- Clutch Problem on nearly new bike
- Trans/primary torque questions 03 dyna low rider
- 3" Primo Open Primary Leak
- darkhorse compensator
- street on skipping gears
- 5spd 80ci on the hwy
- Sprocket Shaft Oil Seal on S&S for open primary.
- Hayden M6 Chain Tensioner
- chain tensioner
- Sledge hammer vs. Blowtorch?
- 180 rear tire
- fluid servicing 2002 heritage converted to trike
- Wider rear wheel and tire
- O-Ring Dimension
- 2008 Street Glide, 30T pulley and Cruise Control question
- New clutch spring, cable???
- To eliminate or not eliminate... compensator...
- clutch whinning
- transmission noise?
- primary drive questions
- Clutch bearings
- Primary Cases Etc.
- 2001 Road King Neutral Switch Problem. Please HELP
- Clutch basket interchangeability
- replacing transmission seals
- Clutch Quandry
- Sporster 883 Transmission Issue
- New Owner/Mistake: Derby Cover/Primary Oil
- Light pull clutch
- Inner Primary Bearing
- Harley92blue
- 24t compensator sprocket
- Secret Hydraulic Clutch Adjustment
- Crankcase oil in the primary
- New style starter on shovel
- Fool proof clutch adjustment or not?
- Trans takes a couple extra "clicks" to downshift
- primary chain broke...what do i need?
- What primary is ok for a Sportster
- Royal Purple
- 1994 Evo Compensator Sprocket
- Re-Use Dampener Spring??
- Clutch adjustment every 100 miles?
- Primary Clanking - Trans/Clutch Locking Up...
- Inner primary bearing.
- How much H.P./Torque can a Harley EVO 5 speed handle?
- whining after oil change
- Broke belt sprocket
- 2014 Primary Cover fit a 2013?
- Bagger primary issues
- Clutch Cable Measurement
- Clutch stuck in 5th gear
- Gear change for twin cam.
- Trans out of alignment?
- Transmission, primary or what?
- Help for Clutch Grinding on my Dyna Glide
- clutch basket
- Tranny, primary or what?
- Outer cam bearing: Roller VS. Ball bearing
- Major clutch issue. Please step in.
- Measureing main drive gear end play
- 81 sportster trans
- Screamin Clutch.
- Clutch slips in 6 th gear..
- Raise gearing on 1200 Sportster
- Gates vs. BDL Final Drive Belts
- Rear pulley teeth count
- Third Gear Grind
- bike acts up while trying to accelerate quickly
- Ultra Transmission Noise
- inner primary mainshaft spacer..
- change from belt to chain
- BDL Belt Drive Starter Problems
- 2006 fxdwg rotor/stator issue
- Jims 5 speed transmission question
- transmission main shaft seal question....
- 1997 FXSTC tranny fluid questions
- Countershaft Bearing Removal 06 RG
- 89 electroglyde shift lever loose
- Which transmission and why?
- hard clunk when shifting through all gears
- Primary foot peg removal
- Inner Primary Race Removal Problem...
- Over flow vent hose leak...
- 2005 FXDI & 2006 FXD (Transmission)
- input shaft
- Is the clutch a problem or just adjusting.
- Hard shift
- kicker moves when bike is pushed
- Whining Primary
- tranny oil
- Tranny tools
- Bashed Inner/Outer Primary Replacement
- 1998 dyna inner primary swap
- Converting a5 speed to a 6
- Six Speed Helical Cut Geared Transmission
- Transmission question
- 06 Sportster 883 clutch adjustment
- Any Flagstaff local?.... Stuck in 2nd
- Replaced clutch cable, no slack, can't pull
- 2nd gear problem
- 1983 sporster, oil primary to engine problem
- leak
- 1997 fat boy primary oil capacity
- Shifter Drum Issue
- Broken clutch cable
- Rear sprocket
- Baker reverse gearbox advice
- Baker DD6 Skipping in 3rd
- Clutch replacement help?
- How to remove the damn starter!!!!
- Primary Problems?
- Primary chain to long?
- Best clutch to get
- 08 FLHX starter problems
- Rivera Pro Clutch or Evolution Diamond Terminator?
- primary drain plug leak
- Primary Noise Fxsts 96
- transmission fluids and gears
- Clutch disengage
- rattling clutch lever
- 02 Sportster clutch problems????
- Accidental shift without clutch?
- Converting belt to chain
- Reverse?
- Primary found with no oil after service
- Help - 1998 Sportster 1200 crank pin nut
- Baker OD6 shifting question
- Baker bearing replacement '06' Dyna
- FXR4 leak from inner primary
- O2 cross talk???
- Primary Chain cover leak
- Taking it apart again....
- 6speed clacking and whining
- Do I need to replace my clutch plates?
- Reklus Clutch
- clutch adjustment
- Transmission Help
- Tranny/Clutch Question
- Primary Chain Adjustment
- 6 speed chatter?
- Rant about getting parts from HD
- Looking for some guidance
- How much hp/tq can a stock trans handle?
- Trans plug
- Can Anyone Help Me Diagnose This Noise?
- Help please, no power in Softail Delux 2014, CVO
- rear wheel tight spot when rotated
- BDL Springless Screw Compensator installed.
- one peice jackshaft vs. stock setup
- Primary chain adjuster
- Noise
- Clutch plates
- Clunk
- Help me understand how how different adjustments affect the clutch.
- 6 speed trans leak
- Whine and Rattle from Trans on FLHRS
- Release disk and pressure plate
- clutch noise
- Tranny issues on a 01 1200 Sporty XL
- 1987 flhtp converted to chain want to go back to belt
- Clutch noise
- Ultima 6 gearset install
- Clutch "pop" "clunk"
- engine swap
- Baker Attitude adjuster
- Syn3 Oil vs. Primary Specific Fluid
- 2007 HD ULTRA Primary chain tensioner
- trouble shooting rattle
- High pitched squeaking
- auto clutch opinions
- new to this forum
- Derby Cover
- Primary Chaincase Noise
- Number of Pulley teeth
- Clutch failing?
- lighten diaphragm spring
- Metal flakes in transmission oil
- 1986 fxst help!
- Latest SE Comp installed
- SE tensioner bolt
- 2006 Street Bob getting into the primary and tinkering around
- 1965 panhead clutch problems
- Clutch doesn't work when hot.
- Clutch hub nut/washer/spiroloc
- 1997 Evo primary chain cover
- Hayden M6
- Transmission Special Tools vs.
- 1998 RK Rear Wheel Spacers
- Vibration
- Ironhead Transmission Install
- Drive Belt Hub Rubbing on Case?
- Compensater. ..Warranty Langhorne PA.
- front sproket from 32 tooth to 30 tooth
- Transmission vent
- clutch slipping
- Derby cover gasket
- Vibration
- Clunk
- Screamin' Eagle Clutch Pack Installation Problems
- SE compensator rotor
- starter drive BIG problem
- Belt loose 09. Street glide
- Touring oil pan plug
- 1998 to 2006 clutch hub
- Recurring Inner primary leak
- BDL lockup clutch modification
- clutch catch early then loosen, fixed with good synth
- 4 Speed Clutch Assembly
- transmission gaskets?
- Easy boy Clutch Kit by Burly
- compensator issue on 14 rk? jumped forward in gear while off
- 07-09 Vs 10-13 HD Transmission
- Primary cover leak stripped bolt/stud
- trans leaking from primary side question.
- flht swing arm interchange
- Is Harley dealership lying to me about part?
- Bdl- evb-2sl
- changing the rear sprocket
- transmission dipstick stripped on the Allen head
- HELP...Changing fluids, hit a snare w/derby cover...
- How to calculate change in rpm's/highway speeds?
- Crank will not turn, kicker as well.
- clutch issues?
- Will this fit?
- running chain to loose?
- 2006 Dyna IPB issue
- Tranny is Shot (I think)
- 98 road king clutch pack
- 2001 Dyna Low Rider
- Inner primary starter seal direction?
- Clutch Cable mileage
- Broken primary chain
- belt tension causing vibration?
- 48 mid controls
- Put my mind at ease... BDL open noise.
- Has anyone replaced the Inner Shift Lever on a 2014 Bagger?
- 2003 Softail Springer high RPMs but no power behind it
- Dropping Gears
- heavy duty compensator sprocket for 04 softail
- Screamin eagle Clutch spring
- vrod clutch lever issues
- Replacing drive belt that broke
- 2014 S.G. clutch
- mystery bolts on primary cover
- Please Help 05 883c
- How to adjust the clutch to have more travel?
- HD Flywheel
- 99 night train final drive adjustment
- Tranny stuck?
