PDA
View Full Version : Wheels/Tires
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Metzler 888
  2. Sportster 1200C 21" Front to 19" - Questions
  3. Acceptable date codes on new tires.
  4. Using anti-seize on front axle re-install
  5. Front wheel spacer question
  6. Anyone ever use bearing reducers?
  7. street glide wheels on heritage softail
  8. wheel question
  9. ** hdf LINK to Good Info (imo) ** - Installing 21mm wide bearings into wheels designed for 15mm
  10. Thunder Star tire size
  11. 21" fat spoke install on ABS bike
  12. Comparable tire sizes
  13. Help Needed for '03 FXSTDSE Wheel Replacement
  14. Breakout Rim Help Please...
  15. Another Tire Thread :(
  16. 21 dna 52 spoke on road king
  17. Looking for different wheels/tires
  18. Wheel fitment question
  19. 1997 road King wheel bearings
  20. Avon Cobra or Dunlop D402?
  21. Vee Rubber JUNK - Tread separation under 2,000 miles
  22. Front wheel clunk.
  23. Wheel swap fitment?
  24. Wheel swap
  25. FOBO TPMS. A good company
  26. 200 rear tire
  27. Need helping matching a rim.
  28. Tire pressures for 21" and 17" tires?
  29. Ride On Tire Sealent?
  30. Dual compound tires other mfg ?
  31. Dunlop Elite 4 Tire
  32. Dunlop GT502 tire treadwear and replacement recommendations
  33. Tires - Bias Play vs. Radial....can we use either?
  34. No weights on wheels from factory
  35. Firestone ANS tires for 2000 softail?
  36. Need help with wheel sizing and install please
  37. 21" wheel
  38. FLHRCI tire recommendations
  39. Milage
  40. Softail to Sportster.
  41. Help finding Rear Hub for Revtech wheel!
  42. Recommended Online Wheel Dealers
  43. Mixing radials and bias
  44. Commander II's for Fat Bob
  45. Michelin Commanders
  46. 21x3.5 tire size question
  47. Help..What's the widest I can go on rear tire?
  48. screwed up 21" to 16" hub
  49. 21" wheel install
  50. 200 on a 5.5 or 6 Inch Rim?
  51. New Tires for '16 Breakout
  52. wheel upgrade ?
  53. Rim advice
  54. Help!...Rear wheel install on a 2011 Dyna Wide glide
  55. Emergency tire repair
  56. Street bob wheels
  57. 2015 cvo replica wheels in 21+
  58. Avon Road hazard
  59. How do I put a 21" or 23" laced wheel on 07 Super Glide
  60. Dunlop D402F vs. D402
  61. 23" front on a '93 FXLR custom??
  62. Tire advise needed
  63. 07 street glide wanting to install 17" wheel swap
  64. tires on and bike feels like its slipping
  65. Harley Turbine wheel
  66. Air strikes on older Ultra
  67. wildpig1 1995 flstn
  68. Running mismatched (but same technology) tires
  69. Tube question
  70. Check this out
  71. Spoke Thread Pitch
  72. tire mounted backwards
  73. Great tire deal
  74. 2013 Road Glide rear wheel fitment to a Fat Boy Wheel
  75. Dyno eats Cobra
  76. Enforcers on 2013 RG
  77. Sportster wheel question
  78. Dyna wheel interchange
  79. Fatter rear tire on an 07 super glide
  80. Spoke Rim Manufacturers, Is it a deal breaker?
  81. 1998 Road King Wheels
  82. Do I Need A New Hub?
  83. wheel swap
  84. rear tire too close to belt guard?
  85. 2005 softail deuce
  86. Replacing with wider wheel "PROBLEM"
  87. 2012 Road Glide 21" single rotor
  88. 21 inch spoked wheel with coker tire?
  89. Tube with New Tires
  90. Cleaning spoked rims?
  91. 2015 Street Glide wheels on 08 ultra
  92. 1999 ST help
  93. Who makes a cheap 5/6 spoke wheel for an 06 WG?
  94. Softail Slim Chain Drive Conversion.
  95. HD spoke wheels on my SB
  96. Wheel Bearing install
  97. 1988 softail help
  98. What fatboy rim fit on back 02 dyna?
  99. Front end wobble..dyna beads?
  100. Wheel swap & brake calipers
  101. Rear Tire Change - Which Jack?
  102. Front rim done...
  103. WEIGHTS of Wheels / Tires (and Assys) for 2000-Later Touring Front Wheels
  104. Axle adjusters
  105. Rear tire for 01' Fatboy with wide tire kit?
  106. wheel size limit for stock forks
  107. 1977 FXE Superglide front tire size
  108. Cush drive hub question
  109. Using Front tire on Rear wheel
  110. Looking to buy billet wheel and tire set for 07 RG
  111. Bearings 99 fxdx
  112. Tire Sizes for 19 front and 18 rear Agitator Rims on a 2013 FLHTCU
  113. Rear Hub Measurement Help
  114. 52 Fat Spoke 21" chrome
  115. Tire/Wheel Fitment Question
  116. Front Wheel Bearing Orientation
  117. 95 softaild
  118. RC Components Czar Eclipse vs Torison Eclipse wheels... Which one ya got??
  119. new looking old tire
  120. tire-fender clearance
  121. Enforcer Wheel / Metzler Tire
  122. Best deal on tires?
  123. Another wheel question..
  124. Brake disc
  125. Who makes this wheel?
  126. 09 touring rear tire to a 200
  127. 21 Inch Impact on Warranty
  128. Sanity check...
  129. Newer 13 spoke wheels on an FXR - what should I know
  130. 21" pre-2000 offset
  131. Wheel Repair shop recommendation needed
  132. Road King rear spacer ? Help a gal out would ya??
  133. Fat Boy tire pressure
  134. 21" wheel on fatbob
  135. Dumb Springer wheel question
  136. Dyna Axle - Cotter or Spring Clip
  137. Wire to cast on a '08 Ultra
  138. lacing new rims... spoke question
  139. tubeless mags for RH classic
  140. spoked wheel questions
  141. Fat Spoke Wheels
  142. Any experience with refurbished wheels?
  143. Question about sleeve between bearings
  144. 200 ore 240?
  145. Help, need tire size for Heritage
  146. 03 Electra Glide Drive Belt
  147. Fat Front Tire
  148. touring front wheel
  149. 2014 wheels on a 2013
  150. 150/80B16 on a late '90s softail?
  151. Knuckle spoke rims in chrome
  152. 2013 ultra 28 Spoke wheel will they fit 2014 StreetGlide
  153. 28 spoke cast aluminum wheels/rims off 2013 Touring ultra classic will they fit
  154. Southern MC chrome jackpot wheels
  155. Custom wheels with composite rotors for dynas?
  156. Switching from single rotor to double rotor
  157. Asymetrical wheel hub
  158. Rocker C Wheel Setup Help
  159. Rear wheel bearings for thirteen spoke mag
  160. 16 RGU with 18" or 19" front Tire
  161. Non ABS to ABS wheel change
  162. 21 x 2.15 and 21 x 3.5
  163. 1995 super glide
  164. 21" wheel Question
  165. What are my options? HD vs PM vs RSD?
  166. Touring tire Q's
  167. Fat spokes for a springer
  168. Road King Classic forged wheels?
  169. buying tires for my new wheels but there is contaversy
  170. 2015 Street Bob Wheels
  171. Is a bizzarely-positioned nail in a tire, that did not cause a leak, still a problem?
  172. 18" wide inner tube with offset stem???
  173. Which set up do you think is better??
  174. 21" Thunderstar front wheel fitment on a stock heritage
  175. Stock Rotors for Anarchy Wheels??
  176. Pirelli route 66 tire
  177. 2009 FLHX tires
  178. Ride Wright Spokes
  179. 180/55R17 on 4.5" rim
  180. Metzeler 888 Tire Pressure - per Metzeler
  181. need help removing my front tire
  182. 21" front wheel
  183. What tires are these?
  184. Long life touring tire?
  185. Older front wheel fit on 15 RG?
  186. Rear tire blowout
  187. White Wall Advice
  188. Widest rear tire on a '10 FXD?
  189. 200reartire on 98' dyna sg
  190. converting 03 mags to fit 14 streetbob
  191. Wide Glide hub between Mid-Glide forks
  192. 180/70 and 180/65 ??
  193. Benefits of 18x4.25 over 18x3.5?
  194. Tire size for 18x3.5 Wheel
  195. Shinko 777's 21" WWW (120/70/21)
  196. How to ID stock spoke wheels?
  197. 401 and 402s
  198. Bad rear wheel bearings due to highway miles
  199. Choosing Rim Strip Size?
  200. Different axle size on rear of WG and FXDC
  201. '15 WG rear wheel on '07 SB
  202. Just purchased 08 Super Glide
  203. 03 Fatboy Rear Wheel on 04 Electra Glide?
  204. 2015 SG wheels on 2005 RK
  205. FXR Cable Speedometer with a 00 newer FXD front end
  206. Nitrogen fill
  207. Street glide rear on street bob?
  208. Sportster 48 wheel hub cover ???
  209. 16 rear wheel on a 180 tire for Street Bob?
  210. Bigger rim on 2010 street glide.
  211. OK, these Harley stamped Dunlops suck
  212. Switch to Cast Wheel
  213. 21" wheel 98 Road King.
  214. 1997 FLHTC Options
  215. Going to use an oder rim - where to get offset valved tubes
  216. Wtf, over??! Front wheel spacer sleeve huh??
  217. wide swingarm on Deuce
  218. DNA Wheels from KCInternational
  219. Tire Change Machine
  220. 14 SGS with ABS single brake?
  221. 2007 FXDB Street Bob
  222. Am I using the wrong size tire?
  223. Max Front wheel size
  224. 2007 ultra classic wheel swap
  225. unusual front tire wear
  226. wheel alignmant
  227. Pirelli Night Dragons
  228. Installed wheel bearings and the bearings don't rotate
  229. 87 flhtc wheel upgrade
  230. Advice: Am I worrying about nothing? Tire crack...
  231. 1989 Ultra Classic (FLHTCU) Wheel Axle Size?
  232. Help with wheel identification
  233. Nightster front brake caliper help
  234. 150 on an '89 FLHS ???
  235. new tires.. old question
  236. dunlop 402/wide glide size question?
  237. Who makes a Smooth / Solid rear wheel
  238. front wheel bearing problem
  239. wheels
  240. Rear Fatboy Solid wheel on Blackline...
  241. Rear wheel has a tight spot in the belt in neutral
  242. softail rear wheel spacers
  243. Ultra 28 knuckle wheel any value?
  244. "Ride On" internal wheel balancing Consensus?
  245. wheel bearings
  246. tire conversion
  247. Best Tire For 2013 FLHTK
  248. Miss Match Tires
  249. 120/70/21 tire on a 2 1/8 wide rim
  250. Need help converting 3/4 rim to 25mm
