PDA
View Full Version : Wheels/Tires
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. what are you using for a rear tire especially on the glides.
  2. Widest Tire/Rim combo without other mods on 2021 Street Bob FXBBS?
  3. Rear Caliper Bracket Alignment
  4. 2018 ultra classic wheels on 2011 ultra limited?
  5. Possible faulty new AE tire
  6. balancing beads not balancing
  7. Tires based on cost
  8. Dunlop AE question
  9. 6 spoke slotted HD wheel 17x4.5
  10. Wheel size change
  11. Using Aftermarket TPMS Sensors on a Harley?
  12. Axle Conversion for 3/4"
  13. Rocker rear tire
  14. Another Tire Question
  15. Wide Tire?
  16. Unknown wheels - will they fit 1999 1200 sportster?
  17. Corrosion in bead area of aluminum mag wheel-tire not sealing
  18. wheel weight and balance question
  19. Battlecruise H50?
  20. rear brakes 2014 dyna low rider
  21. FatBob 114 Dunlops FULL Failure Rear Tire
  22. Dunlop AE Radial?
  23. Substitute a tire size
  24. balancing debate
  25. Narrow front wheel size for bike with 16 inch rear rim and 5 inch tire
  26. 2001 Softail Rims
  27. Kinda weird tread wear pattern........
  28. Ultima wheel question
  29. New front tire today
  30. Changing wheels from 2.15" to 3.5" on Wide Glide
  31. Non abs side bearing on an abs bike
  32. Fresh Dunlops
  33. New rear tire at 5K miles, REALLY ?
  34. Anyone ID These Wheels?
  35. Colby Valve - Emergency Valve Stem Replacement
  36. need help out ! sportser wheel and tire with question seems silly.
  37. Tube with 21" DNA
  38. Solid wheels...?
  39. Tread splice defect or road hazard?
  40. Axle and torque
  41. Wheel Balance and Wheel Balancer Review
  42. D402 www front and D401 www rear for Road king flhrc 2008
  43. Different tire heights
  44. 94 Fatboy wheel spacer
  45. Help with front wheel spacers!!
  46. Another Enforcer Conversion Issue
  47. Rear wheel spacers
  48. Dunlop ae
  49. Swapping Brake Rotors Compatability Question
  50. Switch back wheels?
  51. Sportster Tires for a Heavy Rider
  52. HD Dunlop's from France now?!
  53. New tire manufactured date
  54. New tires recommendations
  55. Broken rotor bolt
  56. Chrome rims?
  57. HF Tire balancing stand question
  58. Tire sizes
  59. Rear Tire Size Question on '96 EG Ultra - Educate me please
  60. Tire type/size Questions - 96 EG Ultra
  61. Rear wheel bearings failure again
  62. Delete
  63. 2000 Road King Rear Wheel Replacement
  64. 19" HD Prodigy wheels on 2020 FXLRS
  65. Wheel bearing conversion
  66. ABS wheel bearings for lager wheels, 21"+
  67. Wheel bearings 1996 Springer
  68. Dunlop American Elite
  69. 80/90 Vs MH90 difference?
  70. All Balls wheel bearings
  71. Tire size
  72. Bias or radial ?
  73. Arlen Ness Y-Forge wheels for Low Rider S
  74. 07 streetbob 18x5.5 wheel fitment
  75. “Sportiest” Bagger Tires
  76. 16 inch wheel re-lacing - are all the spokes the same?
  77. Road King Classic Tire Choice
  78. Got my No Mar tire changer
  79. Night Train Rear Wheel Question
  80. FXR Wheels
  81. Fat Boy 30th Anniversary Wheels
  82. Taller Front Tire for 2018 FLHTXS
  83. Flat tire
  84. Help identifying this wheel and what it's worth
  85. Get a load of this.
  86. thunderstar rim on 2007 heritage softail
  87. Anyone tried this tire?
  88. Thoughts on Avon Cobras
  89. Wheel Fitment
  90. Front fat boy wheel
  91. Attitude Inc Wheel
  92. Need help on rim model.
  93. XR750 19" 40 hole lacing
  94. Set of tires for high torque
  95. What 90° valve stems for 2015 Ultra?
  96. Michelin Comm 2 Rear Tire Issues
  97. 2020 road king front wheel firmest question
  98. 21" x 3.25" on 2014 Road King
  99. Need help figuring out what spacer and wheel bearings I need (dual disk wideglide front wheel)
  100. Radial lacing experience?
  101. Latest Shinko experience
  102. 2008 Night Train Front Wheel
  103. Rear wheel
  104. DIY Tire Changer - Shop/Home Built: Motorcycle, Automobile and ?
  105. Tires finally availabe
  106. Bridgestone Battlecruise tires anyone using on baggers?
  107. Nail.....Superficial?
  108. Radials front and rear
  109. Right angle valve stems
  110. 2015 Road King; bigger tires; little modification
  111. Michelin Scorcher 31 Alternative
  112. Wheel question?
  113. Getting to be time to add winter air.
  114. 08 front spoke L vs R
  115. Wide Laced Wheel
  116. Tire size
  117. 2012 Road King Classic wheel change.
  118. Performance Machine Rotors on Stock Wheels
  119. Do Dunlop tires run flat?
  120. Tire Cupping
  121. Balance with Bearings?
  122. rear wheel alignment question
  123. 2007 Dyna, 8000 miles, change wheel bearings?
  124. Gritty Front Wheel Bearing
  125. Sykik tpms
  126. Wheels swaps for 1975 Super Glide
  127. Tyre options
  128. Question on spokes
  129. Trick-or-Treat with the Metzeler Orangewall Tires
  130. Help me understand tire numbers
  131. Aftermarket wheel off a 09 Electra on a 17 SG???
  132. whats needed to install Enforcer wheels on 2010 ultra
  133. Anyone changed tires on a 2020 touring bike with RDRS (and TPMS)?
  134. Help with softail front wheel
  135. Cordless or 12V air compressor
  136. Dunlop OEM vs Avon Cobra Chromes
  137. 21" wheel upgrade
  138. Low Rider S
  139. Is this normal?
  140. Wheel Chock for trailer
  141. Tyre Shortage
  142. Dunlops...
  143. Contrast cut wheels faded
  144. 2008 rear laced wheel bearings
  145. This can't be normal, can it? 😞
  146. Can I get 600 or so miles out of this?
  147. Balancing bead questions
  148. Rusty chrome wheels suggestion?
  149. FOBO Bike 2 on 2019 FXLR
  150. Question
  151. Need help identifying Aluminum front wheel
  152. What size tube for 120/70-21?
  153. 2005 Roadking front & rear hub sizes
  154. 2005 Roadking front & rear hub sizes
  155. Continental Conti Tour Tire Review
  156. Star hub to disc rotor adapter
  157. Vibration after new tire and wheel bearing
  158. Fix a flat / Slime / Ride-On / STP / FlatOut...etc
  159. Low profile rear tire
  160. 10K Service - Need Rear Wheel Bearings?
  161. Can't find a Dunlop AE front tire, 130/80B-17
  162. New front tire tread depth
  163. 2012 Superlow rear wheel on 2016 Iron 883
  164. Larger front wheel on an ultra
  165. Michelin Commander 3s vs. Dunlop American Elite…from misery to nirvana
  166. Amazon new tire 5 years old
  167. Anyone using nitrogen in their tires?
  168. Odd tire size question…
  169. FXFBS -- New Tires Mount/Dismount Method -- Bridgestone Exedra MAX
  170. PM rims install on 08 Fatboy
  171. newer wheels on older (1995) softail
  172. 19" chrome/texture split six
  173. Valve stems are horrible
  174. 09 street glide, a lot of issues and questions..pls help.
  175. Iron 883 Wheels on 04 Sportster
  176. Balance beads valve cores
  177. Bearings
  178. Tire miles per 32"
  179. Tires to replace cupped/scalloped Metzelers on Road King
  180. Load ratings
  181. Need Tire Suggestions
  182. Date codes?
  183. Tire change from AE
  184. New 16in rear tire on 2020 roadking
  185. Stock tires 2014 Ultra
  186. Front bearings help
  187. Options for dealing with a punctured tube while on a trip?
  188. what can I do to remove the corrosion on my wheels?
  189. Wheel Painting?
  190. Tube in a mag wheel?
  191. Tube with a 90 stem
  192. How many miles on a Metzler M888?
  193. Tpms?
  194. commander II
  195. Rabaconda Tire Changer
  196. Ride on tire sealant
  197. Snapped off all 5 bolts rear pulley
  198. Tire help 99 sporty
  199. What tube can I use on DNA mammoth wheels?
  200. Rebalanced tire
  201. New 21 inch front tire issue
  202. Deuce rim on 99fatboy?
  203. Bye bye Michelin “Shit” Commander 3
  204. Commander 2's or Commander 3' for 2000 Road King
  205. FLT Mag Wheel on Wide Glide
  206. Newb question
  207. Dunlop cracks
  208. looking into a lower profile rear tire need some input please
  209. Avon Tire Wear
  210. Speedo gear won't sit flush on front wheel after tire change
  211. Tube required?
  212. 06 Fatboy help/ advise
  213. 2016 Lowrider Mags on 2015 Streetbob
  214. Rotor rubbing caliper
  215. 16" fat bob front wheel
  216. 90 Degree Valve Stems
  217. Deuce rear wheel on Dyna
  218. Tire cupping
  219. difference between dunlop am elites and oem
  220. Tire Pressure
  221. Dunlop Elite rear tire Cracks
  222. tires
  223. Is this wheel usable?
  224. Michelin Commander 3 Satisfaction Survey
  225. FOBO TPMS forcing a reading
  226. Wide tires
  227. PSA: Don't buy new tires and new brake pads on the same service interval
  228. OE Dunlops “roaring” in curves on 2020 SG.
  229. Oem Dunlops
  230. Dunlop American Elite 180 on the front.
  231. Tubeless wheels on a 2017 Heritage SoftailClassic
  232. 06 dyna switchblade wheel on an 08 street bob
  233. 2001 EG installing 19" 2016 street glide front wheel
  234. More than you care to know about “cupping”
  235. Not having good luck with tires...
  236. street bob wheels on a fat bob
  237. Oversized Rear Wheel Bearing?
  238. non matching tire tread
  239. Huh? ... "Come again?" :)
  240. Tire upgrade good idea or no ?
  241. 2017 Street Glide Project
  242. Clarification wheel 43402-00B
  243. Harley tire warranty question
  244. Broken Spoke!
  245. Fatboy solid disc wheel on a Blackline
  246. street boy
  247. 21x3 or 21x3.5 on my heritage????
  248. 2007 heritage 21" question
  249. Do sealed wheel bearings go bad from sitting?
  250. Chrome peeling off of wheels
