View Full Version : Milwaukee Eight (M8)
- Twenty six degrees
- Starter Issues
- Potato potato
- Tab zombies too loud?
- 117CVO and S&S 465G cam
- I'm I wong here on a engine noise?
- 2018 Passenger Floorboards
- Oil on bottom of air filter backing plate
- 2018 M8 Street bob - oil light
- EITMS engaging
- 2018 Breakout Frame rake
- PO523 code
- Do you need adjustable pushrod with Torque cam?
- FXBB LED light bar
- New rotor and pad recommendations please
- Neutral to first gear. Click or Clunk.
- new clutch assembly part installed today
- New Road Glide Special @ home
- Left side chrome
- Headers opinion
- M8 heat video after highway ride home - 103 on dash
- Top Speed M8
- Best Rear Shocks for 2017 Road Glide Ultra
- Ultra Seat Fitment Question
- Getting neutral is extreemly difficult or impossible
- M8 Trans oil transfer......
- rough idle on m8
- M8 primary chain adjuster.
- Awesome news
- Advice on Buying a New Road King Special
- It finally happened (scraped a floor board)
- Essential tool from Harley to repair the Milwaukee 8
- Low profile front tire replacement
- Make an M8 LOUD!!!
- Tuning ?
- Road King Fishtails
- M8 Intake Gasket Install
- V&H -vs- Fuelmoto head pipes.
- 2000 miles with Feuling race pump and plate
- 12 inch Ape's on 18 Street Glide CVO, Gunship
- What the sump is going on?
- Narrow or wide primary?
- Road Glide stock windshield height
- Sumping wrong
- Alloy Boltz
- clutch questions 2017
- Oberon Adjustable Clutch Lever Setting 1 Works
- The last time we had an economy like this....
- M8 Tuning options (technical)
- To the Father's
- m8 Sumping
- m8 Sumping
- Redline Water Wetter
- I guess I have to go shopping
- Holy S*** my new 2018 Lowrider is making a loud noise
- Installed S&S 465 cam
- Stupid question #37
- Oil Light Question
- Head gasket leak
- main fuse
- BA-E to 169-S,,, Way over did it!
- New M8 RG owner saying hello!
- Blew the Baffles out of Eliminator 400's
- security system for a 2017 ulra limited
- S&S Oil Pump and Cam Plate Two Weeks Out
- 17 RGS steers Left on level, straight road.
- Does ANYONE Like Their M8??
- What do you think? My new road king special
- Interesting observation (sumping)
- K&N P/N for 2017+ Ventilator?...
- Opinions on Tour Paks
- 2018 114 Air Filter Options
- Heat issues on 18 street glide special
- is there an M8 Stage 1 Air Cleaner that will allow me to use old Evo Round cover?
- V&H on ‘18 FatBoy
- Harley won’t remap the ECM for pipes and airflow?
- RGS with lower fairings
- V&H on ‘18 FatBoy
- I own one so I can say Harley's are JUNK for what we spend
- whats wrong with this graph
- Any truth to this oil migration rumor?
- Question about the 107 and upgrade to 114 and boring
- M8 rocker arm studs size?
- Bay area ape hanger install
- Has there been any reports of oil sumping with 107 M8's
- Milwaukee-Eight 117 Engine failures. Expect low resale values for the 2018 CVO's
- 2017 ultra only starts in nueteral
- Sumping Help
- Born on Date
- M8 Oil sumping issues....
- 2018 Softail Slim
- Lifter noise on cold start up
- Have an M8 on the way. Done some reading. Now what?
- Motorcycle Jacks
- Had a grabby clutch that squeaked on my M8
- Things to look out for
- 2018 FLHTK with a Stage 3 installed, New Gas Mileage?
- Who has BMC Widow Maker or The Wall Saddle?
- M8 Vibration
- Vibration ??
- Dealing with a death of a rider
- Fan assisted oil cooler question
- Kuryakyn floor board relocators & CD BAGZ installed
- i got bored and plasti dipped my forks and mirrors
- HD adjustable driver backrest - an elegant fix!
- Trans Dipstick??
- Gettin Ready
- street cannons on stock tune
- is there an M8 larger capacity oil pan?
- Extended Warranties
- 117" M8 Power
- Road and track pipe
- M8 heat: cheap & perfect: OEM slips, A/C, no tune & aftermarket head pipe.
- Question about S&S MK 45's
- xied's
- Magnaflow 4.5 Hitman slip ons
- Looking at 115 Anniversary Limited...
- Trans oil loss leading to blown up trans?
- Feuling 465 Cam M8 Question
- Trans Oil Deflector Kit Poll
- 124" kits for 107" M8
- Today
- Screaming Eagle Pro Street Tuner update
- Pulsing fron brakes
- New M8 owner
- Milwaukee 8 vs Twin CamB balancer designs
- Sincere question to those who have had M8 engines replaced by HD because of sumping.....
- What’s your opinion? Would you consider going back to TC because of M8 concerns?
- To the guys that have modded the stock head pipe
- Engine Light
- Attention Road Glide owners!!!
- Any Sumping problems on the 2018 Sport Glide??
- Broken cam bearing!
- Is it worth it?
- H-D Dealer Reaction to Sumping Issue
- Harley flagging warranty
- Help...broke down in Townsend TN
- 2017 roadking tach
- Poll: What's Your Tire Preference
- new radio replacement for 6.5
- Stage 1 worth the $
- Time for new tires on my 17 Road King SP
- Hydraulic Clutch Issue
- Change risers on ‘17 RK?
- Windshield Tint?
- Cams and Exhaust back pressure
- Stage 4 upgrade or not?
- Fuel Moto 2018 Softail kits
- lotsa' repair and service today
- Limited Stalled
- New 18 roadking
- Which way would you go?
- Clutch Fluid Replacement
- At the risk of starting another sumping thread, I have a question.....
- M8 Help, low compression psi
- Disable EITMS ’18 Low Rider
- Leaks on M8
- 2018 streetglide making a clattering sound
- Cleaning SE Stage 1 Filter
- Big City Thunder Baffles In Rinehart Slimline Duals?
- 2017 m8 intake manifold
- Passenger heat
- Check engine on display but no oil light
- Sucky clutch on M8s.
- Is it worth getting the HD Extended Service/Warranty Plan for the M8s?
- Poll for Milwaukee 8 issues
- Bearing failure ?
- M8 Sumping - Warning signs to listen for?
- Feuling pump/plate
- looking for M8 Cam install video
- Quick PV question
- Stock M8 Sump issues?
- Who needs a dealer install, just buy American Bagger - Feuling Oil Pump Etc.
- what OIL temp are you getting
- Heritage 114 decel pop
- 2017 Freewheeler Security lights not flashing
- Infotainment Boom Box 6.5GT - 3D Mode Not Working
- Sorry for the double post...
- Do I need to upgrade the 114 AC?
- Time for the 4th engine in my 2017 CVO Limited... here we go again!
- When tour pak is off, how to protect fender?
- CVO 3 Piece Pushrod and Transmission Transfer
- Slip-ons and warranty - the MoCo speaks
- 2018 RG CVO grips
- Installed 10” Factory 47 bars on my 2018 Road Glide Special
- 17 CVO SG...Red Shift 468 cam
- slip on mufflers
- S&S M8 Cam Plate and Oil Pump
- Softail slim air cleaner options
- Where Are My Road Glide people at !?
- Fueling Race oil pump and cam plate - best price
- How to steal a Harley
- M8 roarr!
- 18 Limited wobble!
- Faux rear TourPak speakers
- Finding Neutral
- Oil
- Sport Glide Owners Manual
- Royal T exhaust
- 17 CVO SG...Mastertune TTS or ThunderMax Autotune
- 17 CVO SG...D&D Billet Cat or Fullsac
- best and most efficent oil cooler not the cheapest
- Head pipe
- Thinking of getting
- Oil Pump and Cam Plate install question
- When do you expect 2019 Harleys to be available?
- Wet sumping article
- M8 Dyno w/ Tab Performance Exhaust (Zombie Baffles)
- 2018 Road King with Unstable Idle Speed
- harley extended prices
- Air cleaner Blowback
- Oil Light
- Will Tuner Alone Cool Off my M8?
- Stage 1 SE tuner raises RPMs? Flat spot up high?
- '18 SGS 1,000 mile review
- should the 2018 115th Anniversary paint bikes have been BLACKED OUT like the Specials??
- Finned inner primary cover for M8?
- Change Spark Plugs every 5,000 miles????
- D&D sound on M8 vs TC
- Adding contrast to 2018 Special Bikes
- Does your M8 run hot?
- Fueling oil pump and cam plate came in.
- Bike starts and then stalls??
- Self made left saddlebag holder
- Cat Removal Void HD Warranty?
- J&S Jack: Fluid Change
- Road and Track exhaust
- New Road King Special
- oil type
- for steve cole and other gurus
- milwaukee 8
- No electrical..
- Woods 22x
- 2017 MOTOPRO45 RINEHART-4-5-SLIP-ON-MUFFLERS Review
- Anyone know these bars?
- Milwaukee 8 Cam Insatll?
- Please share some knowledge about sumping
- should the rings have been changed?
- Twisted Bolt Off Changing Lifters
- why OEM M8 clutch side pipe does not flow - internal pics
- Dyno Tune for TTS 200 cam.....Thanks to Steve Cole and $tonecold
- Latest Version POLL: Which M8 Motor Sumped On You?
- Hand grips
- Can someone explain the oil pump workings?
- Thinking of an upgrade from 2014 to 2018
- Shout out
- Blown M8s - MTTR and what did HD do for you?
- Who's running Fullsac MX headpipe and Fullsac OEM Recore baffles on their M8?
- Running RPM
