View Full Version : 2018+ Softail Models
- What are the issues with installing a 131 stage 4 in a 23 Breakout with TCS?
- Has Anyone Tried Replacing 2018 to 2020 Breakout Tanks with the Larger 23 Breakout Tank
- An uplifting experience In detailing…
- M8 Mono Shock
- Heritage wheels swap
- Is Softail inventory running low or in high demand?
- Signed on a 2023 fat bob yesterday
- 23 Fatboy vs breakout
- Screamin eagle vs s&s vs feuling
- plug wires
- Shock Preload Adjuster Question
- Tuner after Bassani 2:1 on a 2021 FLSTC?
- 2023 fatboy
- beach bars on a m8 heritage? Pics Please.
- Holdfast Passenger backrest adjustment (Sport Glide/ Low Rider)?
- Knock Sensor Code on my new Lowrider ST
- Lowrider ST Forks
- HD black paint
- Baggage System with quick release Sissybar
- 2018 Sport Glide fork oil level
- Pillion seat options
- Sport Glide, now what? How do you choose??
- Kickstand puck
- Fat boy 114 2023 lift kit
- Lowrider ST vent screens
- Fatboy/Breakout touring option
- 2021 M8 107 Sport Glide Lower Engine Bearing Noise
- 6" Pullback Risers on a Heritage
- Sport Glides, Crash bars and floorboards- fast riding and cornering clearance?
- NastyHog hard saddlebags
- What would you guys do IF...
- backrest - luggage
- Lean angle
- 2020+ streetbob / std axle mount license plate?
- What touches down?
- Unable to ride for a month
- Burns nhb on LRS
- Corbin solo on Marketplace
- Transmission fluid
- 2020 Softail std/fxst black side transmission cover help?
- Breakout Insurance and registration Storage
- Seats for taller rider
- question about frames
- Saddle Bags for a 2023 Breakout
- what alternate rear wheels fit Sport Glide
- 2023 FatBoy noise
- Lowrider st speaker connection failed
- Heated Grip install Confusion
- Cargo Tie Down
- M8 Fat Bob 114 - Mid Controls?
- Holdfast tour pack mount loose
- 17" wheel on the rear of a Low Rider S?
- FXBB Transmission install no Neutral light
- '23 Breakout - Rainsock Included?
- Electrical plug under tank
- BCM magic
- Mid control donor bikes
- Rebuilding a Fatboy
- USB port on M8 Softail - Which was first year?
- Possible primary noise issue?
- Lower handlebars
- Reference heritage classic - thinner grips
- DTC P0153c?
- Clutch won’t disengage
- Service Manual
- Reef Blue aerosol paint in the UK
- Installing Rougue Industries Daytime Running Lights on a NZ Low Rider S
- 6 gallon fuel tank on a Softail?
- Baja Design LP4 on a 2020 FXLRS
- '18 Heritage Mono Shock?
- M8 engine tranny primary Assembly removal
- What’s happening here?….
- 2018 Fat Boy-Error code PO 152h
- Tall HD Shock install review!
- dash hyper flash since LED swap
- 10” bars on 2019 Softail Slim
- Fat bob seat
- Heritage Rear Wheel Removal?
- 22 Fatboy seat
- 2022 softail standard Foot pegs swap
- Feuling M8 external breather
- Two-up riding, possibly overnighters
- 2023 Low Rider S- short rider
- Wires rear flasher softail slim 018
- 2023 Low Rider S Headlight
- 2018 to 2023 changes?
- New Solo Seat for The Standard
- Headlight Nacelle
- S&S 28" kit.
- Stock speedo digital display
- Vibration damper in apes?
- Yes, it's another thread about seats
- New to HC models
- What do I need to switch to cast wheels?
- Deluxe tank emblem
- Saddlebags from Heritage on FLFBS Fat Boy
- Memphis Shades batwing fairing?
- Aluminum swingarm?
- Joined Heritage Classic family
- Low Rider ST: DISAPPOINTED!
- Krhome Werks Slip-ons & V&H FP4 Review
- 2018-2023 Fatboy improvements? I miss my old lump...
- Sport Glide with long pipes
- 18+Fat Bob FXFB/S rear brake lever amazon
- Relocating the coil on 18+ softail
- Heritage 2018+ 114 Winter Upgrades
- 2021 softail ignition coil test
- MPG for 2018 Heritage 114
- Do I need Muffler Gaskets?
- What to do, what to do...
- 2023 Low Rider ST .... floor boards?
- 2021 Sport Clide Windshield
- Gas tank fuel pump connector
- Oil Filter Part Number for a 2023 Fat Boy?
- Measurement between eye to eye of the bolt mounts for a M8 18 - 22 Fat Boy / Breakout fender struct support
- installing fangs on 2022 Heritage
- Painting chrome black?
- Upgraded to a Softail & 131 kit
- Freedom performance opinions
- 54000294 TALL REAR SHOCK reviews?
- Diagnastic code I can't find
- Fat boy fork damper extensions
- More Heritage Kickstand Info
- 2019 Fat Boy Speedometer Tachometer conversion from KM to MPH
- Muffler modd ?
- Drivetrain "Compensator"
- Bobtail Rear Fender
- Does Anyone Recognize This Softail Solo Seat & Handlebar
- Brake pedal pad
- 2018 FLHCS new Primary and Derby covers.
- error codes after handlebars and stage 2
- Neutral
- Seat higher and forward
- Fried another voltage regulator
- Sport Glide to a 2 into 2 Exhaust.
- HD Detachable saddlebags on 21 Heritage
- Took a cool road-trip yesterday….
- Made The Move To A Softail....
- Aggressor Style Fairing
- Harley direct buy 15% off
- 2023 Road King Special with RDRS Stage 1
- Disabling immobiliser
- New Harley Questions
- 2012 Fatboy low horn
- Engine guards, Hogworkz, Cobra, Harley
- Handle bar replacement 2019 delux
- 23 FXBB Check Engine light with Flashing ABS
- Battery?
- FXLRS hard bag brackets
- Heritage front suspension upgrade difficulty
- M8 Softail(especially Fat Boy and Breakout) Hammock Seat owners, How do you like that seat?
- Belt Deflection
- 2018+ sport glide fork on street bob
- Tall Risers and Moto Type Bars on a Slim
- Low Rider ST 1156 to 1157 Questions / Ideas
- Need help finding tall sissy bar for FLHCS
- Passenger foot peg dilema
- Air suspension for M8 Heritage used for touring?
- T-Bars or Moto bars with pull back risers
- Want to get a taller mono shock
- Rear Shock Preload Adjuster Leak
- Sport Glide fork wind defectors
- New risers on 2022 heritage
- Between a 2022 grey or 2023 Black Lowrider S
- 22 Fatboy V&H big radius
- 22 FLFBS handlebars
- Need battery recommendations for Heritage 114
- Quarter Fairing Brackets
- M8 114 Stage One estimated torque & HP?
- Bike won't start after adding wire extenders
- Anybody tried the Fueling vented dipstick?
- Stage II torque cam effect on suspension
- Anyone have S&S Grand National upswept exhaust?
- Removing tank 2020 Deluxe
- I'm glad Harley doesn't use cheap fasteners but?
- ABS light after tire change
- Help with brake flare fitting leaking at junction
- Anybody done a Legend Revo-A mono-shock?
- Quantity of R. Wheel Bearings?
- Used bike mileage concerns
- Harley-Davidson 120 Long Ride Softail Dependability
- Where is my power?
- Headlight options
- Trial and error
- Trial and error
- 2018 Heritage Handle Bar Swap Electrical Issue
- Can the fairing be removed on 2022 Low Rider ST?
- Whats another ~$8-900 ? Looking at the Saddlemen Explorer RS seat
- Convert Fuel Pump 3,5 Gal to 5 Gal
- Moving License plate to rear Fender 2019 Fat Boy
- FXR Division Narrow Crash Bars
- Very excited about return of the Breakout
- What to look for on an older bike with low miles
- Ultimate Seat pix on Heritage’s
- Hurry up Springtime!!!!
- 1K service for dummies
- What kind of cam should I get?
- Sport Glide Odometer reading is not correct
- Low rider S
- 2019 Heritage larger pillion?
- Extended Warranty Plan (ESP) ?
- Thrashin AR Exhaust On
- True duals on the softail ?
- M8 exhaust slighty louder than stock?
- 2020 low rider s single gauge conversion
- Non-ABS FXLRS
- Jiffy stand swap for my Low Rider ST
- Parade mode ?
- Question for an unknown seat for FLFBS
- Street bob tank decal ?
- Corbin Wall
- Where do you stick your inspection sticker?
- Tire Pressure (there’s an app for that)
- 2019 Heritage 107 - upgrade oil pump?
- Lack of 2018+ Heritage Aftermarket Parts
- Stupid question about seat install
- Part number for pins inside connector
- Touring on a Softtail
- Harley Quarter Fairing
- Bobber style seat
- Handlebar and riser?
- Heated Grips Kahuna vs Streamliner
- Low Fule Light On, for no good reason
- 2022 Breakout 114 aftermarket ECM
- Reliability/quality of 2018 Softails vs. previous Softails/Dynas
- Adding a separate additional taillight to a softail street bob with a new fender
- 2022 Fat Boy Diagnostic Port, where is the thing?
- Softail Slim headlight swap?
- Stage 1 price kinda high
- 2022 Fatboy gas cap
- Shifter cap dilemma
- 2022 Low Rider S Rear Fender Rail Bolts
- Need to move my rear turn signals back 2"
- Show Me Your 2018+ Heritage Engine Guards
- Can anyone please tell me what licensee plate bracket this is and who makes it?
- Heritage dash cover options
- 22 fxlrs stock bar rise and pullback
- 2018+ Heritage Tour Pack trunk...
- Tank cover?
- LRST style dash on 21- LRS
- Nitron vs HyperPro vs Racetech monoshocks
- PSA:The Arlen Ness 15in Big Brake Rotor kits DO NOT fit the 2018+ Fat Boy FLFBS. The fitment lists are wrong.
- 2018 Heritage LED Headlights?
- Show me your fenders
- Suspension for heavy rider
- The FixStand Chronicles
- Update: Lowrider S Shifting Problems
- Heritage / slim fitment question
- 2021 Heritage Saddlebag Dimensions.
