View Full Version : 2018+ Softail Models
- What Has Broke on Your Heritage?
- S&S exhaust brake relocation options
- 3.5” Shark Road slip on baffles?
- What's the story with the Clutch Switch?
- Had Harley fix the speedo going issue?
- Fxlrs 2022 front end bounce
- Not another seat thread! Lowrider ST – move seat closer or move bars back?
- Terrible decelleration noise
- Transmission dipstick change
- my FXLRST is just about wrapped up...
- Handling of 2022 Fat Boy with the fat tires
- New 2022 FLHCS Heritage Classic
- 114 to 131 Street Bob
- The front axle does not come out
- Good custom shops in southwest
- Low rider ST
- Trading in 2020 Heritage Classic on a 2022
- Fatboy vs Breakout
- Spacing Out Boards... Will it create Scraping
- Help - Installing a switch to disable ABS
- '20 Heritage 114 Road Trip
- Red light comes on on Dash, Cruise Control will not engage.
- Mystery Crash Bars
- Mod questions 2020 Slim
- Kickstand
- 2020 handle bars
- looking for a brake pedal
- Looking for a little assistance please
- New FXFBS… again
- Power handling of the arlen ness big sucker?
- Floorboards/Pegs
- 2022 Lowrider ST newbie advice – risers, slip-ons
- Bcm caput
- Centurion Tune - Possible issue
- Help me! I think about Road King
- 2019 Flfbs jiffy stand broken
- Longer bolts on Fatbob
- Heritage and fatboy fender bolt distance
- Seat cusions
- 2022 Fxbb horn n black box removal
- Stage 1 ,in my case not sure
- Anti rattle clutch spring’s.
- 128” with S&S540 Powerband
- Cheap way for bottle holder
- Cheater way - neck bearing adjustment
- The M8 Fat Boy and the Counter-Steering problem. I've figured it out.
- 2020 LRS - Mechanical Cruise Control
- 2018's with 114. How many clutch plates
- No electrical after handlebar swap
- 2023 wish list - FAT CVO
- Fuel Gauge INOP After Flash
- le pera bare bones on a standard?
- Broken Compensator Ramp
- Changed clutch springs. Have a problem
- Adjustable brake pedal lever - hd forward controls
- Looking for inverted fork radial bottoms.
- Street Bob 114 2022 question
- Mellowed Out My SG Rinehart
- HD Flush mount gas cap
- ST windshield options...
- Led Turn signal
- Engine vibration
- new 2020 softail standard...
- Question. Low Rider ST, Tuned heavy breather intake and high flow exhaust
- Black Soot Inside Mufflers
- 2021 Low Rider S Chopped or FatBob Fender Option
- HD new black console + compatible speedo?
- Brake pedal messing up my leg stretch
- New C&C Fastback Seat
- 2022 lowrider s 6.5 thrashin risers with pull back
- M8 idle rpm fluctuating
- Brake-Pad Recommendations
- 2022 data link connector location FXLRST
- Oil Pump
- What is the easiest way to get at those Tappet Cover bolts? They were a huge pain in the ass to do. There has to be an easier way.
- 2021 fatbob sharknado plex
- High Quality Gloss Black Bolts
- 2022 Low Rider S owners
- 2022 Lowrider S
- Softail slim primary cover on 20 fxst w/ forward controls?
- Forward controls seem half way?
- Handlebar install help.
- 2018 114 M8 - ~13K miles - Puking oil - Leak Down Test - TSB M1450 - Slight Sumping? - Original Oil Pump - New Oil Pump etc...
- True Dual Upswept Fishtail Exhaust for 2018 Heritage 114
- Bung King Rear/Passenger Crash Bar/Pegs
- New 22 Heritage Classic - WWYD?
- Heated Grips
- 22 LRS speedo gauge bracket other than stock?
- 2022 fat bob touring
- Thrashin Essential Saddlebags
- Will old Power Vision work with M8 softails?
- M8 SE Torque Cam vs HP Cam, which one translates to better acceleration?(I don't care about numbers.)
- V&H FP4 Tuner Still Garbage?
- Rekluse TorqDrive Clutch Questions
- New M8 Softail exhaust
- Cable extensions on a 2021 Softail Standard
- Corbin Solo on 2018 Deluxe
- Longer brake pedal pad
- 22 LRS Died in first 500
- Back to Stock Handlebars
- 7" Aftermarket LED Headlight for 18 - 21 Sport Glide
- Tour Pack for 2021 Heritage Question
- I’m changing out my compensator ramp today
- Question about Low Rider ST exhaust
- Rear brake on Fatbob...
- How to access reserve fuel on FLSB Sport Glide
- Fair Stage-2 Cost?
- Sport Glide with Arlen Ness Fairing
- Warranty with HD's products not 3rd party is also worthless
- Saddle bag locks
- 2019 FatBob metal scraping sound
- feds up Harley's butt over aftermarket parts
- Early Softail M8s - Need to update / replace oil pump?
- 2018 FLHCS Trouble code B2262h
- Scraping Sound (metal fan-ish) 2019 fatbob 107
- Harley M8 worst clutch cable adjustment design award
- malfunctioning tach
- 114 build
- Oh no!! What will all of the warranty police on the forum do now?
- Heritage Seats
- Windshield Vent in Sport Glide Shield
- 107 round air cleaner swap with 114 oval
- Sport Glide - Front Brake Issue ??
- 2018 Fat Boy Tear Drop Tool Box
- 2022 street bob new headlight?
- Speaking of Brakes
- No front abs brakes
- Dyno Tuning after Exhaust and Cam upgrade without a married tuner
- Changes incoming for 18 FLSB
- I hate my Heritage 114 fender
- FXDR Fork Conversion for Fatbob Question
- 2018 Heritage FLHC Front Fender
- 2019 FXLR drag build, what am I missing here?
- HELP! No Throttle/Check Engine
- Anyone here have apes on FXLRS?
- Traction Control/Cornering ABS on the Nighster, Absent in ALL Softails
- Magnum Shielding clutch cable binding
- Instrument brightness
- HD 4" pull back riser on 2018 FLHCS?
- I know this has been beat to death, warranty reliability...
- Heritage 114 Handlebar Measurements
- Fender Reflectors?
- Painting Parts
- preload adjuster
- Replacement heavy duty clutch cable adjuster
- Another bike won’t start…
- FXLRS 2022 screamin eagle ventilator extreme air cleaner v ventilator air cleaner
- Street Bob gauge wire extension help
- Harley LED lights
- Second hand OEM speedometers
- Stage 1 tune switch back to original slip-on for a trip
- 2021 Heritage Classic handlebar install video
- Fxbb inverted front end
- Suspension settings for Ohlins
- Quick detach hardware for bags
- 2018 Hertiage Fuel Leak
- 2021 fxst forward controls with air filters
- Restoration of OEM front turn signals
- 2022 Softail Standard Shifter Movement
- 2020 Softtail Standard License Relocate
- Drag bar ?
- 'Merican Fat Boy Brake Light/License Plate Functionality Question
- FXLRS Oil problem?
- 2022 FatBob Heated grips
- Fender interchange?
- Front Power/Current Source
- rear brake pads
- 2020 Low rider troubleshooting
- 2022 Low Rider S Rear Fender Bolt Torque
- Problem Backing Up My 2019 FLHCC
- Sport Glide 8" T-bar
- Board to peg position
- Best Option to add power...? (M8 114)
- FXLRS rear brake pedal issue.
- 22 FXLRS Sissy bar fitment
- Upgraed to HD SE Clutch
- Stock 2021 Fat Boy Seat Question
- Remove Heritage fender trim?
- 2018 Breakout 114 Speedometer Display
- 21' Sport Glide T-Bars
- Softail standard fender upgrade
- Windshield question
- Exhaust and Tune
- 2019 heritage softail 114
- Sport Glide wheel help
- Shift linkage rod disconnect?
- Corbin Wall
- Tank badges..
- Need louder horn
- Dakota Digital Speedo
- FXLRS Rear Directional/DRL?
- Installation of Fueling Vented Dipstick Hose
- 2021 Softail Standard license relocation
- 2021 Sport Glide, Speedo and Gauge Lamps Intermittant
- Help Identifying this chin spoiler.
- Exhaust note change
- 2020 Low rider S humming noise!
- Exhaust advice for 21 street bob
- Engine aesthetics
- Fuel questions
- Finally got the bar/riser swap done. Bung King/Thrashin
- Feuling Vented Dipstick Polished M8 Softail
- Softail Heat Shield
- KillerCustom Fork Caps
- Accessory wiring using 69201599A Harley kit
- Better Seat for '21 Softail Standard
- Mounted my Garage Door Opener
- BCM Light Configurations
- Front Brake Lever kicks off Cruise.
- Wild One 14" Apes
- RISER EXTENSION ON FXBB or FXST
- Dyna Low Rider S Fueling Question
- What should come with new purchase
- 2018+ Softail chassis vs 83-99 FXR
- Sportglide Owners - Help
- Sport Glide Saddle Bag Bar & Shield Badge
- Best of Both Worlds
- FXDLS LED Lights??
- Sport Glide tank lift?
- How much better do the new softails handle?
- Clutch springs
- Big Als gauge mount 2022 lowrider s with risers?
- FLHCS Light Visors
- 2022 lowrider S rear turn signal to run lights
- Upper Clutch & Brake Cables
- Harley forward control kit
- 2016 Dyna or 2022 FXLRS?
- 2022 Fat Boy California VIN, Stage IV issues?
- Sport Glide Rear Brake Too Far Over Board
- M8 Low Rider Fairing Photos
- Killer Customs Breakout Rear Fender install advise
- How much torque lost with 2-into-2?
- 2019 Fat Bob FP3 Auto tune?
- Sport Glide Memphis Shades Fairing Options
- HD Performance Kits / Stages
- 131 CRATE motor install
- Customizing '22 FXLRS to pay homage to the Dyna
- How soon after purchasing a new bike do you upgrade ....
- Got a little bit of wind therapy yesterday.......
- Pulley/Belt
- Stealth Pipes?
- Heel Shifter for Low Rider S/ST - Is it possible?
- 2020 vs 2022 FXLRS
- 2022 Stage 2 Low Rider S
- Best seat for Heritage
- Think you want to try one of the Graphene brands??
- License Plate Relocation Mod - DIY
- 2018+ Fat Boy OEM Tire Mileage
- 2020 fxst with older dyna mag wheels
- Tackform
