- 07 fxdb slipping under hard acceleration
- Inspection Cover leaking
- 1980 shovel head oil on cjain
- 2001 Harley Davidson Super Glide
- Harley bagger 93-98 Transmission
- Do I have correct spring? Clutch slipping
- RTV Silicone as a gasket or with the gasket?
- Preferrerd 2002 FLTR method for tightening Trans sprocket nut?
- S&S primary race install direction?
- Quad Seal Woes...
- 5th gear seal install depth. The one behind race JGI-12035-B
- Primary chain tensioner and compensator
- 2005 sportster stuck in gear
- Shim Spacer behind Compensator
- Weird Whining/Grinding noise on left side of bike
- Replace rear pulley-2015 Street Bob
- 2016 FXDL goes "sideways on throttle"
- Sportster '03 clutch plates replacement
- Clutch is hard to pull
- New 6 speed locked up
- Alternative way to hold crossover pipe? 08 touring transmission doesn't have holes for 13 exhaust bracket.
- Starter motor wires
- Replace shift seal, no clutch
- Working on your inner primary...? Don't do what I did!
- Spring plate assembly
- Clutch spring question..
- 2000 Deuce - How to change drive belt?
- loose transmision sprocket. Normal to wobble?
- Too high first gear
- helicoil
- Inner Primary Swap 94 Dyna
- EVO Engine/Primary Spacer.
- XG750 clutch cable for "Reach" handlebars
- Jeff
- Is common for the primary to her hot as hell?
- 5th gear bearing fail at 67,000 premature
- Inner primary bearing gone
- front and rear sprocket change help
- 1989 Softail diaphragm spring adjustment plate
- Rattle
- Armored Attitude Adjuster
- Spongy shifting.
- Is it normal
- hole stripped
- Inner Primary Cover
- Which lubricant do I put in my 2003 Road King Primary?
- NEW Hydraulic Clutch Jerks Into Gear. ???
- Transmission Fluid coming through clutch cable
- Need help with compensator re assembly
- Any discount for forum members
- Transmission fluid puzzle !
- Clutch Cable Clearcoat and Shrink Tube
- Which replacement belt to buy?
- Primary
- Clutch slipping
- Metal shaving on oil plug
- 2000 harley heritage
- Clutch won't disengage? Cable just replaced
- Late 84 XLH 1000 only shifts into first gear and neutral.
- Thinkj my primary bearing is going out
- Replaced clutch
- Primary bearing upgrade question
- 1973 ironhead sportster right side shift metal in primary oil
- Jachshaft doesn't engage
- No 5th gear on 96 883 Sportster
- normal??
- Belt primary to chain primary
- Sportster slip shifting and losing power help
- Primary/Transmission Oil
- water in transmission
- Lots of water in primary
- 04 Harley Davidson Roadster (Sporty) 1200xlr
- 2002 RK Clutch Release Cover Bolt Backs Out
- Clutch adjustment video
- 2010 sportster 1200n mains shaft bearing removal & install
- single vs double solinoid braket
- Clutch no work after sitting over the winter
- Transmission help please!
- Shifter Shaft
- 2017 SG Whine in 3rd,4th,5th gear.
- Ratchet Top Shifter Cam Timing
- Difficulty getting into Neutral on 2017 Street XG750
- clutch adjustment
- New clutch cable installation
- Mark I need your wisdom
- mark!!!!!!!
- Help needed please with clutch choice
- Need some opinions
- shop ignorance
- cable adjustment OOPs
- Oil Leak,,,,
- Chasing a noise
- 6 Speed transmission Identification.
- Shifter shaft removal 6 speed
- braking issue
- Gears Clunking When Downshifting
- Dyna 5 Speed Transmission problems
- Shifter pawl adjustment video
- 2006! Road king tranny fluid
- Primo 32t game changer
- HD part #60681-01 chrome inner primary for 2001-2005 Dyna
- What really grinds my gears?
- Starter drive only works half the time
- help removing Starter drive gear
- Are we synchronized
- I broke it
- Is a 22 tooth comp sprocket to small
- Comp ?
- Shift linkage
- Transmission slipping
- 2003 Dyna Low Rider Clutch adjustment nut seized up?
- Impact wrench
- Where is the Slop
- Friction plate question
- Clutch cable length 2000 softail standard
- D.I.Y chain drive conversion kit
- The bastardized 84 clutch question
- Can you switch to neutral at traffic light? I cannot. How many teeth and pins does shifter cam have?
- Primary oil level?
- Chaing tensioner spring and rod flew away, it is $100. Manual says to use zip tie...
- Drive belt
- main shaft seal?
- Disconnecting the clutch inside the primary
- Trans Shift Linkage Oil Seal
- Compensator nut on belt drive
- For Mark @Baker
- Need advice on beefier tranny for a 117 motor
- Baker 7 speed transmission
- New Compensators
- Compensator
- Can 13 Touring oil pan be installed on 08 transmission? Does transmission have to removed?
- Part of static rotor sheared off.
- Compensator
- Speed sensor lication
- 2016 FLTRU rear sprocket
- Slip Assist Clutches
- Vibration in left foot peg (still)
- clutch jam nut
- Transmission fluid level - How critical ?
- Drive Train not engaging
- 30T trans pulley in a Rushmore?
- Trans oil level on a lift is.....
- o-ring
- Vibration in left peg
- 15' RG Primo Pro
- Rekluse Clutch?
- 57h cams
- trans issue
- transmission leak
- Transmission clunk after changing clutch cable
- Clutch Cable Switch
- 1989 FXSTC Tranny leak
- Dyna down shift
- 95 evo primary chain tensioner worn out
- 2013 IPB race?
- Hayden M-6 tensioner or not
- Clutch slipping
- What is size of big transmission bearing? Or manufacturer (not Harley)part number?
- Weird Clutch Cable Adjuster, need to change clutch lever
- gear box issues
- Which non-Harley oil for transmission and primary?
- Do you use red or blue thread lock glue for clutch nut?
- Silver oi, most common problems with 08 transmission, 60 k miles.
- Clutch not disengaging when cold?
- Un-Nerving RPM Spike Issue - Video
- Certified Best Harley transmission installer of Milky Way Galaxy.
- Bike position for removing transmission assembly, jacked, hanged by neck?
- I cannot remove clutch nut because clutch is turning!!!! Help!
- Today I will replace transmission. Questions about replacement.
- Clutch Question
- New 07+ MDG bearing upgrade by Baker!!!
- Transmission case replacement. Should I remove shafts first, then remove case or remove transmission first, then replace shafts?
- Big twin to evo?
- clutch question
- NEW Hydraulic Clutch Question......
- SE comp sounds like a rock tumbler
- Transmission problems
- Primary chain replacement /sprockets ???
- Adjusted clutch and still will not disengage
- Noise after installing SE comp
- Who knows difference between 07-09 and 10-up touring transmissions? Buying a transmission from an ebay moron. moron
- 2001 sportster tranny question
- Best compensator sprocket upgrade
- Best Primary chain Tensioner upgrade
- How long does it take to replace transmission?
- Flakes in trany oil/unable to drain.
- 96 fat boy
- Heel shifter issue
- 2016 FLTRXS Primary bolt question
- Transmission stuck
- Primary Leak on 2009 Heritage Classic
- Clutch sagging In primary?
- Help with my 2012 Streetglide Clutch?
- My 4 speed just died.......
- Silver Transmission Fluid
- Baker Compensator 630-67
- Touring Rear Pulley/Gear Ratio Change?
- Primary Chain Adjuster ?
- OEM or Aftermarket bearings
- Baker Compensator Install Issue
- Just ordered me a Baker compensator .
- 2010 Harley Streetglide FLHX - Oil leak behind/under Primary
- Mainshaft/countershaft lock nuts
- Main Drive Gear Bearing
- Starter clunk
- Chain Tensioner
- Primary Noise
- Pulling transmission
- primary inspection cover
- Clutch hub/tranny/drive belt woes (PICS &VIDEO INSIDE)
- Primary Drive Locking Tool
- Hopefully quick clutch question
- best clutch kit
- Primary Chain?
- 2014-2007 FLH Transmission
- Filter on Transmission case breather hose?
- Front drive belt sprocket
- Primary Case Oil Capacity?
- Sealing the solenoid on my 1988 softail
- Problems with clutch adjustment
- Transmission housing cracked
- Does the All Balls Inner Primary Bearing Upgrade 25-3103 come with the mainshaft race????
- Leak at inner primary from behind transmission sprocket
- Compensator FIX !
- Need your help!!!
- clutch assembly
- 07 fxdb shuts off when I pull in the clutch
- BDL Compensator
- Reverse pattern shift.
- 2004 Sportster Blown 1st Gear
- Upgrade clutch question
- Noise in the Primary
- Installed SE Clutch Spring today
- 2015 Road glide S 1st gear issues...
- Clutch feed back
- Metal on the magnet
- Options for older TC compensators?
- Page Not Found
- First Gear 'Bang"
- Hve a question concerning the IPB on the 09 FLHRC
- Wont catch 2nd
- Se 30041-08
- Trans swap
- 2005 RK clutch question.
- Can't find neutral since fluid change
- 07 Electra Glide compensator
- Shifting Issues on 2015 Street Bob
- Primary gasket kit
- Any mechanics around Milton Keynes
- 72 Clutch going insane
