- Forward controls for 83 fxr-where to buy
- FXR will a 2010 103 motor trans and primary work?
- Gearbox crack
- 1991 FXR Front Wheel Bearings
- FXRS Color Code?
- Anyone added auxiliary lighting to an FXR..??
- [Inquiry] 1988 FXR VIN Stamping & Sticker - Alignment/Rust Concerns
- Can yall help me determine what this is worth?
- New FXR from Buell
- Wilwood calipers for the rear. Bracket/swingarm question.
- Aftermarket Exhaust - Now What?
- Here is your chance
- Issue with 89 FXRP
- Full custom 94 FXR
- FXRT/P turn signal replacement
- FXR center fill tank capacity
- Intellitronix fuel gauge on an FXR
- 1994 FXR 16 inch rear wheel hub question.
- She loves me
- Anyone running 7/8 handlebars? If so, what controls/levers/brake-clutch setup are you using?
- Speedo... rebuild, replace?
- 1982 FXRS - Is $5k a good deal?
- Can anyone ID these forks please?
- Rear seat nut
- Fairing compatible with FXR Visor Mount Headlight
- FXR2 FXR3 FXR4 Updates
- 1982 fxrs shovelhead rebuild
- FXR Tach vs FLXR Tach
- FXR Plug Wire Keeps Popping Off Coil
- Voltage Drop At Starter Motor
- FXR Wheel Question
- PM brake seals leaking!
- 1993 FXRS-Convertible
- Pulley and belt questions
- S-RT mini fairing
- Second FXR in the stable
- Given a Harley-davidson partially put together.
- FXR Oil Tank and Lines
- 88 fxrs oil coming from tank after I shut it off
- Help identifying & value 86 FXRS
- Oil dripping from bottom of bike (FXR)
- love my old harley...sorry
- fxr 1340 superglide 1990
- FXR gas gauge question
- Considering a FXR for Next Bike
- Cutting out and backfiring at 3200 rpm’s
- Can you help ID this 1/4 fairing?
- Stiff Clutch w New Cable
- FXR Ground up build
- FXR Strut lights.
- Drag specialties stainless steel oil line kit
- Injectors and Lifters search
- to torque. Or not to torque...
- Chrome Oil pump cover
- Chrome or polished rims?
- schematic ? 1990FXRS-SP
- Using “police” FXR/S FXRT shocks on my FXRS?
- Cheap vs expensive dics
- Ignition module
- Primary Chain Question
- What's this hole for?
- Bad Stator
- Can't get throwout bearing off shaft
- Badlands ATS-03
- Fxrt tour pack quick release?
- Need Turn Signals
- FLH oil cooler on a FXR?
- Electrical gremlin
- 84 EVO FXRS, kick start
- Parts Supply For FXR
- 1991 FXR with S&S 1438cc Oil Seeping
- Best choice of exhaust for the fxr
- FXR electronic speedo conversion
- 1990 FXRP resto/custom build thread
- Small Change
- looking for feedback
- Yes, it's me again I have just returned from the island of Chandelier With Part # 67059-92
- Seeking Advice- Wiring disaster
- Fxrp
- Speedo / Odometer Question
- 5 best FXR's?
- Whats my FXR gear ratio?
- 1987 fxrs-sp ?
- Clutch creeping
- FXR Oil line kit
- Drag Specialties brake caliper?
- FXR air suspension
- FXR Models are now classics I guess
- What lift or hack to use for fxr?
- What are people using for longer jiffy stand?
- 86 FXR kicker?
- Front axle torque
- New to me FXR...as a project bike
- vibrations
- 86' fxrs upgrade
- Looking for a Thunderheader 1019
- Saddlebag options
- Lube swing arm
- FXRT Insurance Coverage
- FXRP Jiffy stand spring attachment question
- Oil lines question. Fxr
- isolator and swingarm besrings change
- FXRS V FXRS Sport
- My 1988 FXR
- Wiring question: pink wire in headlight bucket w/ pictures
- Fxr transmission: bead blasting, ect.
- 93 FXR sumping?
- RP/RT Model Manual info
- Introduction - new guy
- 94 fxlr
- New FXR?
- FXR Torque Arm
- side stand on a 94
- My new 5 3/4" headlight..!
- OG T sport Fairing
- FXR used seat options
- Can this be fixed?
- 1994 FXLR vs 1994 FXR
- Will it fit? Evo-80 Air Clean Cover
- '87 FXRP ..thoughts, advice ... opinions.
- Fxrs-sp
- Exhaust bracket keeps breaking... any pointers?
- 86 FXRS front end swap to 49mm?
- Help me price some FXR4 parts
- Frame damage, weldable/fixable or do I cut my losses?
- Help with identification please
- 1987 FXRP 35mm front end to 39mm question
- Which way to sell FXR?
- Hit a milestone yeasterday
- Help with ID of Starter parts
- Bought an FXR... How did I do?
- Pre-83 mags on a 91?
- Thunderheader/drivetrain question
- FXR Tour Pak
- West Coast FXR Jamb 2022
- Size of lights to fit fxrp pursuit pods?
- FXR Workshop Manual
- Warbird
- 1984 fxrt
- My "Old Geezer Glide", a little of this and that
- Transmission ??
- Fork slider question
- Looking at an 84
- I need speakers and a head unit
- Thought I’d share…
- Update advice on FXR front turn signals
- Convert rear turn signals to Run/Brake/Turn
- Fxr rear shocks
- Are Galfer Wave rotors possible on an FXR?
- Part number for 1990 FXR battery
- Painting my FXR4
- FXRC Questions
- Mid Controls
- Finally fixed my dented tank
- My new FXR seat
- My new(to me) FXRP
- Birth date of a FXR ?
- RT Fairing Build Thread
- FXRS-Conv Identification
- Fairing assembly
- Swingarm bushing fit
- Quick question?
- CVO pint matched cafe fairing
- Swingarm issue
- A burned up FXR owner
- A passionate FXR 3 owner
- Fairing questions
- The Hinge
- Vance and Hines 2 into 1 exhaust off 2002 dyna wide glide
- Best Time of the year
- Horn?!
- Screaming high RPM's (throttle) on start HELP!!
- Charging system upgrade on 93 FXR should i go triple phase ?
- Speedo
- 1993 FXR Convertible
- Dyna pipe on FXR?
- How close is too close? (Exhaust)
- Just got this 1988 FXR !
- New FXRS project
- The evolution of my FXR2
- Need a new rotor for brake FXR2 upgrade
- 1984 fxrp
- Getting Heated.
- Help with my mechanical speedo
- I had a fun day
- original saddlebag mount kit
- Need a new stator (sort of)
- Need a little help
- Bare knuckle Swingarm bearing conversion!
- Style Collision: Twin Cam FXR Street Tracker
- FXR Trans....HELP!
- 1989 FXRS-SP restoration/rebuild
- Front suspension etc.
- What fuel tank for my FXR?
- I need mental help…
- How to and what needs to b done to put evo motor and motor in to this frame
- FXR Handlebars
- Finding original FXR parts
- Post up a picture of your FXR
- FXR Forum
