PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. '77First Gear Problem
  2. Extend brake pedal 1983 FLT Shovelhead
  3. 84FLH has spark, fuel...will NOT fire...?
  4. 81 FXE starter trouble
  5. Shovelhead Inner Primary Part Interchangeability
  6. NOS FXWG Side Plates
  7. No fire to plugs
  8. Will it fit and how?
  9. Popping noise from engine
  10. Seating IP transmission shaft main bearing 9040
  11. Hard starting
  12. FLH speedo
  13. Swap faring for light-bar and windshield
  14. No fire
  15. What's going on ? the spark plugs come out with oil on the electrodes
  16. 84 shovelhead broken Ignition timer cover STUD
  17. I Keep snapping wires...what to do
  18. Spark plugs fouling. Dry carbon? pictures
  19. '76 FXE: Clutch cable keeps getting loose
  20. Spark Plug Threads Question
  21. Static Timing - 1975 FXE
  22. Date of Manufacture
  23. Uneven rear brake pads
  24. Will a Scissor seat mount fit my 1984 FLH? Pics attached
  25. Need SEAT help!
  26. Converting from aluminum wheels back to spoked
  27. 1979 FXE quit charging
  28. Exhaust Pipe Bolt Removal
  29. Question for the originality crew...
  30. Forward control brake lines
  31. Bendix zenith float height
  32. My 77 Clutch Basket...
  33. Backwards Shovel
  34. New-b Shovelhead question
  35. Choke Cable
  36. Original FXWG Seat
  37. Super E hiccup while coasting
  38. Just pulled the trigger on a 1983 FXR
  39. NOS Brass Eagle Sissy Bar Insert
  40. Front fender interchange flh
  41. Need help converting 71 fx to jockey shift/foot clutch
  42. Passenger foot rest options for 74 flh with kicker
  43. Setting Super E float level question
  44. Is there such a thing as a 77 FXE Willie G Edition?
  45. Question about solid lifter conversion parts
  46. Inner Primary question
  47. Help identify this tank
  48. New Member - Hello
  49. So i got this '74 flh...
  50. Baker 6 to 4
  51. 1982 FLH rear chain size
  52. Noise in rocker = engine out?
  53. New project
  54. 69 Electra Glide Generator Shovelhead
  55. Putting intake back together again
  56. 1984 FXSB Handlebar Vibration
  57. White smoke out of carburetor
  58. 1969 FLH Shovelhead Build is a Radical Swingarm Chopper
  59. Advice on rear sprocket
  60. 1974 FLH Misfiring
  61. What rebuild kit for these Lifeline forks on 1980 FLH?
  62. What to do with this 71 FLH
  63. 66 FLH lamps in nacelle
  64. Lifters
  65. Starting problems...
  66. Clutch issues
  67. 4 speed tranny wont kick!
  68. Clutch mod recommendations for '80 FXEF
  69. 1984 fxwg
  70. Tamer and BDL Big Fix Roller Bearing way to go?
  71. The dog dish carberetor cover
  72. Ignition points cam questions
  73. S&S Super E Shovelhead Blues
  74. Need Head Work done anyone know of anybody in Ma
  75. LED Flasher Issue - '75 FXE
  76. 1976 shovelhead
  77. Springer brakes
  78. FXS restoration : Can you help me ?
  79. Muffler rankings
  80. trying to roll on this for real
  81. the shovelution is ready
  82. starter housing
  83. seat height 1983 FLHT
  84. Clebrake front caliper on '75 FXE
  85. Did the 78.5 fxs lowrider come as a 1340 even with the vin starting with 2f
  86. Tank model/year question
  87. '76 FXE: Starts cold, won't start warm. WTF?
  88. 1978 FLH Swingarm hitting crash bar
  89. front end interchange
  90. Converting hydraulic tappets to solids
  91. Inverting hydraulic tappets to solids
  92. Headlamp Wattage & Amps
  93. Dumb Question....
  94. superglide tank on flh
  95. '76 FXE: Can you identify these?
  96. Bone Stock FXS Rear fender
  97. reusable oil filter works I think
  98. Messed up pretty bad,need advice
  99. how to adjust a ultima 2 carberetor
  100. Compression for stock cases?
  101. '76 FXE: It started!!! And then it puked....
  102. Saddlebag Gasket Residue
  103. Bottom End Longevity
  104. my shovelution
  105. took a trip on the twinkie after the rain
  106. rear pegs
  107. scorcher tires
  108. shinko tires
  109. 73 Shovel Carb leak
  110. Points conversion
  111. Break
  112. Time for new cases
  113. Starter Ground Wiring (Y/N): '76 FXE
  114. Dash Wiring
  115. Progress with the 1982 FLHC Belt Drive Classic "barn find"
  116. oils
  117. Wiring harness pin thingies in headlight?
  118. Tach Shows 1500 RPM - Engine Off - '75 FXE
  119. front primary oil fitting
  120. starter rurning too slow
  121. Racepres you may have missed this one the coil has a part number
  122. Sportster tank on a big twin.
  123. Overheating?
  124. Seat Skirt
  125. Ultima external electronic ignition module
  126. Using cow pie gearset in ratchet top?
  127. evo speedometer?
  128. Rear brake inspection
  129. 83 fxrs with enclosed chain
  130. Ultima electronic iggy woes
  131. Pushrod Tube Leak, middle seal only
  132. Coil choice Need opinions
  133. New to shovelhead. New to this thread
  134. Shop to replace/ream cam cover bushings
  135. Is an external ignition module better than in the cone
  136. Pogo Seat Passenger Options
  137. Edelbrock Carb
  138. Edelbrock Carb
  139. Lower Tank Mount.....
  140. Another Gas Tank Opinions Wanted
  141. Can you use sealant on tappet blocks.
  142. Reproduction tanks for 1980 FXWG
  143. Am I stuck with O-ring intake?
  144. How To Remove The Headlamp Mount Cover - 75 FXE
  145. Coil Wire Got Very Hot - 75 FXE
  146. The prettiest Harley engines in this order
  147. Saddlebag restoration project
  148. cca battery for a fxef 1981 superglide
  149. FXE gas tank question
  150. 83 fxr
  151. spark plug
  152. Good Shovelhead FAQs?
  153. 1982 FXR Shovelhead valve seats
  154. Fishtail MUFFLERS for late shovel FLH not FLT
  155. 1977 fxe
  156. Had a friend blast a head
  157. Original Tins.....
  158. Slap me...don’t work on the bike when tired!!!
  159. Ultima R2 Performance Carburetor vs S&S Super E
  160. Keihin question
  161. Removing clutch hub off tapered shaft
  162. SuperGlide License Plate Mounting??
  163. 81 FXS - Compensator Nut
  164. Trying to identify a part...
  165. Are these timing marks correct?
  166. 2005 and 1981 harley davidson
  167. battery for 79 flh
  168. A good service manual
  169. starter drive gear is malfunctioning
  170. Tech Tips & Tricks and other books
  171. Signal lights not working
  172. Front Wheel Question
  173. Ignition switch problem
  174. Installed cam bearing “backwards”
  175. Molested 1983 FXRT, a few questions.
  176. 1983 FXSB primary belt or not
  177. 72 shovel cam and breather end-play
  178. Favorite cams
  179. Shovelhead leak down test results
  180. think I maybe the only one with this problem
  181. 1981 FXS Lowrider - Wiring and Starting Help
  182. Rockerbox gaskets - Removing heads vs. pulling engine
  183. 1978 fxe
  184. What else besides stroker flywheels?
  185. trike
  186. Need opinions on fork brace
  187. Removing stubborn tappet blocks
  188. 1966 FLH Electra Glide
  189. Late ‘84 electric start not shifting right.
  190. 81 Tour Glide Saddlebag Swap
  191. Dads 80flh Cases to split or not???
  192. wow spark plugs always a headache
  193. '81 FLT Tour Glide Saddlebag Lid
  194. Removing hinge from FLH rear fender
  195. why do a shovelhead sound different from other bikes
  196. 79 fxe.....
  197. 1981 FXS Lowrider - Dyna Ignition Swap
  198. Primary cover won’t come off
  199. 1982 Triple Shovel: One-off Three-Cylinder H-D
  200. Part number needed
  201. S&S Super B Questions
  202. 1965 pan/shovel (panhead w/shovel head top end)
  203. Transmission ?.?.?
  204. single fire and dual fire which one better
  205. Headlight Nacelle Finish
  206. trike
  207. A Permanent Fixture......LOL.....
  208. Ultima heads???
  209. Neutral light and gen light stay on
  210. 80 flh clutch assembly
  211. Next project - a few unknowns 1982 FLHC
  212. My speedo Died
  213. Value of Shovels
  214. 1980 low rider
  215. stainless steel exhaust pipes
  216. feel guilty
  217. 2 inch shotgun pipes for my 83 fxr????
  218. Geeting to know my bike
  219. valve stem seal
  220. Rebuilding dads shovel
  221. 1983 93” shovelhead 5 spd
  222. Rebuilding/restoring my dads shovelhead
  223. Rebuilding/restoring my dads shovelhead
  224. Clutch springs
  225. 1981 FXS Lowrider
  226. 1978 H-D FXS Low Rider Original
  227. relay
  228. 1983 FXDG Disc Glide Rebuild/Restore
  229. Fitting cam cover to new cases
  230. Ham can grille
  231. Lever Action Solenoid
  232. Riser installation question
  233. piston identification
  234. next question, intake manifold
  235. Fender?
  236. What Am I?
  237. 71 engine shaft
  238. Front end options?
  239. Mystery Bolt
  240. Progessive shock bushings
  241. fx rear shock choices?
  242. Fuel fumes/leak checklist
  243. Shovelhead Compression issues!!!!!!!!!
  244. Whaddya' think about this '70?
  245. Looking for little guidance
  246. Gas cap venting
  247. motor identification
  248. Headlight assembly what is this?
  249. rocker arm shaft
  250. '77 FXE sprocket size question
