PDA
View Full Version : Engine Mechanical Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Cam bearing plate and upgraded oil pump necessary in 114" Stage 2?
  2. fuel tank cross over line
  3. Help me build a pissed off TC88?
  4. Looking for a cam change in my 95ci build
  5. 2014 110" FXDB CR-595 Cam Dyno Chart
  6. Hydrolic Lifters and Valve overlap?
  7. Axtell vs Baisley
  8. Compression problem on a evo 1340
  9. FM Level B Heads
  10. Fuel Moto kit for 124
  11. Lifters and Rods
  12. Engine Repair and build S. Fla or Daytona
  13. Planned build, any good? Reliable?
  14. 88" to 96" swap
  15. S&S 475c Cam 2018 FatBoy
  16. Big bore kit on 07 Ultra Classic
  17. New Harley Motor at 100,000 miles
  18. Top End Breather Assembly for 2007 Twin Cam A Motor, what's out there other than stock assembly?
  19. Harley davidson screamin' eagle 58mm throttle body 27713-08
  20. Big bore kit for 88 CI
  21. Roller Rockers?
  22. 103 twin cam hydraulic tensioners. advice needed
  23. Anyone build a Fatso lately?
  24. Inner Cam Bearing
  25. 103 best sound in a cam swap
  26. Fuel Sender In Split Tank
  27. Adjustable push rods vs tearing the top down
  28. Crankshaft/flywheel id
  29. Daytona Cylinders
  30. 110 Drop In, Andrews 57, S.E. Heads, etc. Very Nice!
  31. woods cams
  32. oil drain
  33. Best Engine Builder in the Phoenix Area?
  34. MCR Install
  35. 124 M8 kit and oil port.
  36. 2015 RGS Cam, oil pump etc. questions
  37. Fam chain tensioners
  38. What am I seeing ???
  39. Is this timing off?
  40. Delete
  41. Cam install. Dealer asking if I'm wanting xxxxxx
  42. Engine ReBuild
  43. How to replace engine bolts with stainless
  44. Stage 1 Breakout. 30t 70t pulley. Tw 222 or tw 555?
  45. F#@king adjustable pushrods...
  46. Throttle body
  47. 100" Big Bore Build
  48. Loud ticking and pulled the rocker box off, upper retainer is chewed up
  49. Advice on Twincam build
  50. install stage iv
  51. Oil dipstick blowing out
  52. Loud ticking from front 03 dyna
  53. Exhaust gas temps, what's too hot?
  54. 107 build with hemisphereical heads. Continued...
  55. Is My Engine Done-For? Possible Water Through Air Intake
  56. Heads
  57. TC 88 build??
  58. What size throttle body?
  59. Hemisphereical SE heads
  60. 103+ heads
  61. Piston dome
  62. Sportster screamin' eagle cam part number 25400125
  63. Re gearing for S&S T124 640 Cams
  64. Cams for S&S T124
  65. How to tame down S&S T124 HC 640 Cams
  66. M8
  67. Base Gasket - 93 EVO - Have A Question
  68. M8 swap
  69. 2018 Breakout stage 2 problem
  70. HELP! Screamin Eagle hybrid cam plate
  71. Strange "to me" engine sound
  72. Can you name this part?
  73. Cam question
  74. Cam Sensor
  75. S&S 510 cams
  76. Advice on do it yourself Evo top end rebuild?
  77. Blown Engine
  78. 14 glide leaking jugs..
  79. New Build FM 107 break in Oil Pressure on start up
  80. S&S TC3 cam plate and oil pump
  81. Chris Rivas rocket 554 cam
  82. HD not supplying SE cam tools in UK
  83. Here's a puzzler
  84. Need some advise (Base Gasket Job)
  85. OEM Valve guide OD SIZE?
  86. 04 ultra build
  87. '92 FXRS Dyno Results
  88. Your 3 best performnce tricks
  89. Cams
  90. 2010 TC engine right rear pipe plug function.
  91. 95 or 100 in a tc 88
  92. Keep 22x or change to redshift 468 on 117 bigbore?
  93. Lifter size question
  94. front piston not firing
  95. oil pan gasket...hylomar?
  96. Shovelhead help
  97. Longblock program install advice
  98. do i reuse my push rods?
  99. Upgrade advice
  100. Mackey 598 cam
  101. Shoring up the 103
  102. Pre-Ignition Ping
  103. Lifter noise?
  104. Radiator Alternative
  105. 2018 with SE 114 kit
  106. 88 to 100 upgrade with cams
  107. torque figures
  108. HD Stage 3 or 5 kit for stock 103
  109. early 99' dyna rear cylinder miss
  110. 2014 1200 sportster custom
  111. Engine build
  112. Swapping motors
  113. Swapping a motor
  114. Bike won’t start
  115. How do these plugs look?
  116. 2007 fatboy Thinking of going to 106
  117. Question on Rocker Locker install
  118. 2003 Ultra Classic oil cap/dipstick blows out
  119. 88 Cam Bearing Installation.
  120. M8 crank strength compared to TC
  121. Sporty oil circulation.
  122. Needing help!!! blown motor
  123. Industrial Equipments
  124. S&S 107 Build with MR103 Cams
  125. Extreme Vibration
  126. Where does this hose go?
  127. Either too paranoid or got an issue after changing rocker gaskets
  128. Odd clicking Sound Coming from Engine
  129. Busted a SE tapered Pushrod Nut
  130. what cam to use
  131. 88 ci cams
  132. 120st
  133. irritating ticking noise
  134. Fxr 113 super G rich help
  135. Will cam plate and cams out of a 2007 Dyna 96 inch work with a 2004 dyna 88 cubic inch??
  136. Ironhead performance upgrade
  137. S&S TC3 Oil Pump - worth it?
  138. 88tc questions..
  139. Advice on compression with 97” build
  140. oil with water
  141. Into the camchest
  142. 117ci stage 4
  143. spring loaded tensioners
  144. 103 cylinder interchange.
  145. EVO Camshaft 84-93 CA
  146. Stage 4 on 103
  147. Idle Problems
  148. Valve sweats
  149. Advice Needed on Engine Repair
  150. W6 cam 10:1 compression questions
  151. '16 Limited Motor
  152. Scored Cylinder
  153. 40 Knuckle oil pump gear
  154. Lifter Bore Pitting...Is This Normal...Picture Inside
  155. Back fire and rough idle
  156. 2017 Street Glide Special Oil Light
  157. Strange harmonic engine sound while under load?
  158. mating engine cases
  159. Listed CR of pistons
  160. Cam swap
  161. Is my M8 sumping?
  162. help identifying evo engine inner case numbers
  163. Black smoke when first starting
  164. 85 FXR EVO Rebuild and motor turning half revolution
  165. Twin Cam 107 with headwork vs. stage 1 M8
  166. .600 valve springs and cam lift
  167. Breather Question
  168. M8 124" Bolt on kits!
  169. Help on Camshaft replacement
  170. Front or Rear Cyl? Is There a Difference???
  171. XLCH Ironhead unusual holes in tappets/lifters
  172. 98 Electra glide mmfi
  173. External VS Internal Venting Pros & Cons
  174. 03 HD sportster 1200c timing issues
  175. 78 Shovel Front Rocker Oiling
  176. Bike problem
  177. Am I stupid disliking adjustable pushrods?
  178. Think I toasted it
  179. Engine Upgrade Advice
  180. Help identifying this bolt
  181. HG .030 in a 2012 Heritage
  182. TC95 upgrade
  183. 103 Build ???
  184. 2 different future build scenarios?
  185. Compensator Alignment
  186. Losing Throttle Response
  187. Misfiring in neutral during steady-state mid-RPMs normal?
  188. Any ideas what’s up with these engine markings?
  189. Aftermarket cylinder head temperature sensor placement
  190. FM 110 KIT 777 What Throttle Body and Injector size?
  191. S&S 107 kit with S&S MR103 cams ???
  192. Question for the porting pro's
  193. Socket size for screw lifter guides
  194. Hydraulic Cam Tensioner Pad Replacement
  195. insert cam here
  196. very loud noise from heads
  197. 2013 Forty-Eight No Compression
  198. Replaced lifters and still have a loud tick
  199. Best cam for my 107 build
  200. S&S 124" Hot setup kit parts list?
  201. Engine build recommendations
  202. Brass Balls Bobber ( Engine )
  203. Factory 103 Stage IV
  204. TW 222 or Andrews 48 H ?
  205. Rocker Box Gaskets
  206. New lifters with no bleed down time?
  207. Motor replacement, 88" to 103"?
  208. Andrews 37 vs 48 in 2008 RK
  209. S&S M8 Billet Oil pump and cam plate
  210. Motor Man
  211. Putting oil on valve springs?
  212. Ring compatibility with drop in Harley cylinders?
  213. What brand pistons do you guys use ??? 1340 evo
  214. 2013 Heritage 103 Softail..
  215. Breathing into catch can, WTF!
  216. Impact on crank?
  217. what is the best ajustable pushrod for EVO
  218. 95 fatboy
  219. 2004 Road King / Woods TW6 Cam - overall reliability question
  220. One cylinder running much hotter than the other
  221. Lifter noise
  222. 2007 Ultra
  223. Cylinder location
  224. How to perform a leak-down test on a Harley Twin Cam
  225. Twin cam 88 heads to 103
  226. Compression & Leak-down Results - Easy-Start
  227. Developed loud tick then went away/quieter down
  228. Smoke from right pipe
  229. 09 FLHTC....Crank Bearing "Walking"......
  230. Spark plug and tire rotation
  231. The plugs
  232. Help with Shovelution Heads and stroker pistons
  233. 107 or 114
  234. Who makes custom grind cams?
  235. noise on rear cylinder after 107 top end install...
  236. Can FXDLS 110ci barrels be bored to 177ci ?
  237. inspection scope pic of cylinder wall and piston
  238. Cyco cam chain tensioners
  239. TC oil Pump alignment
  240. cam support plate #1 hole
  241. 88 heads on a 96ci
  242. 2018 road king
  243. Fuel moto 107 kit
  244. Rough cost for crank repair?
  245. 15' 103 HO top end on an 07' 96"
  246. m8 S&S cam install...are lifters needed????
  247. Determining cams from a dyno sheet?
  248. Darkhorse/S&S 117 build questions
  249. No fire in front cylinder, need help
  250. Can the Average Joe install big bore kits?
