- 2000 Road King "historical code" crankshaft/cams
- TC Cam Chain upgrade
- Possible ign/ fuel problem 2003 sporty 1200
- Cam gears vs hydraulic chain tensioner
- 45 engine problem
- Oil Feed line on oil filter adapter keeps on blowing off
- When to rebuild 96Cu Engine??
- keep theoretically 10.5:1 with 255 CAMs or???????
- 2008 Sportster- Major engine work @ 8,000 miles!
- Your thoughts on Slip on Exhaust.
- 86' 1100cc Evo Runs Rough One Cylinder
- Old Exhaust Baffles
- Cam Choices
- please help!
- pistons for SE 103 heads (CVO?)
- dumb(newbe) exhaust question
- Remapping
- setting static timing on my S&S 124
- Help me ID this SAMSON exhaust
- Any tips or comments on using SE Cylinder Studs
- 97 ultra jug gasket
- fatboy engine
- 06 Street Glide.. 88ci
- Tommy gun exhaust 07 Street Bob
- Screamin eagle stage II?
- what is the engine model aftermarquet I can install in a 2004 road king twin cam 88,
- Throttle Body Noise
- 4 degree advanced gear
- some help
- Out of nowhere! Evo starts and runs rough!
- Cam Needle Bearing Orientation
- Manual Compression releases sticking
- 97 Sportster rough at cruise
- Baffle Disassembly
- Smoking after top end job
- Rear Cylinder Blowing whits smoke
- Wont Start After ape install???
- Picture of insde of CAT on 2011 Tourer
- Screamin Eagle 110 Impossible to tune!!!
- Replacing 07 harley sportster 1200 rear spark plug wire?
- Lifter orientation
- [DIY] Fit the V&H Quiet Baffles and Smartpartz Hard Kore Quiet Baffles
- Exhaust Bolt Stuck
- Sleeve size?
- Base Gaskets on 03 Sporty?
- Cat. removal tips?
- Screaming Eagle pipes: fouled plugs
- Andrews TW-26 cams
- P0131...help, do i need a new ECU!
- What can I do??
- bike stalls after new exhaust install
- Loosing horsepower after new exhaust
- Carb tuning
- High Idle
- Please hepl. Can't Keep my idle up
- 88" upgrade
- Looking for clarity on whats involved/recommended, installing Rinehart true duals?
- question about pushrods hydrolic lifters
- Screamin Eagle slip-ons vs. Wild Pig Pipes slip-ons?
- stall on deceleration
- Tappet problems
- erratic start
- need help with lifter noise? sportster
- Sportster starter trouble
- 81 shovle help
- Rocker box gasket job
- reading spark plugs, with photos
- Knock knock knocking in carb
- Big Oops when replacing cams
- Running too Rich...or Lean????
- my gs500f suzuki spark plugs (engine running lean)
- Need help with a starting problem....
- FLHT stock to screaming eagle exaust
- air filter with moth holes?
- Instrument lights coming on
- Engine Gurus, how do my plugs look?
- help! I need new spark plug wires before friday! can I use cager wires?
- Reuse 103" parts
- 96 Pistons and Cylinders
- Do I need a tune?
- Help with exhaust
- Noise coming from "Cam area"
- cam
- exhaust box?
- Hi Compression Horsepower
- baffles require mod?
- Cam Gears
- pipes
- Perfect fit or Stock Push Rods for Andrews 54s
- HELP!!!! I Droped a 1/4" drive in OIL TANK
- Cam swap advice
- What Exhaust is He Runnin ???
- Spark Plugs with crush washers technique?
- Replacing Cam bearings and tensioners on 99 Ultra
- flywheel balancing
- Going back to stock mufflers
- modifing muffler on 2011 wide glide
- preloading lifter with oil prior to assembly
- IT"S ALIVE (vroom vroom....vr........) nope, it's still dead
- 84 EVO Oil Blow-by help
- New exhaust system installation
- Had bad battery, swapped out, still won't turn over
- Engine guard installation question
- oil blow by fix
- o3 roadking cam tensioner replacement??
- Engine Rebuild question about rocker arms and push rods
- Need help with Lever Action Starter Solenoid
- HD Adjustable Push Rods
- removing cross over exhaust pipe
- backfire on letoff
- Stripped oil filter adaptor 06 low rider
- Broken Rear Cam Bolt
- Adjustable push rods...
- Exhaust Help
- big twin and sportster jugs
- Evo engine mounts?
- Replacing stock exhaust
- 1973 Ironhead rebuild
- 1970 Shovlehead Alternator Conversion Kit Regulator
- Heat shield question
- exhaust back pressure
- 98 fatboy will not start..help
- Spark Plugs
- question about truing the jugs
- Could some one help a newcomer
- Samson pipes
- removed tank, no spark 06 NT
- Will 04 Up Jugs fit a 00 ?
- exhust on the 99 sporty
- Exhaust bracket @ Transmission
- Installing slip-on exhaust
- Upgrade a 2003 FLSTF or not...
- cam and piston up grade
- 16775-99b vs. 16775-99a Head Gaskets
- What's "normal" Evo compression?
- Vance & Hines install on 2011 FXDC
- Upgraded Oil Pump...
- Installing Samson True Duals
- HD plugs leads
- rear motor blowing white smoke
- hyd chain tensioners
- Road King starter
- Oil Pump Pinion Shaft Gear
- 05 ultra
- Excess heat from Samson true-duals
- Do i need to re-calibrate ECU for SE heavy breather 29264-08????
- Is it right price? shovelhead engine overhaul
- Ignition module and VOES question
- oil psi relief vavle
- No spark to rear cylinder
- Idle speed
- 95 big bore
- Removing Stock Exhaust Baffles - CHEAP POWER
- Leaking oil like a SOB
- Samson/PC Settings
- Blown motor??? front cylinder not hot...
- Backfiring
- Engine has bad vibration
- 1340 cylinders
- Koo Lines
- QQ Thunder Mtn Baffles on SE II's & Softtail
- 1987 Electra glide Sport, Cutting out while riding.
- evo to shovel head
- Evo, how big can you go?
- 02 road king FI low idle, engine shuts down
- Loud Clicking, Pinging in engine (1200XL)
- Engine shutdown durning cold weather operation
- No response to throttle
- vibrates
- Cracked block
- I need help with Vance & hines big shots staggered baffles
- scooter doesn't start
- Stuck Evo Lifter Block
- E3 Spark Plug
- Rhinehart Exhaust
- starts cold fine... takes a bit after warmed up
- power commander installed correctly?
- Spark plug question from a non-gear head...
- Sportster not starting
- 97 EFI Evo Mods
- Vance and Hines hs slip ons
- Dual Exhaust off a 97 FLSTS fit on a 90 FLSTC
- Gold dust in oil
- New pipes, do I need rejecting?
- rear cylinder not firing
- Baker+1 Oil Pan
- Who uses Thunder Monster baffles?
- Engine backfiring
- engine noise (chirping)
- Carb Swap on a EFI Twin Cam engine
- Hydraulic or solid lifters?
- Spark Plug Anti-Seize
- Push rod
- 883 Head Cleaning
- Ignition Problem/Running on One Cylinder
- Engine Light
- Mods Technique For Quiet Pipes
- oil pump shaft replacement a 97 evo 1340cc
- EFI Idle
- 08 RK Lifter noise
- tappet ajustment
- Any advice on removing packing material in factory exhaust?
- Do it myself stage 1
- Permatex 81343 Anti-Seize Lubricant 133
- Sounds Like Marbles In the motor at Times?????
- quick question about pushrod adjustment
- 89 883 misfire?
- Good or bad lifters?
- how to keep a twin cam alive
- 05 Ultra Classic
- 2003 FatBoy Softtail Slip On Exhaust Question
- exhaust cross overs 08 sporter xl
- Bike left me stranded....
- Ageing exhaust - when is it time?
- Flange Retaining Ring Pliers
- No Throttle
- Exhaust for 2010 Street Glide
- Can't get my 883 started
- 2006 1200 Sporty Blue Smoke on Decell
- What do I do now ?
- Can I Do it myself?
- Crankshaft Repairable?
- timing on a points system and carb
- Need help with my shovel.
- Noisy cams/followers
- Stupid question time!
- Inch lbs.....foot lbs.........what?
- Making V&H newer model fit on a 95???
- Very low engine idle
- lifter install
- Can anyone help me?
- Oil Leak: Help!
- whining
- Looking for some tip
- cam swap, now wont idle
- Baffles Removal
- Can i just install pipes without rejetting?
- Any info on Jim's New 100ci to 124ci cylinder kit upgrades?
- Rocker pinging
- Outer Cam Shim
- Cam tensioner was ok
- cam with stock 96?
- Plug problem or???
- first start up question
- Need spark plug adapter
- Python BSS install question(s)
- Upgrade to 103 or 110
- 95" install....special tools??
- To re- dyno or not to re- dyno
- Engine interference
