- leak on left side engine shaft
- Finishing 77FX build pics and some tech questions
- 81' Headlight
- 6 Speed Box for my Shovel
- Quick release on vintage hard bags?
- Help!!!
- Another Suspension Question
- 1982 Sturgis Edition FXB - PICS attached
- Need Recommendations for Shocks
- Front brake cylinder options
- Rear Wheel Off Center
- hammering
- New Guy needing advice
- 78 FLH 1200 Turn signal flasher
- After warming up, Engine sputtering to a stall...
- AMF 16 spoke wheelassembly, please help
- 1979 AMF 16 spoke rear wheel fitment
- wants to trade
- first gear difficult
- Clutch Vibration looking for Ideas Early 84 (3 finger clutch)
- Torque Specs for exhaust studs
- Question about rear brake- 83 fxr
- Front fender bolts
- 1977 electra glide charging system
- Dot 3 vs. Dot 5
- Apehanger question
- 77 Electra glide passenger footpegs
- 71 Super Glide Motor won't Turn Over
- Starter just spinning
- Starter issue on '77 electra
- Starter grinding
- Barn find needs input on new ignition
- Want to put floorboards on my '72 FXR
- First Shovelhead
- Anti rattle clip
- Stock ignition anomaly
- Torquesetting swinarmpivot FXE & forktops
- My new '72
- found this
- 68 Electra glide
- 77' clutch spring measurement
- Grrr!! Starts great, idles great, backfires under throttle...Video attached
- chopper shops in the central valley of ca.
- Stock Shovelhead usable RPM Range?
- 79 FL Lowrider for re-home
- Drag pipe recommendation?
- New to the HD world and need some help.
- 1968 flh primary full of oil
- 1968 flh primary full oil
- Cost of a decent used Shovelhead
- 4 Speed Trans Identity
- Smoke once it's warmed up.
- What am I getting into?
- Classic Cop Bike
- Hand Controls
- Solenoid plunger greased or dry?
- 73 flh kicker wont engage after clutch adj
- Fixing Twisted Frame
- Dyna S ignition module problems
- kick start install issue
- Color codes on shovelhead cams
- Fixing up the old Shovelhead
- Rim strip width for FL?
- Exhaust for FXR - Cycleshack vs. Paughco
- Possible Purchase 80 FXE
- New to Me! 79 FXS ?
- Running stock headpipes w/o mufflers?
- Spark Plug thread broken...
- floating calipur
- s&s jetting
- Tan wire...???
- 74 Shovelhead
- 82 FXR Brakes
- loose tappet?
- Marlon Brando's Harley
- 1979 lowrider rear axle torque
- Newbie Intro
- Can't start!
- Sealing a gas tank... What should I use to plug it?
- Bad plug
- Tins for 82 FXR
- CV Carb conversion - Air Cleaner Assembly help
- New Home
- Throttle sleeves
- Shovel chop rear signals easy
- 82 fxwg
- 1974 flh not charging
- Is this really normal?
- Shovel is smoking from oilcan and oilfilter? Why
- Carb Rebuild Kit
- need some flt 5 speed help.
- Shovelhead issues
- Kick Starter
- Dumb question about turn signals
- Shovel Signals
- Foam in Oil
- Autolite 4265 vs 2585
- Cutch noise/no kicker
- Preferred solenoid brands?
- Springer swap
- 1985 flht
- Front brake locked.
- Oil Pumps...for best reliability....?
- FXWG 1986 facts
- 2 into 1 Exhaust for 1982 fxr
- 1975 FLH 2 piece handlebar upgrade
- Inherited '80 Low Rider, shoots sparks
- Rotary top jockey shift/rocker clutch
- Solid vs compensator sprocket ?
- tire pressure
- Fork Oil.
- Late model bags on my '77
- Fabob Fuel Tank collects water under console
- Old horseshoe oiltank..
- '71 FX Superglide - couple of questions
- FXR 1982 Shovel Steering Head Bolt Size
- New to me 72 FLH need some advice
- CV carb no go at WOT
- Clutch Push Rod help
- Stewart Warner speedo ID question
- Fender question
- Shovelhead electrical problerm
- 77/78/79 Low Rider MSRP ?
- Kick only not charging
- 1982 fxrs
- 84 FXSB Tachometer Help
- Lifter wheel bearing failure
- Center dash light 1974 flh
- Shovelhead speedo question from Finland.
- 84 lowrider bobber
- FLH extended rear brake pedal??
- Updated the front of my '77
- Am I crazy??
- Oil
- My shovel is in my grasp! Biker soul but beginner wrenchman here!
- 79' FLH Clutch and Sprockets Upgrade - Experienced Advice Wanted
- Wiring vs Switch on 75 FLH
- Fuel gauge needle goes to E full or not
- Upper motor mount on 1982 FXR....
- Spring is finally here, im ready to go
- a question about compression in PSI.
- 1976 Shovel Broke Stuffed in an Evo Motor
- FLH-80 wheel fitment question
- 1200 FL with S&S "B" problem.
- New look for an old girl.....1980 Sturgis
- Compression release or not?
- How to snug up the popsicle?
- Tapping noise 1974 FLH
- 1966 FLH Pogo prob!
- front drum brake
- Oil cooler
- Optimal Jets Super E
- Banana calipur tight
- First Ride 82 FXR
- Shovelhead rear shock dissasembly
- Primary belt drive
- Primary Belt Drive Wear
- Can someone identify this bike?
- 83 fxrs help
- 79 shovel
- Oil Filters
- New to Me 1982 FXR
- Rear 12" shocks
- New to me 1982 FXR, questions
- 1970 FLH DMV says its a 1981 Custom
- Evo ignition on a Shovelhead
- New to Shovelheads
- Removing an Ignition switch
- Trim pieces in place of blinkers
- West Coast gas eats petcock rubber?
- center Stand
- Troubles With Shovels
- dang S&S
- New to me '77 FL
- Rear Master Cylinder Dilemma
- Need reliable FLH mechanic/shop in Los Angeles
- Using banjo fitting on 1978 style MC
- am I missing a front seat bracket?
- Breather Gear Causing Whine?
- Rear Cylinder backfire
- hello i'm new and need some advise
- "Juice" Rear Drum brake adjusment
- WTF...Just happened...?
- Banana Caliper 1974 flh single disk
- Do I need dual plug heads?
- Waterline?
- '85 FXWG Upgrade ??
- Engine Vin Question
- New Shovelhead Owner...Problem.
- 78 FL Shovelhead project
- front brake noise
- 5 speed clutch adjustment
- 82 FXR - Engine Fins - Paint it Black
- Shovelhead FXWG transmission - is this normal?
- 80ci parts in a 74ci?
- 4 way hazard flasher
- Tire Pressure - 82 FXRS Shovelhead
- to old of bike a problem?
- What can I expect from my S&S 80" Top End Kit?
- Starter solenoid 1967
- first bike could use some help......
- ROCKER SHAFT PLUGS/NUT question
- Remove Transmisson question
- scrapes on right hand turns
- fuze?
- rebuild
- Rubber Mounting a '79
- Need advice on 84 FLH
- Kicked Off Shovelhead Forum?
- voltage meter inputs
- negative corrosion
- Screamin Eagle 7 pin ignition module on a 72 Shovel
- Shovelhead Forum?
- The hunt is finally over! Found a full 66 shovel chop!!!
- little black buttons in old style shovelhead controls
- What's a good price for this 1982 FXRS
- Electrical Puzzle
- Looking to Buy a Shovel - FXR?
- Shovelhead killing battery
- rev tech 4 speed made in usa?
- 1997 FLHT front end on 1978 FXS
- need help finding 1971 fx super glide decals
- Solid Lifter Noise
- Help in identifying this rear fender
- rear swingarm bearing upgrade on FXR?
- Nicest Shovelhead Custom out there
- old stf oil lines
- ultima King spoke wheel
- Finally it's Finished.
- 77 flh kickstart install
- carb time
- Swing arm bearing assembly
- Started leaving trail of oil
- 82 FXR won't turn over
- 82 FXR Won't turn over
- shovelhead compression issues
- Blown head gasket
- Obsolete Parts, who knows where to get stuff besides Ebay?
- Andrews A vs AB ?
- Just Purchased a 1966 FLH Shovelhead!
- Ignition recommendation for '83 FXR?
- Shovel build from a pan
- 81 FLH Rebuild
- How many FX Superglides were made in 1974/75/76 etc.?
- Update on my 1980 Shovel FXE/FXWG
- my COB method to counter boring rocker arm spacers
- Parasitic Draw
- 1978 FXS- Gonna keep it stock
- 1980 Sturgis Worth?
