View Full Version : The Dyno Room
- DYNOJET New Target Tune Install: Error Initializing Tune
- DYNOJET Power Vision Dyno tuner in the Maryland area?
- DYNOJET My Map, My Logs, My Problems, Help Wanted
- DYNOJET Power Vision firmware and tune DB update
- HARLEY running like crap
- HARLEY Screaming Eagle Street Tuner - How to obtain stock 103 map?
- TTS Looking for basemap Tman 590 10.7:1
- OTHERS Deceleration Enleanment
- OTHERS downloaded map missing from my VH FP3
- DYNOJET AFR vs VE
- No Device Going rate for a PV dyno tune?
- DYNOJET IAT Spark timing in PV and an oh gosh what's that then in the logs
- DYNOJET Who has just used the Quick Tune option on their powervision tuner
- HARLEY Computer died while programming
- OTHERS Initial fp3 setup
- DYNOJET TPS vs KPA auto tune question
- TTS TTS MasterTune base map
- DYNOJET Power vision & My Tune
- OTHERS FP3 Question
- DYNOJET Lost the tune ?
- HARLEY Is my Tuner now useless?
- DYNOJET Danmoto 2 x 1 and Power Vision tuner
- OTHERS FP3 AutoTune Data Gather Fail
- HARLEY Pro Super Tuner - Throttle position less than 100% at WOT
- HARLEY Smart Tune Question
- THUNDERMAX ThunderMax?
- HARLEY Help with Super Tuner Pro
- OTHERS (I made a) Tool for tracking FP3 auto tune sessions
- HARLEY Software or Windows dramas
- HARLEY Unlocking Tuner
- HARLEY Trouble codes 2015 Street Glide Special
- DYNOJET Help with 107CI Woods TW-555 timing table -
- No Device Tune or no tune....
- OTHERS FP3 autotune
- OTHERS Strange FP3 autotune readout
- OTHERS FP3- Leave on or Remove?
- DYNOJET Dynojet Power Commander III Using Too Much Fuel
- No Device Crappy tune?
- HARLEY Has anyone run a SE tuner on a stock engine
- TTS Tune pretty good except stumble
- DYNOJET safe A/F ratio for mileage in the cruising load/rpm
- TTS 90% duty cycle
- No Device Does the MAP deceleration curve tell you anything
- TTS Need some guidance
- No Device A not so bright question!
- HARLEY How to capture whats already in ECM?
- No Device Iron 883 power commander
- TTS HQ 120" tts base map
- TTS TTS Mastertune how to ride your bike collecting data for vtunes
- HARLEY Anyone use a FP3 or PV (or other) after they had a SERT with Dyno run at HD dealership?
- DYNOJET Power vision and a mac
- TTS Question on map
- DYNOJET New dyno run needed after muffler change?
- HARLEY 2006 street Bob running on 1 cylinder
- DYNOJET spark Tables
- OTHERS Issues with FP3 tuner or not?
- HARLEY SEPST help
- HARLEY Stutter Starts at Times
- HARLEY CVO 95" upgrade (Intake Manifold)
- OTHERS FP3 Autotune confusion
- HARLEY 96CI tune on 103CI
- DYNOJET Powervision - 127.5 in decel VE
- OTHERS Fp3 on screamin eagle st.1 tune
- TTS Tts
- OTHERS FP3 Question: Does the FP3 "positively" retain/store the original OEM Map?
- TTS TTS: How does my plan sound
- No Device Riding post-rebuild
- DYNOJET Power Commander map for Street Glide
- OTHERS fp3 with stage 2 103" Hesitation
- THUNDERMAX Thundermax
- HARLEY timing for easy starting
- TTS Map Request
- OTHERS spark plug knock and fp3
- No Device Tuners/Maps My head's exploding
- No Device 2006 New Softail FXSTI need opinions
- DYNOJET IAT....Intake Air Temp
- DYNOJET Power Commander V
- HARLEY 2017 Breakout CVO Pro Street Tuning
- TTS VTune3 VE tables empty
- OTHERS fp3 in open loop
- HARLEY Maps
- No Device Best budget efi tuner
- THUNDERMAX Blowing ign. fuse
- OTHERS Cobra powerpro fi2000
- THUNDERMAX ThunderMax Tune(s)
- HARLEY Doing the Street Tuner Tango on a M8
- OTHERS FP3 install - first run.
- TTS locked ECM and TTS
- OTHERS Fuelpak fp3 q
- HARLEY SE pro street tuner
- DYNOJET Great another "which EFI/autotuner is best" question. Sorry
- No Device Will I have to retune?
- HARLEY Ho 103
- DYNOJET New tune - New device?
- HARLEY Reformatting Data Output by Street Tuner
- DYNOJET Low MPG 2016 Heritage
- HARLEY Super tuner pro and S&S 583 cams
- OTHERS Good Dyno tuner in/around Carlisle, PA
- No Device M8
- No Device Does fuel range adapt to engine changes?
- DYNOJET Newb Tuning Q - Dyno booth vs Power Vision
- HARLEY Map for TC96" with stage 1 and 255 cams
- No Device Harley-Davidson/EPA Conspiracy Thread!!
- HARLEY Breakout cvo & screamin eagle stage 3
- TTS TTS: Anybody familiar with using the Spark Control vs Engine Temp tables?
- No Device Possibly the most basic tuning question
- HARLEY VCI drivers failed to install.
- DYNOJET To cap or scale
- HARLEY New Harley Auto tune module now available
- No Device Do I need a tuner for this basic Mod
- HARLEY How to check which map is on bike
- DYNOJET Changes to base for break in
- HARLEY Pre-EPA ban software
- HARLEY Help with MyTune
- OTHERS FP3: What map?.. no response from V&H
- No Device Which tune to start with
- No Device General question about Spark tables
- HARLEY Efi super tuner
- DYNOJET Power Commander V on Rushmores
- THUNDERMAX 09 Road Glide Drago 2.5
- DYNOJET Power Vision Feature Enhancements
- DYNOJET PC3 vs PC5 vs ??
- DYNOJET Christmas Present?
- DYNOJET Need help with Auto tune with Power Vision
- HARLEY Quiet baffle re-tune??
- No Device Help selecting correct aftermarket tuner
- HARLEY SEST hold more than one tune?
- OTHERS 08 Softail custom
- OTHERS Fuel Pak 08 Softail custom
- DYNOJET Power Vison or TTS map
- TTS '08 Ultra build
- HARLEY Vance Hines FP3 Problem
- OTHERS Fp3 settings on screaming eagle cannons
- TTS TTS Base Cal
- TTS Spark Knock Help??
- what tuner?!
- DYNOJET Can the Power Vison extract 2 tunes from the same bike.
- TTS TTS Delphi Calibration Listing for Fatboy S?
- DYNOJET Ign timing
- DYNOJET Power Vision Target Tune
- No Device Old tech decel popping
- DYNOJET PC-V auto tune
- TTS Engine Temp's
- HARLEY dyno question
- No Device What are my choices?
- OTHERS FP3- AutoTune an AutoTune
- HARLEY Old Screamin Eagle Race Tuner
- No Device help me learn about spark knock events
- HARLEY bad front o2 sensor
- No Device Buy a Tuner, or go to Dealer
- DYNOJET WBO2 Wire Routing
- No Device TTS and Power Vision?
- DYNOJET any have a PV tune they can send me?
- HARLEY Need SERT advice/software
- DYNOJET Autotune for the powervision
- HARLEY New bike with tuner already installed. Need help!
- DYNOJET Power Vision Auto-Tune Question
- HARLEY Any SESTP pros willing to take a look?
- OTHERS what next mod for winter
- HARLEY Dyno Tune Issues Using SEPST
- HARLEY SEPST and 2011 103 Touring
- HARLEY SERT and rev limit?
- DYNOJET PC5 please help
- DYNOJET Map changes for 120
- TTS Sharing a calibration file possible?
- TTS Starting tune help TTS
- No Device Support maps for TTS mastertune
- HARLEY New Street Bob....New pipes..... need advice?
- HARLEY SE Tuner still being advertised?
- OTHERS 103 to 107 with FP3
- TTS TTS Mastertune Model Difference?
- DYNOJET Can an expert help please. Tune or something else?
- No Device Which Tuner for existing build / HELP
- No Device Brief Synopsis of Tuners
- DYNOJET Need Temp Map ASAP Please
- TTS TTS and ecm's
- No Device Programmer question for a Fatboy
- HARLEY Procedure for unmarrying Screamin Eagle Super Tuner Pro
- HARLEY Harley Pro Street tuner
- TTS Locking to ECM
- DYNOJET Tuning cams
- TTS Flight recorder question.
- HARLEY Tuning in Closed Loop
- HARLEY Harley Race Tuner Kit #32107-01G Question
- DYNOJET Power Vision Question
- HARLEY Anyone try the new Screamin Eaagle Pro Street Tuner yet?
- OTHERS FP3 vs HD Stage 1 Download
- No Device Newb Tuner Question
- DYNOJET 110 seems underpowered
- DYNOJET Power vision with not load stock tune
- OTHERS Hq 120 base map
- TTS 12mm 02 Sensor placement
- HARLEY How Many Runs to Dyno Tune new map
- OTHERS Daytona Twin Tec vs Dynatek TC88 (carbureted bikes)
- TTS Tuning help
- DYNOJET Knock Control
- HARLEY Another SEPro tuner question...
- TTS M8 calibrations
- HARLEY SE tuner cables and software...
- No Device How many dyno runs for our money?
- TTS Only 102hp & 112 torque
- TTS TTS upgrade?
- HARLEY Screamin' Eagle Pro Street Tuner and '17 M8
- HARLEY New dyno run, free
- OTHERS FP3 tuner and battery.....
- OTHERS FP3 question
- TTS 2016 Road Glide- TPS or MAP?
- DYNOJET Here's how to stop decel pop on a M&M EFI Bike
- DYNOJET PV Autotune caused Decel Pop?
- HARLEY Another easy question
- DYNOJET Power-vision...Wont Run right after hits 4000 rpm
- DYNOJET Powervision...Wont Run right after hits 4,000 rpm's
- DYNOJET tman555torqster powervision map
- HARLEY Is there an app to run the SEPST on a tablet or phone.
- HARLEY VCI update
- TTS First time using TTS, How do I do this?
- DYNOJET Back to running lean with PCV
- No Device EPA's over-reach on HD's
- THUNDERMAX Need TMax Timing Help
- OTHERS Issues with possible over fueling
- THUNDERMAX Basemap Suggestions
- THUNDERMAX ThunderMax - Basemap
- OTHERS what map do I start with?? vh fp3
- No Device ECM that has been flashed Part II
- TTS occasional pop
- No Device Tuning EGR/CDE and MAP at idle ...again!
- DYNOJET 1st auto tune run basic
- DYNOJET 2001 FatBoy FI basic questions
- DYNOJET Powervision turns off when I start the bike
- No Device tuner , which one do you like and why?
- No Device should i buy a tuner??????
- OTHERS Question about FP3 Auto Tune
- TTS N00b => Cam Selection HELP?!!
- No Device Do I need a tune?
- HARLEY straight answer to the SEPST BS
- HARLEY Race tuner ECM questions
- DYNOJET Truoble with powervision
- DYNOJET '12 FXDB Need help with Tune / PV
- OTHERS FP3 1 Firecracker
- TTS Milwaukee 8 Testing
- No Device Newbie needs advice on heavy breather/tuner
- OTHERS frustration
- OTHERS Learning, FP3 and recommendations...
- DYNOJET Timing/knock
- No Device 2017 Model HD CARB Documents
- OTHERS Rear Cylinder Knock retard
- OTHERS Fp3 idle afr question for the experts
- OTHERS Suitability for FP3 for my Bike?
- HARLEY Rev limiter and SE street tuner
