PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32
  1. Shovelhead Pukeing Oil
  2. 82 FLT to road king nacelle
  3. aftermarket cylinders
  4. starter for high compression
  5. Speedo to Tach" Speedometer ID Shovelhead
  6. NJ Mutt
  7. Earley Super Glide questions
  8. '76 shovel stator test again
  9. '80 FLT coming along, need cylinders
  10. Rebuild time
  11. Drag pipes or not
  12. Need a simplified 5 Pole Ignition Switch Wiring Diagram...
  13. Shovel top end "clicking"
  14. Updated pics of my FXE
  15. Tempermental running
  16. New battery for 78 FXE
  17. Blinking headlight
  18. Front Rattling
  19. 79' FXE clutch or transmission problems....
  20. First bike, have questions
  21. transission leak
  22. My 82 FXE, first ride
  23. keihin Butterfly Carburetor?
  24. first Harley, first post
  25. starter jumping out
  26. to do: scratch build harness
  27. looking for transmission
  28. Fxsb 1983
  29. front end help, '76 flh
  30. Hesitation when throttle up?
  31. after a little work
  32. 1981 Heritage- want one- stupid, I know
  33. Gearbox
  34. flywheel scraper modification
  35. The 82 shove is RUNNING!!
  36. Puking oil
  37. shovelhead with kit
  38. Inherited a 69 Electra Glide and have some questions.
  39. A quick hello before the questions flow
  40. Parts?
  41. Pics of momentary switch solder connections
  42. One Of The Last FXWG Shovelheads
  43. FLT Clutch adjustment and rear chain bath
  44. mikiuni adapter
  45. Pistons
  46. 79 sporty not running
  47. Rear master cylinder
  48. 1979 lowrider carb
  49. 78 flh
  50. HAD to pull oil pump
  51. oil cunsuption, top end rebuild, plugs, 2150 miles trip: THE AFTERMATH
  52. spark plugs!!!!!!!
  53. 67' FLH Start up problems.
  54. fender and handle bar suggestions
  55. Open to closed primary
  56. 83 Shovel
  57. Sunday fun in the garage
  58. 1974 flh
  59. 1977 superglide no start just a clicking sound
  60. 79 fxs lowrider oil Wt?
  61. 82 FXR back tire out of line?
  62. 79 FXE F Fat Bob Questions OEM Pic?
  63. 67 numbers
  64. Waiting for shop manual for 80 FXS, Have a few more questions......
  65. Interesting Craigslist
  66. chain length
  67. 1971 Super Glide Boat Tail Inner Fender
  68. Looking for a console for my fairing
  69. Distributor Needed for 69 Flh
  70. Speedometer cable
  71. 78 FLH front cylinder not firing
  72. 76 FXE: Unknown threaded hole in Primary Cover???
  73. Compensator sprocket nut removal
  74. Exhaust baffles on drag pipes
  75. shovel accelration issues
  76. Top End Build on '76 FXE
  77. gas in oil tank
  78. Removing electric start, everything involved?
  79. Air cleaners
  80. Buying a 93" stroker
  81. 81 FXS head light bucket wiring mess
  82. New shovel owner: 77 FXE motor?
  83. 80 FLT Saddlebag Lid
  84. True duals...or those with crossover in rear
  85. Air Cleaner Question
  86. Primary fluid
  87. ever heard o this?
  88. My 1978 fxs lowrider.
  89. 1968 FLH Starter Issues
  90. 79 shovel can't find 2nd
  91. clutch issue
  92. Stretched chain or twisted cam - 1980 FXS
  93. FLH Handlebar Clamp Cover tab Breaking
  94. shock stud size???
  95. Back on the road, missed that feeling of freedom
  96. FLH Thumbwheel Trim Knobs
  97. 1979 flh-80
  98. 1980 flt shovelhead
  99. 1978 fxs
  100. '76 FXE Keihin Carb won't start if choke used
  101. '76 FLH Clutch Noise
  102. piston pin circlips
  103. New to me 82 FLT. Need windshield help...
  104. Side Plates & Sissy Bars
  105. Looking for parts for a 1977 FLH
  106. Bendix Zenith Carb is now working
  107. Clutch Hub Won't Spin By Hand
  108. Need a little wiring help...
  109. 1979 HD Super Glide 1340 starter wont spin
  110. BDL Belt Drive
  111. Where does the horn go?
  112. shovel problems
  113. 71 superglide questions
  114. 1982 fxb
  115. Quick leak question
  116. Shovelhead Value???
  117. 1974 FL Quits running
  118. Bad rap
  119. Gas bath from vented cap
  120. 1984 flhs?
  121. Breaker plate screws - hard to remove on my 1978 FXE
  122. Primary Fluid
  123. 1979 flh-80
  124. Replacement heads 74" 1973
  125. Sparkplugs... again
  126. Gas Tanks for 72'
  127. Swapped out rear sprocket
  128. Early or late 1977 FLHS ?
  129. poll question about FLH verses FLT
  130. Help on shortening final drive chain
  131. Stripped Threads, What Now? 79FLH
  132. Sovelhead or no?....
  133. 77 low rider
  134. Lowrider forks
  135. stator question
  136. 78 flh 1200
  137. Another coil bites the dust!!!
  138. 1983 flhs
  139. Inherited a shovelhead
  140. 78 1/2 not starting
  141. Timing 69 shovelhead
  142. My father gave me this frame. Could someone help me identify it?
  143. Oil pump rebuild (83' OEM pump) - Small lake of oil as result
  144. 197? rear brake caliper. Can u identify?
  145. 1979 H-D Models Flyers / Brochures
  146. 1978 fx. Backfires and misses.
  147. 1972 superglide
  148. starter issues
  149. How many horses?
  150. oil screen
  151. (72' Shovelhead) Need gas tanks - Any info is appreciated :)
  152. Shovelhead noise?? loud hollow ping
  153. Fl exhaust headers for kick start
  154. Busted starter housing.
  155. Removal of starter solenoid questions...
  156. Clutch slipping?
  157. What kind of rigid/shovel would you build?
  158. What coils for Dual plug Shovel with Ultima?
  159. Oil and high beam light stay on
  160. Identify the correct engine for the frame
  161. Sudden loss of compression
  162. Shovelhead WG Flame Tanks??
  163. Primo brute extreme 2 1 1/2 primary
  164. Keep burning up solenoid to starter cables...
  165. Duo Seal Super Nut Questions
  166. Speedometer Help Needed
  167. 1978 1/2 1200cc Low Rider
  168. Oh crap. Someone tell me I can fix this.
  169. What fluid for Tammy?
  170. Could someone help me identify this frame?
  171. Are seats fairly universal?
  172. Shovelhead Clutch Basket Repair
  173. help with oiling problem
  174. Brought back from the dead
  175. Oil line to primary
  176. need cam for stock shovelhead
  177. Older frame
  178. High test gas
  179. 1975 Shovelhead
  180. Can you guys throw out some reasonable prices?
  181. Dead Man's Shovel
  182. Looking for floorboard kit...forward
  183. FLH blowing smoke from front cylinder flouling plugs backfiring
  184. Gonna replace rockerbox gaskets...what kind to replace with?
  185. 1979 FLH-80 Bendix gear removal
  186. Shifter travel
  187. all of a sudden won't run for long
  188. lowering the front of a 1974 FLH which front springs?
  189. Update on the 78 lowrider
  190. 1979 flh-80
  191. Oil cooler issues
  192. How many leaks are too many?
  193. Well I'll start hanging in this forum a bit....got an '83 FLHS
  194. I am in love.....
  195. Which rear wheel for a shovelhead??
  196. S&S E-Carb
  197. Front end probs - Axle caps **PICS**
  198. Power Loss
  199. 1983 FLH Turn Signal stuck on...
  200. Plese help.... need to remove front head on '79 fxef
  201. wide glide front end
  202. 79 Low Rider
  203. Stuck clutch?
  204. clutch adjustment
  205. FLT vs FLH Dual Exhaust
  206. Super B Carb Questions
  207. broken/missing/sheared rivets at ring gear '79 FXS lowrider
  208. First casualty- thrust washer?
  209. Shovelhead Starter Recommendations: Spyke ?
  210. 1981 FLT Classic Seat
  211. Memorial thanks
  212. Shovelhead Electrical Troubleshooting No Lights, No Start
  213. Seat adjustment
  214. Thoughts on this bike?
  215. change fork oil in '76 FXE
  216. 78 FLH- Adding front brake switch?
  217. Machine shop needed
  218. 79 FLH value and opinions
  219. '79 FLH cow pie tranny and starter issue
  220. Adding a Kick Start
  221. Rear Brake Light Switch '75 FLH
  222. newbie - vibration question
  223. Converting a 74inch shovel to an 80incher - need some some advise.
  224. Shovelhead shocks
  225. Brake Fluid Question
  226. Need advise on purchase of a ride
  227. oil lamp is on, oil is flowing?
  228. S&S Super G Carb Jet Setting for 88" Shovel
  229. 1981 Rebuilt shovelhead, reconstructed title. Buy or no buy..
  230. my bike is an odd ball, which year service manual to get 84 FLHS?
  231. New to the forum: Looking for some Shovelhead advice
  232. Oil bath primary pros & cons
  233. Oil bath primary pros & cons
  234. 1974 FLH muffler support tube brackets
  235. Oil issue
  236. shovel oil tank blow back
  237. HH cases, House of Horsepower, Clell Richards
  238. rebuild and light restoration of my FLHS
  239. Wire or Hose Attached To Gas Tank, 80 FLT
  240. Oil temp gauge
  241. S&S Cylinder Casting Number Identification
  242. A calm cough cruising between 50-55 mph. '66 Electra Glide
  243. Copper Washers, and oil
  244. flt drive sprocket
  245. oley event any one go this week end
  246. Blown?
  247. 1+ sifton
  248. pillion pad
  249. '74 FLH sputtering at high RPM?
  250. Intake boots and clamps.
