- Hydraulic chain tensioner
- Primary empty upon return
- B motor counter balancer chatter
- Hard to get out of first
- '22 Touring Clutch Lever Installation
- Slow Cranking
- 04 road king efi
- Nothing Worse Than
- Sportster won't stay in gear while riding
- sealant on transmission splines?
- Clutch issue question
- 07 Primary Chain...
- Clutch springs
- Inner Primary Stripped Cover Hole
- Clutch slipping
- Found in the primy
- Clutch hydraulic line o-ring
- Clutch Flush Transmission Cover
- Primary Chain Tensioner Broke
- Trickshift
- 2020 RG Derby Cover Bolts
- Clutch fluid
- Any idea what causes this?
- Inconsistent clanking sound
- IPB aftermarket
- 73 Ironhead Kick start removal.
- Clutch Slips During Hard/Fast Shifts - 08 Softail
- Foot clutch vs Hand clutch
- Neutral Light Comes on When In Gear - '22 M8 RK
- Final Drive Belt.
- Strange Noise clutch
- 2021 RGS Clutch Cable Broken
- Bike rolls while in gear
- What year trans are interchangeable
- Ultima Kickstarter for Evo 5 speed problems
- Rebuild Trans
- Dry clutch inner primary removal
- Need new clutch pack/spring
- Sprocket wear
- Noticing a Click/Clunk when engaging/disengaging Clutch
- Clutch basket..
- Aim lockup rubbing
- Clutch issues after primary removal
- Hard shifting
- Will an EVO Softail Trans work in an FXR
- XLH 1990 Driven sprocket mounting bolts
- Transmission door
- '02 Road King compensator question
- Feedback on Twin Power primary tensioner
- Mobil 1 in transmission
- Clutch cable too tight
- Looking For a Clutch Recommendation...
- transmission dipstick
- Please help, 07 Dyna CVO Clutch Creep!
- Hydraulic Primary Chain Tensioner
- Marbles in the primary
- Who makes a black extended 1” shift lever, besides Softbrake?
- Grinding noise 2003 touring
- Harley beginner question
- Muller Hdyro Clutch Questions
- Primary Bolt Sizes
- Clang…..
- Auto start with clutch lever
- Installed used Ultima 6speed over drive in my 06 RG. Clutch won't release
- 1985 FXWG inner primary to FXSB inner swap
- 2018 XG500 Street Runs/doesn't Drive
- Rear Sprocket 1978 FLH
- 09 6 speed clangs or bangs when shifting
- 1979 FXE eating clutch pushrods
- Grip getting old
- Any Rivera Primo dealers?
- Help with broken pressure plate
- Ultima primary start problem Dyna 2010
- OEM 6 speed gearset difference?
- FXLRST Cable Kit Extension / Clutch Not Disengaging
- Clutch Cable Has No Tension
- Twin cam primary chain adjustment
- Twin Cam six speed updated main drive gear and bearing.
- Needing a new primary cover
- Height difference.
- Help Identifying This 5-Speed Softail Transmission
- Where's my Primary Bearing Inner Race??
- Thoughts on the teeth on my 03 RK Comp.......
- Best M8 clutch option for 150 squared?
- 2011 Fat Bob Inner Primary Part #
- M8 transmission bolt (8 pattern) torque
- 03 Electraglide pinging noise
- needing inner outer primary
- Any tips on clutch cable re-route for 12” KST Pioneers on ’22 Road Glide Special?
- Race Brace / Torque Arm
- Damn it man! Rock vs Belt....... Again!
- Clutch won’t disengage
- 2005 ElectraGlide - took too much primary fluid
- EZ Pull clutch
- Intermittent clunking in all gears
- Rekluse clutch hard 1-2 shift
- 1982 FXWG - Mainshaft seal
- Why can't I find friction plates
- Repairing a lousy Harley Compensator
- Reducing Clutch Pull
- Overhaul on the Road Glide
- How can a sprocket nut loosen?
- '09' Compensator Spring Pack
- Derby cover leak.Help needed please
- 1984 FXST dry vs wet clutch question
- Rdrs
- 2000 FXD TRANSMISSION Door leak from bolt holes
- Problems shifting
- clutch sticking 82 FXRS, again
- Inner Primary leak
- Service Manual -- Compensator Section
- Clutch torque capacity
- Primary chain adjuster question
- Primary Cover Off for way to long
- clutch spec
- Road King chain drive conversion sprocket options
- Bucking and Primary Grinding Noise From Primary
- 2008 sportster primary gasket leak?
- What size sockets? Main shaft hub and compensator
- Cracked transmission case question
- tranny oil level
- Kicker kit?
- max offset on 2005 fxst with chain
- Problems with clutch
- Baker compensator question
- Arbor press for bearings
- I think I found out why my 5-speed was shifting hard
- '05 Super Glide clutch replacement - smaller friction plate doesn't fit over damper/judder spring - HELP!
- tranny oil
- Fluid on Primary Case
- 88 electra
- New clutch disks and pressure plates . now won't release to move bike.
- tranny bearings 50k miles
- opinions on buying used belts
- Rear Axle -- Reversed
- Clutch adjustment – jam nut's a b***h
- Compensator Upgrade
- Shifter linkage heim joints
- Drag Specialties Aramid Clutch Friction Plates Kit 9
- Quick 1990 clutch ramp orientation question
- 2007 Electra glide special custom funny clutch
- 2005 Road King Acceleration/slipping Issue
- Primary oil for Barnett clutch
- FLHT Trans/clutch issue?
- Evo drivetrain
- Primary bearing/race removal/install.
- Backcutting Service's Who?
- trans problem
- Charging problem.
- S&S inner primary bearing race
- Muller 120-60 bleeder size
- Rattle when clutch pulled in
- identify my clutch friction discs?
- 1949 pinhead 4 spead transmission
- Main Drive Bearing
- Stator Rotor cracked
- Baker grudgebox
- Leaky Shift Shaft Seal......
- Primary Part Number
- Primary noise on a 14 ultra Limited
- 88 CI comp or sprocket
- Primary Oil Level
- 2018 RGU Hydraulic Clutch Lever sudden loss
- Clutch spring ?
- Must read regarding ESP extended warranty clutch repair
- Transmission rebuild dilemma
- Help....2008 fxcwc transmission issues
- 2003 Rd king in need of serious assistance
- Blown or not
- How can you troubleshoot no reverse on tri glide
- Installing primary bearing Race trouble?
- 09 Nightster transmission not engaging
- Compensator thread size 111 s&s
- New clutch replacement became a whole lot more??
- Chain final drive questions
- Compensator shim source
- I swapped out my transmission cover yesterday, and now my clutch engages differently.
- Aftermarket hydraulic clutch slave cylinders
- 83 lowrider shovel head 4 speed hard shifting
- 5-speed clunk & hard shifting once warmed up
- 65-66T rear pulley for '04 Heritage
- Is this bad?
- '05 Road King Classic Clutch Adjustment
- Transmission filler hole threads damaged
- Chasing threads on inner primary bolt
- Clutch replacement failure
- Tool Cost.
- Inner Primary Bearing Replacement - 2020 M8
- Shovelhead engine swap
- Inner primary case bolt
- I hate my clutch feel (2019 Limited)
- Compensator noise/bike dies/2nd stator failure in just over a month
- Had it with these SE Comps, going Man-O-War......
- Primary Noise
- What to count?
- M8 6 speed trans. V’s Twin cam 6 speed trans
- Compensator parts
- PSR or Vulcan primary adjuster
- Twin Cam Primary Chain Tensioner VS. M8 Tensioner
- Primary chain misalignment
- Clunk while decel and throttle
- What drive belt?
- 09 trans rebuild
- Chain to lose or tight
- 3rd gear slipping
- 3rd gear problems
- Leaking inner primary seal again?
- dealer installed new primary, just forgot the oil
- Parts sheet for a 5 speed Jims tran rebuild kit
- primary chain adjustment confusion
- 06 dyna low rider IPB
- Ultima 3.35 Clutch Replacement
- Neutral light suddenly inop
- Installed pro clutch
- Stator output
- Best primary chain tensioner
- Engages clutch when too fast on a lot of throttle automatically
- Torx bit
- Torx bit
- 2003 sportster grinding after it fires up
- Checking transmission level
- TriGlide Won’t Shift into 6th
- Won’t Shift into 6th
- 2013 Touring FLHTK primary oil leak
- 3"Primary Belt Drive
- Confused about compensator part number 2016 Dyne
- Evo dyna inner primary cover same as softail?
- 2013 Ultra Limited downshifting into 1st. 32,000 miles
- Downshifting difficulty
- Rekluse Radius X Auto Clutch
- twin cam primary drain plug....boy wth
- Primary Cover Gasket
- No neutral light
- Clutch issue when and extra noise, 1st gear
- new drive belt ???
- Sound from behind derby cover
- 6 Speed Gear Pack Assembly Internchange
- Clunking on Deceleration
- Primary noise mystery
- inner clutch hub
- Something's in my belt
- Bike wonn't shift.
- Help - Clutch cable ferrule binding
- Downshifting hang ups
- Gear Indicator on LCD showing wrong gear when clutch is in friction zone
- M8 Tranny/Primary Grind Question.
- Should I be alarmed?
- 1989 883 primary cover interchangeability
