PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33
  1. What is it?
  2. primary oil
  3. The BITCH is back!
  4. shovel wont start
  5. battery question
  6. build almost done..
  7. Nightster front end
  8. 1980 FLT chain enclosure - yay or nay?
  9. 1980 FLH-80 Classic
  10. newbe
  11. New member of the family
  12. advance weights
  13. New to Harley's and to the Forum
  14. What is this bike worth?? 1960 HD SHOVELHEAD
  15. Mid control Photos needed, please.
  16. Rocker Arm Shimming kits
  17. Big bore Shovelhead
  18. Finally Going to do it.
  19. 4-Speed Rotary (Matag) Trans
  20. Hone or not...
  21. Was this a good buy for $6000
  22. Removing a shovelhead motor and transmission
  23. Anyone have experience going to dual spark plugs?
  24. oil out of breather pipe on startup
  25. What frame do I have
  26. Starting a Moth-balled Sovelhead???
  27. 78 Shovelhead, whats it worth?
  28. flh rear wheel has lots of drag
  29. Looking at a 77 FLH, have questions
  30. '68 Electra Glide Restoration
  31. 1981 Harley Davidson brochure regarding Sturgis bike
  32. hea scooter heads have a 80' fxe need advice?
  33. 80 FXEF seat and bars?
  34. Got to Ride Today!
  35. FL front fender fitment
  36. cams ???
  37. 78 Superglide
  38. In the market for a shovel...have you ever...
  39. engine ping
  40. Transmission Fluid Specs
  41. how do I clean the bottom end
  42. 1983 FXRT fuel gauge/sender
  43. starter
  44. Nostalgia Motors Shovel
  45. Brake system & proper fluid
  46. Shovelhead Advice
  47. '84 shovelhead lowrider questions
  48. '78 FLH re-build...thoughts?
  49. cam and piston recomendations wanted
  50. 2000-06 FXST for 1973 FX
  51. 80"shovel wiring harness????
  52. 80-83 brake up-grade
  53. 69 exhaust options ????
  54. 1976 shovelhead Fx in need of a 74" rear jug
  55. FXB Sturgis question
  56. 1973 FX Superglide
  57. 1983 FLHT Shovel Seat Question
  58. 76 Shovel w/dry primary
  59. 1980 FLH Fork Tube Length?
  60. help with new engine build
  61. Shovelhead pin and keyring
  62. is it worth $7,000.00?
  63. rewiring 76 shovel
  64. '84 FL Fork Conversion Question
  65. 1982 FXR Primary Case - Need To Vent?
  66. points question
  67. Smoking at ide
  68. Advice on 1980 FLT80...
  69. Help finding picture of 67 shovelhead frame
  70. Heat Shields?
  71. new build 77 flh any good tips
  72. Octane Boosters, Lead, Fuel Additives?
  73. Best Battery to use??
  74. 1980 FXE 4-speed tranny leaking...
  75. dry primary leaking
  76. Kicker Stuck
  77. Axle's/ 2006 wheels on a 1981 FXEF
  78. Clutch cable travel all of the sudeen too long
  79. 77 fxs
  80. super e problem... i think
  81. modern bags on old brackets???
  82. Shovel blows oil out breather line (78)
  83. h4 headlight install help
  84. Why Can't I Post on Want to Buy Forum?
  85. Help with not shift in 1st gear
  86. Duel plug heads????
  87. Stator Question on my Shovelhead
  88. 82 fxr shovel
  89. Front and rear axle layout: 1980 FXEF
  90. Im going blind looking at grips!
  91. Best lube for primary?
  92. Lower end rebuild...
  93. Pics of my 1980 fxe super glide
  94. Bike dies after 5 minutes of running
  95. new starter drive hanging up
  96. Removing Bendix and Pinon shaft on a 69
  97. Shovelhead parts in Vegas or Miami?
  98. Shovel Head motor torque values
  99. just a few questions about my shovelhead
  100. 1973 FX Superglide Intake/Carb
  101. 67 FLH-New to the group
  102. lost rear cyl.
  103. Advice needed: FXB Sturgis
  104. front pulley
  105. Quick! Is this a good deal?
  106. Some Progress
  107. Front turn signals for my '77 fxs
  108. 88" shovelhead with Mikuni HSR42
  109. '79 FLH 80 Cube Stator info
  110. noob with some questions for shovelheaders
  111. '74 FLH starter going out?
  112. fatboy wheel
  113. Bent handlebars
  114. Anybody have an Idea ? triple tree ID
  115. Need some help with some old shovel saddlebags
  116. Best Looking Frame of All Time
  117. Brake Light switch question.
  118. passenger pegs and drag pipes
  119. Dry primary makes engine very wet!
  120. Stripped down bike
  121. Low end hesitation
  122. simple wiring diagram?? 81' fxs
  123. 83 FLH Belt Trans Upgrade
  124. Grabbing Clutch
  125. Best battery for a '66 shovel?
  126. shovel woe's
  127. Handlebar controls...old v. new
  128. Starter "Roll Pins" are they really necessary?
  129. In CA, need my '66 FLH painted - any recommendations?
  130. Shovel Rocker Bolts
  131. red tank strips 1976 fxe
  132. Oil leak - electronic compensating sprocket on '78 FLH??
  133. Traded my 68 FLH
  134. More pogo stick help please?
  135. First manufacturer of internal stop head parts?
  136. Breakers
  137. Replacing 1:1 speedo with a 2:1
  138. 1983 Shovel
  139. good battery, no lights or horn or elec. start
  140. cuts out at high rpm
  141. HI new 79 FXS Here
  142. What went wrong???
  143. New member.
  144. Oil leaks!
  145. line out of lifter block?!
  146. rear suspension
  147. Pogo stick help please
  148. diaphragm clutch installation on '78 FLH advice needed
  149. 82 fxr clutch makes a scraping noise
  150. rocker boxs 1976 fxe
  151. decals 1976 fxe need help
  152. Top end suggestions
  153. Andrews AB question
  154. 79 shovel kickin back
  155. 75 FLH won't keep running
  156. Early FLH Front Disk brake fixes
  157. Need some help with bike value
  158. New to forum
  159. 1968 or 1969 FLH?
  160. Where Do You Order Parts?
  161. Charging Issue
  162. what is best source for shovel motor
  163. spit & sputter
  164. 1340 carb
  165. Shovel Riders 6' and taller..
  166. 75 shovel sumping oil
  167. Difference between FLH/FXE
  168. My "new" 1980 FXE Super Glide
  169. Vin number location
  170. 1975 FLH fork leak
  171. Grounding problem
  172. 77 FLH waddayathink?????
  173. 1983 Tour Glide
  174. Drive fianl drive and a 57 straight leg frame
  175. dyna shovel
  176. Hard Starting Shovel
  177. Tire pressures, Please!
  178. Bendix Carb Question
  179. 1984 Shovelhead Ignition Module
  180. Turn signal issue
  181. solid tappets
  182. stripped starter mounting holes
  183. Signal flasher
  184. Shovel Top End
  185. Points or Electronic?
  186. 72 flh value
  187. Shovel wont start
  188. Auction tomorrow
  189. FXE & FX the defferance
  190. Help with Vin location on neck
  191. noob with a few questions
  192. 1976 Superglide Bicentennial Shovel
  193. From the touring section
  194. Tank Decal, Badge or Paint?
  195. '04 Road King
  196. Identifying Starter Ring
  197. whats it worth
  198. cuts out at hiway speed
  199. should i or sould i not
  200. Shovelhead Battery cover?
  201. Need a Fairing for a 1980 FLHT Shovel
  202. blew out plug on highway....SURPRIZE!!!!!
  203. 74 FLH problems with rear chain oiler
  204. 79 FLH Ignition points
  205. Shovelhead, Best Years
  206. quick question on my shovel head
  207. Installing kickstarter on shovelhead
  208. want crank @#&* it
  209. tranny swapping
  210. My 78 Low Rider restoration project
  211. Decals
  212. 78 Low Rider..what's it worth?
  213. Pops out Carb
  214. oil leaking
  215. fork oil ?
  216. worn-out exhaust port on rear head
  217. 1983 FLHT Front Caliper noise
  218. clutch not engaging
  219. front sprocket 1976 super glide
  220. Shovelhead starting problems
  221. valve knock
  222. need help with my tranny!!
  223. mid control shift linkage advice?
  224. '74 FLH correct tank badge?
  225. 230mm tire on a shovel Reviews of using a wide tire kit for them?
  226. 83 shovelhead
  227. Why aren't people jumping on this Shovel?
  228. '74 FLH need new gaskets?
  229. I need help with saddlebag brackets for my 1975 FL
  230. 79 fxs no spark
  231. starter shaft/clutch
  232. motor size
  233. need help identifying numbers on heads
  234. 74 FLH pours oil...
  235. swingarm bearing pre-load
  236. FXE SuperGlide Air Filter cover
  237. Starter issue.
  238. 1981 FXE shovelhead paint color and decals
  239. 73 sporty- no rear spark
  240. Rattling taillight
  241. Oil on start up
  242. Do you know who makes these cases?
  243. 77 FXE Suprglide electric start button problems
  244. Circuit Breaker locations
  245. oil for my shovel head
  246. But yet another clutch issue
  247. But yet another clutch issue
  248. Thoughts on lowering fxs
  249. Can You Put A Shovel In A Softail Frame
  250. seat change 72 fx
