PDA
View Full Version : Engine Mechanical Topics
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Evo Cam to Crank distance / drawing
  2. High Oil Pressure?
  3. Burning a lot of oil on test drive
  4. Compression for '89 Sportster
  5. Pingle rear motor mount (no case split instal) question
  6. New Cam and Suspension
  7. 2002 roadking crank no start issue
  8. Need to fix leak
  9. Spark Plugs
  10. Who Knows Factory Markings?
  11. Air cleaner won’t come off
  12. twin cam cam install, getting top end noise.
  13. Oil leak new Lowrider
  14. 94 Fatboy head gasket
  15. TC88 cam install help
  16. What’s a reasonable price for a 88 to a 107
  17. Engine swap questions
  18. S&S Quickie Pushrod Install
  19. Evo engine noise
  20. Clutch worm gear
  21. Cylinder chamfer
  22. Jagg oil cooler
  23. Anyone Running Solid Roller Lifters???
  24. Primary Chain Tensioner
  25. Ugh, Pulled threads
  26. S&S 475 Cam install tick?
  27. Andrews 37 cams in an 88"
  28. First time lapping valves
  29. 1972 Shovelhead motor question
  30. 2005 Road Glide w/ Oil Seepage After Rebuild
  31. Made my own oil catch can for my 21 TG
  32. 110" build
  33. 110" build
  34. Wrong cams for plate or engine.
  35. Oil in my air filter at 3000 miles
  36. Lifters
  37. Adjustable Stabilizer linkage '24 117 models
  38. Fuel Moto 98" Big Bore Kit
  39. 96" compression
  40. Twin Cam 88 not running after tensioner replacement
  41. Pushrods question
  42. twin cam sumping?
  43. 1999 FXDX Chasing Blow By
  44. Help I'm lost
  45. SE Stage III 122 Ci
  46. 96 twin cam camshaft ID
  47. Over heating Ultra
  48. SE 255 Cam Question
  49. Replace upgraded bearings each time with new cams?
  50. Cam swap and Engine lights
  51. 95' Heritage Ticking (Swapped Cam, lifters, bearing, more..)
  52. adjusting pushrods with lifters not primed
  53. 2012 street glide issue
  54. SE Cam Plate and Oil Pump
  55. Oil pump/cam plate.
  56. 23 low rider s cam labor
  57. 96" s&s sidewinder
  58. 1st Build advice
  59. S&S M8 cam plate and oil pump
  60. twin cam lifter issue
  61. Opinion on cams for 117 Low Rider ST
  62. Scresming Eagle 110" squeaking noise
  63. Stripped oil pan drain hole threads
  64. S&S 96" sidewinder
  65. Head porting
  66. Rebuilt engine won't turn over
  67. SE204 Cam Swap
  68. Twin cam inner tensioner tool im on a mission!
  69. Valves guides unknown
  70. 2002 Ultra Classic
  71. Runnout specs
  72. Milwaukee eight runabilty issue!
  73. End float on evo crank
  74. What is this tool?
  75. 1974 Aermacchi Z-90
  76. Low power
  77. Trouble with 103 Cylinder Base O-rings
  78. improper install of TW-222 cam, potential problems ?
  79. Knurled Pistons
  80. 07 heritage 96" putting in 103" stage 4 kit with woods tw222 cams
  81. 2003 flhtpi throttle body assembly
  82. 2003 FLHTPI Throttle body assembly
  83. 2007 ultra classic poor performance with s&s 551 cams?
  84. Primary & secondary chains
  85. 1999 TC88 Rear outer cam bearing
  86. Cam whine
  87. Keeping Engine Temperature down
  88. 1997 Evo blowby
  89. Have you had crank issues with TC?
  90. TC 117 Sumping
  91. Cam chest tapping when warm
  92. Sportster 1200S, 2000
  93. Head oiling question
  94. Question on upgarde stcok 13 SG with 103
  95. Metallic sound from engine Sportster Iron 1200 2020.
  96. Inner cam bearing removal?
  97. 103" build
  98. Metallic noise at low RPM
  99. When do you need compression releases
  100. Manual Compression Release Fell Out
  101. Crank repair/repalce, what is involved?
  102. Tc88 stage 3 cam choice
  103. Time to pick a new cam........
  104. CCP 245 psi !
  105. 110 to 117 screaming eagle kit
  106. hesitation
  107. 120r spigot size ?
  108. camshaft end play
  109. Adjustable Pushrods
  110. 88" 103" Flywheels
  111. M8 Lifters S&S or Wood Platinum
  112. How's the plugs look?
  113. Twin Cam 96" 70k mile rebuild
  114. wire stator oil leak
  115. 1996 Road King (FLHR)
  116. Tensioner pads for hydraulic timing chain
  117. sump issue....?
  118. Standard bore 10-1 pistons for 1990 evo
  119. Trying to install circlips!!
  120. SE 110" Tire Shredder Kit Report
  121. Experiment
  122. Motor Builders in Central CA........??
  123. Changing M8 oil pump
  124. Oil leak problem having trouble finding source
  125. twin cam oil pan cleaning
  126. Csn I put a 09 Dyna twin cam motor into an 04 without any issues?
  127. M8 ticking...still
  128. Dog bone for rocker arms
  129. Compression reading
  130. 2003 Dyna Low Rider camchain tensioners performed but now more vibration
  131. 2007 Yamaha Vstar 650
  132. After cam upgrade bike won’t turn over
  133. FLHRSEI2 2003 road king screamin eagle 103 cam tensioner upgrade
  134. Milwaukee 8 114 Engine Rebuild Piston and Cylinder Issue
  135. T. Cam tensioner
  136. How to break nut free
  137. Dyna 2006 crank
  138. Runout process
  139. cam tensioner replacement VS hydraulic upgrade
  140. 2007 1585 FXDL EFI Engine idle/cutting out. Please Help
  141. 2017 Street Glide Special engine noise
  142. 1996 HD fatboy running issue
  143. TC 103HO cam bearing tool
  144. 117 kit help
  145. 1987 fxst 1340 evo head bolts
  146. 2006 Engine Swap question
  147. Are Oil Pans Interchangeable?
  148. Woods X cams
  149. Engine knock??
  150. Cams for 103HO
  151. Getting compression right for Comp cams TC-3103
  152. Strange sound from Cylinder head
  153. 2023 117 breakout
  154. Change flywheel on big bore kit?
  155. This sucks rear o2 sensor backed out on my 2019 eglide
  156. Fueling 574 cams
  157. 2012 flhx please help
  158. 2012 flhx please help
  159. 2018 FLHXS oil pump / cam
  160. Damaged Crank Teeth
  161. Piston type and compression ratio confusion
  162. What do you think about the condition of these piston heads
  163. First time Harley owner
  164. Cometic head gasket
  165. Tune after 106ci build
  166. used cyl and pistons
  167. 1982 FXRS restoration
  168. Woods 222/555 vs Andrews 48h/57h for FXDB
  169. Gear drive camshaft or rocker noise?
  170. 2016 Fat Boy S engine knocking suddenly
  171. Carb size for 107 Twin Cam build
  172. Dealer double dipping on stage 3?
  173. M8 intake leak with SE aluminum intake.
  174. SE AC Install
  175. Harley 135se vs built motor
  176. Roller Lifters: Bushed or Needle Bearing?
  177. Diagnosing an engine noise.
  178. popping through throttle body
  179. Idle Issue fixed; Street Glide
  180. Revisiting Adjustment of push rods
  181. Testing Harley ACR
  182. 2012 ultra limited
  183. 09 triglide top motor mount bolt torque
  184. How/why does heavier oil quiet ticking top end?
  185. How to primary drive ?
  186. Milwaukee eight 107 Cold start
  187. Cam Plate Stripped bolt
  188. Does this Breather Setup Look OK?
  189. 2019 Cvo StreetglIde no 6th gear
  190. Weird issue
  191. Help identifying noise from motor. (With Video)
  192. Rear cylinder base gasket leak
  193. Fuel Commander?
  194. Milwaukee eight Longevity
  195. Occassional problem
  196. Is a good engine rebuild as good as a new motor?
  197. Lifters and Cam swap to new bike?
  198. 2023 CVO 121VVT Motor
  199. M8 Lower Rocker Box- tools needed for correct torque
  200. Engine Decoder
  201. Blowing oil through breather and sprocket seal
  202. rattle on acceleration
  203. Feuling vented Dipstick
  204. Trying to Help a friend....Strange Issue
  205. K & N air filter vs SE Stage 1 filter TC 103
  206. "75" XR750 piston circlip
  207. "75" XR750 piston circlip
  208. Finally back up to my ideas....
  209. Watch, you might learn something.
  210. engine warning light 2017
  211. engine warning light 2017
  212. S&S Super Stock Evo heads on a 95 twin cam build
  213. Code U-1255
  214. Reuse piston rings
  215. Cool rear exhaust
  216. Valve spring noise?
  217. Unknown connector 07 RK
  218. Sifton Adjustable Pushrods: ok or not?
  219. intake seals
  220. rider02
  221. Cam chain tensioner dot placement
  222. Scissored Crank Question
  223. Harley FLHX (07) Twin Cam won't turn over with plugs installed
  224. A different cam chain tensioner question
  225. 89 evo Clutch basket wobble
  226. Rocker box gasket / new pushrod install
  227. S&S low end cam for stage 2
  228. engine dying
  229. 1998 EVO starts nicely but takes to long to warm up
  230. Help!! 05 dyna engine in a 03 flhtc
  231. Thoughts on Feuling 543- Twin Cam 96
  232. Reverse gear
  233. Milling and dome pistons
  234. Help identifying pushrods.
  235. Cams are shot
  236. Roller rocker arm hitting valve spring
  237. Weird idle issue
  238. Andrews 57h or Woods 777
  239. Breather Assembly
  240. Cam sounds
  241. Which cam?
  242. 84 low rider non cv
  243. Tri Glide Cam Help
  244. 2011 883 temporarily loosing power at 70mph - 80 mph 5th gear.
  245. 2013 RG 103 Cylinder Wear
  246. Quality gaskets & O-rings
  247. Motor heads Please. TC88 Current Stage ll.
  248. injector O-rings
  249. FSM shows O-ring, Gskt kit has O-ring, oil pump no O ring
  250. TDC and Timing Dots on Sprockets
