PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33
  1. Want to start lookin' at Shovel FXRs...what to look out for?
  2. Anybody exchange shovel engine cases w mo co?
  3. Kleiv Motorcycle Products
  4. solo seat clips
  5. '83 FXRT valve noise... sometimes
  6. Rocker gaskets, carbon build up
  7. 1979 FXEF 80 ci need fuel tank, want belt drive
  8. starting problem
  9. FXWG sideplates on FXE?
  10. Overheating Shovel / Timing Issue
  11. Early Shovelhead FX Forks - Need help
  12. 68 FLH Basket Case
  13. Tappet/Hydraulic Unit Question
  14. front peg mounts
  15. Any suggestions on were to buy parts?
  16. Sissy bar side plates for 83 FXE
  17. Starter solenoid question
  18. clutch plate springs help
  19. gasket sealant
  20. '74 FLH backfiring...
  21. Shifting Problem
  22. Touring tires
  23. Looking for a good mechanic in Tallahassee Florida
  24. S&S super E trouble
  25. Sticky rear brake
  26. Drive chain stuck between trans and inner primary
  27. Was I just insulted?
  28. Tsubaki final drive chain
  29. Any Shovelhead FXRs here.
  30. Looking for 12.5 inch shocks for 68 FLH
  31. Age-old oil leak around transmission output
  32. 76 FXE Redo
  33. Leaky Tank
  34. 73 fxe
  35. Rivera pro clutch noise
  36. led tail light for 78 FX
  37. Lost my carb!
  38. seat for 83 flht
  39. Crazy Frank Rear Fender
  40. Need help locating
  41. Polishing Engine and aluminum
  42. 1983 fxdg
  43. super g on a shovel
  44. What do I have?
  45. thanks
  46. charging system
  47. Panshovel Conversion
  48. cam,lifters.HELP
  49. 1982 superglide suspension
  50. Drive chain
  51. what did I jack up?
  52. Brake drum/ backing plate/ hub
  53. cam timing
  54. Front jug bolts.
  55. HD blues
  56. Hole in round swingarm
  57. Oil Pressure
  58. Oil pressure light
  59. amount of fork oil per leg
  60. push tube leak
  61. screaming Eagle
  62. Rear brake lever for '79 FLH?
  63. adjusting hydro lifters
  64. Exhaust Question
  65. crank case
  66. New to shovels
  67. Smoke
  68. Squish exhaust removal
  69. Shovel Porn just because
  70. 73fx bad news
  71. Purchasing First Shovel
  72. 73 fx cam removal
  73. Primary oiling question
  74. 1973 fxe oil gear
  75. What do you guys think this is worth?
  76. Installing piston squarely front banana caliper 1978 FLH
  77. Hard Downshifts - finding neutral not easy either
  78. petcock
  79. Crank Case needed for my 1969 FL Early Shovel
  80. carb
  81. oil pressure gauge location.....
  82. Chain
  83. Can you over oil the top end?
  84. Draining oil from cases?
  85. cant get it started
  86. Clutch Squeal
  87. rear suspension for 68 FLH swingarm
  88. Backfire
  89. Turn signals
  90. no spark
  91. What's it worth?
  92. 1971 fx
  93. 5 speed for shovelhead?
  94. 1977 oil leak from front drive chain sprocket
  95. Oil, types and volumes
  96. 84 FLH...A Proper Intro
  97. Trying to ID my motor
  98. Fairing questions
  99. Exhaust headers for 68 FLH
  100. 1971 idle twice as high when hot
  101. Any forum cover a 1975 Harley SS 250?
  102. pushrod seals
  103. primary leak
  104. 1976 FLH Electra Glide 1380cc AMF Service Manual?
  105. 103"stroker
  106. Looking for help- what are these parts worth
  107. Disassembling inner primary
  108. headlight dim
  109. Shovelhead aluminum control finishes
  110. shovel
  111. Shovelhead tries to start itself
  112. Setting up a CV Carb on a Shovelhead
  113. what do you guys think about this shovel
  114. Can the cam be 180 degrees out ???
  115. New Member in Ga.
  116. Minimum disc brake rotor thickness
  117. Coughs and sputters
  118. shovel drum brake swap for disk
  119. 1979 Low Rider Shovel
  120. Spitting a low RPM's
  121. Noise & Unknowns
  122. My old 76 Electra Glide......
  123. 84 shovel
  124. shovel oil leak
  125. Hylomar
  126. oil lines
  127. 82 fxrs died on hwy
  128. Starter problem
  129. Aftermarket WG frontends
  130. leaking AGAIN
  131. New Guy question on Shovelhead mystery...
  132. Interchangeability of Tappets - 1980 FLT
  133. Rear tires
  134. solid lifters on 74 shovel
  135. FLT to Road King front end
  136. Need help with tuning...
  137. Newbie here and new shovel owner
  138. constantly blowing oil...
  139. Fwd Controls
  140. 71 shovel dies when decelarating
  141. banana caliper
  142. Brand spanking new shovel
  143. I need your advice
  144. The problem is keeping her going...SOS
  145. 84 clutch help
  146. Newbie Advice needed.
  147. new shovel owner
  148. '76 flh starter relay wiring
  149. oil sumping?
  150. Mechanics quote
  151. Need help making barn find road ready
  152. S&S Superstock Shovelhead
  153. S&S shovelhead...carb/air filter problems?
  154. Riding again
  155. Compare Old Shovelhead Electra to New Twin Cam Road King
  156. Trans Trouble Update
  157. 1977 fxe motor
  158. fxrt
  159. '67 Shovelhead Electra Glide: What's it Worth?
  160. 84 shovel worth
  161. Starting Problems
  162. shovelhead
  163. 1983 shovelhead rear cyl poping
  164. brake question
  165. Is this YouTube video any good...
  166. 81 shovel re-build
  167. Vendors for NOS Parts
  168. 1983 shovelhead, misfireing at high speed???
  169. Primary clicking noise.
  170. Need parts for 84 FXEF
  171. 67' FLH rear shock bolt
  172. Newb W/ questions.
  173. backfire through carb.....timing to advanced?
  174. Dry Clutch
  175. V-Factor Ingition Mudule
  176. I can already see that the Shovel Forum
  177. Clutch lever going slack??
  178. Replacement Parts or Interchangeable
  179. Ignition module bad?
  180. Dipstick blowing out of oil tank on 1973 fxe
  181. 1978 fxe
  182. shovelhead starter Jack shaft
  183. wanna add a kicker to 83 fxe
  184. 1981 FLT Tour Gluide Value
  185. '77 Electraglide
  186. turn sigals
  187. Starter just keeps on crankin
  188. Aftermarket speedo
  189. 78 shovelhead primary help
  190. leaks
  191. Starter Relay
  192. Coast to Coast Shovel
  193. brake movement and rattle
  194. 1982 FXB 'Sturgis' dry clutch question
  195. Motor Shims???
  196. sweet 1980 fxef fatbob for sale in the uk for £6000
  197. Need help removing Barnet Scorpion clutch
  198. 67 eg
  199. aftermarket inner primary
  200. Old project on back burner for over 10 years
  201. Casting Numbers - Outer Primary Cover 60506-77
  202. 73 FX From Points to Electronic
  203. Shovel oil leaks
  204. transmission trouble
  205. Oil Leak Problems
  206. 1979 FLH won't start
  207. shovelhead engine id by features....PLEASE THROW IN YOUR .02
  208. keihin spit and sputter
  209. shovelhead engine in sporster frame
  210. got no spark
  211. electronic ignition
  212. 1977 Low Rider OEM parts
  213. From 16" to 21" on FLH
  214. Ultima Wiring Harness on an '81 FLT rebuild
  215. "69" cv linkage?
  216. Saddle bag question for my 1975 FLH
  217. Can anyone help me identify this frame?
  218. 1982 fxrt
  219. Chain guard...
  220. How'd They Make the 74 an 80
  221. Bendix gear removal
  222. rochester two barrel
  223. Hydraulic lifter problem-Time to convert to solids?
  224. shovel
  225. 1982 flt
  226. 68 FLH Electronic Ignition Conversion?
  227. A Simple, Dumb Question
  228. starter just keeps on cranking?
  229. Fork Seals.. First time replacing them, what do I need to know?
  230. Gear housing question (wont shift)
  231. Leaky front Brake...76 FXE
  232. Finished Pics of Bike
  233. Smoking
  234. Roller rockers / Evo style oiling
  235. GMA or PM brakes?
  236. 59-66 front hub on my Shovel, can I update the wheel bearings?
  237. What is it?
  238. primary oil
  239. The BITCH is back!
  240. shovel wont start
  241. battery question
  242. build almost done..
  243. Nightster front end
  244. 1980 FLT chain enclosure - yay or nay?
  245. 1980 FLH-80 Classic
  246. newbe
  247. New member of the family
  248. advance weights
  249. New to Harley's and to the Forum
  250. What is this bike worth?? 1960 HD SHOVELHEAD
