View Full Version : 2018+ Softail Models
- Loose Passing / Auxiliary lamp
- Going to try THIS to dry the HD after washing it!
- Electrical help! New 2020 heritage owner
- What is favorite slip-on for 2023 FatBoy?
- 2019 Lowrider running rich
- Lithium battery’s
- Fuel pump mount
- Can be a cam too loud?
- Black Gauge Bezel
- Difference between wide and narrow primary covers?
- Solo Seat and backrest for 2018 FLDE
- 2020 softail standard almost murdered...
- Questions about saddlebag guards, or rear frame sliders.
- throttle response
- trickle charger cable ?
- Which motorcycle lift?
- HD Brakelight boots - good and bad features
- Ultracool Oil Cooler
- Battery tender harness dust cover.
- Sold 2020 Low Rider, parts for sale
- 3rd party slip-ons
- My new 2022 HSC
- engine change questions 107 to 114
- 2023 Low Rider ST Bars/Risers
- MAJOR change in electrically heated clothing - for good reason
- M8 Street Bob - Forward Controls vs Highway Bar
- Fat Boy tire mileage/lifespan
- A little garage decorating
- Sawicki carbon tank dash
- 2023 FXBR Rear brake line removal tips
- Changing my mind about the FXLRS and the Heritage
- Futuristic date coded Dunlops
- Hard Starting
- It's Goodbye HC Hello RKS
- Heat Shield temperatures
- Any FXLRST owners eyeing the new 2024 RG?
- 1" Softail Floorboard extenders mounted on my 2018 Heritage.
- Fatboy Shifting Problems
- Heritage fender trim question
- 49mm touring fork leg sliders on m8 street bob softail
- My '22 FXLRS tuning plan. Your thoughts please.
- Stock FXFBS Fat Bob Seat Dimensions
- Vermont State Inspection sticker plate
- 2018 Stock sport glide exhaust on 2020 low rider s?
- LRST to just LRT
- Users of HD Bluetooth Screamin' Eagle tuner: Why get "low voltage" message when battery voltage is NOT low?
- Seeing my engine on the road from the inside: OEM vs Stage 1 tune ONLY vs Stage 1 tune + SE slip-on exhaust
- Installing flat bar... FLSB... Sport Glide...
- See-thru Screamin' Eagle mufflers - does that mean no cats?
- Ken’s Factory air cleaner
- Injectors and Lifters M8 114
- 23 Low Rider S forward controls
- Seat pad source??
- Saddlemen step up seat Heritage
- Help choosing my first Harley
- Anyone go from a 103 to a M8?
- I have a 23 heritage classic looking for seat recommendations
- Can sumping cause excessive blowby
- Rear Turn Signal Y-connector Harness question. Need some help finding parts for my rear lighting setup.
- OK. How do you see this.
- Mini floorboards instead of pegs?
- Stripped a screw
- Mirrors with extended stems made TWO improvements to my ride
- HD Windshield bag failed after 1 month
- Polishing Sport Glide Mantis Wheels
- Ft Ex Lifter occasionally clatters at cold start
- Fender bolts
- Numbers on slip-on mufflers don't match number on box??
- Rear turn signals sync with brake light
- New heat shields or re-use oEM shields with Street Cannons?
- Straight bar engine guard for my Heritage
- New here.
- ABS bleeding issues front hose replacement
- Fork slider installation ?
- Clunk in clutch after screwing up clutch adjustment
- Found the source of Engine Vibration
- M8 Ohlins Screaming Eagle Suspension Review (54000325 / 45400356)
- Idle surge at idle after warmed up (2018 Heritage 114)
- Atach a Garmin Zumo 396 to the HD USB Port
- Ok to mount an iPhone onto a Softail handlebar? (HD offers an "Antivibration Module)
- Tinny, Whirring, Rattling Noise....any ideas?
- 19" to a 21" front wheel on the bob?
- simple oil pump question
- FXBB digital clock resetting self
- 2018+ Street Bob Rear Fender Thread
- low rider S tank emblem color?
- The Smart Tune Pro Chronicles
- New Heritage Classic
- LED tailight
- Softail deluxe detachable windshield mounting hardware
- My 2023 Breakout 117 & its M8 nengine impressed me today
- Aftermarket headlamp for 18+ Heritage?
- Heritage Fang / windshield grommet--torque spec?
- Firebrand GP 2-1
- Aluminum Headlight Fairing
- Big-Assed Clearview Windshield on my Heritage
- Tall shock belt tension/Sport Glide
- HD Fuel Range Calculation Methodology is "interesting"
- T max
- Foot control option from Kraus
- General tuner questions PV & Tmax
- Bike is 6 years old today.
- Low Rider ST license plate relocation
- Shift points
- What is the damn chirping/squealing George Jettson mobile noise.
- ARG! No More Sundowner Solo Seat
- Mustache Engine Guard
- Riding boots ?
- Helibars on my Heritage
- clutch interlock switch starting in gear
- Looking for lower kickstand/jiffy stand for 21 Heritage.
- Lowrider S- converted to a heritage
- What devices enable "live" iPhone display of engine & other CAN data via Bluetooth from diagnostic port?
- Heated Seat Cable Routing for 2021 FLSB
- bassani fishtails anyone?
- 114 Air Filter Cleaning
- Powder Coating Tins
- Just did stage 1, couple of V&H related questions
- Pullback risers
- 2021 FLSB Bar Swap
- softail tire mileage?
- Front Rotors
- Harley SplitVision Mirror dimensions?
- Anyone recognize this exhaust?
- Low Rider ST with Apes or meathook pics
- Baker Drivetrain?
- Low Rider St stuck in 4th…575 miles on it!!!
- 16x3.5 HOPROUSA aluminum front wheel ? for the bob
- Low Rider St Engine Temp
- Wider Front Tire 21 FXLRS
- New Heritage question
- eBay wheel
- 2023 LRST forks too soft- discuss!
- Won't turn over and Hazards flash won't stop
- Headlight
- need some input on heritage tour pak or aftermarket
- New Heritage
- Transmission Fluid Add/Full Difference
- Dirty, gross gators?
- Custom Dynamics Red/Amber 1157 kit - how?
- Maybe I can MAKE (vs buy) a wind deflector for my Breakout
- Harley ST Fairing vs Advanblack ST Fairing
- Lower exhaust pipe heat shield
- So who has cut their baffles out?
- 2021 M8 front motor mount
- Which windshield for a motorcycle (Breakout) that should not have one?
- Street Bob or Low Rider Exhaust Headers on Fat Bob 114
- RANT! I hate the human race a little more today or why I'll never stop to help anyone again, ever
- Motobar swap on 2022 Fatbob
- 2021 street bob belt tension ?
- Low Rider S '22 RUN Switch
- On a Softail now!
- 2024 Breakout preload adjuster spring and ball
- dual sport tires yes thread
- The Everything M8 Street Bob Thread
- 2023 fxlrs
- Trans Cover Removal Made Easy
- Risers for stock Breakout beach bar.
- is there a gas cap that doesn't rattle?
- Brake Banjo Bolt Thread Pitch
- Bung King rears
- Overly sensitive throttle-by-wire
- OEM clutch cable and front brake line lengths
- saddle bag brackets
- C&C Seats fourm discount?
- Streetbob wheel swap 2021
- I Put on a Rad Guard
- 2022 Softail Standard not starting
- Man I love this thing...
- What Are These Connectors
- Lowrider S finally home
- 2021 Softail Street Bob FXBBS Build
- Looking for someone with Original Garage Risers
- 2018 Breakout - extensions for new risers?
- monoshock woes
- Anyone fitted floor boards to a low rider ST?
- Low Rider ST, new owner has octane/ethanol question
- Matching Axle Covers
- Is There a Grab Rail Out There?
- Low Rider ST handlebars
- HD Engineers have mechanic experience?
- 2020 FXST won't switch 3-2-1
- Source for a trailer hitch and wiring harness for my 2023 Breakout 117?
- Fat Boy hammock seat - convert to solo?
- Brand new FXLRS oil leak
- Fork-Mount Wind Deflectors?
- No start cranks once then nothing
- 2019 Softail Slim Tachometer
- Traded my FLTRU for a Hydra Glide
- Front fog/driving lights on Lowrider ST?
- teardrop/kidney toolbox?
- Fat Bob 114 speedo on handlebar
- Faint squeak/chirping under acceleration
- Back To The Softail Fold
- Need help with Lowrider ST rear wiring
- Head gasket....
- New CVO Air Cleaner on a Lowrider S
- Corbin Solo for Heritage
- Oil level changing?
- air filter change???
- A complete review of my 2024 Hydra-Glide Revival FLI
- 2018+ M8 tuner device suggestion
- 2 to 1 slip on to oem headers
- rear shock max height oem swingarm softail
- Ape Hangers?
- Oh, oh. Clutch on new Breakout 117 with 875 km on it SUDDENLY won't fully disengage
- Low Rider S/ST - Wrinkled Engine Cases??
- Low Rider ST Chin Spoiler/Fairing
- Has anyone here used Magnum Shielding Brakelines for their bar swap? Did you need anything except the adaptor and line?
- Lowrider ST Big Bear (Ohlins) fork rebuild
- LRST Engine Guard
- Idle Speed
- Touring derby cover on softails
- What kind of mileage are you getting?
- FXLRST Screen discussion Thread
- Amazon Rack Installed
- 16" mini apes heritage
- Any easy way to use front turn signals also as BRIGHT LED run lights?
- Heritage handlebar riser
- I am STOKED! My New 2023 StreetBob!
- K&N M8 intake
- O2 sensor connector?
- Vertical license plate bracket
- Reach Seat & Reach Bars - my short review
- Captain Itch
- Pazoma
- NOCO Boost cables--mounting?
- USB-C Conversion
- What is a good brand of ape bars
- Rev limiter on M8 Softails?
- 2023 Fat Boy Saddle Bag Options
- 2021 Heritage Rear Shock Lenth
- Parts
- Pull Force Scale
- Spare fuses in Main block cover?
- Flhcs 21 front 18 rear
- No combinaiton oil level / oil digital temperature gauge available for 2023 Breakout 117 ??
- D&D Exhaust
- 2020 street bob
- Best handlebars for a street bob,apes or breakout bars
- Do you really need 272 Loctite on sprocket nut
- Front axle inside hex size
- Interesting DTC occurence following battery change
- Mean City Seats
- Engine guard on a FatBoy
- Max size on Rear tire replacement
- Sportglide Owners
- Discontinuation of satin color parts
- 2020 Low rider S riser
- 33" Bassini Fishtails with Hog workz bags
