PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Newbie here 82 FLH single fire coil prob
  2. wtf is this rear caliper - split reservoirs
  3. Front master cylinder gasket
  4. S&S Hydraulics Upgrade
  5. FLH Brake Pedal/Arm
  6. Handlebar emergency flasher question
  7. This can't be original paint, can it?
  8. Starter gear/bendix removal procedure
  9. fatty pushrods too long to come out of lifters
  10. Tribal knowledge tell me if this looks right
  11. 1983 FXDG Clutch Hub Studs
  12. 76 flh
  13. Prestolite or Hitachi
  14. took in an early 78 - shimmed front motor mount
  15. '77 FXE Front Brakes
  16. wide rear tire with a chain
  17. '72 FLH wiring diagram
  18. JIMS Powerglide Upgrade Kit #2411
  19. Harley 1979 FLH Purchase
  20. S&S top end mysterious oil issue
  21. Is this bracket ever used?
  22. Charging issue? Hot battery
  23. Shovel head normal noises?
  24. 81 FLT To do list
  25. cylinder and spark plug foul out with black dry soot on rear cylinder only on a 1965 harley davidson servi-car 45 engine whats the problemm
  26. fix that spun cam bearing
  27. Help with front fender bolt size
  28. engine numbers
  29. Stock 1981 electronic advance question
  30. 81 fltc
  31. Buying my first harley as a shovelhead?
  32. Exhaust question for wide glide
  33. starter issues
  34. Nitrous
  35. Totally Surprised......
  36. What brand of paint did HD use in 1982?
  37. Rear brake upgrade question
  38. 1973 shovelhead
  39. 1979 flh 1200 shutting down
  40. Motor mount hardware.
  41. Issue with my 69 flh
  42. Starter Shaft Housing Replacement...
  43. Won't start when hot
  44. Emergency flasher on 1972 FLH
  45. 77 Shovel VIN
  46. Need help with saddlebags install 1973 FLH
  47. truing wheels - cant close to spec
  48. '72 FLH needs a new stator. Which brand?
  49. Just bought a wide glide shovel head
  50. Rocke Box 'O' Ring Replacement
  51. 1985 FLT headlight cover
  52. my new 79 flh
  53. 1982 FLH speedo cable
  54. Restore/Repair Saddlebag and Tourpack Finish
  55. Starter shaft separation.
  56. Rebuild on my shovel
  57. 1980 FXWG Where can you buy points/condensers?
  58. Mid USA 32 Amp Stator - Stock Rotor?
  59. Paint questions
  60. Putting Grandfather's '72 ElectraGlide back on the road
  61. No windshield, looks like a new bike!
  62. flywheels
  63. Back in the saddle again.
  64. Shovel gettin some new shoes
  65. On to the next problem
  66. 1980 FXWG location of Directional Flasher
  67. Crane Hi-4 tough to kick - but pulls hard once started
  68. 81FXWG fork oil amount and grade
  69. Avon Gangster whitewall tires MT90-16
  70. ignition switch, fuses, circuit breakers help
  71. Sprocket vs pulley ratio or 6 speed?
  72. What's wrong with this picture?
  73. Pre 1983 4 speed - what gear oil?
  74. New Starter & Solenoid Not Working
  75. 1972 FLH rear wheel bearing spacer
  76. New shovelhead owner/ need help
  77. tube only for 81 flh spoke mag rim???
  78. '80 FLT electrical issue
  79. exhaust leak
  80. need source for washer 6027 pic included
  81. Headlight doesn't brighten as the engine revs
  82. looking at an '80 FXE...
  83. '72 FLH Ride height?
  84. 1982 FXRS opinions
  85. rocker box year?
  86. service manual
  87. 1972 FLH Stock muffler fit
  88. Time for some intense maintenance
  89. '81 FXS wiring harness
  90. 82 FXB Engine Number Help
  91. help with rear dual piston caliper 81 FLH
  92. Rear terminal plate for electrics question
  93. jubilee horn on a shovel
  94. looking at a shovel later this week
  95. '79 FLH-80 Keeps Eating Ignition Coils
  96. radiator on 78 1/2. why?
  97. 4 speed fork alignmen tool, old ok for newer?
  98. starter disinages too early
  99. Shovelhead maintenance schedule
  100. I'm in here now
  101. How would you fix this: strut not aligning with fender bolt
  102. 1980 flt
  103. Cross threaded Stud.
  104. 1980 FXWG rear wheel not centered
  105. FXE Starter, Solenoid and Relay Wiring
  106. Electrical Issues
  107. Speedo
  108. Beginner & just got my first motorcycle
  109. Cam Choice in Mostly Stock 74
  110. side oling or end oiling cam cover
  111. Year and model please
  112. belt belt baby - 81 flh on the road
  113. 72 flh primary chain alignment/spacer
  114. liberty edition?
  115. no start - blowing oil
  116. 1980 FXWG Color Brown, with brown seat
  117. 73 shovel cylinder head bolt question after rebuild
  118. Police Model VIN
  119. Mechanical pre-trip checklist?
  120. Points v's Electronic Ignition
  121. Vin number question
  122. 1976 FLH Neutral Light Question
  123. alternative seats for 1982 FLH
  124. 1983 flht
  125. Feels Great to be on a Shovel
  126. Starting
  127. Oil line question
  128. Isolating the primary drive question
  129. 1980 FXWG Front end....so...umm....is this right?
  130. Some purists will hate this...
  131. sumping, check ball.. or maybe not
  132. fork oil
  133. Hard time cold kick starting
  134. Chain tension
  135. Should I buy this shovel?
  136. New England Shovelhead
  137. FLH SHovel Head Electric Starter
  138. Bringing the old girl back to life, but she is a little resistant...
  139. Vintage Harleys
  140. 1980 FXWG 41mm Fork Rebuild Question....
  141. Carb Support Bracket
  142. 1980 FXWG fork mounted turn signals
  143. Starter & Solenoid Install 75 FXE
  144. Shovelhead GARAGE FIND
  145. Valve guides:difficulty of replacement?
  146. Fuel Line Routing
  147. Oil starved front head?
  148. no oil pressure
  149. 75 FXE Speedometer Trip Meter
  150. starter
  151. s&s super e gas leak
  152. 76 shovel fx single front disc brake line picture
  153. FX Wiring Options
  154. 75 FXE Carburation Issue?
  155. New FX Fenders......
  156. Need help identifying tank
  157. Opinion? I can't decide...
  158. 79 FLH-80 Need Help with Fenders
  159. '76 FLH ... your opinion
  160. 79 FLH-80 Rear Brake Pad Change
  161. Mounting FXE Tank?
  162. Coil ohm question...
  163. engine keeps flooding
  164. 79 FLH Oil Cooler
  165. 1985 flhp shovelhead oilcooler
  166. 4-speed sprocket super tight
  167. Timing
  168. Jetting
  169. New Gremlin
  170. Occasional Backfire Through Carb At Idle
  171. Oil Temperature
  172. Just Dawned On Me.....
  173. Exhaust Deposit Color
  174. Shovelhead Idle Speed
  175. clutch hub is stuck !!!
  176. Exhaust sound
  177. rocker box oil lines leaky
  178. VIN on 1980 FXS 80 Lowrider
  179. 78 FXE 4 speed clutch help
  180. Ok... what's the trick... pushrod tube keeper
  181. Oil Puking
  182. 79 FLH-80 Update and Clutch Question
  183. 1983 FXSB Speedometer Cable
  184. Need to rebalance and true flywheels if cases split?
  185. Need to rebalance and true flywheels if cases split?
  186. 1980 fxe upgrades
  187. Rusty flywheels...what to do?
  188. 74ci or 80ci ?
  189. Fuel Issue maybe Carb
  190. That has been sitting
  191. I just put my 117 s&s back together but it won't start ,
  192. Starter & Solenoid Recommendations - 75 FXE
  193. Transmission Rebuild Kit?
  194. Popping out the exhaust on my Shovel... Help
  195. 83 FLT no power over 4500 rpm
  196. Clutch Drag On My '77 FX
  197. Loctite all electrical?
  198. Never seen such idiocy in my life
  199. Harley switches
  200. LMAO about this seal!
  201. Oil pipe/Exhaust pipe
  202. Inner Primary Off-what seals should I replace?
  203. Dual Carb Intakes
  204. Mount FatBoy rims to 1979 FLH Frame
  205. What spacers are requirred to mount FatBoy Rims to a 1979 FLH Frame.
  206. 79 FLH80 Dash Filler
  207. Lifter Blocks.....
  208. 70 FLH-80 Spot Lamp and Headlight Questions
  209. oil temperature gauge
  210. 74 FXE circuit breakers
  211. How do you remove engine primary shaft extension?
  212. 1975 shovelhead primary drive?
  213. What's it worth? 82 FXR
  214. Replacing Tappet Guidels
  215. 100/90-19 Does Not Fit A Narrow Glide
  216. flh80 front fender bumper
  217. 4 speed ratchet top trans (aftermarket)
  218. installing compensating sprocket nut
  219. Belly numbers question
  220. pete (iceman)
  221. ID my cam
  222. FXE Newbie frame mount Questions
  223. Stator assembly question
  224. Wiring question
  225. Gas odour 81 FXB
  226. poorly running and I don't know why
  227. 79 FLH80 - Gas Tank Lines
  228. Andrews AB Cam?
  229. Brake Light Activation From Front Master - FXE
  230. New Ride
  231. FLH triple tree repair
  232. Wiring of 5 point ignition shovelhead
  233. Need some schooling
  234. Duplicate Keys
  235. Looking for FXWG pics
  236. Looking for FXB pics
  237. 82 FXR Engine clunk
  238. 1980 FLT clutch
  239. Wheel bearing end play
  240. HELP Shovelhead no spark
  241. Intake manifold question
  242. 79 FLH-80 Turn Signal Wiring Questions
  243. Engine reinstallation 72 FX
  244. Smaller tank on a big twin shovel frame ideas
  245. Shovelhead FLH brake calipers
  246. 79 FLH80 Front Brake Master Cylinder
  247. Questions on 93" S&S big bore engine
  248. 72 flh rear axle spacer direction??
  249. Shovelhead wet primary questions
  250. New '75 project, Rust in Rear Cylinder
