View Full Version : Wheels/Tires
- 2017 Ultra rim and tire to 2014 Ultra Limited
- Pre 2000 rim to 2001 sportster conversion help!
- HELP! Converting a 21" to a 16" on a 1988 Springer
- 2006 fatboy thunder star rims to put on heritage softail
- '07 Ultra: How to go from 16" ft to 18" Ft?
- Out of balance tire
- Commander 2
- Leaky valve stem
- Wide/fat front tire kit for Dyna Wide Glide
- Tire rubbing or something else ?
- Wheel Bearing Install - Torque Spec?
- 2000 touring rims on 2007 softail heritage
- 08 softail wheel on 98 Touring???
- Worried about my front axle!!!
- What to do when the tire is off of the wheel
- Sportster spacers
- wheel change
- Tube in a tubeless tire
- 16” x 3” / 16” x 3.5”
- 16 inch wheel to 18 inch wheel
- 08+ Mags on 2007 FXDB
- Recommendations on bearings
- What tires do you like
- 02 road king rear rim ,,, help
- 2008 E-glide wheels on 2004 E-glide
- Should I consider a different tire size?
- Wider Rear Tire
- '93 Sportster wheel bearing seal
- Relacing wheel, spoke/rim recs?
- Saved a bunch doing it myself.
- Dyna to touring wheel conversion?
- Front Tire
- Is tire ok to keep using
- pulley bolts
- Tire pressure help.
- 2003 Softail 200 series tire
- Front wheel spacing issue
- 2003 RK PRO’s and CON’s of 21” front wheel
- Suggestions for rear wheel please
- Car Tire on Rear
- ABS vs non ABS
- Low profile rear tire for street bob
- Dunlop or Michelin Tires?
- Help
- Wheel bearings
- whats new in tires for street glide
- Tires Tires
- Continental tires
- Sportster 48 Tire Suggestions!
- Tire Valve Question
- Crack in tire pretty much all the way around, time to change it?
- To all with SPOKE wheels: Keeping it true!
- 2003 Heritage Softail
- Used Wheels or Buy New
- Need help identifying these wheels manufacturer
- Dunlop American Elite Prices
- Chroming my SG enforcer wheels looking for the best
- Tire safety / replacement advice needed
- Softail slim front tire
- Wow so H-D aluminum is cheapest for FXDB?
- Who makes these wheels? Looked everywhere
- ABS Bearings Touring
- Tire Size
- 5.5 hub width
- 21” wheel
- Hub bearing depth? is there a reason for the difference?
- 21x3.5 spoke wheel
- 18x5.5 wheels on 2013 fxdc
- Can this be right?
- Wheel Size Question
- Shinko 240 on early Twinkie?
- 16" front wheel on 2017 touring
- Retro looking tires
- Wheel weights
- white walls and mag wheels
- 2018 fat boy alluminium wheel has become dull in shine
- Metzler cruisetek tires
- Rear Wheel replacement on an '01 Road King.
- New wheels
- 17x4.5 wheel fitment on a 2003 Dyna?
- Ceramic Wheel Balancing Beads
- 3 peice wheel
- Spoke nipple question
- Problems
- Best month to buy new tires?
- CAREUD TPMS System
- Street glide wheel fitment for different years.
- Tapered roller bearings and spacers
- Check out this deal!
- 06 Road King wheel to 97
- Wheel bearing puller
- Quick Question
- Fitment issue?
- Sport touring tires on 17” rims
- Three Questions
- swap rims
- Aftermarket non abs wheel to abs wheel (performance machine)
- Harley wheel bearings
- Heartland softail 250 kit rim hub width
- Getting them off
- Quick tire question.. (Ease my mind👌)
- Xl1200 48
- Sportster 2006 wider rear tyre?
- New Tires
- Go get them boyzzz
- Tires
- FOBO t-valve stems
- wheel change
- 23" front
- Need info on 180 200 rims and tires
- No-Mar Tire Changer Question
- 21 x 3.5" and ???
- Help need wheels that won’t break the bank!
- hd forty eight back tire
- Wheel Spacers - Service/Parts Inconsistency
- Wheel compatability
- tyres
- Can’t get FOBO TPMS to connect to iPhone
- Night Dragons vs American Elite
- Wheel dilemma...
- Street Glide wheels
- I hate my 2018 Sport Glide wheels
- 2009 Night Train - Stock wheel/Rim...Non stock Axle?
- 2014 dayna street bob front rim on to a 2011dayna wide glide.
- Infamous 19 vs 21 bagger wheel thread
- sportster front wheel change
- Cupped? Trash?
- So You Want to Run a 180mm Wide Front Tire?
- 19/16 wheel upgrade
- 96 FLH front rim which direction?
- Wide front on a Wide Glide
- 16" 9 spoke wheel rotor install
- 180 rear tire up front
- Running a 120/70R21 on a 21 x 2.15 rim
- Pro's Cons 19 inch front verses 17 inch front.
- Front End Vibration
- 280-35-18 on a Breakout?
- Need help With new rims and tires
- Wheel change
- Slowish leak?
- Metzler ME888 front tire
- Fatboy 2007 tyres need widening
- 19x3 13 spoke mag?
- Tools
- wire wheels need to be trued every so often ?
- Can anybody ID these wheels from the 90's?
- 2015 flhtk Gap in front axle is this normal and safe?
- Mixing radial and bias ply tires
- Metzeler 888 for RK
- Avon Cobras Sans Balance Dot
- Biggest Front Tire Size
- sealing spoked wheels
- Tyre pressure for FXDWG
- Fatboy Wheels on Heritage Softail
- My First Nail in Rear Ever, I know lucky
- Could low tire pressure contribute to a crash
- Tire wear on EG + side car
- Wheel Manufacturers
- Tire pressure light
- Enforcer front rim onto 1998 softail???
- Rear tyre is rubbing my turn signal wire ?
- Can anyone tell me what wheel/brand this is??
- 2006 street bob wider tires????
- Will Stock 2008 Street glide Wheel/Tire/Rotor fit on 2006 Streetglide
- Wheel identity
- Question about tubes.
- wheel swap help if you have a second
- 2009 Heritage wheel bearings?
- Widest Wheel on 2017 Street Bob?
- Wider rear wheel/tire
- Dunlop new tire rebate pays REALLY SLOW
- Anyone put a 21” wheel on a street bob?
- 21 inch front ThunderStar Wheel
- 91 Sportster Wide Tire Questions
- wheels and Bearing GURUS
- Tires and brakes easier than I thought
- Do I have to replace a tire that's been plugged?
- 1999 Dyna, wanting cast wheels
- Snapped bolt in caliper
- Front tire tread depth at 4/32 with 9k miles: about right??
- 2018 cvo streetglide, want to add custom wheels
- 21in wheel issue heritage softail
- Which tire
- Shinko 777, dont do it
- 2008 Wheel Swap
- 02 Heritage 21" FW
- Valve Stems
- Radial tire search help
- Boyd Coddington Rims On My Bike, Calling all Experts.
- Where to find a 21” x 3.5” hoop
- 2010 FLHTP rear tire
- 92 electra glide
- Is it me or is the thread showing?
- 180mm Front Kit
- Tire beads...does the kind matter? Dynabeads, Tyrebeads, EZ Beads, Counteract
- D404f
- Wheels on 2008 Touring
- wheels
- Front tire won’t hold air pressure
- Bronze spokes?????
- 2001 Duece needs new shoes!
- 21" Ultima King Spoke from 2007 Street Glide on a 2010
- 2008 Softail New Tires Poor Handling
- Spoke Rim Fitment
- Swapping tires
- RC Components Eclipse wheel
- Wheel, Brake, Hub Size
- Which brand makes the fattest 90/90/21 at the moment?
- PSI Change
- Tire alignment on wheel
- dunlop
- Chrome 21” twisted 80 spoke front rim for 03 Heritage Softail Classic.. HELP!
- Confirmation on bad wheel, w/guage video...
- Keeping laced wheels trued?
- Whats New In The Tire World?
- How to put1982 rim on 2001 heritage softail
- 150/80 16 rear on front of 2016 road King?
- Dunlop Elite 3 sidewall cracking?
- Wheel swap
- Rear tire for 2013 Road King
- Looking to trade mag wheels for spoke wheels
- Help! New 21" fat spoked rim isn't centered!
- Trike tire on bike
- Rake needed
- 1998 Fat Boy rear tire fitment
- Tire confused
- 1997 883 sportster
- Anyone running a 120/70/21 on a sportster?
- Front Brake Lever Locked
- Tires and tubes
- Ruined Axel threading. New axel?
- Dunlops and Avons
- Bigger front tire on a Sportster
- 16” rear on a dyna
- Dyna rear wheel swap, belt tension and alignement change?
- Need a source for rim/hub dimension on 08 FXDC profile wheel
- 16" front wheel on 2017 touring bike
- Ride-On Review
- 99 sportster standard 883 front wheel change
- 97 Fatboy solid rim valve stem replacement
- Sinister Phat spoke wheels?
- 2012 Harley Ultra Classic
- Wheel Balancing
- softail wheel ?
- Metzler marathon 888 air pressure
- Continental Conti Tour
- 21 inch Front Rims
- Abs and wheel change
- How to tell what a wheel will fit?
- Dunlop models
