- New carb
- 79xls bore?
- 76 Sportster help needed!
- 79 xls overfill?
- starter brace
- starting up after the unfreeze
- 75 XLCH
- oil pressure issue
- transmission mainshaft
- Replacing wheel bearings
- carb popping on 80 iron head fixed
- Mallory electronic distributor
- Carb. Coughing (Piniongear)
- cam cover ???
- Old tyme tune-up
- iron head clutch headaches
- 79 xls ( Does that mean Roadster)
- Point gap
- DOES ANY ONE HAVE A THROTTLE CABLE
- 84 ironhead wont idle
- iron head primary cover gasket
- Battery poor man fix
- what model?
- Wheel Size?
- Question for piniongear
- sneaky starting problem
- cracked starter endcap
- regulator damage
- Oil Level - 1972 XLH
- battery question
- stuck in gear and aint going anywhere
- Primary Nut, etc...
- Electrical Questions 1972 XLH
- Battery Cable Question
- tachometer options?
- Mikuni HSR42
- NJ title / registration question
- it's time to put it in the stand i made
- Oil Questions
- 67 Ironhead... Let me know what you guys think
- Choke closing
- '78 Sporty/bleeding front calipers
- 1000cc poping?
- Oil question...
- Installing Intake Manifold
- what weight oil
- 75 turn signal problem?
- Color Pictures
- battery eliminator (large capacitor) on xlch
- 1973 Ironhead Sportster
- Finally!
- 76 liberty edition info
- Dirt bike Sportster
- Some photos of the finished 74 XL...
- Any links on a starter unit for a 70's XL
- late 84 sportster - Need rebuild pdf
- Jetting Suggestions
- wont start when hot
- Starter question
- 75 xl forsale
- oil temp gauge
- Shovester
- Ironhead Mikuni VM 38mm?
- 79 XLS
- 76 xlh carby problems i think
- Is this guy telling me the truth?
- Slow drain in generator or regulator
- Wiring Question for the wire Guru's
- 74 sporster pic
- Quick opinion of tanks.
- compression and carb pop 80 iron head
- Pics of rough 68 sporty
- A question of interest regarding vin numbers...
- Wolf....Your brake plate spacer is made.
- New Bike, whole new set of challenges.
- What to do with a rough 68 XLCH
- 70's gas tank coating?
- Hey all....couple of questions
- ignition switch replacement
- Forward control enxtensions
- IT'S ALIVE!!
- high speed performance weirdness
- Stupid seat question from the King of Stupid
- vibration
- regulator
- new clutch plates
- idea to solve ironhead slipping
- to forum mods
- throttle cable
- Help !!! 81 XLH with Engine Noise
- 81 SPORT TURNSIGNALS
- thanks to all
- 75 ironhead exhaust..pinion.you around?
- wants to turn left
- Who besides me has an XLCR?
- chain adjusters
- speedo cable hookup
- Daniel Boone Forward Controls
- Wheel Spins on the stand
- spring seat
- charging ???
- 76
- oil line route.
- timing issues
- Leaded to Unleaded
- electrical question
- digital electronic ign. HELP
- carb poping
- Adjusting the clutch spring tension on a 1971 XLCH...
- Signal/Horn/Hi-Lo Beam Switches?
- fixed tach and ignition
- forward controls
- ironhead oils
- S&S tuning and jetting..
- 1975 XLCH
- 1971 XLCH Speedometer Ratio?
- historical plates
- is it worth 1500 bucks?
- bendix????
- pic of my 75 sporty
- new to ironheads
- Oil Filler Cap on 1981 Sportster
- Progress report
- idnumber
- twisted front
- XLS 1000 gas tank
- painting chrome
- changing ignitions beb
- drag bars on sport
- Family Tradition
- 68 xlch spark issues.
- DIFFERENCE BETWEEN 81 82 SPORT
- ignition/tach
- Passing time with oil pump question.
- dumb questions
- shifter lever
- Wheel sizes , Front end Q's
- Ironhead pin
- What do I have? (aka - Another VIN question)
- Its ALIVE!!!!
- oil??
- Riser Bushing Set
- Paint code
- VIN
- Speedometer
- back with oil tank issue
- 65 XLCH ironhead help
- has anyone put a kicker on a XLH ? need help please
- valve stem oil seals
- Tank Rust - Before/After Pics
- Ironhead wrenching weekend
- Off Center
- Super B w/ Accelerator Pump
- clutch adjustment
- I need help from ironhead veterans!
- Apes? ....
- XLH 1000
- My First Harley
- Some pics of my hand-tooled seat....
- 59 xlch stroker
- I'm putting electric start on my Iron....
- 81 Sporty - Leaking Primary
- 81 Sportster - Solo Seat?
- Looking for some knowledge ...
- Progress today!--updated w/pics
- S&S carb intake
- IRONHEAD FROM HAWAII
- My wife says it's fine, but I think it's too short.
- Right side shift
- Switching from Drum to Disc?
- SoCal SportSter Show
- Non HD question
- bendix carb
- Hard or not to hard.
- line up rear wheel
- death to my piont ignition
- Right side shift arm quest.....and some entertainment for you
- open primary on a sportster
- Adult subject - My hog is too hot
- Widest tire on '79 Sporty
- Where... What...
- My memory fails me....help
- Starters
- A thank you to all you guys...finally she fired
- Mikuni Tuning
- jet size
- Truly stupid trans question
- new to board and need some IH help
- NEWBIE question about Primary oiler
- Wheels
- 1974 sporster
- Rear Wheel
- Generator for parts.
- 81 Sporty - This doesn't look right
- Timing Questions - 81 Sporty
- Here's something that makes me want to shoot someone...
- 2007
- Confused cams
- need help .drains battry every 3 days.
- vac switch and carb
- Is it a 38 or a 41?
- Ironhead's back...let the nightmare's begin
- Crank
- Springer for a '78
- Oil bag question.....
- First step before maiden fire
- custom seat ideas please
- Clip ons for a 35mm front end......
- Fender blank for a 74 Iron...
- 69 xlh need help cuts off when i break
- Input please...
- Okay, this is one more question about the front end
- 7/8" stem to a 1" stem.....?
- Burnt out gears
- Another question about my front end
- My 1st Basketcase - 1973 Ironhead
- I am ignorant....
- do i NEED a battery for XLCH?
- MOVED: remembering
- Best Electronic ignition? 68 xlch
- riser bolts
- another Ironhead rocker box question
- Tube tire pressure
- Car battery to test turn over?
- Ironhead decided to eat wrist pin
- question about neck races
- Dead battery :-(
- '77 motor seems frozen,dynamite?or other?
- "Glittery" oil
- How hard would it be....
- steering stem (replaceable?)
- foaming oil after top end job
- Computer is down....
- 69 sporty factory chrome frame? yes/no?
- piniongear.are you on tonite
- accident victim
- Gas milage is very poor
- Wheel size?
- ironhead clutch
- 81 Sportster Running Rough
- Frame Question
- Sportsters & Tall People
- NEW FUEL TANK TREATMENT
- rocker box removal
- Best Rocker Box Gaskets?
- sporty knee
- 69 xlh stuck in second gear
- 71 ironhead
- photo request: forward controls on a right-side shift Sporty
