View Full Version : Milwaukee Eight (M8)
- When to install stage 1
- My first ever MOD garage opener
- floorboard ext.
- Brake line help
- 2017 Ultra Limited passenger sissy bar!
- Reviewer's strange observations about the M8
- Non OEM Harley heated grip install
- Merry Christmas 2016! What did you get?
- Changes from '16 to '17 at the footpeg mounts?
- I know this isn't very helpful....
- What tools do you carry on your bike?
- Judgment call.... 1000 mile service
- TTS100-M8 cam test
- Harley 114 VS. SuburbanHD 120
- Service Manual
- Thunderheader
- Has anyone had thier clutch and brake master cylinders chrome platted
- Oil Filter Question
- First issue
- chrome switch house cover questions
- Finished up the cosmetic stuff
- Cams
- Does Stage II change the exhaust sound?
- Battery tender harness and fuse location?
- Solo shifter, will it fit
- Charging System Output?
- Another HD Delete on the 2017's
- Security system issue... Haven't set pin yet.
- Maintenance qustion
- What Happened !!
- Hooking up Corbin Heated seat?
- Is it too early to say the M8 is a good engine?
- Check engine light on...
- Steering head lubrication
- What type of oil came from the factory ??
- Octane rating opinions?
- Free flowing exhaust question
- M8 clutch improvements and mods.
- Can HD tell if ecm was ever altered?
- S&S MK45 mufflers
- Vance & Hines Hi-Output Slip-Ons??
- Anyone hook up a Corbin heated seat to the M8?
- Love the Bike/ Hate the clutch....
- Any idea what the stock air filter flow rate is?
- How many Miles on Your M8
- Gas Tank Removal.... Need Help...
- Bassani 2-1 Road Rage Exhaust....
- Gas treatment over the winter
- Jiffy Stand is way stiff
- She's home!
- M8 Problems, White Smoke and ???
- Anyone pulling a trailer with a M8 yet ??
- Just a little Tease
- Non oem parts
- M8 crate motor availability
- CVO mufflers for SGS advice
- FLHTKL Seat on FLHTK
- Vance & Hine Power Duels
- Who's using a after market tunner
- 2017 Touring Service Checklist
- Question on your Riding RPM on the M8
- Solo Seat pics
- Money down
- Would installing a Stage 1 upgrade void the warranty?
- Milwaukee Eight M8 bolt in cam install step by step w/ dyno
- Looking for pic of road glides with ape's.
- Front fender light
- Upgrading audio. Your thoughts?
- Stage 3
- Video of my Fuel Moto Jackpot Hi Roller "legal" Exhaust
- New Road King finally arrived
- Make room for me Fellers!
- Oem 2017 saddle
- 107-114 Stage 3 - acceleration videos, Biketronics, and 500 mile review
- Incoming!!! 2017 Ultra LTD:
- Milwaukee 8 speed limited?
- Help with Baffles
- My Take on the new M8
- New FLHXS!
- 2017 Heated Hammock seat....Help!
- 2017 M8 107 to 114 project :)
- Exhaust Issue
- Anyone add a new headpipe yet?
- 114 conversion and warenty
- Need help with ordering CB.... ASAP
- Future M8 models...
- Battery tender on OEM pig tail
- Rinehart note change?
- Hidden antenna kit?
- Oil return hose leak
- m8 oil change - yeah Im back
- Oil Filters
- Are folks still using Ride-On?
- Finally...pics
- New Bike arrived today
- Aftermarket Exhuast Legal or Not
- Slip ons without stage 1
- Stage 3 Completed
- It's finally here...
- Stage 3 117 kit is underway!!
- 1,000 mile check up question
- Rear suspension riding two up.
- Squeaky/Whistling motor at idle
- New 2017 CVO Streetglide. Couple of questions.
- SoftBrake shifter and brake pedal installed *PICS*
- need help with back off module
- Which stage 1 filter
- Finally, she's here!
- doing M8 107 first oil change
- shift linkage failures
- Added Fuel Moto Hi Roller Mufflers to my M8
- M8 ECM flash update
- License Plate Frames?
- street tuner calibration advice needed
- Idle Stabilization Upgrade
- Huge Cans!
- Shopping new bike- Pros/Cons?
- Engine accent parts
- Tool Roll?
- Old vs new
- Two must have Road King accessories
- Join the M8 Club today! PUMPED!
- Question about Street Tuner for the M8
- Anybody Go Stage 2?
- It's NOT Red!
- Bloom is off the rose
- Anyone doing the breather bypass on your M8?
- Harley Road Glide Chizeled Handlebars?
- To stage one or not?
- Road Glide chopped engine guard with highway pegs?
- Piggyback tuners vs flashing ECU?
- Rinehart Slipons with FP-3
- Powder Coated Stock Wheels
- Article on screaming eagle stage kits and corresponding 1/4 mile time
- M8 headpipe
- Batwing or Sharknose
- Can the tension to pull in the clutch lever be adjusted.
- HD Information on new Assist & Slip Clutch
- Added HD Heavy Breather today...
- oil pressure gauge
- Any difference in floorboards from 16 to 17?
- Pic Request: M8 Road Glides with wrapped fender and aftermarket wheels
- 1000 mile service - Primary Chain case lubricant
- Road King Spot Lights
- 107 to 114
- Value of stock 114 cylinders, pistons and cam?
- New M8 Owner
- Weak Rineharts
- Tapping noise from engine not good
- clutch master cylinder
- I really want this bike
- Standard over Special? Is the GPS really worth $1000?
- Anyone with service manual? Need a look up.
- Got the bug but...
- D&D New Exhaust
- Tell me about your Milwaukee 8
- Review of 2017 CVO Limited after 1077 mile ride home.
- Rineharts
- M8 design
- New Dyna is Way Past Due
- Any changes since release of M8's?
- Crazy oil pressure "issue" with my new 2017 M8!
- Suspension Preload adjustment???
- Part changes on M8?
- Rubber Mount Changes?
- Question about M8 oil problems
- Dealers with custom m8's
- M8 Testing
- Certified Tech for M8
- Stage 1, stock ECU, tuners and warranty. Anyone have a definitive answer?
- M8 oil leaks at top of tranny housing
- 107 Milwaukee-Eight Vibrations @ higher speeds
- The research continues
- M8 power vs Gearing is a good thing
- New Milwaukee 8 engine Victory copy ?
- Is the stage III on a 107 the same as a 114?
- POET ~ M8 and Final Debate
- It was 1/2 quart more, now it's 2/10th's?
- 2017 Road Glide using oil
- New Bike Problems
- Fan Operation on Water Cooled
- HD Power and Torque Cams Stage 2
- Oil Temps
- It happened to me today
- Speed limit on tourer
- Breaking in a new 2017 Road Glide Special
- 2017 bike out of service 114" stage 3
- 2 In a week
- Upgrade??
- Water cooled plus or minus?
- Parts Online... no 2017's?
- Air cleaner/ I don't get it
- SE Mufflers+SE Air Cleaner+ FP3 is a winner
- Opinions on stage 1??
- Dyno numbers for CVO 114
- M8 5K report
- M8 Failure count?
- Another 2017 M8 Oil Pump Failure
- Anyone NOT digging the rear suspension
- Having some issues downshifting into 1st
- M8 advanced oil cooler system
- M8 crate engine
- I got a new canvas today
- Impressed...
- M8 Stage 1 Breather Question
- New Engine Installed- It's Alive
- M8 Engine Temp
- An Observation
- FP3's here but.....
- Anyone having a hard time finding Neutral?
- 114 Badging
- Oil leak on my 2017 Street Glide Special
- What are you seeing for mileage?
- M8 cam?
- Plug change?
- Test rode a Milwaukee 8 Road King yesterday
- Smoking M8s
- What price should I sell the take off jugs for?
- FP3 Fuel Pak for M8
- Help! How to install auxiliary electrical harness
- clutch
- M8 vs TC103
- Oil verse water
- Missing Hardware?
- Air Cleaners
- Sloooooow SGS M8 HD Demo Trailer Ride
- Milwaukee 8 Build... Experienced input?!?
- '17 Road King build...
- Street Vibrations Demo Ride
- 2017 Street Glide Special 400 Mile Review
- 2017 Engine Oil Light -Update-9/24/16
- Show us your M8
- Seat
- Well, deal was too good to resist. New Road King
- TTS M8 calibrations
- Meet my new 2017 SGS in Mystic Purple Hard Candy Flake
- Tool kit
- Milwaukee 8 in other HD bikes
- 18 model
- New Milwaukee 8 Limited
- M8 Factory Oil
- Stage 1 air cleaner and mufflers
- Who's got a new M8 and had no problems
- 2017 Limited running hot?
- 17 Road Glide M8 oil leak at top motor mount
- 114 big bore kit ordered
- After Market Exhaust for the Milwaukee 8
- First year gremlins
- M8 clutch/shifting
