View Full Version : Shovelhead
- top end rebuild
- Now I get it!! I love my 1971 FLH
- 75 shovelhead Circuit Breakers
- Front wheel assembly
- Shop
- True dual fishtails?
- Rear wheel bearings
- Decided to sell it....
- Harley FLH Engine Whine
- Tail light and left turn signal quit working
- 81' 4-speed trans question
- '81 Sturgis Starter Problems
- 74 to 80 inch differences
- 79 FXE belt to chain swap
- 73 shovel timing cover ?
- 1974 harley flh 1200 question
- How long does it take for your Shovel to warm up??
- Fairing Stereo Install
- Strange electrical problem
- to all the shovelhed guys
- Finally....it's right.
- Shovel manual
- Solo Seat Post Springs
- Ignition Problems
- another batterie
- 79 flh
- Leaking oil into cylinders
- 1980 FXWG primary chain housing oil fitting
- Need order of installation.
- foaming oil
- Carb question...
- Disc brake 78 FL
- cheap sell **** dunk,**** shox,**** air max,******1-23cheap
- oil weight
- Bates style seat on swingarm frame???
- help! growling primary
- 1974 harley flh chain specs
- 77 shovelhead valve noise
- Another Clutch Question.....
- Starter issues...
- carb
- clutch issue
- '72 Saddlebag Lids Coming Loose!!!
- 78 shovel oil lines
- 78 FLH shovel ign help
- cables 79 shovel
- Can't get a full turn on my S&S super E
- Slow return to idle
- what is this, dyna lowrider shovel???
- Blowing Oil
- Shovelhead insurance
- oil filter shovelhead
- 77 flh
- dry push rod adjustment
- Need some help on Value of a 61 FL
- Evo style Lifters
- Whats with the little spacer between the manifold and carb?
- Raked trees
- 1983 FLT Parts on a 1980 FLT
- Whats the secret to open primary install?
- hydraulic conversion lifters?!
- betteries or somthing going crazy
- Looking at 71 FLH to buy
- 1968 FL Valve Adjustment
- Shovelhead module
- Smoking Shovelhead
- Shovel- starter does not engage
- Advanced Carbon Composite helmet recall
- Lowering '76 Shovelhead
- oil pressure
- Spares on board
- '76 Shovelhead clutch slippage at speed.
- 77 Shovel loosing jugg an power while riding
- electronic conversion to points
- Battery problem
- "72 FLH Hit The Road Last Night!
- Carb cough
- starter
- Cam upgrade?
- 81 FLT Saddlebag Latch
- Oil line help needed....
- spark plug time serts
- Oil draining out of breather
- Shovster question.
- Spot Lamps on on "High Beam"
- 84 FLH Need Good Source for Parts/Accessories
- dual plug heads.
- turns over but won't start
- Head Casting #'s
- Throttle for S&S Super E
- Need help ID'ing a frame
- 1979 FLHC. Seat (ditch the Pogo??)
- 75 FLH Starter issue
- Harley davidson 1207cc shovelhead flh 1977
- Piston change
- Short circuit or sum thing....
- Shovelhead bigbore/stroker owners!
- Short circuit or sum shit....
- 83 FXR Low Glide
- 78 shovelhead clutch issue
- 1972 FLH Electra Glide "NEW TOY"
- "72 FLH Gearbox Oil
- BAD oil leak
- 73 FLH Restoration Information
- 76 troublehead, lol
- question 2: Passenger footpegs
- question 1: fender struts
- 77 FLH forward controls
- '76 FXE Rear Caliper
- 83 FXSB Sturgis
- knockin in my primary?
- 79 fxs
- Help With my FXWG...
- 81' FXS Lowrider font end question
- Shovel roller
- 190 main jet
- 1982 FLT shovelhead
- Windshield.....
- Help a girl out??
- bigger front tire
- 80 Wide glide rear brake problem
- Old tank liner chipping...
- 1975 FLH w/ 1975 Z-90 vin number
- Swap gas tank on 75 FLH what years are the same?
- clutch hub and compensating sprocket nut sizes
- Speedo Dash Light
- clutch adjustment 80 fxe
- Stuck motor
- oil in primary on 78 FLH shovel?
- 25 years & Older Insurance
- #1 points cover
- Super b pop's / thru pipe's ??
- trouble shooting coil
- 25th gear
- what is stock rake for fxs &flh
- Extended clutch cable
- what's a CLE
- suicide is painless.....
- Inner Primary Help Needed
- need to modify cable for suicide.
- Part Number f/ rod set
- CV on Shovelhead
- Old FX fenders
- crane cam install help needed !!Ok, here’s my question, I have a 1978 shovel head mot
- potential damages from valve adj
- shovelhead value
- Brakes for a 1974 FLH?
- Intake manifold for CV to '66 Shovel
- Shovelhead Compression Release
- Need help on shovel
- Spoke rims on an 80 FLT
- Stator Issues
- Bendix Zenith Carb Rebuild
- hydro lifters
- exhaust
- Inherited the FXB! Questions.....
- Shovel project
- Softail shovel
- 72 flt feels slugish
- Old OEM Shovel parts
- fork leaking fluid
- Solid lifter question
- need some help
- What about this 1984 FXE?
- in the cone ignition system?
- Ok gearheads, need some advise....
- Tappet Explodes, First 4 me!!
- Chain enclosure for 1980 flt
- lifter adjustment
- lifter adjustment
- 1980 shovel
- Should I buy this 1979 FXE?
- putting main gear seal 4 speed
- 78 FLH gear oil leak and fixed pipes
- valves
- Rear Brake Assembly for 1980 FLT
- 1980 shovel
- Baker 6-into-4???
- electrical problem? pow pow
- engine dress-up?
- Silicon-bronze guides and Manley S/S Vlv.
- valve guide seals
- Shovelhead Neutral Light Stays On
- Super E on shovelhead
- Should I seal primary or not??
- 1982 flt
- FX Rear brake master cylinder mount
- 1977 Harley FXS low Rider
- Softail wheels on my shovel
- new oil tank
- will sporty front end fit?
- Replacing pinion shaft
- best spark plugs and what model#
- Looking at buying a 1977 FL, any words of wisdom for me?
- Suggestions before starting after long term storage
- gas tank
- Clutch release bearing question
- piston problem
- Interchangeability of saddlebag rails
- shovelhead torque
- 1975 AMF build?
- hard to start 78
- Primary/final drive..
- Carb Issues
- Recognize this?
- Engine Transfer and will it fit
- wrecked shovelhead
- i need help
- serial --shovelhead
- need a builder in nj
- Shovel hybrid 128 cu in
- oil pump
- crankcase vent
- Removing decals under clearcoat on saddlebags
- Rocker Arms
- 79 fxe tank lift
- Comfort-flex assembly dimensions
- cluth hub removal issue
- Help my 82 fxe broke today
- Shovel Top End
- 1979 flh
- So...how important is an oil cooler?
- Looking for Primo Brute Classic Belt drive
- 1980 FXWG kick start
- Ignition issues on a 1980 FLT
- Pro Clutch noise?
- 1969 Electricglid front forks
- Jetting for Keihin CV carb
- FX Sturgis 2:1 pipe question
- What to flush tranny with before new trany oil?
- How hot is too hot
- 1966 FL-Ape Hanger Install
- Spark plugs keep going bad
- Dual Plug SHovelheads Ignition Choices
- kickstart install instructions?
- 1980 FLT bend inlet valves
- 71 superglide
- Crankpin torque
- ignition
- 1978 flh
- 67 FLH issues
- 63-69 saddle bag latch
- shocks
- More Blonde Questions...
- Going Rigid.. What do I need?
- Clutch adjustment 1980 flh classic
- New style Forks in an 80 FLT's trees???
