View Full Version : Ironhead
Pages :
6]
14
- 75 ironhead clutch issue
- 72 xlch
- need help
- Heads: valve job, porting, polishing
- Crane HI-4 dual/single fire
- Scavenger pump
- 1977 Ironhead Sportster
- Showa front end
- idle goes up
- Iron
- 63 xlch ??
- Help with 1971 ironhead generator
- 2 piece sportster handlebars - vintage
- new paint
- 75 ironhead rear tire
- Ironhead intake question..
- Need Help with a 74 Ironhead
- Winter is upon us..
- Help! Missing Pages from Manual
- Hiccups / Misses
- Hello,
- Starter Problem
- new guy picked up a 73 ironhead with a clutch/tranny problem
- 1971 ironhead engine oil passing through to Primary??!!
- Ahh the smell of burning electrical stuff!!!
- Points, Dual points & Single fire
- looking for info on Mikuni HSR42 carb install
- New to the site looking for info
- 75 Ironhead
- gas tank over flow
- Black Smoke
- Whats the trick?...
- 77 ironhead missing and backfiring around 50 m.p.h
- Fowled plugs...
- Cant find a used cover anywhere!
- Got a Leak !
- SHE'S ALIVE. MY 1977 XLH Sportster
- 84 xls 1000 makes noise starts loses power
- bendix high speed circuit adjustment
- OW F**K my knee!
- '76 Sporty engine dying after short ride...
- Ironhead Resale Values
- New electrical problem
- ironhead has mind of its own
- roadster or not
- What to do??..
- '81 sportster tranny problem
- trans hole question
- gas mileage
- bolt on hardtail question
- wheres pinion?
- 1970 quick question
- Hey you guys ridin a ridged !
- Has anyone?
- Generator Noise?
- another rear master cylinder question
- Whats the Deal !
- The Lollipop !
- help identifying 1972 ironhead
- Brake and Ignition problems.
- 1975 sportser on the road again
- More @#$%^&& oil leaks
- Evo Motor in Ironhead frame?
- quick clutch question
- rear brake master cylinder help
- 1972 Ironhead Transmission Problem
- Carb Identifying and Triple Clamp issue..
- i need a measurement pls
- 1974 ironhead generator problem
- Sheared starter gear
- I'm just short of certain my motor is fubar/toast... Pls help!?
- 1983 Sportster XLX gauges
- Exhaust crossover
- Mikuni VM36
- Leaky Oil Tank Cap
- looking for a rotor
- if anyone here needs inspiration....
- hello and Thanks! !!
- Ironhead Motor
- 1977 ironhead transmission
- sandblasting/powdercoating
- Hot Iron head
- '74 IH clutch makes noise, then no workie
- 76 ironhead starter terminal short
- Some new stuff...
- Lights running down battery
- oil line routing 1985 XLX
- replacing oil lines
- parts manual
- Kicker for a 79
- new owner - 1973 XLCH Ironhead
- zero comression in rear cylinder
- 73 sporty no spark
- 1975 sportster shifting problem
- Clutch adjustment procedure
- 1973 ironhead let the games begin
- Where is a good place to buy engine kits from?
- cv carb
- ironhead help
- mikuni jetting
- Hard Tail and a Springer!!
- Ironhead rear shock bushings
- ironhead woes
- 1968 xlch shifting issues, please help!!
- 73 xlh
- Bogging / Hesitation / Sputtering
- I need YOUR opinion please...
- I am an idiot!!
- Best Way To Remove Shocks?
- possible Generator noise?
- Carb question
- Banging My Head against the wall!!
- Rear disk pads squealing.
- Help! New 74' sportster!
- starting problem
- 1980 XLS Ironhead clutch tranny
- Glutton for punishment I guess....
- Two more dumb questions....
- Help apehangers!!!
- help me make a decision
- Thinking of buying a 76 Ironhead Sportster
- Possible Mismatched Cams, Or??
- 1984 ironhead slip ons
- testings regs
- Very Interesting
- mechanical vs solid state
- Ironhead w/sidecar ????
- Good Info
- Handlebar options
- hI-4 crane electronic ignition dual-single
- 71 ironhead sporty shifter shaft
- Exhaust pipe discoloration very different
- Wide Glide frontend
- wide tire kit?
- Ironhead pinion removal
- Good Source for parts
- Weld on hardtail
- Ironhead starting question
- Botched carb rebuild
- Harley carb cable XLR
- 71 XLCH Questions ?? / mikuni cable / sprocket
- !ronhead oil leak update...F#@K!!!!
- dead engine :(
- help needed with crankshaft rebuild
- Disc brake upgrade
- 1978 Refurbish Complete - Video
- s&s help added baffles
- Tires and Wheels:
- ironhead oil leak
- Generator Red Light
- How many 1958 XLR's were made?
- Sitting at a red light when...
- 1962/197X build
- Carbs
- wiring turn signals?
- wtf! I'm going thru batteries
- Choke problems
- Adjustable Jets:
- Exhaust pipes changed is Carb o.k.?
- 81 ironhead tappet adj.
- oil leaking
- 84 XLH 1000 - Ready to trash
- Pushrod adjustment and noise:
- S&S - E rebuild:
- Torque cones or washers?
- 72 ironhead questions
- Decals for Sale ...
- fork tubes
- Tank and Fender decals..
- Flywheel ID
- parts
- turbulators and power tubes
- XLCH Paint/Pics
- Stator eatin alive on 84
- what to look for...
- exhaust back pressure, or lack of.
- Lost my damned key?!?!
- Timing advance cover:
- 65 Sporty Ironhead
- Convert kicker to Electric 65 XLCH
- Fuel Treatment
- Horse tradin
- spedo light
- Ironhead frame change
- Forward Controls
- going digital
- 81 xlh1000(1st harley, can you help with ideas?)
- springer front
- 85`IronHead Voltage
- cycle electric regulator
- Surprise!
- running badly and overheating solved
- IronMick's favorite book on engine modding
- 68 XLH Basket Case
- Rear chain & brake adjustment & tire pressure??
- 82 1000cc charging issues
- '75 overheating?
- help wiring points
- Rear Jug Overheating??
- 80 ironhead
- Throttle cables??
- 82 1000cc ironhead backfiring/wont run
- Couple of improvements
- Clutch Adjustment Question
- need battery info
- charging issues
- ironhead m.p.g.
- Spring has sprung!!!!!!!!!!!!!!!!
- A little bird told me.....say it's true!
- cam lobe on a 72' ironhead
- 71 XLCH ?'s [fork stem]
- Compression
- 75 gearcase
- Clutch Cable
- No Spark
- Mazda starter?
- Ignition condenser
- 75 iron slimmed down wireing
- 1972 Ironhead Pictures
- New headache
- IronHeads
- Bike running badly and hot
- My 78 Ironhead
- need advise on 82 sporty
- solenoid boot install on 1975 ironhead
- 74 XLH Face Lift
- Cycle electric regulator
- starter gear engagement
- just a few updated pics
- Bike started backfiring then took a dump
- factory air cleaners {the ham can}
- 76 XLCH smoking
- Lifter Block Leak
- how did you learn
- backfiring/popping corrected
- carb/kick start
- 3.2" vs 3.4" fire ring - sportster heads
- Best place to get Ironhead parts online
- head bolts
- Taper Bead Base Rim / Tires - '71 XLCH
- 1974 xlch oil filter - did it have one
- running rich update:
- echo,echo,echo....
- oil leaks on 82 sporty
- clutch repair
- OkcOffRoaders '75 Ironhead Thread
- new pics of my 80 ironhead
- fender help
