- Help to remove connectors from plug
- LED issues
- Upgraded Turn signals to LED's
- '72 Sportster rebuild electrical problems
- Radio
- Lower Handle Bar controls don't work
- 1997 sportster having issues
- Jump Started Bike and have lighting issue
- lamps for 88 heritage?
- Passing Lamp - Cyron 881
- LED License plate lighting
- Front end wiring dilemma
- Why aren't they following their own advice?
- Where to pick up brake light power on '16 FLTRU
- 06 ultra classic electrical problems
- 03 Fuel Injected Road King - Dead battery
- electronic speedo to an 89
- Anyone use OLD brightass taillight on '17
- poor packaging of battery from JP Cycles
- bike to bike communication
- 03 Ultra Classic Electra Glide Battery Problem??
- At my wits end, Driving lamps troubleshooting
- Street Bob speedo & tach problems....
- Thunder Mountain headlight replacement
- Fatboy/Softail Tach Wiring
- Led gauge speedo wire harness help!!
- 07 Dyna dies at idle
- Tool tip for electrical connectors
- Needed or Should have Tools....
- 88 Sportster Starting Issues
- 16 FLHXS & JW Speaker 8770 Evo 2 Issues
- Wiring a 2016 ultra tourpak to 2015 FLHXS
- Need Help! 2012 Dyna tach install
- 2013 CVO Road King Audio Issue
- Smoked rear lights
- Reflector or Projector
- Starter button issues
- New XL1200CX Speedometer LCD Problem
- Starter won't turn
- Debug 2002 FLHTCUI Cruise Control??
- Headlight.
- Need starter help
- Switching Oil Brands
- Fob and security code
- Fuel Gauge stuck on 1/4 tank
- Neutral/Oil Indicator Lights
- Weird Electrical Issue
- Speedo disconnection
- Halogen to LED?
- Barely visiblele headlight & passing lamps
- LED Tail/running light issues on 14 Road King
- Drop-In LED Headlight Replacement from DK Customs
- Day maker spot lights fogging up
- Ground wire
- Small two or three wire plugs availability? OEM?
- Turn signal issue
- Bike keeps dying
- Intermittant Speedo Sensor?
- Security Light remains on after using hazard lights
- H-D 7" daymaker headlight.
- Resetting TSSM Issues
- Hot wire
- which bleeding wire
- 93 electra glide ultra classic light turn off and on while driving
- Warning light with Kuryakyn headlight
- L.E.D. vs Halogen Headlights
- 2003 Heritage Softail EFI
- Sportster stops charging once hot
- Brake lights stays on at all times
- 03 dyna wiring issues
- Brand new Harley battery need's to be charge before installing.
- Voltage Regulator or Battery Problem
- Have a miss while running after replacement of battery
- 2001 Ultra Electrical problem
- Accessory question???
- Long time listener...first time caller.
- Bought a cop bike 2008 rd king need info on switching siren over to horn and getting
- Sportster Ignition problem - rigged run/off switch with jumper wire
- Brake Light Stays On 2007 FLHT
- Yet Another Voltage Regulator Thread
- wont start lights go out
- light bulb cross reference Harley to regular
- 1999 Super Glide Tombstone taillight
- cluster f**k of BCMs, brake lights and headlights...
- Bad voltage regulator
- 2003 Dyna FXD Tachometer Wiring Question
- Don't even know where to begin...
- Replacing my front brake light switch
- No left hand running lights
- Passing lamps for 1980 LXH1000
- 16SG, how low should volts register on start?
- Are there any Street Glides with the JW Speaker 8790 Adaptive users out there?
- Rear turn signal bar for Elecra Glide Ulra Limited
- cruise not working 03 electra glide
- Breaker keeps tripping. Please help.
- Turn signal not working
- LED indicator wiring.
- Electrical problems
- 2014 Ultra Classic FLHTK - Lighted Mirrors not working
- Removing indicators to remove carrier fxdwg
- Re-wiring Aux Driving Lights
- Need help with TSSM...
- Help - 05 Sportster 883 custom Electrical Problem
- Engine and battery lights are on on a 2011 sporty
- Kuyerkyn side plate led
- High beam not working
- Oil gauge bouncing
- 07 Superglide security info
- Dakota Digital on 16 RGS
- No power to speedometer
- 2011 Street Glide Rear Under Fender lights issue..
- Starter for 73 kick start fx
- 93 Sportster having starting troubles
- Iron 883 brake lights
- Fuse for tail light
- Neutral/oil pressure indicator led light board out
- Which is low beam wire on 2012 streetglide?
- Fat Bob Main Harness.
- Alarm beeping for no reason
- Electrical Gremlins
- Street Bob electrical gremlin
- Amp draw 2007 Screamin' Eagle Ultra Classic?
- Running Lights blowing fuse
- Battery tender
- Nothing working after handlebar swap
- 09 FXD Blinkers not working
- 2014 Dyna Low Rider Brake LIght Issue
- P&A Power?
- No power
- Gerbing permanent controller wiring question
- LED Headlight Upgrade
- '13 FTLRX issue
- Help with tp led light strip
- Bus Er
- factory ECM or alarms a Parasitic drain?
- radio and cruise shutting off while riding
- 2004 soft tail coil question
- Speedometer and indicator lights not working
- Issue with head light and brake light?
- Turn On Switch and Nothing - Help Needed
- Headlight upgrade and questions?
- 08 StreetGlide
- electrical issue with softail deluxe 2013 help
- New Parts (x2) and still have issues
- headlight upgrade ?
- Bad Battery, bad coil?
- Spark no spark dead coil
- Help with Accessory Fuse
- Dirty ground wire
- Solenoid repair
- Front turn signal relocation.
- Does anyone have a picture of inside the lower right handler control switch cavity
- Dead Sporty
- I have two bikes mine and my wife's bike both have batteries that are about 3 years old
- Proximity problem between fob and module
- 2013 ultra classic limited
- turn signal starts flashing on its own
- Bike won't start even with clutch in. Neutral not showing.
- 2011 fat boy switch modifications
- LED Guage bulbs.
- Need help chasing trons - indicator lights
- Which brake light modulator to use?
- 1997 to 2000 dyna handlebar control compatiblity
- Tutorial on replacing a Sportster battery
- Security install question
- Need 1995 Road King Wiring Schematic
- help wireing new bike im lost
- 1997 Dyna WG rear brakes and turn signal out
- All lights turn off when I plug in the grey harness
- 09 RK fuse or alarm issue?
- Deka ETX20L battery - is that HD original?
- Led strip ligjts
- My horn stop working on my 2015 HD SG special.
- 85 flhtc power problem
- circuit breaker tripping
- Rotating PLATE mount w/light...
- Clutch Cable Spark
- Converting to LED and need some help with the wiring
- 05 Sportster turn signal fault
- Strange Low Voltage Problem
- Security System Question?
- 2005 fxdxi help!!
- All Electric Power Sudden Total Failure while riding
- Unplugged all wiring to remove fairing, doesn't get power anymore
- How do I replace read turn signal bulb on 2015 streetglide
- 93 sportster hugger no start
- Electrical/Lighting Puzzle
- Smart Siren and Pager
- 06 street glide battery issues
- Charging System Issues.. Stator??
- 2008 FLSTC Overcharging batteries/Burning up Regulators
- charging issue ironhead
- High Voltage Problem
- How to remove pins from this connector?
- dual auxiliary power connector?
- Security light remaining on
- New Custom Dynamics LED turn signals...one side works, one doesn't.
- DK led lights - question
- Shovel head voltage leak
- 2007 softail FLSTC no electrical power
- Upgrade of aux-passing-spot lights
- New voltage regulator, dead battery.
- Complete loss of power.
- Rear bulbs overheating/burn out?
- 1992 fxrt fairing signal stays illuminated
- Bike Won't Start
- Help with Accessory Switch
- Security help!!
- 07 FLHTC Security
- Tsm/tssm problem im 2002 fxd
- Speedometer stopped working
- Lightbar high beam causing short?
- 1998 harley davidson fat boy wiring
- were to buy strobe head lights and tail lights?
- No Spark!
- Great Support from Custom Dynamics
- Wiring headlight without harness
- Wiring in a horn (basic wiring question)
- Reverse help
- 2016 infotainment system in a late model Electra glide
- 1972 FLH Charging Problem
- Truck Lite Low Beam Failure
- 2007 dyna superglide custom Right Turn Signal inop
- Signal between fob & alarm receiver too low
- 2003 FXDL won't start
- 15' hd 48 speedo , trip, ,gear ind. not working
- Strange Speedo prob
- Electrical warning light-intermittent.
- Voltage Regulator Scary
- Came outta work to dead 1991
- 95 harley davidson heritage softail ignition switch wiring diagram
- LED Passing Lamps on '14 Slim... Error code
- Passing Lights on '04 Roadking
- Another Cruise Control not working
- found my problem, but stumbled on something else/harness wiring
- Speedometer Problem
- Wire fender light to brakes
- Custom Dynamics Question on FXDWG 97
- ECM flashed with different VIN sync with factory speedo?
- All dash indicators not lighting up..but signals work 99 Softail
- lithium battery
- Voltage spikes
- Speedo problems
- Adding GPS to '07 FLHRC. Need info on connector.
- Starting problem
- Check Engine Light
- Passing lights not working.
- Engine Guard-Mounted Fog Lamp 68000118 Install
- 85 Sportster XL883 Electrical issue
