- EXhaust products info
- torque specs
- fast idling
- quiet muffler advice neded for 04 EGC
- Evo flywheels
- will this fit (heads q.)
- 2003 vs 2005 jugs TC 88
- I am new to the forum
- Cylinder return holes do not line up base gasket
- Evolution engine crankcase breather filter. Fit one or not?
- To Wastegate, or not???
- Help needed with V Rod Muscle Air Filter!!
- check yer NUTS ,,and bolts
- Possible bent valve?
- TMan Cam
- Throttle body
- Cv help!!!
- Does this combo make sense?
- TC Timing
- Starter trouble
- Best Harley dealership mechanics in NY State?
- adjust valves
- How can I Remove the chrome tappet rod covers?
- Derby cover gasket
- What kind of cam bearings is HD using ...
- twin cam heads
- Need sugestions
- 99 Road King Starting Problem
- engine stuttering
- Backfire between gears and misfire
- DIY - Black exhaust
- 2006 XL1200C Idle Adjustment
- need to know the head torque
- How to inspect lifters and lifter blocks
- Modifying exhaust on '09 Softail Crossbones (Catalytic Muffler)
- Reprogram
- 08 Deluxe Tick's
- front cilinder is not working at idle
- spark plugs
- Installing Compensator Sprocket
- Multi prong Spark Plug
- compression
- Need timimg help!!
- Replacing tensioners in 04 EGC with Hydraulic.
- NKG Iridium spark plugs
- Crank Runout
- oil drain plug
- Spark to plugs problem
- How to install points & condenser
- Help with Cam
- new exhaust gaskets?
- Why would I get a P0117ET Sensor low
- Top end noise @ 3000 rpm
- something is wrong with my bike... again...
- Overheating alarms on 2007 Street Glide
- Turning a Stock 88ci into a 103ci or 110ci?
- what type of pipes
- exhaust popping
- engine noise
- slip on
- 74 XLCH project (with love from Dad)
- Help with cam!
- Nightster will not start
- Used idle cable adjustment to adjust engine idle
- Fouled plug...need advice
- Cam Chain Tensioner
- HD High Volume Oil Pump O-Ring
- Lowrider Exhaust
- Where can I buy new motor
- 89 FXR Ultima El Bruto Engine - Anyone Know?
- How to clean up after lifter ate cam lobe
- Cam tensioner adjustment or replacement.
- From Rinehart to Vance & Hines
- 2000 Ultra exhaust
- 07 96ci clutch adjustment
- Need some HELP
- motor swap
- anyone use revtech valve springs?
- 08 Pistons, jugs, heads for 02?
- Exhaust Fitment
- rough idle
- help! No oil pressure!!
- XL1200N - Need gaskets for full-system exhaust?
- 06 Cam Chain Tensioner upgrade vs: gear drive
- Engine stops
- 103 break in?
- Removing Baffles from 07 Sportster
- Remove stock 08 fatboy muffler
- Strong Exhaust Fumes
- Question about oil usage on Fatboy
- Intake & exhaust lifter bores
- Replacing exhaust
- Valve Adjustment
- Engine Ringing - HELP!
- Hybird Cam plate oil pump problems!! HELP
- Engine Break in
- Spark plugs
- Starter Hesitates
- What does this mean? Andrew Cam
- NGK Iridium
- Oil leak from rocker box
- Exhaust Leak!!!!
- head gaskets
- 80 ci upgrade
- any more power from
- bottom rocker leakin...what do i need to know?
- new hybrid cam tensioner
- Sportster firing on one only!!
- Shovelhead and NGK plug gap
- I trust its not a lifter!!!!!??
- Baffles for Porker drag pipes
- Intake Maniflold - Help
- Lifter clack? 26G Install, any ideas?
- changing muffler 03 Dyna low rider
- piston scuffing
- exhaust ?
- Best way to clean heads???
- Cam & Crank Gears won't Quite line up
- Drag pipes
- 883 to 1250 conversion...
- Map or Not
- Is that lovely patato sound gone forever?
- Home made Tru Duals
- Regarding oil pressure on new case rebuild
- Baffle wrap removal??
- Vance and Hines baffle removal
- Starting W/O Primary Chain
- TC 96 cam tensioners
- Smoking exhaust
- rain last night - what did i do?
- Pushrod Top Clip Problem
- Why does a twin cam run hotter than a Evo.?
- compression releases
- Looking for camshaft options
- front engine mounting..
- Speed and RPM
- Spark plugs
- Help with Getting a 7-year sitting 1996 back on the road
- 2007 FLHP 103ci
- Which Cams and Head Work For 2oo7 TC
- need new gaskets
- *NEWBIE* Would a Twin Cam 96B (07)motor fit a 99 DWG ?
- I want power from my 2005 FLSTSC
- Flat cam, spun cam bearing on TC88
- Upgrading your Ride
- 08 Fat bob cams, exhaust
- 08 fractured cylinder fins!
- Code clarafication???
- stripped spark plug hole
- cams
- stripped threads...help!
- rear pipe showing smoke
- Retune or not?
- I hate HALOMAR
- Tried NGK plugs - your favorite?
- Upgrading Stock Mufflers on an FLHTCUI
- Andrews 37H
- Top end noise
- cam realated parts maintenance
- question on primary case oil
- Plug problem
- no speed from 1942, 45
- Ultima El Bruto 113
- TC88 description by Donny Petersen
- Heat Cycling A NEW Engine
- Spark Plug X Reference Chart
- Exhaust Heat Wrapping
- Plug Reading 101 (Properly)
- Different Types Of Spark Plugs
- Cats In The 06 Mufflers (Pics)
- Exhaust Pipe Blueing
- Wood Cams Specs
- Stop The Pop!
- Twin Cam Chain Tip
- Feuling Oil Pump/Delkron Cam Plate
- Checking Deck Height
- Exhaust Gaskets
- TC 88 Motor/Bike Build
- Sporty Maintenance/ Performance Tips
- Big Bore Project (Pics)
- Custom Billet Exhaust Tip
- Pushrod Adjusting Tip
- Fixing Stripped Out Drain Plugs
- 99-04 Heads vs 05 heads
- Winterization Tips
- Components Of A TC88B Engine
- 05-06 Oil Consumption Fix?
- Cycle Shack Exhaust
- RB Racing Exhaust
- Bub Exhaust
- V&H Exhaust
- Bassani Exhaust
- Evo Oiling Systems
- Spark Plug FAQ's
- S&S IST Ignition
- Compression Releases
- Engine upgrades (HDWRENCH)
- Torx Bits And Service
- Carlini Torque Arms (EVOS)
- Exhaust Manufacturers Listings
- Evo Lifter Oil Screen Removal
- Twin Cam Oil Pressure
- Mod/Installation and Repair Index
- 95 Inch Upgrade
- TC Cam Swap
- Cams And Tech Info
- HP Figures For Sporty Engines
- Stage 1-2-3-4 Explained
- New Starter Motor For 06
- Break In For A 95 Upgrade
- Ignition Comparisons for Carbed Engines
- Making Drag Pipes Work (Thundermonsters)
- Understanding Exhaust Systems
- Exhaust Baffle Wrap
- Interesting Info On Engine Efficiency
- 883 To 1200 Conversion
- Andrews Cams For Sporties
- Timing Chest Breakdown Diagram
- Flywheel Breakdown Diagram
- Rocker Box Breakdown Diagram
- 06 FXDWG Service Manual Error
- Chain vs Gear Drive (Pics)
- Spark Plug Indexing
- Cam Chain Tensioners (Pics)
- The "Oil Fix" For Harley Davidson Motorcycles *
- Pinging or Detonation on Acceleration
- Which is Better 2-1 or 2-2 or Slip On Mufflers?
- Twin Cam with S&S/Andrews Gear Drives Install
- Proper Engine Break In For New Motors *
- Spark Plug Information and X Reference
- Comparing Various Exhaust Systems & HP figures
- Stage 3 EVO
- Stage 2 EVO
- Stage 1 EVO
- Stage 1 Twin Cam Explained (1 of 2 )
- Single Fire and Dual Fire Ignitions Explained
- Jim's 95 Inch Build
- Bassani Slip on Install
- HP Figures For Big Twin Engines
- Dyna 2000 Ignition Install & Setup
- Crane Hi-4 Ignition Install & Setup
- Sportster 883 vs. 1200
- Early Twin Cam Bearing Problem Identification
- TC -ION Sensing Detection Explained
- Ticking EVO tappets
- Adjusting Pushrods
- 05-06 Diagnosing oil Consumption
- Engine Blow By Explained
- Gear Drive Cams Install
- The Art of Noise ( Mufflers)
