- 00-05 Sporty 13 Spoke on my 07 Dyna Questions
- Road Commanders ....
- Arlen Ness Wheel Chrome Quality Issues
- Ride On Sealant Mess
- Tyre replacement time on my Super Glide FXDC 2010
- Time for tire sales yet?
- Rg3
- Need help with setting wheel endplay with Timken bearings
- 79 FXS wheel size 16x3.5??
- Front wheel rotor bolts hit forks
- Sprocket De-chroming
- Wheel ID?
- WTB Lightning Star Wheels
- 2013 vs 2014 and up front rotors the same size and bolt pattern?
- Whitewall Tire Sizes - Feedback Wanted on Sizes Needed
- Same size tire and rims front and rear, Shinko 270s
- Brand "new" tire that is 2 years old aready. BS?
- 21x3 inch rim 2005 Harley Heritage Softail
- Time to replace yet?
- Anyone know exactly what Harley this rim is for? And price?
- fat tire kit
- Post your wheel/tire setups on street glide
- Softail 17x6 wheel hub width?
- Tyre Pressure
- Softail to Touring swap?
- Can anyone identify this Harley OEM rim? Will it fit my 2013 Ultra classic non-ABS?
- Dunlop MC tires
- Can someone identify these wheels ?
- 1976 Superglide FXE Wheel Size
- Primary Side of a Wheel
- Whitewall
- Looking for rim repair around San Antonio, TX ?
- How Much Off-Center Rear Okay?
- Out of balance wheels?
- What brand wheel is this?
- Front chrome 48 fat spoke wheel for 2010 Softail
- I thinking this Continental rear tire deserves a install on a Harley
- Better then stock sealed bearings?
- Bias ply front -Radial Rear
- Rear brake pads
- "EZ" fat front tire kit from Arlen Ness
- 16" wagon wheels, to 19/18" Prodigys.
- Wheel balancing
- Front wheel install/spacers
- Help identify wheels and forks
- Aluminum mag
- Hubs
- Hubs
- Tire life
- Enforcer 16" rear 19" front for '15 Road King?
- Custom wheels
- 2017 streetglide front rim install onto a 2015 flhtk
- 15 CVO Front wheel to a 15 RG Special
- FXR wheel bearing no end play
- Street glide wheel swap
- WTB RSD Judge 16x5.5 black ops rear wheel
- Can anyone decipher this date code on tire? (Picture)
- Help with Wheel Identification
- Need new tires
- My tubeless tire had a tube in it...
- Reseal Big Spoke rim
- Agitator 18/19 in wheels on 2019 Limited ok?
- Modify 2001 and earlier wheel to accept 1" axle shaft
- New rear tire
- New rear rim problems
- Is there a reason to go with American Elite over Commander 2?
- anyone like their avon cobra chromes?
- 23” wheel causing ABS TC light
- worth watching
- Drum to disk conversion
- Need help in purchasing tires
- Dunlop D402 H-D Tires Made in France
- 2016 Heritage 21” wheel issues.
- Let's see them bald tires
- Wheel bearing help
- Rear Tire Failure.
- 16 spoke aluminum rear mag
- 16 spoke aluminum mags
- Reuse wheel bearings
- Wheel end play questions
- Aluminum factory mag rims
- American Elites
- Anyone used a No Mar to change 35 inch truck tires?
- Rim widths question #dyna #street bob
- Fugitive Wheels Question
- Valve stems
- Rear Wheel Bolt Size
- Using Rotor spacers to align rotor with caliper.
- Tire pressure - how often are you adding air?
- FLHR - Checking Rear Axle Nut Torque
- Wheel swap for touring
- Flat tyre Fat spoke wheels
- Compatibility of Iron 883/1200 Wheels on FXBB Street Bob
- Quick Review of MICHELIN Commander III Touring Front Tire
- I don't Understand how this works
- Odd Size Front Tire (130/70/19) looking for one.
- Inner tube damage
- Finally fixed my exhaust!
- Found a snap ring in the driveway
- Looking to run a 150mm tire
- Dyna Switchback front wheel?
- ABS Wheel Speed Sensor
- Rear Wheel Bearing? Swing Arm?
- need a little help
- Rear Wheel Alignment
- Spoked Rims, inner tubes and straps
- Wheel bearings
- Pirelli tire promotion
- Bad tires?
- American Elite rear + Harley Dunlop in front?
- Is Wheel Hub Can Be Replaceable?
- 2000 FLSTF - rear custom wheel spacer order
- Time for tires - Got a Dumb Question
- Tri glide ultra rear tire replacement
- Searching for Harley Topper Sidecar Help
- 23in wheel
- Dunlop d408 front tyre
- 280,metzeler tire on 2018 fatboy
- 21" x 3.5 rim On a 09 Street Glide
- 05 wide glide front spacers
- Original OEM Tires 2013 Blackine
- No-Mar tire machine on dually wheel rim?
- Tubeless Wire Wheels for '23 Softail Standard
- Wheel Bearing tapped out!
- ABS vs Non ABS wheels
- 21x.3.5 wheel swap brake issue question.
- 86 fxlr torque specs
- Type of wheel
- Shinko 250
- Changed the front tire on my FatBoy
- 16 in slotted rear wheel
- front wheel swap
- 2019 SGS Rear Tire
- 2013 Street Bob rear tire...
- 180/65 B16 Dunlop American Elite Nww
- Ultima Manhattan Wheels
- Any gotchas when changing a tire that used Ride-On?
- Fitting a 120/70-21 on the same rim for a 100/90 -21
- Tube or Tubeless Tires in a 2009 FLHRC
- Are Tire Pressure Sensors Reliable ?
- Laced Wheel Rim Strip Question
- 7-Point Rotors
- Pasadena Discount Tire
- Sahara Moto High Speed Tire Sealant
- Strange Scuffs on new Dunlop Elite
- Shinko 999 touring tires
- Dyna Timken Wheel Bearing Service Oops
- ‘91 softail rear axle flip
- Ultima 80 spoke wheel on FXSTSI
- 18" rims
- Switchblade wheels 2006 fxdbi- front wheel bearing bind
- tire recommendations
- ironhead tire on a street bob
- 2001 Electra Glide Rim Help
- Commander II vs. Battlecruise H50 rear tire crown profile comparison
- 16x4.5 40hole rim in gloss black
- New tire models
- Wheel swaps, year compatibility, and ABS bearings?
- Bridgestone Battle Cruise H50 Tires etc.
- HELP ! Timken wheel bearings for Ultima Fat Spoke
- I have a Flat tire.
- Axle nut tightening question
- ABS in ceramic?
- Drag Radials...
- These new bikes this sloppy?????
- 2013 wheels on a 2004
- Matching front & rear tire size? Bias VS Radial?
- Harley Davidson Softail FXSTDI Deuce This Front Axle
- Enforcer wheel exchange
- vintage tires on 18x4.25 rim
- Changing to rear aftermarket wheel
- Changing wheel bearings on Prodigy wheels??
- Wheels/Tires DYI vs Service shops
- 2012 Fat Boy front tire
- Change FLD wheels (17,18) to 16's. Issues?
- Where to buy tires
- Axle Alignment Plugs for ‘16 Breakout
- What wheel do I have?
- D402 verses d408 anyone?
- 2013 Ultra Limited front tire torque setting
- crossbones wheel
- Leaking @ bead
- which spoke wheel for 2000 sportster
- Tar Snakes
- FXDLS wheels on FXDB
- Tire size
- Tire delima!
- AE tires
- 3 1/4 wheel vs 3 1/2
- 21 spoke that matches Harley spoke on 14 RK
- Wheel direction?
- Tire Pressures
- 21" front wheel
- Is there a need for a new front fender?
- 2007 nightser front wheel fit on 1998 roadking?
- 21 Street Bob - vibration
- Weird tire wear
- Is it better for the tires if you store the bike on a jack during winter ?
- What do you think?
- 2014 Enforcer on 2007 Street Glide
- Powder coating
- Tink testing spokes
- Help identify wheel/tire size? 1998 Superglide
- 16x3 rim biggest tire?
- Daily Rider Tires
- Spoke covers- do spokes rust underneath?
- Noisy (new) Michelin Scorcher OEM tires
- 04' Road King Wheels work on 04' Heritage?
- 16 inch aluminun rear rim
- width of 200 tire swingarm?
- unusual tire wear
- Michelin Commanders
- CVO TriGlide Rear Tires
- Wheel lacing question?
- Winter tires touring
- Springer tire size conversion question
- Wheels: Spokes vs. non spokes
- car and bike valve stems the same?
- American Elite tires
- Anyone know who makes these wheels?
- Metzler Cruise Tec
- Night Train rims swap to a wide glide questions
- How free should front wheel bearings be
- Who mounts their own tires and what's your method?
- Scorcher alternatives.
- Cracks at bottom of tread grooves
- Screw in front tire
- Front Wheel Bearings - Turn by finger or not?
- Radials both front and rear
- Tire prices to high
- Tire replacement w/ESP
- Ridewright wheels
- 14 fxdb 13 spoke mags
- Mags for 03 electra glide standard
- Any Manufacturers Known for Running Wider than Listed Size
- Looking for tire product "Ride-On"
- Powder coating wheels question
- Best bang for your buck
- 2020 FXFBS Front Axel Stuck
- Performance tires for '11 Fat Boy
- direct bolt on aftermarket wheel options for 2022 fxlrs ?
- How much Ride On
- Changing From Spoke to Mag
- Wider Front Tire for 2014 CVO Road King?
- Heritage 2012 - 10 yr old tires
- Best Performance Tires for my '13 Heritage Softail Classic
- Sportster rear brake
- Wheel swap: Breakout to Heritage
- Rear tire balancing issue and questions
- what are you using for a rear tire especially on the glides.
