- A few Q's about re-assembly after cam chain tensioner shoe change
- Zippers Redshift dual piston cam chain tensioners
- .030 head gasket
- 2019 FLHTK fans not coming on after cam upgrade
- Air Blowing Back Through Air Intake
- How do know what cc heads I have?
- 05 Deluxe 95 build
- How to tell if cam chain tensioner was "fixed", or replaced with gears?
- 07 CVO 110 Jugs, pistons, cams on 2015 103?
- 2012 flhx no rought/no cold start
- Adjustable PRs or oem?
- 2015 Twin Cam headwork
- Whats your Winter Build
- Recent S&S top end with oil leak at Jug Base ..
- Darkhorse Man-o-War crank runout
- Chevy lifters in twin cam motors?
- Will heads from a 2011 Softail 96 B fit on a 2006 Softail EFI 88 B?
- M8 Noises
- 2800 to 3000 rpm ping or chatter stock 88 (low mileage)
- Evo cam chest cover replacement
- Top End noise after rebuild
- M8 Head Bolt Re-Torque
- Squish and Volumetric Efficiency
- CV carb jetting for mild 95ci
- Ring gap
- Build advice.... 2020 Low Rider S.
- Easy start cams vs manual compression releases
- Bike idles high after motor gets a good 20 miles on it .
- Vented dipsticks / crankcase breathers
- High Valve Lifts and Dish Pistons
- Cam for a 2011 fat boy lo 96cc
- Problem getting Pushrods back in
- Cams for 98" dyna build - S&S 585 vs 570
- 114 & SE III Valve Spring Pressure and Height
- Oil pump failure?
- HELP! She just died...
- Only runs right for a min.
- Hard Starting
- LRS 110ci reliability
- TC oil flow and valve noise question.
- Bobber Build
- M8 Rings
- TC Engine modifications
- Early TC silent cam chains and strech ??
- cam question, lift vs reliabillity
- Engine Noise
- Best cam & 11:1 piston recommendations
- 2020 M8 Lifter Failure
- Lifters 99 TC 88
- Need A High Tech Laugh?
- Are performance vavle spring kits on M8s noisier than stock
- 2000 ultra cam install ?
- Rebuild mileage
- 1971 - 1972
- Screamin Eagle Heads
- S&S quality
- Cam issue or ?
- R&R Cycles - Manchester, NH
- S&S T143 vs. T2 4-1/8" Bore
- Woods Tw 999-6 vs Tman 590 ps2
- Fuel moto order for my 2020 SGS
- Breather assembly question
- Installing a LeNale Fan
- What Year Heads?
- FXDF 2011 96ci oil cooler
- My 4.250” piston build (twin cam)
- Custom DK Products and Engine Heat
- 2008 Softail Custom mods needed
- Checking camshaft and breather end play with new gasket?
- 58 Pan/Shovel rebuild
- Valves and Springs advice
- 04' TC88 big bore build on a BUDGET
- S&S 106" - 94.5hp/114.3trq
- Transmission muffler mount r&r on 03 flhtci
- Hylift Johnson Lifter?
- Need some help: New motor or scrap
- Valve spring markings - what does a white paint marking mean?
- M8 cams
- KB forged pistons - wrist pin install question
- 3.885 big bore head and base gasket ?
- Zippers 468 cam upgrade. Oem oil pump or..
- 95ci with S&S 635 Cams
- Head difference between 74 and 80
- My Dyno...What do you all think?
- Softail Deuce upgrades?
- Shovelhead Full Rebuild, Won’t start
- Knock Knock(whos there) part 2
- Twin cam 88
- Bike struggling to idle when restarted shortly after shutting off
- Biggest bore for TC88
- Andrews 55H
- M8 using oil. Wasn't before.
- Cam chain tensioner issues on 2015 103ci
- Need help with diagnose, IDK what’s wrong.. HELPPP!!!
- When start up cold, weird nose
- 2007 twin cam poping intake and exhaust
- Xl1200NS rattling noise at full throttle
- Diy cam install...can i do it?
- Rebuild/cam questions
- 91 Softail heritage classic
- Loud ticking after cam/head break in run
- Evo Engine Rebuild
- old subject TC heads
- Engine Removal
- 05 Road King won't start
- HD Stage IV Big Bore kit # 92500011
- stupid question time
- Valve chattering?
- Engine noise Help
- Finding cam base circle on a M8
- New build
- Extremely intermittent P0118 DTC Advice
- Power train swap
- Top end rebuild findings - 09 dyna super glide fxd 19k miles
- 2015 Ultra Limited
- 2001 road Glide
- Chevy lifters in Twin Cam?
- M8 engine noise
- Turns over wont start
- 2008 Fat Bob Cuts Off
- 2002 TC88 - Camchain needed?
- Liqui Moly - Molybenum disilfide engine oil flush safe for evo/twincam Harley motors?
- Big bore kit info.
- Upper end knock?
- 88" Bone Stock - What do the Experts say?
- 117 Drop In Kit SE 259e heat compared to SE 255?
- S&s big bore 100?s
- Screamin Eagle Premium Tapered Quick-Install Adjustable Pushrods
- will harley 117 jugs bolt up to a 96 motor
- Dyna good to bad
- evo left case
- COMPLETE gasket set
- 06+ cylinder heads.... How much better are they
- Specs or M8 stock HD case studs and bolts
- Upgrade motor on 2004 HD Ultra Classic
- Break down
- Cometic .020 base gasket question
- Track Mist Free Breathers
- Cam upgrade suggestions
- Rushmore 103 build options
- 88 B rebuild
- Electrical failure 1988 flsth
- Questions about fire damaged heads
- 58mm throttle body
- Help - SE Adjustable Push Rod Nut Cracked
- Any reason not to use Screamin Eagle pushrods
- Upper / Lower Rocker Box
- Heritage 114 Stage 1 stock air intake - good enough?
- 96 to 110
- Valve spring compressor tool
- Well, shit, since Im in there......
- Arlen Ness Air Cleaner Q
- Straight up; No bs...
- Oil line replace trick?
- 2020 RKS Feuling Camplate/Lifters/Pushrods?
- Maintenance questions
- Anyone know or heard of a 25/26 TPI adjustable pushrod?
- 08 Road King Misfire when Hot
- ABS Error code?
- High idle after highway speed q
- Incrimental 124 build
- 99 fxdx motor advice ?
- Binder clip method
- Crankcase venting
- Engine and Trans oil mixing
- TC 96” cam choices
- Evo cam change - missing part?
- Cranks, but will not run
- Cylinder Base O'ring
- How to locate cause of engine noise - Twin Cam
- Dream bike totaled!!!! Need help with 2020 Engine Upgrade
- Cylinder base gasket
- Shovelhead Lifters
- 07 road king power loss and primary side noise
- Unknown Sound at High RPM (Video Linked)
- Metal filings in the primary
- Road king 07
- Hot starts and idle
- next step build...best way to go?
- '08 Heritage - Replacing a compensator
- SHOVELHEAD BENDIX ISSUES - I Think
- Broken motor mount?
- Cam dilemma - need help ASAP
- Mystery Problem
- CVO 110 and TW-555 on Dyna Low Rider S
- sleepy
- 99fxsts softail custom
- Valve to piston clearance
- 2006 dyna engine heat oil pressure
- finally happy ( if ther's such a thing)
- S&S Lifters
- Cylinder exchange vs new
- Roller rockers w/590 cam on TC?
- Engine builder in Austin
- Crankshaft run-out
- Sputtering and misfire under load after being warmed up. Mostly in 3rd and 4th
- 2017 Fatboy S. Something doesn’t look right.
- Engine Shutdown
- Finally finished upgrades on 04 fatboy!
- 1990 fxstc cuts out at 65+
- Compression Ratio Calculation
- 2017 103” engine and cam questions
- 88 stroker
- Andrew's gear drive kit.
- 2004 Sportster Engine Problems
- Upgrading a stock 103
- 1970-1972 shovel BT pinion shaft ??
- Check Engine and Oil Light M8 2020 FXST
- Compression release mechanical angle & location
- 103 Heads on TC 88-95 build
- Late evo cam
- 99 twin cam fxdx crank no start.
- frustrated
- Need help with M8 counterbalance shaft install
- m8 counterbalance shaft
- 06 Fatboy, upper cylinder noise.
- Super E vs Super G 113 “ motor
- S&S 113, rear cylinder wont fire.
- West Michigan Engine Builder - Sorry for the double post
- How Many Miles Before Replacing Lifters?
- 110 cylinder swap question
- Oil pressure question/HELP
- Jprecision in Quebec
- Thoughts on these cams
- 2013 Harley codes
- Engine noise during cold start
- Rebuild or new motor??
- M8 124 thoughts
- SE rocker plates or stock
- Need help identifying some bolts
- Suddenly noisy valve train on 97 Evo
- Will all this work together
- Stuck cam cover
- Upgrade 103 motor build question
- Engine Mount Bracket (I think) 2001 Sportster Hugger
- Help with possible lifter sound
- Budget throttle body swap- awesome results!
- 2006 Softail Springer Won't Idle
- Help Crossbones won't run
- 103 TC Cam choice - Andrews 48, CR 570-2 or Woods 222
- S&S Evo engine - loose part
- 124" fuelmoto street outlaw motor
- Question about an Oiling issue ... ( I think)
- 1.940 valves on stock seats
- Build starts tomorrow!!
- Lunati Voodoo cams
- TC88 Wish list
- Please educate me on lifter/pushrod/valve function
- Need help replacing M8 throttle body
- Oil in Air Filter
