- 71 ironhead
- photo request: forward controls on a right-side shift Sporty
- Looking to buy a 70 XLCH
- chain oiler/cover removal questions
- Idles fine, but can’t accelerate
- Assembled Sportster question
- Certification label
- My '77 Ironhead Story
- "steering wander"
- Put it on a scale?
- speedo light is "lazy"
- piniongear
- Need some pics of turn signals 68's
- 75 ironhead rear cylinder removal
- Looking for project bike
- tailight question
- stock front axles size
- Nice Restored 1952 K Model
- Is it worth it?
- headlight
- Big Bore Ironheads
- Oil Oil Everywhere Vol II
- question about timing marks
- Compression?
- starting problem 72 sporty when hot
- New Chain?
- backfire on shutdown (and an occasional miss)
- frames
- newby help needed
- Looking for Speedo/Tach/Cables 1972 XLH
- 79 basket case
- New (to me) 1972 Sportster
- anyone have experience w/ fwd controls on a right-shift Sportster?
- Spark Plugs
- s&s super e install questions
- question on hot start (or rather, the lack thereof)
- '81 Roadster turn signals
- 68 Sportster fouling plugs.
- '74 stock carb problem
- Starter Seems to be turning backwards?
- looking for an air cleaner
- Just a click??????
- Nudder stupit question
- big twin transmission?
- oil line routing
- Sealed Battery?
- Pushin Oil
- quarter mile ? times
- Skjold's Rebuild Thread
- ok, new one. final tune up.
- Starting question?
- Piston pin clips @#$%!
- Are Ironheads up for long highway rides?
- 1983 generator questions
- rake
- rivets
- Dyno charts
- what is this for
- oil gauge
- vintage saddle bags..?
- Rocker shaft nut stuck
- Drive Chain free play
- 1971 XLCH
- 1980 starter
- front wheel on 1973
- oil oil everywhere and not a drop to drink
- Couple Questions
- coper terminals
- topend rebuild
- 4th gear speed
- '77 idle not quite right
- 1958 Sportster Chopper
- Tach error
- Getting a frame level......Nardo
- "Rotate the engine..."
- locating dowel and shift fork shaft plug
- dumb question bout magnetos..
- 73 ironhead rode hard seriously
- oil leak
- another jam
- I fought the temptation
- Having a brain fart. XLH vs XLCH
- Saddlebags
- oil filter
- Oil routing on 76 Ironhead
- 69sport, you asked for pics
- Primary covers
- Big Bore Kit
- parts for parts
- Parts for IronHeads
- 83 XLX-61 Brakes
- legnthened kickstand
- Front wheel wobble....help
- sat for 10 years, what to do
- pushrod adjusting questions
- Oil line size
- mystery with rollers
- rear rim/tire size, ground clearance
- offset sprocket
- Opinions wanted
- Left side shift lever issues
- 73 xlch1000
- Starting to lose faith.
- 81 Ironhead isn't charging
- Manauls
- Handlebars
- got some pics to show
- GOT HER HOME !!!!
- Carburetor problem discovered...
- 76 Sportster top end
- I can't go fast all the time!!
- Top End rebuild
- another post re: engine won't run smoothly...
- New Guy
- Aftermarket parts any good?
- tranny sprocket question
- Introduction and 73 XLCH ???
- Timing Issues....I think
- new sporty!
- rebuilt motor runs like a raped ape!!!!
- o/t
- nted.update on 72 ironhead
- shifter linkage
- So are these Irons really roadburners?
- acceleration issues
- S&S Carb on 1972 Iron Head?
- brake light switch.....
- Worth keeping/Repairing?!
- forward controls
- Help Polarizing 71 XLCH
- Last cleanup (oil) question (I hope)
- suicide shift info.
- speedo and tach cable location....
- oil tank/ ignition coil
- Oil weight suggestions
- im not gonna use a starter. lankystarter cover
- 79 sportster
- Need clutch help, 73 xlch!!Help!!
- Rear disc brake
- CVCarb on 65 xlch
- Open Belt
- My, how things change
- '72 project jam
- 1976 Sportster for Sale
- Tires
- Kick to electric
- rear rim
- Really dumb question here.....but humor me
- Starter blues......again
- Number one in the classics section!
- New tranny
- Please Help
- Ironhead starter issues....
- 76 Starter Issues
- Oil pump?
- Bendix to CV Conversion
- Bore and Stroker kits
- Backfire on start-up
- Won my first Bike Night Trophey
- VIN #
- 74 Sporty starter
- The "Correct" way to Kick-Start a XLCH
- home made catch can
- thanks for the ironhead forum!
- Best Carb
- Thanks for the new Ironhead Forum. Now lets talk Horse Power for our Iron Hogs!
- Lets See Some Pics Of Ironheads
