PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32
  1. 1980 rotary top trans Mainshaft play?
  2. How mount Buddyseat to the frame?
  3. FXE Foward Controls
  4. kicker on a ratchet top 5 speed
  5. Need solo seat for a 76 FXE
  6. Plate between tranny and engine with belt drive
  7. Where do I find the turn signal relay on my FLH?
  8. 93" S&S- OPINION
  9. cold kicker
  10. Howdy all"
  11. 76 FXE oil overflowing from tank
  12. Harley parts made in the US
  13. How to clean a bike?
  14. 1977 shovel custom
  15. Sturgis tank decals?
  16. Carb rebuild on 81 sturgis
  17. My 1980 FXEF80
  18. Re-use rings????
  19. sidecars
  20. Shovelhead advise requested
  21. Speedometer
  22. Shovel shops
  23. Wheel Hubs
  24. 71 shovel pic
  25. Swedish style shovelchopper!
  26. Shovel cylinders
  27. 4speed rebuild - what am I in for?
  28. 82 FXE advice
  29. new forward controls, dot 3 and dot 5 ??
  30. 78 shovel ingition wiring?????
  31. Help color FLH 1978...
  32. Should I buy a Shovel?
  33. ignition problem ??
  34. Narrow Glide Front End
  35. 79 Superglide q for a friend
  36. 71 kicker no spark
  37. RK 530xso chain
  38. 82 shovel cam
  39. keihin year
  40. Low Rider ignition switch
  41. 79 fxe Shovel
  42. my o`l girl
  43. Wont start when cold/no power to starter button
  44. Harley machine shop in Georgia needed.
  45. my best friend's shovel
  46. New Bike
  47. why square
  48. Help on transmission plug 81 4speed
  49. the one and only !
  50. LockTite on Exhaust?
  51. progressive suspension air tail
  52. 1981 FXB Sturgis
  53. Pedistal solo seat
  54. Just bought a 79 FLH... my first harley
  55. Finally a picture of my shovel
  56. '78 FLH indicator switches
  57. good shovelhead maintanence video
  58. 84 Wideglide for sale
  59. New shovelhead
  60. removed
  61. Engine Oil Leaks, 72 FLH
  62. 1980 restoration information
  63. Speedo costing you more than what you'd paid
  64. Electronic Ignition - new product?
  65. Chicago Graigslist 1974 FLH
  66. My Ol' Shovel
  67. My 68 FLH
  68. starting issues
  69. 72 FLH clutch problems
  70. Help: FXE stop switch
  71. Reminder: Beware on VIN numbers
  72. Increasing rake
  73. Frame mod required for stroker
  74. 78 SHOVEL STARTER STAYS ENGAGED
  75. 1978 FLH turn indicators not blinking... short?
  76. Help on a 1982 Shovel
  77. Help! driveability problem
  78. newB needing shovel help
  79. Starter Relay
  80. NO TORQUE/POWER
  81. Shovel FLH exhaust
  82. rocker cover removal
  83. Clutch Or Tranny?
  84. Wiring Diagram for 80 FL
  85. Changing back to Hydralic lifters
  86. 75 shvl primary chain tensioner ?
  87. 68 flh info
  88. 68 flh colours
  89. 1980 fxf never seen an fxf
  90. Back fire through Carb...
  91. 78 FLH not run for 5 years, risks on startup?
  92. Rear Brakes
  93. wide tire kit for 73 fx low rider
  94. 79 FLH clutch adjustment
  95. Value of 80 FLH Classic..Is It Worth It?
  96. Exhaust Question
  97. cam cover/nose cone
  98. 71 fx superglide parts?????
  99. powdercoat or not to powdercoat that is the?
  100. Vance and Hines
  101. Engine RPMs for a 4 speed
  102. Extended brake pedal
  103. Where do you mount and how should I wire a...
  104. oil leaking on ground
  105. newbie bike owner
  106. DC carb tuning,, anyone have information
  107. My bike caught on FIRE!
  108. Getting a Key made...
  109. Carb Jets
  110. Closing shovel crankcase vent.
  111. Wet Sumping - sometimes
  112. 78 FLH Anniversary Model
  113. bike cuts out while driving...problem solved
  114. adjusting pushrods
  115. Parts for your Pre-84 Harley
  116. 73 electra glide
  117. My 69 FLH back at it's Birthplace
  118. Shovel engine ID?
  119. turn signal switchs
  120. Shovel Noise
  121. Wet or Dry Clutch?
  122. Shovels
  123. shovelhead vin question
  124. 82 FLH Main Drive Gear
  125. Question about my new Shovelhead
  126. 1983 FLHT Shovel
  127. 77 flh assembly started
  128. Need help with dash
  129. '82 OEM carb jetting advice needed
  130. Replacement transmission opinions needed
  131. looking for a part
  132. tranny noise
  133. AM I CURSED??
  134. Difference between late & early 79 Shovelhead?
  135. '82 FLH handle-bar wiring
  136. adjusting hydrolic lifter pushrods
  137. Need some info!
  138. Shift pattern backwards, whats wrong?
  139. oil line routing
  140. Paughco Pipes
  141. head bolt wrench??
  142. oil, oil, and more oil!!!
  143. What's the best way to seal off the chain oiler?
  144. Clutch Question???
  145. clutch adjustment
  146. any ideas what this engine noise might be?
  147. need a seat
  148. Slight knocking noise '82 FXE
  149. Thoughts on this 77 FXE?
  150. How hard to replace oil pump?
  151. Fender Question
  152. New Rocker Arms.. Do Ya Grind 'Em???
  153. '82 FXE howling on deceleration
  154. Where to find 3" forward control extensions for FXWG
  155. Need Advice, bucking, and repair manuals
  156. Looking for Pics of FLH w/ Comfort Flex seat
  157. Thoughts on price for 83 Shovelhead
  158. engine misfire
  159. oil leak
  160. Any Ideas??? Breaking Motor Mount Bolts
  161. HELP! Fork Caps Keep Leaking
  162. Out of gas?
  163. breather gear for 1972 flh
  164. ignition module test
  165. 70 FLH pukin oil out the crankcase breather
  166. fouled plugs only at high rpms???
  167. how to align primary trans rear wheel
  168. Seeking opinions on transmission and drive conversions and motor mounts
  169. selling my 83 FXWG-front caliper rattles
  170. Oil in Air cleaner?
  171. Charging System ??
  172. found my pestky leak ??
  173. No spark
  174. Comfort Flex seat question
  175. Pics of my new FXE
  176. carb help please ...
  177. shifter conversion
  178. Resized Pics of my Shovel - 79 FXEB
  179. I am a new HD owner...
  180. Need stock carb for '82 FXE
  181. pic
  182. 81 80"FLT 5 sp...starter fun(need input)
  183. shops that work on shovelheads
  184. Bike not charging
  185. 1980 Shovel primary
  186. Jumps into gear!
  187. 74 super glide
  188. collapsing lifters??? I NEED HELP YESTERDAY!!
  189. Motor builders and price
  190. Neutral switch location?
  191. Just got my first HD
  192. Will a knucklehead fit generator shovel cases
  193. WONT TURN OVER
  194. Marking her spot
  195. Hot list
  196. carb jetting advice
  197. '78 vs. '78 1/2 - How to tell?
  198. Primo belt drive primary - opinions?
  199. Oil cooler on '82 FXE?
  200. clutch and Pri
  201. Late 1978 points ignition
  202. metal prep and engine tear down
  203. shovelhead routing oil lines
  204. 1974 FLH, what's the market value?
  205. S&S Super E vs Mikuni CV
  206. Need some advice.....
  207. loses power at highway speeds
  208. FL v FX
  209. TIRES?
  210. Advice needed re: buying Shovelhead
  211. FORK SIZE
  212. 1981 superglide electrical ignition troubles
  213. 1981 superglide electrical ignition troubles
  214. NEED WIRING DIAGRAM PLEASE
  215. I Need a Book!
  216. Timing
  217. INFO WANTED
  218. Cam help
  219. Shovel newbie
  220. 81 FXE Shovel
  221. Potentially Stupid Question on Cam Lift
  222. no spark
  223. Is this 78 shovelhead FLH worth the price? Quick responce needed!
  224. starting problem
  225. S&S diagram
  226. oil leak!!
  227. shovelhead noise!!
  228. 1976 Superglide..what to look for?
  229. Sealed Wheel Bearing Removal Help
  230. Restoring 69 FLH
  231. 72 FL exhaust
  232. front cylinder
  233. S&S help
  234. S&S Reed-type Breather Valve
  235. tranny problems
  236. Roller rocker's
  237. Speedo Drive Re-Location???
  238. Cough, power loss, dies @ highway speeds
  239. Fresh Build.. How Much Oil In Crankcase?
  240. Front Brake control
  241. '69 Shovelhead Custom
  242. will not start
  243. Trans-swingarm removal?
  244. Did I get ripped off on repairs?
  245. dies on deceleration <fixed>
  246. 82 FXRS build
  247. Buddy Seat Comfort
  248. lifters
  249. 78 Early / 78 Late ??
  250. another BDL question
