- Rear Tire Question
- Merry Christmas!
- Weird Starting
- Name that bike!
- new harley rider..please help
- 1st time Ironhead owner
- Cold = lean?
- I threw in the towel
- 1972 xlch
- Pinion Gear and Clutch Repair Combo
- 75 Ironhead Starting Issue
- Starter issues escalating
- Mikuni VM38 Questions
- Lowering the front end
- Just bought an 71 XLCH.
- '79 Sportster Seals/O-Rings issue
- Lets see your Ironhead
- dumb oil question
- Reddish / brownish gas
- 69' XLH checkin in
- Guess its a wrap !
- 1980 ironhead
- Transmission / Primary Oil Leak
- Frustrating Problem...interesting conclusion
- Ironhead -shovelhead diff
- Decaffinated the Ironhead...
- Oil pump
- Anyone ever see one of these???
- 73 XLCH bogging down on acceleration
- generator replaced wont start!
- electric start problem
- Shifter replacement?
- What causes backfiring thru the carb?
- Waking from a 30 year slumber
- Main jet adjustment??
- rear jug won't fire....stuck valve?
- 75 Ironhead idling / electrical problems
- Timing and points for my ironhead
- I actually got that Ironhead!
- 1975 ironhead
- late 84 short
- stripped starter gears
- 74 Ironhead
- Oil Diagram for a 74 sportster (ironhead)
- 78 Ironhead Electrics???
- 74 sportster front brake
- Manuals etc
- oil leak trough gearcase vent
- Float no longer there
- fork stem removal 83 sporty??
- Temperature problem solved (Long post)
- Front and Rear tires for 1983 Iron Sporty "Wider"
- generator bosch voltage regulator problem
- round two
- What to do with this rare bird
- For you iron head guys
- Need crankcase covers for 1981 1200 Ironhead
- 75 sporty original
- 76 bicentennial sportster possibile bad motor, what would you do?
- tranny oil early 84
- Smoking Between Shifts
- Ironhead value?
- Turns over no spark
- Clutch problem
- 0il pump
- oil puking
- What year is the last real ironhead?
- If you could own any year of Ironhead, which would you pick?
- Another one to the fleet
- Gunna buy Ironhead tomorrow
- maybe last ride
- 74 XLCH Starter stays engaged
- ironhead 77 or 79 custom build
- Headlights
- trade a rat 73 xl for a 61 xlch chop??
- Cleaning metal particles out of engine
- I need a lesson - ironhead
- "New" Ironhead in Michigan
- ironhead wiring
- I think this will work
- Looking for an early Ironhead
- Generator?
- 77 sportster growl
- Looking for advice on 1971
- Problems in the rear cylinder
- Bendix carb tuning
- '71 clutch ramp woes
- IronHead stock exhaust - Drag pipes?
- Reliable company for springer front end.?
- Push rods question
- rear shocks
- Hello fellow ironhead's. Need info.
- voltage regulator issue (I think)
- Ironhead SPorty Prices?
- 1977 cam cover question
- Brake caliper piston removal
- Clutch Kit
- Trans fluid amount
- Lost my key.....while riding..
- Keihin Carb Issue
- She is rough shape now....
- 81 XLH points or electronic???
- 1973 Sportster XLCH 1000 - Choke Issue?
- rear light question....
- early 73 or late 73?
- Cv carb for ironhead
- gaskets ?
- ironheadred pic
- up date ironheadred
- broken heart
- aluminum or iron
- Do it yourself iron head
- Any rule of thumb on replacing condencer?
- i can't get the starter out
- 74 Ironhead pushrods spec
- Getting There
- 82 ironhead 1000 backfire with FLAMES!
- Why you should always listen to IronMick
- 81'
- Ironhead was running well
- Tappet Mix up???
- What to do now
- 83 Ironhead clutch replacement
- Torque Specs
- Battery hold down
- oil pressure issue?
- Red or Blue?
- To seal or not to seal
- Oil Pump Question
- 1972 ironhead carburetor adjustment
- fuel problems
- primary oil and chain
- New to this
- chain
- 1983 Sportster XLX Complete Rebuild
- Ironhead regular maintenance
- wiring questions
- Barn Fresh !!
- 1983 Ironhead cams (P,PB,PB+,......Q?)
- Ironhead rear motor mount stud
- clutch spring
- rocker gasket?
- 79 ironhead trans question
- Speedo gears
- advance weights
- New Ironhead owner!
- Finally took her for a ride!
- kickstarter
- Plug Gap ?
- Frame identification & help
- Elec ign ?
- Metal Dust in Carb
- bendix carb question
- 81' Ironhead carb issues
- Fuel line?
- 1966 xlch - What's it worth?
- 72 ironhead trans fill
- oil line
- Kick Starter Clutch
- Ironhead woes
- plug wires
- What is it?
- front forks question
- Almost done
- Lost the #%&ing battery filler cap
- 77 xlch 1000
- timing issues
- vintage tires needed
- click click
- not shifting properly
- chain tightens and loosens
- Mounting a Superglide tank on Sportster
- Hello, and a I need help with my 1966 Harley Ironhead
- Help for 1977 Ironhead engine.
- rocker cover gaskets
- oil pressure
- Help Me
- Battery question
- 76' XLCH Top-End rebuild
- pics of homemade pegs
- dunlop 404 tread/arrow problem
- Recoat or not?? Found the one problem area on the new bike
- Mertle Update
- Springer for my 65 XLCH
- Unleaded vs. Leaded gasoline
- Mick, PG or one of you other gurus
- Forward controls and bags 1984 (Late) XLX
- 65 xlch, wont start a day before i head to daytona! WTF!
- Ironhead Help.
- 72 sportster clutch
- I Don't Get It
- New Oil Leak
- Will Later year parts fit a 75 frames
- Hello fellow Ironhead riders
- wiring fun :/
- Just checkin in.
- S&S stroker flywheel
- Trying to get her started
- Horn Relocation
- Newbie question
- Flathead topend on a iron head bottom
- 83 Ironhead 1000
- 1978 Front Brake
- generator cooking?
- Hey IronMick !
- 6 weeks 'till riding season!!
- Do Harleys have a Soul?
- Shoulda Restored my 80
- 72 sportster parts
- Turn Signals
- wiring
- Cv Conversion
- break calipers
- 1977 xlcr
- 1981 weak points
- to split cases not?
- break light
- 83 Roadster XLS 1000 Stem size?
- 1971 xlch
- jpcycle tires
- Front rim widths: 2.15 vs 2.50
- Setting Idle
- Best way to jack up Ironhead
- Mech advance
- Best way to align rear wheel
- fouled plug
- Head gaskets
- Snapped Case Bolts?
- How do YOU judge sprocket wear?
- Source for used drum wheels?
- 'CH security
- indiana fabricator?
- 1972 ironhead sportster primary leak
- new ironhead cases
- C V Carb
- Almost done tearing it down, help me out.
- can i use a late model front end?
- New Stuff
- Are ironheads the meanest sounding?
- starting problem
- Keihin burping on 81
- What is your Favorite year of Ironhead?
- Looking for an Ironhead
- Magnito NO spark
- My Ironhead turns 37 next week
- Carb question
- cam vent
- Happy Holidays!!!
- 1970 XLCH Speedo
