- Gearbox Identification
- 84 FXR 1340 evo Vehicle Speed Sensor Location
- Hydraulic clutch cover - '82 FXR
- Metal flakes in tranny oil Noob question
- 3/4" or 1" 2018 Softail deluxe
- Final drive suggestions
- Another belt ratio question
- 2006 SH help
- 86 Sportster Transmission Questions
- Sanity Check for suspension set up please
- Hard shifts into 2nd gear
- 82 FXB issues
- Clutch recommendations
- Can someone explain why the Heartland 280 kit is $3100?
- New Grudge Box, Question on Shifting
- clutch cable adjustment
- New Heads - possible clutch slipping?
- Fat Bob 2015 gear issues
- Clunking/lugging type noise
- M8 Clutch Slip After Cam Install??
- M8 shifting
- AIM Tamachi Cable to Hydraulic Clutch Conversion Kit
- Am I the only one?
- 82 shovel 4spd shifting issue
- New clutch cable.
- 2009 Road King just started making loud noise in 6th gear when increasing rpms.
- 16 SG Replacement Clutch
- 2019 Ultra Limited Clutch Hub Bearing failure
- Ticking noise from right side (clutch)
- Transmission issue , causing vibration ?
- ROTOR wear an tear?
- Transmission Noise
- Trapdoor rebuild
- trans swap
- 2003 Titan Sidewinder
- Excessive play in shift linkage
- Compensator, Inner Primary, Seals
- EVO 5 speed replacement options?
- Engine chokes/lugs when starting from dead stop in 1st
- New compensator
- Found this below the Starter. What is it?
- Secondary chain adjustment
- Slipping in 5th gear only
- Concerns with over torque on clutch basket hub nut (Belleville Washer)
- Clutch Basket Damage
- Does Harley or aftermarket company make better drive belt pulleys?
- closeup pictures of new or low-miles rear drive belt
- Transmission Issue 2000 FLHTPI
- M8 primary chain auto tension adjuster
- Mainshaft movement
- Countershaft Gear Movement
- Have a drip coming from the primary?
- Sportster stuck in neutral
- Loud knock when starting
- 2016 103 Ultra, 37k miles, slip/jerk in 3rd only
- Drivetrain alignment
- Does this look like 9K of tranny metal to you?
- new chain
- 2018 Softail Street Bob Clutch Issue
- Clutch lever end play
- Clutch basket removal.
- Going into neutral
- Twin Power Clutch Replacement Problem
- Belt keeps breaking. Sold compensator?
- Jims FAT 5 Side Door Exhaust Pipe Spacing
- New to Group 07 1200C transmission removal
- Primary chain tensioner
- 04' 1200 Sportster stuck in 5th and clutch smoking
- Stock clutch
- Clutch Cable Adjustment?
- Shifting transmission by hand while bike on stand?
- 86 FXR Liberty Edition Clutch Issues?
- '82 clutch hub nut stuck
- Clutch Push Rod Locknut Question
- Chain to rear tire clearance?
- 1981 flh 5 speed trans case
- Primary rattle
- EVO final drive gear operation
- Leak after starter fixed.
- 1991 FXSTS Springer
- 2016 Ultra 103 primary side clunking during EITMS
- Primary cover gasket on 2019 FLHP vs 2005 XL1200C
- 03 Low Rider clutch release cover fluid and primary fluid question
- Scraping noise or a grinding 07 night train
- Clutch Issue
- Grinding Noise from rear primary and no power
- screw up
- 20115 Ultra, sometimes grinds when downshifting from 2nd to 1st
- Barnett Clutch Spring Conversion kit: OH YEAH!!
- 2012 street bob speed shifter
- Static-like white noise coming from primary
- Converting from clutch cable to hydraulic clutch
- Sticking Clutch After Plate Replacement
- Squeak when downshifting
- How much end play on main shaft?
- 4 speed conversion
- Transmission oil to engine
- Trans leak help!!!
- Striped thread on bearing housing
- Chain tensioner
- 2016 street bob 103 transmission or clutch issue!
- 06 dyna super glide down shifts when stopping hard
- Hot Drive Line Looseness
- 1962 Duo Glide Belt Primary - Tensioner solution sought
- When to replace compensator
- Trans clunk on 6 speed
- Clutch adj nut keeps coming loose
- Burnt clutch smell
- The predominant reason for IPB failure
- Looking For Starter Clutch Recommendation
- 77 xlh sportster clutch
- IMC custom motorcycle
- Transmission freeplay
- Just to get confirmation
- Rivera primo clutch hub removal with a 2 post puller
- 96" twin cam leaking at crankcase split.
- Question about motor sprocket
- Front pulley change
- 6 speed for 2002 road glide
- 2018 Softail clutch springs
- Barnett Scorpion lo pro lock up.
- Reverse the shift pattern
- Primary self adjusting
- Does this sound/look right?
- main shaft moves in and out
- Road king going into first gear
- Drivetrain "thunk"
- 2018 FXFBS rear brake pedal
- 2019 touring won’t go into first.
- gearing
- Transmission problems
- Barnett tapered spring removal
- Loud whirring sound from primary
- 2001 softail need easier clutch pull
- Clutch lever freeplay varying
- Bandit Sportman clutch 124” TC
- Neutral Knock
- Sportster hard to shift/gears not fully engaging/false neutral diagnosis and solution
- Diagnosis of noise
- 2008 Electra Glide Ultra Classic 6th gear wheel part number
- Changed clutch lever, bike won’t start
- question on clutch adjustment
- Noisy Primary (all the time)
- New DS inner hub, what about the nut?
- Side free play on clutch internal adjuster screw and lock nut touring harley
- 2003 softail transmission drain plug size
- Stripped primary head cover bolt
- 17 Road Glide Speedo not working
- Hot transmission
- Stage 4 clutch question
- Clutch Cable Tightens and Loosens on its Own
- Strange noise primary area..
- what chain for old evo FXR
- Down shift clank on 2018 RG Special
- 03 FXDL Hard to shift.
- Primary Noise
- Twin cam clutch interchangable?
- 1981 Shovelhead Transmission Pops Out Of Gear
- Loss of pwr riding in rain
- Leak proof primary ???
- Which Barnett pack?
- Stator Plug Oil Leak
- Primary preventative maintenance
- Compensator or Solid Sprocket?
- Feet grounding out with fw controls and 10.5 springs.. Would mid controls be better?
- Trans case 91 FLHTC
- Primary case torque specs
- Transmission identification help
- Clutch help
- Clutch cable advice
- Clutch Pushrod Question: Is it free floating inside the mainshaft? - TC88/5spd
- New Clutch - BALL & RAMPS BINDING🤯
- Using 1 1/8" belt for 30t Sprocket conversion
- 2016 dyna low rider s Trans problems
- Derby covers
- Clutch wobble
- Clutch
- Harley Davidson Police clutch
- 94 Sportster
- "tink" when accelerating - primary chain?
- 2007 Road King Police 103"
- CounterShaft Question?
- Inner Primary Bearing Timken
- Noice primary 2010 trike
- 2010 Harley ultra classic trike
- Manual primary tensioner
- Shift Fork Wear
- Help ID my Primary/Transmission Leak, PICS!!! (04 Dyna, 88TC, 5-spd)
- Twin cam primary gasket leak
- New member torque specs dyna evo 1992
- Supercharged?
- clutch play / trans issue?
- Issues with tranny/primary?
- Rushmore street glide clutch noise?
- Inner Primary cover bearing
- Sorry everyone, cant search anymore and I need help Please!!!
- Transmission hammering noise
- Anyone have a review of drag specialties rear sprocket?
- Shifter shaft oil seal
- Best complete clutch kit
- Forward to mid controls
- V-Twin Manual Primary tensioner
- Loaner Tools
- Softail clutch cable adjuster in wrong place
- Primary Noise
- HD Heritage Softail Classic
- New to the forum/primary belt questions
- Ultima primary drive starting problem
- Noise when pulling in clutch
- Clutch Adjustment help (yes I have searched)
- Clutch problems fourty eight 2017
- 10 Harley sportster 48 clutch noise
- 2010 Harley fourty eight sportster clutch noise
- 2008 sportster 1200 wont shift down please help!!!!!
- Stuck in gear - 2005 Sportster 883
- Help with gear set interchange
- Look what I found in the Transmission side cover
- Clutch cable measurement
- When To Replace Primary Chain Tensioner
- 1976 flh1200
- 883 acts like it's missing a gear
- help with mid controls
- Clutch Will Not Stay Adjusted
- 1999 FXR2 Chain Tensioner Problem/Questions
- Swapping 06 FXDB transmission
- Transmission advice
- Looking to Find/Understand primary belt tooth count
- Clutch slipping problem
- Are these fluids the same?
- New Clutch Plates, Slips in 5th Only
- Shovelhead inner primary cover
- Adjust belt tension on Fxcw Rocker
- 2014 ultra limited trans whine in neutral and coasting
- belt breaking
- 32 Tooth comp eliminator
- TWIN POWER 32 Tooth
- Primary Ratio Change
- Harley dyna 2004 trans oil pan
- Clutch Replacement questions
- Transmission dipstick ?
- Clutch Cable Retaining Ring Orientation
- Checking Transmission oil level?
- Rebuilding Primary '04 TC88 - Please help me ID these parts from the Cometic Primary Kit
- Clutch: Rebuild or Replace?
- Barnett Extra plate kit w/ spring conv. Not engaging
- TRANS and PRIMARY OIL
- Clutch Shell Wobbles - is it normal?
- Did I F this up??
- Neutral between 3 and 4 gear
- Transmission service or rebuild?
