PDA
View Full Version : The Dyno Room
Pages : 1 [2] 3 4
  1. DYNOJET 18 Heritage. Calibrating speedometer. Need PPK values
  2. DYNOJET PV auto tune basic. Question about VE tables
  3. HARLEY Screaming Eagle Super Tuner (32109-08C)
  4. THUNDERMAX Tmax timing curve advice
  5. HARLEY Tuner Novice Info Requested
  6. HARLEY Screamin' Eagle Super Pro Tuner
  7. DYNOJET HARLEY VROD MUSCLE tunes
  8. DYNOJET Help PLEASE 110 cvo with 575 zipper cams map
  9. HARLEY Going from Thundermax to Screamin' Eagle Smart Tune PRO
  10. DYNOJET Map 96” 48H 2:1
  11. OTHERS Screamin Eagle EFI Race Fueller- any info on this?
  12. OTHERS S and S Vfi
  13. DYNOJET 2002 1450 road glide, sc cam plate and pump kit, sc stage 1 air cleaners, dynojet 3 usb kit, street canon with qbl 1625 baffle, andrews tw21 cams
  14. DYNOJET Spark advance tables in powervision
  15. OTHERS DYNOJET or FP3 or orther tuner decisions
  16. HARLEY 2014 FLHT Running Rich
  17. HARLEY Stop and Start SEPST recording
  18. DYNOJET Power Vision with Target Tune issue
  19. OTHERS Power commander v thunder header
  20. TTS Will TTS work with Harley's wideband sensors?
  21. HARLEY Power Vision Tuner and License Question
  22. HARLEY SoCal Tuners?
  23. DYNOJET Reputable dyno shops in NE Ohio, Western PA area.
  24. HARLEY Can you go back to stock with a Super Tuner Pro?
  25. OTHERS Setting idle with an FP3
  26. OTHERS Rear tire explodes
  27. TTS Looking for map2017 ultra w/tts, torque (447) cam, heavy breather, full sac headpipe
  28. TTS first long ride
  29. HARLEY Tune after new pipes
  30. DYNOJET Data logging
  31. HARLEY I need help with a tuner
  32. TTS probably a dumb question
  33. DYNOJET Dynojet stack
  34. TTS tts map for 15 softail with D&D fatcat
  35. DYNOJET Tuning
  36. DYNOJET Tune with closed/open loop together?
  37. DYNOJET Adjust Spark Advance for Hot Starts
  38. No Device cylinder variances in a(any brand) tuner.
  39. HARLEY Still runs like crap after Dyno tune
  40. OTHERS Decal popping after Dyno tune
  41. DYNOJET PV - Display gauges on a computer ?
  42. TTS 2012 Road Glide 117" base map needed
  43. HARLEY Cranks to Fire with SEPST
  44. HARLEY Red hot Rear Pipe
  45. HARLEY Smart Tune Live
  46. OTHERS Alberta, Canada Tuner
  47. HARLEY Race Tuner vs Power Commander
  48. HARLEY SE Stage 4 injector size? 2017 FLSTF
  49. HARLEY 2008 Open or closed loop?
  50. DYNOJET PCV Map Request
  51. HARLEY Stage 4 with O2 sensors
  52. OTHERS fp3
  53. HARLEY Bought bike 2015 883 with tts tune didn’t know it
  54. DYNOJET Is the Power Commander V a solution?
  55. TTS 2017 FXDLRS Starting Map?
  56. HARLEY SEPST 103 with 204 Cam tuning file #
  57. THUNDERMAX Any way to view values in thundermax tune?
  58. HARLEY 2017 Dyna Street Bob
  59. HARLEY Multiple Smart Tunes
  60. TTS TTS Master Tune base map
  61. OTHERS shooting in the dark DTT tunes
  62. DYNOJET Target Tune O2 Sensors
  63. HARLEY Tuning '17 FXSE 117" with SESTP
  64. TTS TTS main lambda question
  65. TTS TTS Base Maps - Is a dyno tuner still needed?
  66. HARLEY FP3 tuner and Cobra Slipons
  67. HARLEY Smart tune pro
  68. HARLEY Smart tune pro
  69. No Device M8 Softail Rinehart slip on mufflers.
  70. HARLEY New S&S T111 - Need Map
  71. HARLEY Tuner in Central MA for SEPST?
  72. HARLEY Whats to gain by fine tuning with the Street Pro after canned map?
  73. HARLEY Odd map in my bike
  74. No Device The cat
  75. HARLEY What tune for 2018 M8 107" w/ Rinehart Motopro 45's and SE Ventilator?
  76. HARLEY M8, 107 - Is the original map the same as the stage 1 map?
  77. DYNOJET Thoughts on Dyno After Upgrades
  78. OTHERS Fp3 wideband
  79. DYNOJET Tuning help
  80. HARLEY Old software for Pro Street Tuner
  81. DYNOJET PCV Questions
  82. DYNOJET Power Vision: Actual vs Commanded AFR after tune way rich
  83. HARLEY FXSTSSE2 map help..
  84. DYNOJET Dyno shop in WA, OR, ID
  85. TTS which calibration?
  86. DYNOJET autotune questions (PCV & AT
  87. DYNOJET 05 FLHT 117" Mega-Flo heads
  88. DYNOJET Looking for a tuner??
  89. DYNOJET Autotune spark advance
  90. TTS should I do a Vtune
  91. THUNDERMAX Found a way to squeak a few MPG out of Tmax
  92. TTS Help with cam calibration before tune
  93. TTS Looking for TTS map. 103 with Harley stage 4 kit. 259E cam
  94. DYNOJET Power Vision Headache
  95. TTS spark plugs and wires
  96. HARLEY Turn off bike during auto tune recording?
  97. TTS Need help. TTS on a 2015 road glide. Newbie to this stuff.
  98. OTHERS post tuner issues
  99. HARLEY In need of cal files for 2010 fxdb
  100. HARLEY Looking for old SERT Software
  101. OTHERS Fpk3 won't run in auto tune
  102. DYNOJET Powercommander V or Fuelpak 3
  103. DYNOJET Speedo calibration with ABS
  104. TTS tts with or without wideband O2 sensors
  105. OTHERS FP3 On A Stock Bike?
  106. DYNOJET Dyno tuning a bike with Target Tune installed
  107. HARLEY Wide band o2 sensors
  108. HARLEY 18 Heritage 114. SEPST question
  109. HARLEY The SEPST: keep it or not
  110. No Device Help plz. Is my bike tuned?
  111. HARLEY Street tuner pro cables?
  112. DYNOJET PC3 for TBR?
  113. DYNOJET PC5 need map for initial start up
  114. No Device what tuner? 08 E Glide
  115. No Device VE VS Comp
  116. HARLEY Does a thunderheader baffle mod require retuning?
  117. HARLEY Does a thunderheader baffle mod require retuning?
  118. HARLEY SE Street Tuner with Auto Tune Module
  119. HARLEY Chromebook and Tuners
  120. No Device Stock tuned dynos (request)
  121. DYNOJET Power Vision Stg 1 Base Map (2018 107ci M8)
  122. HARLEY Super Tuner Base Calibration
  123. No Device Anyone working on Torque map tuning yet
  124. DYNOJET Power Vision and Target Tune question
  125. DYNOJET PC5 W/Autotune anything left on the table?
  126. HARLEY SEPST for dummies, yea it's for me !
  127. DYNOJET How long can ECM hold a tune
  128. HARLEY VE difference
  129. No Device Street ported 103 with Andrews 57H - My apologies for when I was not listening
  130. DYNOJET Anyone noticed knock on the stock Softail 114's tune
  131. HARLEY a little help
  132. OTHERS Upgrade to widebands with PV-1 or switch systems?
  133. DYNOJET Power vision help
  134. HARLEY 103 CI upgrade
  135. No Device Tuner pro's / cons
  136. No Device Error in VE tables produced from exhaust/intake changes
  137. TTS Vtune my 2009 V-rod
  138. OTHERS Can anyone tell me about the Wild things Fuel Controller??
  139. HARLEY Recommend a map?
  140. OTHERS FP3 Map for Stage II 2017 Road Glide
  141. OTHERS Need plug wear identification help.
  142. TTS Mastertune 2018 updates
  143. TTS New Calibration
  144. DYNOJET Advance #'s
  145. OTHERS FP3 different menus for different bikes
  146. DYNOJET Dyno tuner in southern ohio
  147. DYNOJET Auto tune ?
  148. OTHERS FuelPak AutoTune Error FA-F04
  149. TTS tuning help please
  150. DYNOJET Why add fuel at 0% throttle position under 1k rpms?
  151. HARLEY Dyno cost
  152. DYNOJET Uninstalling power commander
  153. DYNOJET Power vision
  154. No Device Why not Xieds?
  155. DYNOJET For the tuner guru's
  156. OTHERS FP3 tuner
  157. HARLEY Need help fine tuning SEPST
  158. DYNOJET PV - new pipe, autotune existing tune or start from scratch?
  159. HARLEY pro street tuner
  160. HARLEY Timing Issues
  161. DYNOJET Need PC-V map 08 Touring, SE 103" kit, SE 255 cams, SE Air Breather
  162. TTS 2016 RGS Factory 103, 030 hg, Andrews 57, Supertrapp Supermeg, TTS, SE heavy breather
  163. No Device ThunderMax vs Screamin' Eagle Smart Tune PRO Automatic Tuning Module
  164. TTS Is this an intake leak (log enclosed)
  165. DYNOJET Power vision auto tune basic
  166. THUNDERMAX i ORDERED THE WRONG THUNDER MAX IS THERE A WAY TO MAKE THE ONE I ORDERED ON A DIFFERNT MODEL
  167. OTHERS Fuel mapping help!!
  168. HARLEY Pro Street and Pro Super Tuner 2018 model updates
  169. DYNOJET Email map?
  170. No Device Flash ecm cruise enable with se pro tuner
  171. HARLEY SEPST error code, what does it mean?
  172. DYNOJET Still having spark knock issues!!! KILLING ME!!!
  173. OTHERS FP3. What map for better highway miles on my 2017 street bob
  174. DYNOJET Dyno jet difference
  175. HARLEY Super Tuner Pro ERROR
  176. HARLEY Should install the Vance & Hines FP3 if I've only installed slip-ons
  177. DYNOJET new to this need tune help pcv
  178. DYNOJET Dyno Weather
  179. OTHERS Old fuel pack
  180. No Device Looking for dyno shop Near Upland or Rancho Cucamonga, CA
  181. No Device need some tuning advise
  182. HARLEY 2009 CVO Screaming Eagle Race Tuner
  183. OTHERS HD Dealer using FP3 to tune bike?
  184. OTHERS Fuelpak FP3 iPhone not Supported
  185. DYNOJET My attempt to dyno my sgs
  186. OTHERS FP3 - question about numbers
  187. OTHERS V&H FP3 Questions...
  188. HARLEY SEPST Red Cells after "Auto tune" run
  189. DYNOJET Power Vison easy way to see Calibration loaded in ECU
  190. HARLEY Street Tuner Web Course will not advance past 29 of XX
  191. TTS TTS Map Search!!! HELP!!!
  192. HARLEY SE Street Tuner
  193. DYNOJET Power Vision PV1 problems
  194. HARLEY Beginner tuner help
  195. HARLEY New exhaust tune help
  196. HARLEY SEPST VCI recording files
  197. DYNOJET AutoTune Make More Decel Popping...Possible?
  198. THUNDERMAX New member with Thundermax questions.
  199. OTHERS Fuelpak
  200. TTS Decel popping
  201. HARLEY SEPT Help
  202. DYNOJET Need pcv map
  203. TTS TTS & M8 Warranty
  204. No Device Dyno on a stock M8 114
  205. HARLEY Pro street tuner
  206. DYNOJET Help with 2006 Dyna Power Vision
  207. HARLEY 05 road glide ECU question
  208. OTHERS FP3 - Saved Auto Tune Sessions Q.
  209. DYNOJET Map for S&S 557?
  210. OTHERS Possible tuner issue
  211. DYNOJET Ignition Timing Pre-Tune
  212. DYNOJET pcIII remap advice
  213. HARLEY anyone still using SERT?
  214. DYNOJET Power Visions questions on a few things
  215. DYNOJET Power Vision firmware and tune DB update
  216. HARLEY Beginner Tuning
  217. HARLEY 2014 switchback vo2 install
  218. DYNOJET O2 Sensors for PV Target Tune
  219. THUNDERMAX 99 electra glide idle issue
  220. DYNOJET Canned map vs auto tune
  221. HARLEY Married ECM & Super Tuner Question
  222. HARLEY Vacuum Connection
  223. DYNOJET FM EFI tuner
  224. TTS Factory de-cat headpipe
  225. THUNDERMAX Tuning process for a new modification.
  226. TTS TTS Help Please
  227. DYNOJET Tuner says to leave it in open loop?
  228. DYNOJET PC v and adjusting tune
  229. HARLEY Can't Decide On MAPS To Use
  230. No Device Tuning help
  231. THUNDERMAX ThunderMax issues
  232. DYNOJET Adjusting idle with a PowerVision while running a PC V
  233. OTHERS Fp3 questions on readings
  234. DYNOJET Pv ?
  235. HARLEY SE Pro Super Tuner Update 10.003.0002
  236. DYNOJET Show me your PV timing map.
  237. OTHERS FP3 WAY too rich
  238. DYNOJET auto tune sessions
  239. No Device FP3 vs. PC5
  240. HARLEY SEPST MAP for 103 stage 4
  241. OTHERS FP3 Initial Map Suggestions
  242. OTHERS fp3 no vin
  243. DYNOJET Pv-2 deleted ECM
  244. HARLEY 2v3 wheel
  245. DYNOJET REALLY NEED a good start MAP for PCV decatted
  246. HARLEY Tuning with older SERT
  247. OTHERS FP3 Tuning ?'s
  248. OTHERS FP3 Won't stay connected to Bluetooth?
  249. HARLEY Do I need a Tuner ?
  250. DYNOJET Spark Knock issues
