View Full Version : Wheels/Tires
Pages :
13]
14
15
16
17
18
19
20
21
22
- pirelli tires
- 14 wheels on a 13
- parts swap
- softail wheel change 05 to 09
- 2012 Fatboy front brake problem
- Are 2008 and older RK wheels compatible with 2009 and newer RK
- 19.50" wheel, how wide a tire can I go
- Tire decision
- Burly Bagger bar install question
- Biggest rear tire on 12 FLHX
- Wrong Wheel-Spoke Metals Dangerous?
- Front end buzz after brake and tire replacement
- wheel spacers ?
- Wheel Fitment
- diff between 43626-96 & 43499-96? 19" 13 spoke black rim
- Michelin Commander II's or Pirelli Night Dragon's?
- New Wheels
- Bigger tyres on a Slim ??
- help with putting a tube in my dna rear wheel
- Pulley Issues
- Time for a new rear tire for the Ultra
- Let's talk tire repair kits.
- best wheel bearing for 2010 wideglide
- School me on steel belted tires.
- Roadglide rear wheel problems
- Lighter wheels - 2009 FLHTC
- Brake pad fell out.
- Hot Rear Brake Rotor
- whiningtype noise 40-45 mph
- wheel/tire advice
- Single Brembo Master Cylinder??
- Now I'm screwed
- wheel explodes at highway speeds please read
- Stock HD tire vs American Elite ?
- Help I.D My Wheels??
- front brake problem
- need some help
- need help fast
- Rotor, caliper alignment brake pressure issue
- Wheel/Rim tape
- need new tires, new to area-SoCal
- Tire Tread Depth
- Avon Cobra AV72 250/40VR18 on Rocker
- fork reflector removal disastor
- trying to decide on front wheel and tire size
- Losing rear brake pressure? Ideas? Help?
- New tires on my bike, what have I done?!
- Tire question for you Wide Glide owners ...
- Can I get these 2013 street bob wheels on my 2007???
- Brake lever 2006 street glide
- Biggest front tire w/ stock Street Glide fender????
- i want to put fatboy rims on a 1980 FLH can it be done?
- ? about 2013 super glide custom
- New bike, front brakes rubbing.
- Need some wheel help on a 09 deluxe
- 40 spoke rear wheel offset
- rear wheel on front 2012 fxdc
- Rim/tire fitment
- Changing Tires with Windex and Zip Ties ?
- Is there a good Metzler dealer in the Sedona Arizona area?
- The single best mod I have made to any bike ever.........
- Softail Slim Tubeless
- Front brake noise is killing me!!!!
- Using Flush Mount Axle for 18" SG Wheel upgrade on 06 SG. Recommended/Safe/OK?
- ABS Free Float Rotors?
- Rear brake losing pressure
- Can I swap an old style ABS for a newer style?
- 2013 Fat Bob Noises
- School me on spokes
- Tire Gauge
- Metzler 120/70-21 68H or Avon 120/70-21 62V
- installed wider tires and handles differently!
- Help wanted 2005 deuce fxstdi
- bigger front tire
- Caliber cross thread
- rear brake light switch
- 180mm rear tire on 08-older touring?
- looking for a 40 spoke wheel
- 03 softail standard to 16" front wheel
- 2010 wide glide rear tire?
- solid rear wheel for 98 ultra classic
- Front Master Cylinder ? - 91 FXR
- Amerian Elite
- What wheels are these?
- Brake swap ?'s
- ME888's woooooooo!
- FXST front wheel switch
- Origional tire size
- Brake rotor rubbing after 21" install
- '13 Street Glide wheel on '07 Road King
- 2003 wide glide wheel fitment
- where can I buy an ABS computer for my 07 Road King Police nissin ABS?
- 21" front tire help
- 2012 Utra Classic Wheel Change
- Deer collision and now no front brakes
- Front wheel options for a 94 Electra Glide
- Will OEM Rocker front wheel fit 2006 Fat boy?
- Front end Shake
- Michelin Commander II - $303
- spokes to mag switch
- rear break
- 2001 Electra Glide, Dunlop E3 Tire Size
- Performance Machines rims
- I fixed my sloppy dual caliper brake lever on Fat Bob
- Will 02 Fatboy Rear Wheel fit on 04 Heritage Classic
- Rear Brake Pads
- tire size
- Brake Bleed Tip
- 21x3.25 rim question
- Knuckle wheel install on an electra glide police
- wheeels HELP!
- Slow leak/ Flat Tire
- Widest tire on 21" rim
- rotor warp
- 21" front wheel conversion
- Tube on cast wheel
- Help me identify this master cylinder
- 2012 iron 883 rim and tire
- Dynabeads and Hauling Trailers
- Line lock on rear brake with Jockey shift
- What Rear Wheel do I choose?
- rear brake pulsating 2009 street glide
- Z pad problem?
- What Pads ?
- Spacer question
- ME880 time
- switchback / heritage wheel swap?
- inner tube size
- Need new rear tire for my SB.
- 04 spokes to 03 12 spoke mags wheel bearing question
- 130/80-17 front tire for '11 fat boy
- Need some help from the pros please
- Cast wheel bearing spacers
- Rim Swap
- What kinda miles you getting from Michelin Scorchers?
- Rear Rim "Dechroming/Discolor"
- Retro tires to suit 21 and 18" wheels
- Street glide rims
- pad slap
- lower profile tires
- Need help selecting new tires
- Front brake pad change on 06 Dyna
- Biggest tire on rear of 07 FLHX
- Troubleshooting Front Wheel Drag
- Rear WideGlide Brake
- first brake pad change
- Air leak around base of valve stem
- 2008 Road King - 'new' front wheel from older FL - axle vs bearing question(s)
- 94 Flhr front bearing 1" down to 3/4"?
- Trike Front Tire
- Has Anybody Tried The Zip Tie Tire Mounting Method?
- difference of tire sizws
- Tires
- 06 SG Rear Wheel
- can any brake rotor be used on ABS bike ?
- Is mixing tire brands OK?
- LUNASEE, side lighting strips...
- FXSTC front rim. Offset or centered?
- Softail front brakes
- 4 speed starter gear removal
- axle diameter
- Fang Custom Wheel part
- Need Input-Radials on spoked wheels
- Touring wheels on fatboy?
- Dunlop D402
- how to get the most mileage out of your tires
- Dyna Beads Cons?
- Rear brake rotor bolts 06 sportster
- Aftermarket wheel companies
- Wide White Wall for a 21x3.5??
- Wheel dimensions
- Brembo Upgrade ??
- sealed bearing or non sealed interchange
- Did the brake line go to ground?
- tire info
- Wheel spacer question
- Tires less than yr old, cracking around bead - anything that I can do?
- Need help finding correct 3.5 bolt space caliper for Showa
- Strange rear wheel noise
- Brake lines
- performance machine rear brakes for 85 wideglide???
- Pretty significant wobble in my tires.
- Front wheel for soft tail slim fls
- Changing 1" bearings to 25mm
- wheel size ?
- Tire traction issue.
- Are all 18x5.5 wheels created equal?
- Diameter of spokes
- New Tires - Braked Hard during first ride - Advice?
- Speedo Drive Repair
- Chrome Calipers-Cost to Install/Add Parts??
- 2013 street glide dual disc to single with ABS
- Shimming a front brake caliper
- brake fluid please help
- Brakes
- How often do axles require grease?
- 2010 street glide wheel on a 1997 electra???
- What is widest rear tire I can put on stock road king rim ?
- 2007 Ultra Classic Wheel Swap
- Tire diameter calculator
- Metzeler Tire Mounting and Red Dot
- Help
- Help
- Chrome Brake Caliper Questions
- Tires
- forty eight front wheel in an 883 iron
- Bled brakes, dual rotors, lever engages later, would you leave it alone?
- Hey new to the forum and had a question about my brakes grabbing=)
- in need of some major knowledge
- New rear tire...
- which side id the drive belt side fat boy rim
- Brake fluid coming from wrong place
- Anyone have a new diamondback 120/70-21 WW?
- Wheel question???
- Torque specs for a 2008 cvo springer front axle
- Switching to 18" front wheel....issues?
- Bent front Rotor and can't idenitify wheel
- 1993 FLHTC New rear tire
- 2000 Electra wheel replacement
- Tire Repair in Chicago???
- Electra Glide back tire Question
- How long would you run these tires?
- Softail spokes on my 06 FLHT
- 23" front/18" rear on Night Train
- 2010 Touring Front brake reservoir gasket
- Avon Venom w/dry rot in treads-Warranty?
- Anyone running the new Metzler ME888
- Rear Caliper piston seal. I may have blown it!
- Quality Wheels and Tires
- Pre 99 Wheels on a 2000+?
- Coastal Moto hooked me up at Daytona
- Truing stand recommendations?
- Problem with spokes. Help needed!
- 2011 Wide Glide wheels to 1" bearings.
- What are you paying for tires
- Rear Brake Lever Bushing Installation
- Wheel Manufacturer
- 21 inch spoke wheel bent?
- Metzler Me 888 just put on
- front tire on the rear?
- pirelli dragon
- michelin commander 2 vs. avon cobra
- michelin commander II
- Fat spoke wheels on a Sportster?
- wheel plating
- Front Brakes Locking up!!!!!!!
- Removing back tire Ultra Classic
- Polishing Rim Lips
- swapping rim sizes ???
