View Full Version : Wheels/Tires
Pages :
14
15
16
17
18
19
20]
21
22
- tubes or no tubes...that is the question...
- 17X4.25 wheels hello performance machine!!!
- 16 inch to 17 inch swap
- dot 5 brake fluid
- Handlebar diameter
- HELP! 2008 Ultra Rear hub
- bleeding rear brake
- metzler
- Clueless in NY
- New tire question
- smaller rear wheel?
- another HELP question
- Brake Pad Break In
- how far does brake plunger come out of switch?
- Rear axle torque
- Where is the best place(cheapest) to get a rear tire?
- Black Spokes?
- white powder coated rims? pic request
- Fatboy wheels On Softail Deluxe?
- Noise in front wheel area
- Brake Switch, Bleeding, and Fluid.
- FLHTC replace rear bearing
- dunlop k591
- Will 2008 touring wheels fit on my 2004 touring
- dunlop tire
- Rear Disc hot
- Guys with a 21" Front Wheel
- newbie brake question
- brake pad adj - too close and rubs
- 05 FLSTSC tire advice
- D427 Dunlop blows
- Cracked front Brake Rotor..with pics!
- Front Brake Rotor Question
- Retrofit ABS?
- Agitator Wheel Question
- Dyna wheel on a sporty?
- Sportster All Wheel Corrosion
- Backwards tire
- disabling abs to allow for single front rotor?
- FLHR Brake Lines (front)
- Question about New Stainless Brake Rotors
- in badly need of a new tire
- Dayton Ohio area tires mounted?
- Front Caliper Piston Will Not Retreat!!! WHY!!!
- Blue plastic stuck on new tires
- New Tires and Cruise Control
- Wheel bearing sizes
- Crossbones 21" front wheel
- Nail in my tire
- Caught my buddy doing his brakes wrong.
- universal brake lines
- Front Tire Rubbing Fender Bolt
- Rear Wheel Noise On 2009 Street Glide
- Replacing rear pads on Deuce
- Anyone lace a 19" rear on a Dyna?
- wheel lacing
- How to fit 150 tire on 02 Electra Glide?
- Metzler Rear Tire?
- 180 tire substitutions?
- Uneven tire wear
- Metezler ME 880 or metezler lazertec front tyre
- Harleys New Chrome Fatboy Rims?
- fat bob rear tire.
- 2004 XL1200C Front Wheel
- 150/70-18 on fatboy
- Metzler 880 160/60vr-18
- Importance Of Tire Pressure
- Kenda Tires
- Front Brake Clearence
- Need info on front master cylinder disassembly for chrome
- Tire Size Questions...
- Front wheel torque
- 1999 fatboy rim on a 2006 l883xl sportster?
- Brake pad swap
- Can The Front And Back Tire be Exactly The Same Size?
- straight answer on tire pressure
- What year(s) were my wheels made??
- Dunlop Direzza Sport Tires?
- Do wire spoke wheels need inner tube?
- Question regarding internal wheel spacers (new stock wheel on older bike)).
- Rear brake question
- More tire info
- No Front Brake!!
- Front brake problem?
- Dunlop Tires
- Brakes work when parked not moving???
- Stock Wire wheels
- 2008 WG, anybody use radials?
- Any dual compound tires for cruisers?
- What Are the Differences Between MH90-21 & 90/90-21 Sizes
- Looking for black std laced wheel for touring bike
- Replacing Rear Breaks
- read brake pad replacement problem
- Where to get VD-191JL pads?
- Miles to replacement?
- Wheel Bearing Sizes???
- Rear brake suddenly lost
- 01 electra glide brake fluid
- Can I fix a bent rim
- White Wall question...
- squealing brakes
- Front master leak
- softail deluxe 2007 frontend feels uneasy when i let off the throttle.help
- New smooth profile lace wheels on 01 Fatboy?
- Rear Rotor is probably warped and the pads are toast...
- rear brake reservoir 2010 Fat Boy
- 80/90-21 vs 90/90-21
- Softail Front Hub Question
- 03 Fatboy Front Rim
- 2001 electra glide classic brakes
- 2006 200mm compared to 2007 newer
- My Rear Disk Ain't Hot Anymore
- rear pad change
- 2002 RK wheels on 1986 Electra Glide?
- 6.25 0r 5.5 rim
- New chrome controls brake problem
- Metzler tires and wear bar vibration
- Bleeding ABS brakes.
- front brake
- opinions on tires
- 2007 Softail Custom: Metzeler or Avon?
- Touring axle spacers / photos
- Removing rear wheel
- Front right side brake uneven contact / wear.
- 21'' Front tire
- Wheel cleaner and tire shine
- 2009 Touring model front tire issues question
- question about hub measurement
- Dumb question on new billet wheels
- Anyone Know if they Make a Chrome sprocket Cover for 05 roadking?
- new wheels, bearing question
- MU85 VS MU90 speedometer readings
- Mixing tire brand question...
- 09 RKC Rear tire question
- Need someone that can lace a spoke wheel
- Front Brake Rotor squealing
- Modular wheels
- 06 fatboy, time to replace tires.
- wheel crush sleeve?
- 5/8 master cylinder rebuild instructions?
- Dunlop vs Michelin Tires
- Bigger Tire for 2002 Electra Glide Classic
- What tire? 07 ELE Glide
- Advice on brake fluid flush.
- powder coating wheels ????
- Front brake switch question
- Need Brakes
- New HD owner needs tire info
- Please Help Installing Front Brake Pads: Direction? ?
- Front brakes hangin up?
- Dunlop 407s, opinions please
- Dunlop tire question.
- Rebuilding front master cylinder piston what type of lube should I use?
- After market vs. HD brakes
- Coker Super Eagle Replica tire.
- hardtail rear brake
- '07 SE RK Road Winders under 06 SG
- Front fender and tire expansion clearance???
- Someone please education me on road winder rotors
- How to clean roulette wheels?
- Well crap !!!
- Dunlop Elite 3's on my 08 EGC
- Need help on replacing rear tire and rim
- Where to measure rim size?
- rear wheel belt adjustment help
- Best price on tires?
- Powder Coated Rims
- 11/16 MC on a single disk?
- &%$* brakes
- 2010 wheel on a 04 Deuce
- what a difference!
- SportTouring Tires on Softails
- Floating rotors or solid?
- 2003 Ultra new 18 inch chromes
- springer front brake
- light bar fitment on fat rear fender
- Mamouth 52 fat spoke wheels no bolts! "help"
- Custom/Home made Brake lines?
- Can't get rear pads in with floating rotors
- Revolver Wheels
- Can i put a '96 rear wheel on my '05 Heritage
- Frame, Suspension and Front End questions?
- New ABS brake system
- Average labor to replace tires?
- Question for HD Technicians behind the scenes at
- 09 Wheels on an 07?
- 21' wheels on my Dyna FXDB Street Bob
- Extending your brake lines? This could save you money.
- Tire HELP!! Belted, Bias, Radial??
- Importaince of changing Brake Fluid for the season
- rear brake question
- GMA brake parts? Are they available anywhere?
- bleeder fitting seized in caliper
- Touring black brake lines FS
- Rocker C wheels on a Dyna
- Question about wheels (probably dumb)
- Deuce wheel
- Biggest front tire on stock 06 FXDWG wheel
- New skins for the WG
- Anyone is using Pirelli MT66's?
- NEED info on how this 21" wheel will mount to my bike
- lyndel composit brakes
- Anyone using Pirelli MT66 tires?
- mixed brake fluid advise
- wider rear tire 99 road king
- brake pad rattail file
- 06 Dyna WG Rear Wheel Install
- 08 fatboy tire options?
- Rear Tire size 150/80B16 vs. MT90B16
- Fat Boy wheels on a Road King?
- 21"/18" wheel HELP for '05 Softail Deluxe
- Slime in Tires??
- Brake rotor mounting bolts?
- New Rubber for my Ultra Classic
- 180 Tire on a 150 rim?
- Wheel Alignment Questions
- 09 Fatbob front brake master leak
- *Moved* Looking for HD front wheel education
- fatter rear tire on fat boy
- front wheel bearing removel
- 1977 fxe front caliper
- When to replace tubes (spoked wheels)?
- Cross Bones Front Breaking Power
- spoked wheel weights
- wheel swap problem
- Help, Metzeler High Speed Death Wobble
- noise from front wheel
- New White Walls Are Blue
- new wheel
- Front Brake Line question
- 2008 FXSTC / PM Wheels / Centered or not ??
- 160/70/17 tire on dyna
- Goodridge Ebony
- tires
- duece wheel on 99 fxstc
- Fatboy front wheel on a Standard?
- Rear Tire Size for 07 Street Glide
- Minneapolis , Mn tire mounting
- Tire question, mixing radial and bias
- front wheel spacers
- Front brake free play
- new pads on my front wheel???
- Dyna Beads
- Tires
- New front E3 is too noisy...
- Wheel ID Question
- Tire question
