27. Pushrod Adjustment
  28. Throttle by wire problems
  29. 96 to S&S 106 - Safe?
  30. Andrews 48 cams
  31. Cam tensioners - I think they don't need replacing yet
  32. Run hard, speed shift, dies...
  33. Unusual idling
  34. Opinions needed on tear down pic's
  35. crank woes
  36. Cool Jugg's...Ward's Cooling Fans ...
  37. S&S 509 or 510
  38. 1993 1200 Sportster smoking
  39. Crap! What is that noise?
  40. Is this bad for the engine?
  41. What is this noise??
  42. 106 build
  43. Dealer flash for lifter rattle...?
  44. 2001 Twin 88 stock cams
  45. What would you do with a brand new 103HO?
  46. Shovelhead pistons orientation
  47. After crashed, Oil Leak....
  48. leaky front pushrod middle?
  49. Forged crank years
  50. Quick cam chain tensioner question
  51. 103 lifter question
  52. ifference between the 30041-08 rotor and 30041-08a?
  53. new 124 S&S difficult to firing,starting
  54. typical deck height for a 2002 88
  55. Oil in Fat Bob air filter!
  56. cam chest upgrade question
  57. Woods tw222 cams
  58. Mild tc88 build
  59. The Price of Performance
  60. Help w/ Compression release valves
  61. 2016 SE 110 motor issues
  62. Serious motor issue
  63. Which injectors?
  64. When to deglaze clinders and install new rings
  65. New sporty problem!
  66. Stg 5 vs FM 107 vs Drago 107
  67. Oil Pump Screen
  68. Tman 110 CVO Signature Thumper Series Kit
  69. 03 twin cam sounds like bad cam tensioner
  70. How to make my Shovelhead "cackle" when I pull the clutch in??
  71. TECH TIP - Cyco hyd tensioner shoe install
  72. 110 bolt on kit w/ kompressor heads
  73. Thoughts on my 103 project
  74. Blown Motor?
  75. Compression Releases...
  76. Cam Tensioners 2013 103
  77. Intake gaskets
  78. stock heads airflow numbers
  79. Intermittent Valve Train Noise
  80. 98" Build cyclerama 575 vs Wood 5/G/6
  81. Workshop manual 2014 FLHTCU
  82. 1974 ironhead shorted out
  83. Adjusting Lifter Pre-Load Question
  84. Thrust collars
  85. Talk me out of this...
  86. Lifter question
  87. Click but no start
  88. My head is twisted!
  89. Cam lifter question
  90. Iron 883 Excessive Play in connecting rod at flywheel
  91. Cam for 89" EVO?
  92. Weak engine head casting? Poor mechanical skills? I'm doomed?
  93. HD Inherent catastrophic design flaws
  94. Pressed flywheel
  95. Stage III SE kit just had dyno..what do you think?
  96. Plug change, possible problems??
  97. 500 miles on bike, how to identify damaged motor.
  98. Bang, knock - Help
  99. Cam plate installation
  100. New breather design sucks
  101. Anyone running bigger Throttle Body on 103?
  102. 103HO High flow stock air cleaner. Switch to another without tune?
  103. tensioner comes apart when tensioning...
  104. Powder coat pushrod tubes
  105. 06 Dyna 6 speed RPM vs MPH
  106. Doing my legwork -- 88" to 95"
  107. Dyno at 500 ok or wait for 1000
  108. Tc96b build advice
  109. Cylinder heads 06 Electra glide
  110. Help fm107 new build
  111. Pan covered evo.
  112. Opinions on Andrews 26g cams..
  113. Do I need to beef up my lower end?
  114. how to find out what my cams are
  115. Help: twin cam 88- cam journal marred up
  116. New to Ironheads. Cam cover question
  117. Want to get it running better
  118. oil leaking from breather hose
  119. Andrews 26N cam end play?
  120. 98" build Piston Questions
  121. Adjustable Pushrods Question/Headaches
  122. SE Ventilator or other Stage 1 AC enough for SE 110 motor?
  123. VEE TWIN runs 7.10!!
  124. Please chime in on my engine build set up
  125. FM 107 build- throttle body smoke
  126. 95" build
  127. Adjustable pushrod question
  128. VIDEO noise on primary side ...? any guesses
  129. curious. 110ci and 117ci kit questions?
  130. Odd noise at hot idle.....
  131. question about 95" and 96" engine
  132. Roller rockers worth it ??
  133. Odd Knock or Rattle when settling to idle
  134. Help urgent !!! 88" 2006 dyna
  135. Twin cam tensioners
  136. Weight difference between 96" and 117"
  137. 124" rod length differences
  138. 88 oil pump
  139. Fuel Moto
  140. single loud knock when rpms are coming down
  141. 120r setups
  142. Low funding upgrade
  143. 124R Build - long story
  144. Pull pump or not?
  145. IH 1000 flywheel/connecting rod question
  146. 2001 sportster 883 with 1200 upgrade Lifter problem
  147. Harley M50 Sport
  148. 120r
  149. Question 06 fxd SE95" pushrods question
  150. Requesting spark plug analysis
  151. DP Clutch Kit: Thoughts?
  152. Throttle body knock
  153. Just some opinions on a 107 build
  154. evo engine
  155. Need help. FXDX blown cam bearings (obviously ) blown oil pump
  156. Cam Tensioners
  157. TECH TIP - cam tensioner upgrade
  158. Loud Tick At Idle
  159. T Man Performance
  160. shovel head oil pump
  161. Feuling Pump / Cam Plate
  162. Doing a 95" kit on my 99 tc88 need opinions on cams [sorry]
  163. Which Dyno Chart? Want opinions please
  164. S&S Gear Drive Backlash Setting
  165. Softail Slim 117" build
  166. Feedback on a possible build - 117"
  167. 2008 flhtcu efi
  168. best way to treat an engine that has been sitting
  169. Question On TC88 Front Cam Drive Chain
  170. New 106 build
  171. Disconnect Automatic Compression releases?
  172. Cylinder Head Damage & Blown Head Gasket 1980 Harley FLH-80 Shovelhead 1340cc
  173. S&S 117 build up
  174. Stripped cam plate repair advice
  175. 96" to 103"with 57H cams... stock pushrods?
  176. EVO oil question
  177. Intake Leak Dyna 2014 Low Rider
  178. FM 107 cylinder base leak
  179. question - any internal breathing issues with using torrington cam bearings in 2013 TC stock motor / 57h cams?
  180. 99 1200 sporty acts like it's flooding or not getting enough fuel
  181. Wards cooling fans
  182. SE 585 Cams with stock heads on 2010 ,103ci
  183. Quick pushrods help
  184. Quick pushrods help
  185. Panhead question
  186. Downshifting Question
  187. Abnormal piston to cylinder tolerance??
  188. Rocker Arm Bolt torque?
  189. Carb jetting
  190. will a 103 Engine mount in the place of my 96
  191. Increasing compression with an Andrews 37
  192. Swapped engine question
  193. For the engine builders out there
  194. T-Man 120R - 124 Conversion
  195. New cam install thread
  196. 5 piece crank to 3 piece crank?
  197. Leaking cases
  198. Harley ST120 Throttle LAG
  199. compression ratio for ultra bagger
  200. VIN on engine doesn't match frame
  201. Poll: Geardrive cams, do it yourself?
  202. Annoying Tick & Rocker Lockers
  203. Hylift Johnson lifter feed hole 90 degrees out
  204. 107 build, couple of questions
  205. Rocker box gasket question...
  206. Looking to upgrade my 88ci Roadking custom
  207. V thunder pro magnum lifters adjustment
  208. Questions about making a 106 with S&S 4.5" crank.
  209. Possible Gasket Leak?
  210. Wrinkle black inside my lifter (tappet) blocks
  211. Case Boring Question
  212. SE 255 cam/pushrod ??
  213. 107" build thoughts
  214. another .30 gasket thread... (S&S 106, Feuling 574)
  215. PCV Map Request - 117"
  216. SE CNC heads max lift?
  217. school me on the CVO 110 motor
  218. heads and jugs from a 2015 Road Glide to a 2009 Fatbob
  219. 07 street glide not starting right
  220. 96ci died last night
  221. Cam curved snap ring issues
  222. Cometic Top End Kit
  223. Better to buy new crank i.e. Have one done up
  224. Another "Which Cam" question
  225. 57h in a 103 ...having second thoughts
  226. Strange knock like when you use bottom of the barrel fuel
  227. 103 engine swap
  228. crankshaft problems
  229. Is there a way to tell if someone installed a 103 kit?
  230. STUMPED - Yet another Leaky Rocker Box Thread
  231. Lost in the stages
  232. Can I get these cams (and parts) to work together???
  233. Benefits from .030 cometic gasket
  234. More confused than ever...head gasket question
  235. Any ideas?
  236. 2009 tc96 to 103ci cylinder interchange
  237. cam replacement
  238. Piston upgrade for a 103"?
  239. Another Cam swap question
  240. Budget Minded 103 build
  241. 88 twin cam tensioner replacement
  242. Question on enlarging stock 46mm TB to 51mm plus adding larger 4.9 injectors
  243. Head work, need to replace base o-rings?
  244. Can't pump Lifter plunger. Replace it?
  245. Fuel Moto 107 kit in Alberta?
  246. Do I have a problem?
  247. Stage IV Reliability - Next weak link?
  248. Evo trouble
  249. Throttle body removal trick
  250. Lifter oil holes IN or OUT?
