- Definitely looking at a turbo soon
- Anti-lag settings
- Aerocharger questions
- What clutch mods or clutch are you using on your turbo H-D?
- NOS mini 2 stage progressive controller
- Draw through plenum?
- *Free Turbo Installation*
- Draw through fuel pump?
- Boosting a Harley...
- Turbo Kits in Stock Ready to Ship.
- Sturgis 2023 Recap Video
- Superchargers
- My turbo chopper build
- Intercooler mounting
- Fuel pressure?
- Procharger on 103"
- RK Ripping 10.6 in the 1320
- Aerocharger hi-low switch
- Mikuni HSR42 mods for turbo?
- Trask turbo?
- Built my own turbo system for 2013 Fat Bob.
- Contact info for Magnacharger?
- Fun with nitrous
- Twin cam with a turbo and blow through setup
- Procharger belt part #
- Turbo sportster
- How to fit a tts supercharger to a v rod
- How to install a inferno supercharger
- Unknown blower
- New build 107ci turbo bagger !
- Boost proofing a 103
- two turbo baggers battling it out!
- 2010 ultra 96 I turbo dyno pull 121hp and 133tq
- Power Vision tune for Aerocharger
- Turbo for M8 ?
- Thundermax base map for turbo 2010 ultra
- Aerocharger / Mikuni HSR42 mods
- ProCharger or Turbo Installers in PA or MD?
- Procharged harley questions
- Thinking of Trask Bolt On System for 2016 StreetGlide
- Post your Harley drag race photos and videos!
- Stage 5+
- Nitrous on a Jims 131
- I'm A big turbo guy any do a 91 flhtp
- Hunting for power.. need to drop compression
- New turbo install need help troubleshooting
- Milwaukee Eight Supercharger
- 103 stage 5?
- Boosted guys on the forum i have questions
- anyone running a Trask turbo on a stock engine????
- Turbo heat
- Trask turbo - exhaust questions
- 2 bar map sensor and procharger base map.
- Trask Turbo exhaust options?
- What shop or person is a Nitrous guru?!
- Anymore power? For iron
- Turbo or supercharger
- Cost to add a turbo to a 2015 sportster
- turbo sizing help 131"evo
- ProCharger Users
- Turbo on bike that tours?
- Practical turbo?
- The little 'ole 95" Softail that could... ;)
- Turbo 117
- Aerocharger
- Rotrex twin cam blower
- 2008 Harley Davidson Sportster xl1200N
- Need Help With Procharger map for TM
- Mikuni hsr42 turbo plenum source?
- Procharger - Bolts Coming Loose..WTF!?
- Cam for Procharger
- Thinking about buying an Aerocharger
- 2014 softail standard custom turbo gt28 setup
- Softail turbo boost gauge location
- Just at 10" heavens door , CO2 spryer may help?
- Big new Intercooler and to the Dyno
- Velocity intake
- a blown Dyna at the local bar
- Low Compression Pistons?
- My Aerocharger Build
- 124" + Aerocharger + Dragos = TQ!!
- Sturgis 2016
- Chain
- Procharged 120R 11 Streetglide
- Another Aerocharge Install
- trask problem
- trask help
- Aerocharger Turbo Set Up
- Nitrous on 2015 48
- Procharger vrs Trask
- Water Methanol injection snow performance
- 1996 Softail Procharger Carburated
- Here I come Turbo
- Bike's with turbo installed ?????
- Supercharged finally.
- Turbo my Sporty...EFI/ECU Advice Needed
- Welded crancshaft ??
- Which clutch to use on high torq engine ?
- 106" Trask Turbo
- NOS and Ignition Retard
- 10.5:1 Compression to Much For Turbo Setup?
- Supercharged
- Intercooled Aerocharger & stretched bags?
- Aerocharger & fuel in motor oil
- Baffles or no baffles with a blower
- Blow off valve and a boost gauge
- Daytona Twin Tec TCFI III
- '15 Road Glide w. Aerocharger Turbo
- Thundermax Nitrous Setting
- Turbo Cams choice.
- Nos
- 263 HP / 248 Torque...124 Inch Twin Cam
- wild thing 57
- Boost Leak
- Help with turbo sizing
- Head Work for a Turbo Engine
- 124" blower motor and Trask turbo 199 hp
- joined the supercharged family
- Turbo for my iron
- pretty cool vid
- Installing the Aeorcharger
- Playing with a Blowoff valve
- Fuel regulator
- Procharger shop NJ
- Procharger case questions
- 120R w/Pro Charger Potential Nightmare?
- Sean Ray Turbo systems
- Input wanted on home made rearmount turbo
- New SE compensator and procharger pulley
- Blow Off Valve Question
- Frank at Drago's
- Supercharger Kit by HD Blower - Thoughts?
- EMC Superchargers?
- Thinking of using a procharger
- Interested in nitrous again
- Aerocharger Dyno Sheets
- Boot lace in procharger
- HD Aerocharger Turbo System
- 2010 wideglide S&S124" HSU Procharger 8psi,propipe
- Tmax Tuner or Smartlink for boost..HELP!!
- Aerocharger
- 2 in a row for kirby/vee twin racing!!
- good replacement head gaskets?
- dry NOS system
- turbo sportster
- Ordered up a Trask for the Street Bob
- Ultimate Street Legal Build - Motorheads Please Chime In
- want to ger turbo setup for my 120R engine, need advise!!??
- Hollow rear axel
- Frame to Engine Stabilizer
- E85 anyone???
- Thundermax nitrous wiring specs on TBW 08 SG
- Wishing You a Supercharged Holiday Season
- Aerocharger Question - Too Much Boost!
- Methanol Injection
- 2011 Dyna Fat bob with Procharger 107 Threshold engine stage 1
- ProCharger Rebate - Save Up To $500!
- Supercharger with turbo Wastegate Install
- SE 251 and SE 257 cams under boost
- Looking for some advice regarding nitrous
- Dyno Run for the FXR finally done!
- ProCharger on 127" Ultima?
- Fun at hamster drags sturgis 2012
- RB Racing v Trask kit
- Maybe an electric supercharger...
- Procharger on a Night Train softail (EFI),http://www
- Advice on AF Targets for my setup
- CVO TQ monster with Trask Turbo
- Trask turbo anyone??
- SE Compensator and Procharger
- Im curious about REAL H.P. Numbers from a AeroCharger on a 103
- 120 turbor Bagger.... Getting reay to hit track
- 120r Procharger?
- Turbo Bagger
- Pro Charger Pros/Cons?
- Aerocharger Fuel Pump Question
- tune for turbo 106
- Procharger cam??
- Procharger B-1 or B-2
- Considering forced induction
- Aerocharger Manual?
- 204 HP 167 TQ Drago's 107 procharger
- Supercharged Sportster
- New Turbo builder in town
- 200 rwhp bike- who actually runs?
- M.A.P sensors?
- Thundermax dry nitrous
- Aerocharger Build - Cam selection
- Turbocharging a Harley CV carburetor
- Boost Gauge location
- Planning a move to Procharger
- Big CUI with blower
- Thundemax and MAP-sensor wiring
- 222 HP and 194 tq Dragos built motor and blower
- 08 Rocker build to make 200 hp 160 tq.
- procharger and motor reliability ?
- procharger or motor work
- Woody's super charger problem
- install stock 120r and procharger
- nitrous tune
- Drago built blower bike racing a drag bike that does 10.2 at tarck
- AHDRA finals,new personal best & record for vee twin racing!!!!
- Dragos Bike Works 213 HP and 183 Tq
- BIG weekend for kirby/veetwin racing!!
- 202 HP 175 TQ. Dragos Bike Works
- procharged SE120R
- procharger belt failure
- Sneak Peek at a New Prototype High high hp Exhaust.
- Tuner for boost
- Procharger up for grabs!!
- Drag Dyno At Sturgis 2011
- looking too buy a bike too build.questions
- 145 inch dbw + procharger == power
- We are at it again
- Which Oild with a Turbo Harley
- 120r Turbo
- 120R and 8 lbs of boost= 190 HP!
- 120R-procharged
- were do i start
- New cams for the turbo?
- 2011 Road Glide --Procharged
- magna chargers
- 110 cvo with Procharger 574 cam and Dragula exhaust 161 hp
- Dragos 107 with procharger goal 230 hp
- Boost gauge
- Thundermax map sensor problems on supercharged/turbo bikes ?
- turbo cams?
- I finally pulled the trigger and decided between blower and turbo..
- Nitrous Newbie...
- Joining this group
- Proc haegr on ultra clasic with lower fairing.
- We are now selling trask turbos
- Procharger on 10.5 CR motor ?
- Dragos bike works is move to new building
- Beware turbo issues
- AEROCHARGER....up date....
- Turbo, daily rider & dependable
- Dragos 200hp 175 tq pro charger dyno
- Look into the future on whats to come from Dragos Bike Works
- Here is one of my sercrets on making big power
- thundermax nitrous tune up
- Nitrous with power commander?
- veetwin racing/kirby wins AMRA championship
- Turbo 124"
- What cams should I use on 95 big bore kit with blower
- 192.88 hp 165.88 tq 09 ultra
- prochargers in the wild for torque?
- Custom Turbo Build 2007 FXST
- Where to run Oil Feed/Return on Turbo Setup
- Is the Vrod as fast as some say?
