PDA
View Full Version : Engine Mechanical Topics
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 78 FXE no start
  2. How much air should come from top end breathing
  3. TC88 -> S&S 100", which cam?
  4. Missing Cam Timing Marks 99 Dyna?
  5. 2000 Twin cam 88 Backfire issue
  6. Engine cases
  7. 00' 88ci to 106" starting issue
  8. Best Evo HP for the buck
  9. engine codes
  10. Why Oil Comes Out Header Breathers
  11. ACR 103” heads
  12. FXDLS heads vs "CVO"
  13. Evo wet sumping ?
  14. S&S 97" Big Bore Kit part numbers all different
  15. Question about lifters
  16. Engine Identification
  17. Forty eight o2 sensor Bosh part number
  18. Compensator
  19. 96" Top End Noise?
  20. Water pump 2015 CVO
  21. Engine swap
  22. 2010 Heritage cranks but won’t start
  23. 124 crate install for a Road King
  24. Exhaust with SE 258 Cam
  25. 80 evo Big Bore Kit
  26. Dyno Comparison
  27. Lifter minimum travel ?
  28. Type of cams
  29. Woods 777 vs 999-6a
  30. Cam upgrade – Need for bearings?
  31. Woods 222 Performance (bolt in) cams kit
  32. 2003 Engine Case Damage help!
  33. engine mount
  34. .005 runout. Leave alone?
  35. Does valve job increase combustion chamber volume on twin cam 96" heads?
  36. Determining my buildout
  37. Symptoms of engine/trans mount going bad
  38. Oil leak
  39. When should the crank be upgraded
  40. 06 XL1200C has gas in the oil
  41. Tick, tick, tick
  42. Head work and Bigger throttle body ? need help
  43. 1981 shovelhead oil lines
  44. Help me identify the sound
  45. 110 kit availability
  46. SWAP 2015 103 to 2021 114
  47. SE adjustable pushrods and ueling liters
  48. Cycos at 28,000
  49. TC88 Winter build.
  50. 1993 fxrs knocking! help!
  51. Oil change before or after cam swap
  52. oil seepage...
  53. Build Opinions
  54. screaming eagle 110+ ?
  55. 124 s&s
  56. 99-06 cam tensioner shoes - can't get Cyco replacements?
  57. Pushrod question
  58. head and base gasket prep
  59. fuel ratios
  60. Evo Wego 3 log file
  61. Compression Ratio for Woods cam.
  62. cam recomendation
  63. Compression Ratio Info?
  64. Twin Cam Tappet Replacement Recomendations
  65. 07 Road King stalls when idling *FIXED*
  66. Heads and low lift cam
  67. Panhead cases question
  68. Engine swap
  69. Do you think this is ok?
  70. Rear cylinder isn't cut level
  71. 2007 Ultra Glide Wants to Die
  72. Sucking oil from bottom of crank case
  73. no oil pressure/ oil line routing?
  74. Cam upgrade
  75. What could cause this?
  76. Hillside ported heads
  77. Cylinder studs
  78. How much power can tranny/primary handle?
  79. This ever happen to you?
  80. Center crankcase bolt between the cylinders on real big cylinder builds?? Twin Cam
  81. Screaming eagle twin cam heads
  82. 2015 Sportster 72 help
  83. 120R Head Stress cracks
  84. Thoughts on this plugged and welded crank
  85. S&S V107t crank case breathing issues
  86. Valve/springs/etc options
  87. 103 motor build questions.
  88. Fork Oil...
  89. Does anyone know if the thing that activates the neutral safety switch needs to be centered?
  90. Cam shaft
  91. 103HO Upgrade Good Deal ?
  92. Need .030" and/or thinner cam shims for Evo
  93. 114 M8 475 cam stage 2 advice
  94. 103ci oil leak between head and rocker box
  95. Tensioner oem vs cyco
  96. Compression question
  97. stock piston weights
  98. porting twin cooled heads
  99. DK Stealth ExternalBreather Kit
  100. Cam for a stock 96" Softail
  101. S&S crank and piston balance
  102. Valve train noise.
  103. Help Needed M8 Front Cyliner not firing
  104. 2017 Breakout Swap 103 with 114
  105. Twin cam interchangeable heads?
  106. Lots of hair pulling questions
  107. 88 twin cam noise?
  108. Stupid question...again
  109. S&S travel limiters
  110. 117 piston options
  111. Upper end noises
  112. 110 CVO barrel into 103 bases
  113. 110 cvo
  114. Stamped breather assembly
  115. Vance & Hines Cams
  116. Evo breather gear and tappet block questions
  117. Cleaning throttle body
  118. S&S or Feuling lifters
  119. Evo upgrade
  120. Smoke on startup 71 ironhead
  121. Scavenge gear rotor orientation
  122. Cams, SE cam plate and oven/freezer method question
  123. Machining valve pockets pics and video
  124. 2012 fat boy Lo cranks won’t start
  125. replace cam plate?
  126. Possible Cam Swap, advice needed
  127. Anyone used these cheap roller rockers ???? KcIntl. $100 shipped
  128. Is the cam/oil pump replacement necessary?
  129. Finally taking the plunge to 124" TC
  130. Evo cam gear measurement
  131. Help with mods
  132. Removing Old Head Gasket Material
  133. Rocker geometry for woods tw68 (pics)
  134. cam bearing size difference?
  135. Question about SE 10.25 compression pistons for 95" big bore build
  136. M8 cam upgrade issues, coughing poor idle
  137. MLS gaskets
  138. 1988 EVO engine cases 24563-84 and 24563-84B
  139. Bike dies randomly on startup
  140. 114 high head temp
  141. 114 high head temp
  142. Check run out or not?
  143. Dynamometers
  144. Twin cam cylinder head fitment
  145. Release Valves?
  146. 2014 Ultra limited ...103 OUT 124 IN
  147. Grade 8 my ass...
  148. Bill
  149. Grinding noise from primary AFTER warm? Time for a comp upgrade or ???
  150. 05 fxdli starting issue.
  151. Canadian bike shops
  152. Is this really a thing?
  153. Build your own engine
  154. Boring Cylinders to 98"
  155. S&s 124lc vs se stage 4 tire s for 08 street glide
  156. HD SE Adjustable pushrod lock nut
  157. M8 128" Harley stage 4. Can I upgrade this further?
  158. Another tensioner question!
  159. Big Bore Break-in Tune Question
  160. 88TC dowel o-rings
  161. 1969 FLH sprocket shaft seal
  162. Valve to piston clearence
  163. Engine numbers
  164. Engine noise - sound familiar?
  165. Evo engine vibration
  166. Scotch-Brite Pads for cleaning gasket surfaces
  167. 05 88tc cam upgrade cost
  168. Help with my head work and bore plans
  169. Dave Mackie Engineering
  170. More EVO tps setting
  171. Twin cam 107 big bore and want more
  172. Checking deck height
  173. ARP Ultra-Torque Fastener Assembly Lubricant
  174. Leading Edge engines
  175. Pushrod Motor Life Extended with Variable Valve Timing
  176. Crate motor off?
  177. Adjusting.. adjustable pushrods
  178. Performance from Heads
  179. Pushrods loose, or something else?
  180. Screeching on startup
  181. Headwork first or pistons first?
  182. Oil Leak and possible Cause ?
  183. Pushrod adjustment for lifters
  184. S&s vs daytona cylinders
  185. TC103 Cam Removal/Install Tool
  186. Wood TW-999-6a or comp cams
  187. Power "left on the table"
  188. Cleaning the heads
  189. 107 And 114 Compatibility.
  190. Cam chain tensioners
  191. Twin cam timing
  192. Transmission Side Cover Removal
  193. Gardner Wescott head bolts
  194. S&S Lifters 330-0718
  195. 1995 Road King vibration
  196. Crank seal replacement
  197. Help identifying this cam
  198. 110” in a 2013 Ultra Classic
  199. Compression ratio
  200. S&S Push Rods
  201. Cycle rama cams
  202. Gear drive camshaft. Which one?
  203. Tri glide Engine in EG Frame?
  204. To pull Rockers or Not (Cam upgrade)
  205. Evo oil breather judgement
  206. 2010 SG Upgrade- Zippers or FM 124
  207. Compression release question.
  208. S&S Cams
  209. More of a question’09 96” twin cam would it be worth it to convert the heads to twin plug ?
  210. Oil leak
  211. M8 engine swap
  212. Need a little help identifying "Jugs of Mystery"
  213. Throttle Body Chatter
  214. Are stock Harley EVO engine cases strong enough for the S&S 113" engine kit?
  215. Lookjng for M8 engine.
  216. newb engine question: Can you use Twin Cam Flywheels in an Evo case?
  217. cylinder boring
  218. Engine build help
  219. Clicking from air cleaner
  220. Cylinder Heads...
  221. RevTech flywheel
  222. Stock vs. Fueling HP+ vs. Woods Alpha Lifters
  223. engine swap
  224. 1995 RoadKing - How to determine what Screamin Eagle mods have been done?
  225. Delkron case/engine decoding
  226. Lifter/Tapper Bore Hole scoring
  227. Oil pump seal early 19 m8
  228. 110 options for 103 S&S or FM?
  229. Narrowed down to these 2 cams:
  230. 98" big bore
  231. Big bore opinions
  232. Engine dies while riding, difficult to reststart
  233. stock '98 road king EV13 cam?
  234. Starter noise
  235. Oil From Breather Hose
  236. Motor Upgrade questions
  237. how bad did i mess up
  238. Do I need to check crank runout
  239. Chatter noise
  240. Stupid question
  241. Piston options with Screamin Eagle HTCC Heads
  242. Big Bore Kit on a 2008 96" w/90K Miles
  243. Installation of tappets and push rods
  244. What seals/ o rings should I change?
  245. Harley Stage 3 VS
  246. How many hours to rebuilds an Evo and Trans?
  247. SE 107-128 BB Kit
  248. M8 Engine Defect From Factory
  249. 05 Road King won’t start
  250. A few Q's about re-assembly after cam chain tensioner shoe change
