View Full Version : Shovelhead
- Rebuilding Rear Shocks 79 FXEF
- Shovelhead fork oil not passing properly
- Isolated primary
- coil cover
- Whats it worth?
- Exhaust stud broke
- Tank Emblem
- 1970 FLH Tranny top
- 73 FLH is this normal piston wear?
- Comfort Flex seat question on 74 FLH
- Shovel head parts
- Ignition System Recommendations
- Need a solid guide on 80 fxs
- oil pump gasket
- Plastic Breather Gear
- In A Moment Of Weakness
- 61 pan/shovel
- Milling Primary Cases
- Engine- parts color
- Evo 5 Speed in a Shovel
- "Chasing The Dream" Re-loaded 1983 FXDG !
- My new to me 55/66 Pan-Shovel
- Oil filter
- high comp starter?
- Delete
- ...Blown head gasket, or oil line leak?
- Ignition on the blink.
- New Parts for 78 FXE
- pan shovel
- Shovelhead Ham Can air cleaner on Twin cam
- which pistons?
- S&s no longer warrant their engines
- Stumped with wiring. Wire getting hot.
- Harley rims
- Looking for neck (frame) protectors
- Battery cable terminal sizes
- Tank question
- Yay for Lucas Oil!
- points, ignition questions
- posting pictures
- best shovelhead gaskets
- Ignition coil busted?
- Torque Specs
- 11 digit AMF VIN
- Wheel spacers.
- cast wheel end play
- Clutch Push Rod Length Question
- Has anyone tried this?
- 1981 fxb sturgis
- Struggling to get new build running (kick only)
- What valve seals do you have on your shovelheads?
- 1981 FXB For Sale
- 80 FLH insight please.
- Cone/witch hat throw out bearing hits kickstarter gear
- Shovelhead Electra Glide with Sportster seat
- Wagner Master Cylinder issue
- hey forty bikes at the bar and I'm the only shovelhead.
- Shock hardware
- Headlamp upgrade
- 76 FLH Lifters
- 82 FXR Cam question 3B996
- 1980 FXB Sturgis
- Tube or Tubless on cast wheels
- Oil Sumping woes.
- Left engine case surprise - help!
- First Shovel! 1980 FXS
- Akront 3.5" Rear Rim Clearance Issues
- Height difference, normal?
- Electrical Question
- 74" top end freshen up and cam
- 21" under FXE narrow glide fender?
- Are spoke angles same ?
- 18" rear 9 spoke wheel on 83 FXR
- alt rotor?
- Transmission bearing support/spacers issue
- Internal fork stop kit?
- 1983 FLH Keihn Screaming Eagle carb parts
- 1982 FLH mirrors
- 1978 Electraglide Maintenance
- Spark plug wires
- New Years Day Ride
- Shovel porn
- Shaker floorboards FLH
- Evolution of a Shovelhead - Picture Essay
- Ray's Magic Tranny Spacer
- different dash swap. brackets the same?
- 1972 Shovelhead Oil Pump Binding
- Exhaust stud snapped off...
- 77 FLH for sale near me.
- Shovelhead belt primary (internal)
- Fly wheels
- First Shovel
- Merry Christmas
- Latest shovel project
- Countershaft Endplay/Spacer Mystery (Caged Bearing Late 77)
- Rotor info, please
- DOT 5 Brake Fluid Small Blue Lumps
- 3.59 overall drive ratio on a 74” shovel?
- spaceship harleys
- Liberator Vetter Fairing - The Bay
- 1978 flh 1200
- early FL head stem steering damper thread
- Color
- Too much carb for my shovelhead?
- New lipstick on the old girl
- 1980 Fat Bob Big Twin Carb
- 49-77 fork internals questions
- Trans is out
- Solid pushrods vs adjustable
- Rear Chain
- Rear Schock mount issue
- 84 shovelhead ?
- Stator?
- FXB-80 value?
- Late 70’s shovelhead in panhead dropseat frame
- Need a little pushrod advice
- Starting Issues
- Stator oil seal
- 1970 FLH Clutch/Brake Levers
- Aftermarket 2 into 1 exhaust
- Oil pump... pack or no?
- Your's for only $35,500
- Some starter advice needed.
- 82 exhaust
- Sales literature
- Smaller Battery for FXE
- pre 77.5 fork questions. upgrades?
- 73 FLH Wheel size?
- 81 FXE Restore
- Primary isolation
- old shovel top fuel
- S&S oil pump install - question on Step #5
- can anyone tell me what this is?
- !979 Low rider Carb recommendations
- Oil pressure switch leaking on new shovel motor rebuild
- 1984 fxsb
- 83 FXDG constant oil drip from crankcase vent: broken breather gear
- Replacing gaskets
- Piston recommendations
- Float valve
- Joining you guys over here with my unusual Shovel
- Clutch rod question
- Pan-shovel pics please
- Hypoid gear oil in 5 speed
- Mouse trap function
- Shovelhead OEM Replacement Oil Pump Cover Question
- Advice on starting new rebuild
- Pic of FLT or FLH with forwards
- Rocker cover Carb support
- Rainy day project, brake pedal lever
- Rocker arm end play, is it a thing?
- Starter spins when connecting battery
- Tour-Pak install
- whats a good engine stand?
- Performance machine rear calipers
- Starter Assembly Housing Thrust Washer
- 76 super glide fxe stroker
- Laced wheels
- Accell A557
- Chop Question
- Exhaust Flange Bolt Hole Repair
- 72 Superglide
- 81 Shovelhead Electrical Problems
- S&S piston I'd
- Oil leak from case bolt ?
- Shovelhead Years / Models
- 66 Shovels
- Contemplating selling the shovelhead, what is it worth?
- Choker seems broke
- Reproduction Buddy seat
- Kick starts cold, but not hot?!
- Dash bulb sizes
- Karata belt drives
- Mounting king tour pack
- FXB inner primary color
- AMF wheel fitment
- battery
- Can someone please explain what is going on here.
- Dies at idle after top end rebuild
- 5 point clutch hub
- Push rod cover tools are back
- Need help truing flywheel’s 82 big twin
- 71 Electra Glide resurrection
- Trany fluid leak thru mainshaft
- Daytona twin tec issues
- James Fire Ring Gasket - Stud & Nut Kit
- Battery
- Old Blue has been patient long enough
- Would you trade mine for this?
- Engine vin question
- New to me FLT
- Primary Oiler Question
- 1/2 Bendix intake spacer?
- do shovelhead runs hotter than other engines
- Shutting off Randomly
- Top End Break In Miles - ReTorque
- Best replacement compensator for 1978 FXE?
- Trying to figure out how I measure the thickness of the washer I need on pinion side.
- S&S Carb to manifold mounting bolts torque
- Update on my Ham Can install on the Twin Cam
- Dull knocking sound
- Enclosed beltdrive primary
- refresh 76 Shovel
- Chassis number question
- Any help with a factory ham can cover
- Gearbox leak
- 1978 FLH-80 fork oil refill problem
- fender struts, fender width?
- 67141-67p or 67143-78 speedo mount?
- 76 FXE tach wiring question
- New to HD...78 Shovelhead
- New Ride - 76 Shovelhead
- Identify parts
- 79-80" - 4 questions
- S&S SH 93 vs stock shovelhead sound
- Breaker Trips
- Trans locked up !
- clutch
- Internal Throttle Screw Removal hints
- 4 speed ratchet top kick arm throw
- FLH with handshifter
- This might be the one.
- Old style FL saddlebag lid foam replacement
- Intake Manifold Alignment
- Cometic Rocker Box Gasket C9986
- Anyone Running 25 Tooth Engine Sprocket?
- Kicker cover studs long vs. short
- Assistance required for Shovelhead Novice
- Spark plug thread size?
- checking a shovelhead for swingarm play
- Starter/solenoid shorting issue
- Found one closer to home.
- Old dudes I need help
- Gonna try a PTFE 3/8" ball for check valve
- What would ‘PAY’?
- Trying to read my spark plugs
- 75 Shovel
- The end all of shovel guys
- Engine case porosity.
- good article on crankcase breathing
- AMCA Australia weekend
- FXR Exhaust Pipe Help!
- Engine Assembly
- Deka ext16 battery
- Working on my 83 FXDG
- Carb Swap S&S/Kehin
- Gas Tank
- Hyd Lifter Adjustment
- AMCA Meet Greenfield Ma - anyone going?
- 84 FXSB Shovel, need educating
