- Evo shift shaft bushing/spacer
- Rivera Pro Clutch w TPP-Assist ??
- How much pull is normal
- Clutch Lever Adjustment
- 1981 fxs Low Rider CLUTCH Issues
- pinging
- 02 deuce stuck in neutral
- knocking and judder when pulling away GRRR
- Hair line crack in inner primary
- Transmission Sprocket Locking Tool
- Need help diagnosing a zzzick noise
- Motor knocking on my 2005 88ci
- Baker 6 spd? Or have i been missguided?
- Baker 6 spd a good idea? Or am i being missguided?
- Compensator Issue I think
- will shift through gears but won't go?????
- Clutch
- Clutch Engagement Position Question?
- Installing new clucth cable
- Limp shift lever in first gear
- 1980 Rotary top transmission arm adjustment
- Clutch slip
- Excesive Primary noise
- Clutch adjustment need help
- Screamin’ Eagle® Cam Chain Tensioner and High-Flow Oil Pump Upgrade Kit
- Pressing out mainshaft bearing question
- Downshifting my 1994 FLHTCU
- Primo Brute 3 vs. Stock Clutch
- Amsoil redline gear oil 2007
- Fluid change advice?
- Loud clatter
- Having trouble getting spacer off mainshaft
- Need some advice
- leaking clutch cable
- Clunk!!!
- 6 speed Issues
- 2003 ultra shift linkage
- Spectro Platinum 6 Speed
- 2008 xl1200 transmission problem
- 1980 fxwg clutch hub bearing
- Mobil One 75W 90 Gear Oil
- Primary belt replacement
- Clutch Won't Engage
- lifters on a 88" bumped upto a 98"
- 84 FLHT enclosed chain shop manual info
- Help please 04 fatboy clutch problem
- Iron 883 Clutch Problem
- Major or minor issue?
- 2007 1200 sportster clutch adjustment
- help with clutch hub installation
- Redline Shockproof........
- 4 speed not shifting
- Turbo noise when turning
- question about transmission
- FLH primary and trans
- Hard to down Shift out of 6th and into 1st
- da*n clutch cable broke.. length of cable and a quick fix
- Need to remove rear wheel?
- Trans lag noise
- 27t comp sprocket
- Help me diagnose this engine noise please
- Clutch interlock switch
- Adjustment screw not 'seating'
- Derby cover O ring
- Process of changing out the clutch to a rivera old fluid cleanout?
- Starter problems
- Reverse gear
- Changing pully on tranny
- 2000 flh
- 2006 Electra Glide Classic Primary drain plug seal
- Downshifting Issues, New Owner, Same Problem
- Clutch cable won't pull
- inner primary
- 91 flhs clutch cable
- 1986 Softale Belt replacement
- quick clutch advice
- 1976 Ironhead Transmission problem
- 'Screech' sound - drive belt?
- noise in 1st gear, intermitten
- Overfilled Transmission
- Weird Clutch issue - readjusted itself
- 85 fxr trans oil leak---HELP
- hard to pull clutch lever
- 2011 RoadKing won't Roll in Neutral
- 57 panhead kicker problems
- 2011 Fatboy Lo Transmission Dipstick Bolt
- Automatic Primary Chain Tensioner
- alligning rear tire
- off balance clutch
- 2012 Ultra Limited Compensator Sprocket
- Transmission squealling Noise
- Differences in 06 and 07 Softail Primary (looking at belt drive)
- Tranny/Primary Rattle
- Changed clutch cable now have problems
- Belt is chirping/whinning on decel?
- Primary Scrapping Sound
- gas coming out of the air filter
- Shifting problem
- Primary/Transmission Bearing Questions...
- Inner primary numbers
- BDL - Can't Remove Inside Bearing
- Clutch adjustment... no resistance at hand lever
- Shifting into second gear trouble
- 2011 Ultra shift lever from tranny question.
- Noob clutch grinding noise
- Transmission case removal 1999 ultra
- Extra part found in primary case
- Shovel won't select 4th gear
- Clutch troubleshooting checklist?
- need help bike wont start
- Questions About RPMs
- Open belt primary on a 1980 FLT
- primary hole
- Need Tranny Sprocket
- compensator or m6??
- SE Compensator ... Pre-'07 models ...?
- Slapping in primary
- 1st gear is LOUD - why?
- Have to gun throttle to shift transmission
- 01 Deuce Clutch adjustment
- Transmission problems (I think)
- Special tool needed to remove derby cover??
- Screws for tensioner anchor size and loctite?
- Shifting Problems
- HELP - Final Drive Belt Issue
- "Clacking" Noise
- Clutch/neutral question
- problem with 1986 sporty clutch
- oil problem
- compensator part #
- Clarification on primary chain adjustment
- 1997 Fatboy primary
- Friction zone, sticky clutch
- 85 fxwg trans
- Whining sound in 5th gear
- Electra Glide reverse gear
- Torque specs inside primary 07 FLHTC
- 1989 tapered shaft
- Bike is sick - Kinda freaking out
- cluch not disengaging
- transmission main shaft oil leak.
- Trouble finding N
- Change a broken sprocket in primary?
- 5 into 4 case revtech sprocket
- vibration under acceleration
- Stock gear ratios and rpms?
- 82 sportster
- Anyone else use the Burly "Lite Clutch"?
- Drive belt life
- Outer Primary Fitment, 93 and 94
- 3rd gear Issues in 6 speed
- transmission sprocket mystery? sprocket wearing into side of case?
- What fits what???
- choosing a good drivetrain.
- Bike lunge when starting
- Shifting problem
- busted comp nut
- mobil 1 in all three holes
- Drive beltsize for 01 nightrain
- Help with getting my starter together
- Clutch squealling
- Screamin Eagle clutch spring nut backed off!
- Starter pinion ignorance... help
- Primary cracking
- Tach to Speedo accuracy
- 99 harley
- Inner Primary and Race possible leaking
- Down Shifting: Good or Bad?
- Replacing Primary Belt. Help!
- Squishy clutch
- Bobber Clutch
- Dipstick 1 tony 0
- 1997 Road King leak
- clanging sound from primary
- Help IDS
- 99 harley fxr clutch fork wont engage higher than 2nd
- 2 weeks at HD - too long?
- Blown inner clutch hud splines!!
- 82 Sturgis!
- Rollin in the Canyons
- Whirring in neutral
- clutch problem??
- primary case pinging noise
- Primary Case Clatter (chain adjusted)
- Night Train Primary Case noise
- How to check primary on 2008 Softail
- hp racing trans oil in primary?
- 2005 sportster sl883 shifter seal replacement
- Aftermarket forward controls
- Clutch Cable/ Lever
- 04 sportster custom clutch problem
- 2008 Ultra trans bearing and now compensator
- Clutch Noise and adjustment Question.
- Inner Primary bearing change ?
- Transmission top cover removal...bolt super stiff! Help!
- very hard shifting!...help!
- 86 EVO Clutch Install
- auto clutch
- AMP Power Clutch removal
- Inner Primary Seal Leaking again...
- HP VS Transmission life.
- 1990 FLST oil leak
- Leak @shift rod seal
- Routing Clutch Cable?
- 2007 FXD Bad Steel Plates in the Clutch
- Compensator Sprocket
- Primary Oil Amount Mystery?
- shovelhead transmission
- Will I took it apart
- Reminder check that clutch!
- 99 evo starter recomendations
- converting BDL auto clutch to fit Primo
- Starter bendix
- Whining 5th gear
- Whiny final drive belt on deceleration
- KNOCK KNOCK in the drive train.
- When to replace a drive chain
- 05 Softail Primary CADD File?
- hydraulic clutch
- 03 883 primary oil
- Starter kicks in, will not turn engine, but there's more.
- Clutch cable loose after changing stator
- Slipping question--what did I do?
- Have primary off...and a couple questions
- rear dirve belt pully chewed up
- Panther Drive Belt vs. Standard HD Belt
- Clutch Switch - FIX
- Pushrod/throw out bearing question
- Primary Chain Tensioner worn ... what to do?
- leaking tranny fluid!
- Outter Primary Part Number Question ...
- Need Help on a Clutch issue
- no problem / simple fix / HELL NO!
- Primary Change
- 1972 Shortster shifting
- Gear Shifting Problem
- Clutch noise coming out of 1st gear
- compensator question
- 77 fxs speedo options
- Learning the hard way about my first Harley Sportser
- Hot to remove chaincase of the primary
- primary condition
- 4 speed tran fx
- Primary Fluid Level Pic
- clutch lever
