View Full Version : The Dyno Room
- DYNOJET Need A Tune...
- TTS O2 Sensors Bad?
- DYNOJET Disabled Target Tune...
- HARLEY Jim’s Daytona Twin Tech ignition questions with big bore build
- No Device DISABLING DECEL FUEL CUT OFF
- HARLEY Dyno Chart vs actual usable
- DYNOJET 2025 Fatboy Dynojet PV-3 Dyno tune FAIL
- DYNOJET Looking for Tune Shop in PA
- DYNOJET Looking for a Tuner in Mooresville, NC area
- HARLEY AFR Table for SE110" Stage 1
- DYNOJET power commander 5 ???
- DYNOJET PV3 The Bike Runs Better While in Auto Tune
- TTS Why is my idle timing bouncing so much ?
- DYNOJET 05 wide glide power commander 3 baby must be a teenager
- DYNOJET timing change initiated by decel enleanment?
- DYNOJET Global VE quick tune on PVOG
- DYNOJET pv with smart tune pro
- DYNOJET Seeing tables without permissions in C3?
- DYNOJET Looking for a pv-2
- DYNOJET Convert pvt to djt
- DYNOJET AFR Table Advice
- TTS Lost TTS MASTERTUNE2
- DYNOJET Runs bad 2000-2500 rpm, and large valleys in VE tables
- DYNOJET Acceleration Enrichment Mode...
- DYNOJET Old School Tuner User
- HARLEY Dyno tuner
- No Device affect of gearing on dyno numbers?
- DYNOJET PV3 & Software Issues
- DYNOJET 114" w/ ss475 low rpm loading
- DYNOJET scored cylinders new 131 crate motor.
- DYNOJET 2005 Road King Andrews TW48 Tunes
- DYNOJET Power vision question
- HARLEY tuning stage4 131 kit with Wood 77x cam
- OTHERS Tuning 131 kit with Wood 77X cam
- DYNOJET can someone look at my tune? please? im desperate
- DYNOJET Tune opinions
- DYNOJET P0155c code after getting it tuned.
- HARLEY Matching Fuel Injectors - Throttle Body or Intake Manifold Sizes
- DYNOJET Another one on IVO/IVC settings
- DYNOJET pv says invalid vin
- HARLEY VE vs VE NEW
- DYNOJET Powervision Database
- DYNOJET POWER CORE TOKENS?????
- DYNOJET ION-Q Pid.
- DYNOJET Using Power core Tune lab with logs
- DYNOJET Powervision tuner folk?
- TTS TPS vs MAP VE’s ‘14-16 touring
- DYNOJET Anyone have a PV4 tune for 883 to 1200 conversion
- DYNOJET (PV 2B) Autotuning results keep asking to Cap or Scale. What should I do?
- DYNOJET New to tuning and Power Vision
- No Device New to tuning
- DYNOJET 03 Electra Glide post tune issue at cold idle
- DYNOJET Pv4 installed preloaded tune. Still getting o2 codes
- DYNOJET 2019 street glide special. PV4. Sands 475 cam
- DYNOJET PV4 and now bike runs really really bad. 3k idle and backfires!?!
- DYNOJET Lowrider st idle sounds strange?
- DYNOJET New to understanding tuning
- DYNOJET HELP 2024 Lowrider S
- DYNOJET Dynojet pv3
- DYNOJET Having issues with a 250I
- No Device 2023 Low Rider ST tuning necessity questions.
- DYNOJET Powervision 3 ecm compatibility
- DYNOJET 2017 Road King w/ PC V. Should I keep it?
- DYNOJET Closed Loop Lambda Range...
- DYNOJET CDE, Charge Dilution Effect...
- DYNOJET PV2-B with Target Tune...
- HARLEY Tuner questions
- HARLEY need map for s&s 124
- DYNOJET What to Look out For When Looking At Used 250i's
- DYNOJET IAC issues?
- No Device Data Recording
- DYNOJET PV-3B on my 2022 114 FLT
- OTHERS Need to know about tuning...
- DYNOJET PC 3 USB Tunes
- FP3 Custom dyno map and fp3
- HARLEY SE Smart Tune PRO Automatic Tuning Module
- Alberta Dyno Tuners
- DYNOJET What Makes the Dynojet 250i The Standard Of Tuning
- TTS TTS widebands
- DYNOJET P0135-P0155 error after tuning M8
- OTHERS '20 FLHXS 114 Woods 22xe, Rinehart DBX 45, DK customs ac
- HARLEY Magneti marelli
- OTHERS Problem with adjusting fuel settings
- OTHERS Daytona Twin Tec TCIF 2
- TTS Looking for a TTS map for Tman 625 on twin cam
- HARLEY Looking for SEPST Calibration Description
- DYNOJET m8 114 ss475 power vision map needed
- DYNOJET When To Manually Adjust VE Tables
- DYNOJET 23 Screamin eagle stage 3 122 kit not available?!?
- TTS updating TTS software
- DYNOJET Fine Tuning...
- DYNOJET 07 Ultra Glide
- DYNOJET PE, Power Enrichment mode...
- DYNOJET Discrepancies in data logging...
- DYNOJET Auto Tune and Timing...
- DYNOJET PowerVision IVO/IVC settings...
- OTHERS any techno research guys in here?
- DYNOJET Need Help
- DYNOJET Power Vision 3 Not Connecting to ECU
- FP3 Power duals with rinehart 4"
- DYNOJET 2021 Street Glide hanging idle..
- HARLEY SEPST HELP PLEASE! '17 Road King Special
- DYNOJET Power Commander V and TTS
- FP3 V&H FP3 tuner
- DYNOJET Looking for a custom tune 2014 sg
- HARLEY carb cv 40 emoution tube
- No Device Why Decrease Timing in High RPM Range???
- TTS vtune help
- HARLEY Will this fit my dyna?
- TTS Looking for map. 2019 114 FLHTK SS 475 CAM
- DYNOJET New to tuning with PV Help please
- FP3 FP3 Throttle Limit vs Gear. Anyone from V&H here?
- DYNOJET Autotune vs Megalogviewer
- OTHERS Old orange screaming eagle tuner trouble
- DYNOJET Help with what tune I need to install.
- HARLEY Which SE SuperTuner map for 96ci w/ stage 1 filter and true dual Reinharts?
- DYNOJET PV settings to make bike start easier
- DYNOJET 110 race kit tune questions see thread
- DYNOJET Power Vision beginner learning resources
- DYNOJET Need help/guidance. I'm stuck
- THUNDERMAX dyno tuner
- DYNOJET Help understanding VE tables between two maps
- DYNOJET Power Vision WinPV and windows 10S
- DYNOJET setting throttle blade control
- HARLEY Tuning basics
- DYNOJET Red and green hits on Auto tune
- DYNOJET TTS or PowerVision map request
- DYNOJET Hi
- DYNOJET How to determine Proper Injector size...
- DYNOJET Auto tune basic and rpms above closed loop range
- DYNOJET Question about new map
- DYNOJET Quick tune low mid and high rpm range (VE adjustment)
- OTHERS Magneti morelli dyno tune question
- HARLEY Super Tuner Pro- retrieve custom tune
- DYNOJET fxdls 2016 detonation
- DYNOJET Dyno tuning vs tuner brands.
- DYNOJET Help with screaming Eagle tuner
- DYNOJET 2021 road glide Screamin eagle pro street tuner help
- DYNOJET Dynojet maps vs FuelMoto maps - Powercommander V
- THUNDERMAX Dyno Tuning with Thundermax ECM
- HARLEY Seeking map for 2017 SGS Stage 2 power
- DYNOJET At my whit's end with idle RPM issue and PCV.
- HARLEY Help me i reverse the warriors in the tpms
- HARLEY maps please
- HARLEY Magnetti Marelli Tuner Cables
- TTS PE mode for J1850 Sportsters ?
- HARLEY Dyno Tuner in Wisconsin or Indiana.
- No Device tuner confusion
- DYNOJET 106BB upgrade Street Tune with Power Vision
- DYNOJET Twin cam ignition timing.
- No Device Tuning problem on 2005 Road King
- DYNOJET 2020 114" Lowrider S, CR480 cam, S&S pipe
- DYNOJET Sputtering after Auto-tune
- DYNOJET considering Pv w/ AT pro.
- TTS Seeking answers to Data Graph and Tuning
- TTS Total Loss for ideas
- TTS Iac help
- OTHERS Daytona Twin tec Ignition TC88 vs TC88EX
- HARLEY Finding SE Pro Super Tuner software
- OTHERS Cobra Fi-2000 PowrPro Black 👎🏻 Vance & Hines 👍?
- DYNOJET Power Vision tuning charts...
- TTS Vtune TTS vs Dyno tune
- THUNDERMAX Readin', Writin', and re-tuning!
- FP3 Fuelpak Compatibility with Engine Mods???
- DYNOJET Help Me understand EFI Tuning...
- TTS S&S 465C Calibration
- DYNOJET S&S 475 Map
- DYNOJET start up flare with PV
- DYNOJET Brake Pads For old Dynojet 150
- DYNOJET Gear indicator issue with sprocket change.
- No Device Upload tuning file extensions
- HARLEY Fuel pack on 2006 harley
- HARLEY Updated SE Pro Street Tuner software version 20.006.5008
- DYNOJET 2300-2400rpm skipping at 10%-20% throttle
- DYNOJET I need a tuner!
- No Device Total Newbie, What Device do I need??
- TTS Looking for TTS map
- HARLEY need advise on SEPST Spark advance adjustment advice
- HARLEY Average cost of Dynotune
- DYNOJET PV with the SE Smart Tune Pro
- DYNOJET help with map for 98ci 2into1 w/ 48 cams
- DYNOJET Worth to upgrade from FP3 to power vision
- DYNOJET Power Vision Questions
- FP3 Confirmed- V&H FP3 sucks
- HARLEY Smart Tune Pro
- FP3 upshift pop
- FP3 fuelpak fp3- only runs good on stock tune
- THUNDERMAX Tuner Procedure
- DYNOJET Winpep 7 report w/o AFR
- DYNOJET 06 FXDI35 Anniversary Super Glide
- TTS tts mastertune updates
- DYNOJET Autotune on Power Vision questions.
- OTHERS Fuel Pak LED
- OTHERS Translation Wanted for Tune...
- HARLEY Question if speedo and/or odo re-calibration is possible?
- DYNOJET Generic questions on Power Commander V
- HARLEY SE Pro Super Tuner base calibration for 103 with SE 257 cams
- DYNOJET Power vision map share
- HARLEY Question on decat stock exhaust and crosstalk
- HARLEY Will the original 2001 SE Race tuner still work?
- OTHERS TechnoResearch/Direct Link
- HARLEY 2019 Softail Slim (FLSL) tune trouble (SE Pro Street Tuner_
- THUNDERMAX thundermax upgrade question
- HARLEY 2009 Fatbob throttle issue
- DYNOJET Pcv map
- DYNOJET PV auto tunes introduce severe vibrations
- DYNOJET Lower my AFR to lower eng temp
- DYNOJET Surging idle after new map using power vision
- DYNOJET Effect of engine temp on VE tables in auto tune
- No Device Tuning an Unknown '04 Dyna?
- DYNOJET Dyno tune and pv questions.
- TTS Baseline map for RS527 Cam
- DYNOJET 124" big bore ECM Trouble
- DYNOJET NB:O while autotuning
- DYNOJET Power vision question re: starting bike
- FP3 My encounter with V&H support
- DYNOJET Power Command V questions
- DYNOJET Couldn´t read original tune
- HARLEY using diff model SEPST file
- DYNOJET tuning help pc5
- DYNOJET Hard start after hot soak--DTT USB3--95",Carb
- HARLEY Anyone know where to find some good build AFR Map tables
- HARLEY Pro Street tuner
- TTS A tune is a tune, right?
- No Device Saw this cool app. It is available does anyone know
- No Device Slip ons, new breather, no tuner
- OTHERS Cobra Fi2000 powrpro
- OTHERS Unmarry Tuners?
- TTS AFR table
- HARLEY 2015 CVO w/117" kit & SEPST Help
- HARLEY Help...adding new pipes and tuner to a bike with a stage 1 already installed
- TTS Table Comparisons
- FP3 FP3 Question
- OTHERS TechnoResearch spark knock
- THUNDERMAX Need a map for a 88 cu with S&S 509 cams
- FP3 Vance & Hines
- DYNOJET Datalogging for PCV
- HARLEY 2015 Fat Bob tuning help for a rookie
- HARLEY FP3 w / S&S 465 Cam
- HARLEY Central Massachusetts Tuner for SEPST
- OTHERS FP3 Accel Enrich does nothing?!?
- HARLEY SE Pro and Street Tuner Return to Previous Calibration
- OTHERS FP3 auto tune session question
- DYNOJET Need Target AFR for a AT-100
