View Full Version : Milwaukee Eight (M8)
- 2019 SGS Paint Question
- FM 2/1/2 header torque insert.
- M8 Cam install Tool
- New cam, fuel moto gasket kit....what are these tiny ones to
- Fuel Moto 128 build piston orientation question
- 2020 Road Glide Ultra Vibration
- 2020 streetglide
- Clutch Limits
- 114 SE Stages and comparisons
- Noise when turning off engine after stage 1
- TSB's
- Oil ventilator
- 131" Crate Motor Installed
- Electrical problem help
- which header?
- Whine?
- Steering Head Bearing Inspect/Lube Step-by-Step
- I just dont get it...
- Primary Crankcase Gasket Multi-Use?
- Early M8 gasket leaking
- Solenoid starter button
- Stage 2 TQ Cam, Street Tuner, VH FP3
- Owning both touring and softail bikes
- Strange sound
- TPMS Tech Tip
- S&S MK 45 issue
- Best heated grip for a 2018
- Is this sumping... or sumping worse?
- Hot Right Leg on FLHXS?
- You can now put the late model Harley radios in the 2017 & later years.
- side vent buttons sticky
- Nothing serious yet but...
- Cat equiped aftermarket exhaust
- Build complete
- M8 124CI with Dark Horse Crank work (info and questions)
- Drilling and tapping 02 bungs
- Rear tank bolt flange
- This is my M8. This is my M8 on Social Distancing. Any questions?
- Header pipe exhaust gasket question
- Cam for 107 fat bob
- M8 107 hard to start when cold.
- Help with p0503 And erratic idle
- M8 107, to 107- 22X to 114"
- First Brand New Bike Price Question
- S&s gnx
- Oil change
- Stage IV 131 air cleaner
- The 8 lobe pump,128/131 kits, the new oil filter.
- Khrome werks 2-2 review
- CoolFlow Fan or Fan Assisted Oil Cooler Kit?
- M8 noise
- New larger oil filter recommended for all M8s
- Boom box 6.5 new update
- Rides don't download to Boom GTS
- Khrome werks 2-2 full system
- First Ride
- Boom GTS Apple Car Play
- Final drive belt replacement
- Cylinder head finish.
- 2020 Road King exhaust suggestions?
- 2020 TPMS not reading?
- Fork tubes
- Boom GTS and Android integration
- Electra glide standard.
- 2-1 and effects on dyno tune
- Temp vs VE tables in PV auto tune session
- What is this Vent ?
- Semi-Synthetic in a 107 M8?
- 17-18 Harley Clutch feel
- Garmin Zumo or BoomBox GTS
- Milwaukee 8 Coil Differences
- 2 new RGS colors
- Low Oil Level
- whiny fuel pump
- Oil cap
- Did HD fangs change?
- Sumping smoking gun
- HD offered Performance Packages
- Came from an 88 to the M8
- Did they resolve the Milwaukee 8 problems yet?
- New oil leak crank position sensor ?
- CVO Tri Glide Ride Review
- Restriction in Stock Mufflers
- Which manifold
- .550 or more, cam lift
- To build or not your everyday touring bike
- S&S oil pump
- Do I need a SE or equivalent throttle body for 128 build?
- Stage 4 SE Header
- transmission case casting flaw
- Rekluse Radius HD Auto Clutch
- V&H quiet baffles with cam install
- Well wrapping up the 18 RGU for the winter
- Any suggestions for finding flywheel assy - 24100045A
- 2017 Road Glide Ultra
- Added GPS to my RKS
- La Chopper Kage Fighter Bar for Road Glide
- M8 107 engine and head temperature.
- Lifter Clatter After Cam Install
- Exhaust flange stud size
- Relieving Transmission Outer Side Cover
- Dyno tuners in Northeast Ohio
- 5.5 or 6.2 injectors on 124 Build.
- simple CVO exhaust sound improvement
- Sumping in un-modfied HD117CI CVO
- Cam bearing
- New to the M8
- Can you look at this picture.. MK 45 , decibel reducers attached?
- Oil pump Dilema!
- TBars on a 2019 Street Glide!
- 128/131 delays
- Question about replacing just the oil pump
- Actual tdc doesn’t match timing marks on 114
- Twin Cooled Oil Pump #62400248
- PSA on Grips
- Possible to Lower Rear End But Maintain/Improve Ride Qualtiy?
- Softail Standard
- What is a good leak down test number for a stock engine?
- How much Stage IV to install?
- M8 Crank bearing replacement have questions.
- Screaming Eagle timer cover
- M8 Crank. What can be done to it?
- Oil in stator cavity.
- La Pera Outcast
- Cam bearing tool- UK based owners
- S&S 124 Compression ratio
- M8 Stock Engine Whine (video)
- new M8
- DeCat...
- Free SE 131” upgrade?
- Interesting info re: leaking oil jets
- Screamin’ Eagle Heavy Breather Performance Air Cleaner Installation Video
- 2020 Road Glide Limited HP
- [Discussion] Milwaukee 8 Barnfind in the year 2094
- 2017 FLHTK Brake Squeal
- Cam Change, Oil Pump Change?
- Neutral is not nuetral
- Oil pump upgrade
- Fan assisted HD cooler or filter relocate and external frame mounted cooler?
- Does fluid come out of these when I take them off?
- Lower idle on m8
- Adding Fan to Oil Cooler
- Help!!!! Looking for loudest exhaust with stage1
- 2018 street glide clarity cover upgrade
- feedback on Hacker Custom Exhausts?
- SE Stage 3 kit print out.
- K&N replacement air filter
- tuner question
- Muller clutch slave
- LED Headlight Adapter for 2018 Street Glide
- Worried
- Purchased a 2019 RGS. Looking at exhaust
- Priming Oil System After Rebuild?
- High Flow exhaust on 131” build?
- Leaving it Stock
- 12” Meathook Handlebar install ‘19 RG
- 114ci to 131ci Stage4 + D&D 2 into 1 full exhaust
- 2019 Ultra License Plate
- Problems Installing Barnett 303-30-10019 clutch kit for M8
- Matt Laidlaw Review of 2020 CVO RG
- What is the most popular slip on for the baggers?
- M8 Primary
- Thunder torque inserts on Cobra Neighbord Haters
- Navigation Maps Update...PITA
- 2019 fat bob 475 cam backroads and highway pulls
- Dual Cooled M8
- Got my sumping 114 torn down have questions.
- exhaust only
- Stage IV 131" which cam
- To Dyno or Not... Big Bore kit with TTS
- Do I need to prime an M8 S&S oil pump
- 20 RGL oil cooler yes/no ?
- CVO RG is on HD site now
- Another Sumping question but with a twist
- 124 build tear down
- Tab performance baffle size dyno results
- RGS Owners FYI
- Lock washers for pipe flanges to head
- Red Lower Rocker Box Covers
- Changing transmission fluid on M8 for first time
- M8 114 stage 2
- S&S Stage 2 update
- Best M8 114 Stage 2 Set up for Max HP AND Torque
- SE Stage IV 131 kit engine & dyno testing 2020 FLTRXS
- Parts compatibility: 2019 114 stock parts to put on 2018 107 stock
- Stage 1 exhaust and Stage 2 Audio
- How do I know
- Looking for feedback
- Head pipes?
- Will I feel a difference?
- Cruise Control
- New 2020 Road Glide Special!
- SS cams
- Mayhem Paint Set
- LED blinkers
- New Jackpot 2-1 availability??
- My Air Cleaner Mods
- Looking for input from those that went to a 124 or above
- 131” Crate Motor M8 from Harley
- Oil slinger - what year?
- Questioning Quality of Harley M8 Jugs
- 14" factory 47 RGS install
- Milwaukee 8 rattlers when cold
- Inner fairing switches
- Voltage drop when starting
- D&D XCat 2:2
- Dealer “special” on installing torque cam
- Free 131 kit with a new bike purchase
- Rocker Arms Shot
- Neck Bearings on a m8 touring
- My first cam install: thoughts, tips, etc...
- Stage 3
- RDRS Rain Traction Control setting
- Battery Tender
- PV Target tune, who's using? thoughts? Worth it?
- Question about running wires
- Slip on comparability
- 2020 RGL Stage II Air Cleaner Question
- Re-use of 2020 Road King Special 114 on a 2020 Sport Glide
- Better deeper sound on 17 sg
- Changing out Engine guard on 18 twin cool Road glide ultra
- M8_ thunderheader, 475 cam
- Packtalk bold and boom 4.3
- New Mufflers & Head pipe for 114
- Just made the jump to an M8
- New Boom GTS Update
- 128/131 Bolt on Kits
- 18mm wbo2 in 12mm hole
- SE Smart Tune Pro ?
- Header power boost?
- Shark ate the king
- Software to make GTS compatible is here
- Map tts mastertune Ultra Lim 114?
- Transfer issues on a 19?????
- 114, WM8-22X cam, Power Vision & Target Tune
- FM 124 ring gaps
- How to adjust idle using SE tuner
- S&S 475C Cam 114 Fat bob hard pulls!
- error U0125h? pn 40800155A? in RGS 2020?
- TPMS set too high
- are the stock handle bars that bad on a 2020 RGS
- Prices on M8's dropping - moco changing it up.
- Sumping, Transfer, Breather..........
- KST Outlaws vs Straight Jackets vs Road 6 Standard Apes
- SharkRoad M8 Touring Mufflers
- HD (OEM) extended Clutch and Brake lines #s....
- Can anyone identify these plugs
- Reinhart 4.5″ DBX45
- I want to decat but worried about sound
- Is auto tune needed on a power vision
