PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. 72 flh speedo with tach wiring?
  2. Will these mirror be right?
  3. Need opinion on a shovelhead.
  4. 1979 Electra Glide Shovelhead comfort flex
  5. Charging 'amps' explained?
  6. 1979 Electra Glide Shovelhead
  7. New to the Shovelhead
  8. What kind of starter relay on 73 FLH?
  9. What kind of starter relay on 73 FLH?
  10. Clutch Hub Stud Issue
  11. hydraulic lifter adjustment / valvetrain noise?
  12. Mousetrap/clutch spring question
  13. Toggle switch
  14. Any Good Shovelhead Mechanics in Houston TX?
  15. 1973 FLH 4-speed noise.
  16. solids to hydraulics: pushrods suggestions
  17. Coating My Jugs
  18. 1983 FLT 6100 miles!!!
  19. Tranny help.
  20. Black '75 FXE Engine Case
  21. Broken Ankle
  22. Rear Master Cylinder plunger stuck
  23. Smoking after new topend
  24. synthetic oil
  25. What Gives....?
  26. Tire Recommendations
  27. Shovel won’t start
  28. Safety wired lug bolts.
  29. Super Glide Boat Tail or not???
  30. 77' Flh dash wiring
  31. 86 fxrs
  32. 1980 flt primary issues....a plenty
  33. Forward controls/floor boards
  34. Stocking up the Toolbox...
  35. what model and yr is my shoveled
  36. Rocker boxes.
  37. Blacked Out Chrome....
  38. help with cables
  39. Combined speedometer-tachometer
  40. Hey, from Baltimore, MD
  41. Interchange questions
  42. shovelhead flywheel ID?
  43. windshield
  44. ultima oil pump 73-91 big twin
  45. S&S Shovelhead
  46. 81 Low Rider front cylinder running hot
  47. Neutral Switch Location
  48. Chain Oiler On A '75 FXE?
  49. 1980 shovel
  50. 83 Fxr starter problem.
  51. Anyone running the stock 2-into-1?
  52. 1970 FLH - handle bar mount torque
  53. kicker stuck at 12
  54. Harley 4-speed Transmission Rebuild Service?
  55. stinkin aftermarket oil pump - ball seat not machined
  56. Leaky Bolt
  57. High Beam Indicator Bulb Removal
  58. Fueling Lifters
  59. Yard Sale Cam
  60. 10" rotor on a newer 21" wideglide wheel for FLH
  61. 1982 FLH top engine bracket
  62. new member FLT questions
  63. Oil out the breather
  64. Mixing oils in the transmission good or bad idea?
  65. 1974 flh help
  66. tubeless tyres
  67. Clean-up on butchered fender
  68. Head Gasket Maybe?
  69. Shovelhead Motor Removal
  70. Need help on starter solenoid
  71. Roadside exhaust fix
  72. correct sparkplug and gap too suit Crane HI-4 Dual Fire ignition on a Shovelhead
  73. Top End Upgrades For A '74 Cube Shovel
  74. Oil Seep At Cylinder Base
  75. Showa Forks, No Damper Spring?
  76. TRW Pistons with 45" T-slot pins - 3/32" rings
  77. Lifelong dream. got myself a shovel!
  78. Shovelhead Kicker Grind
  79. String Damper?
  80. Brackets for overload spring on Pogo seat?
  81. Correct Part Number for 1972 FLH Mufflers
  82. How do I remove headlight nacelle on 1984 FLH
  83. 1978 FXE Exhaust and Muffler
  84. Valve Guide OD and sizing
  85. Next problem: Carburetor
  86. 1983 FXDG Shorty Exhaust
  87. Building a shovel chop.. need some advice
  88. Might need a memory jog here...
  89. 1983 FXDG vin# sticker
  90. Shocks - Any Magic?
  91. Pushrod Tubes - early or late?
  92. Sato Marine Cycle's 1968 Shovelhead
  93. One Dead Shovelhead
  94. Research For a Book
  95. 1981 Heritage Edition
  96. knucklehead rear panhead front shovelhead cone bottom
  97. Delkron Lower Sump Cases
  98. Gas tank leak, Repair of the leak repair
  99. Bore Size of front master cyl 1980 FXS
  100. more pics of my shovel head project
  101. ‘76 FLH Won’t Idle
  102. Any Pics and Thoughts On Older Mac Brand Exhausts?
  103. POS hand controls
  104. Help wiring new ignition
  105. S&S carb ignorance
  106. 30 Amp Circuit Breaker Location
  107. 10" or 11.5" discs?
  108. new ignition question
  109. Front Wheel Drive FL speedo Cable
  110. CV Carb
  111. Speedo Drive Issue
  112. Ignition Module 84 FLH
  113. Brake Fluid
  114. Painting lowers on 71 fx
  115. 83 FXWG Restoration
  116. boatail vin typical sequence
  117. Sealing a gas tank?
  118. 1977 shovel flywheel #'s- "J1932-2AL". Anyone able to I.D, them?????
  119. Maybe an Interesting Read for First Time Buyers or Anyone with advice 1974 FXE in a 1964 Step down Frame? Is it Legal or Even Possible?
  120. This 1976 Shovelhead Trap May Get You Into Big Trouble
  121. Ignition for 1984 FXSB
  122. 1971 Super Glide Club
  123. My shovel
  124. FLH Starter only spins when spun by hand.
  125. FLH Starter only spins when spun by hand.
  126. starter grinding
  127. Question on tappet lifter assy
  128. What are these?
  129. 83 FXDG Shift Lever Problem
  130. Up grading for performance and reliability.
  131. Custom Cable
  132. 81 FLT front fork sliders
  133. New bags for the 84 FXSB
  134. SIFTON hydraulic tappeds
  135. Kickstarter for 81 FLT???
  136. New Bags
  137. Parts
  138. Super E on Shovelhead
  139. Generator Shovelhead belly numbers, where are they?
  140. 64 Pan tank emblems on 68 tanks???
  141. screw
  142. Brake drums
  143. High Idle - Carb Binding?
  144. FLT/FLH rear caliper upgrade info needed!
  145. tour pak install info for architect
  146. Trying to set timing, what is this.
  147. Bore size
  148. Ignition Coil Location
  149. Voltage Regulator Relocation
  150. 1988 fxrs starting problem FIXED
  151. 71 shovel clutch push rod
  152. FL vs FX rear fender struts.
  153. Don't understand
  154. Starter question
  155. Engine Paint
  156. Lifter ?
  157. Low Rider Exhaust Question
  158. Changing triple tree question
  159. Aftemarket inner primary Ok? Bad?
  160. OIl Pump - Pressure Switch
  161. White exhaust smoke
  162. Agm batterys
  163. 1979 flh 80 fork slider bushings
  164. Trans Upgrade 80 FLT
  165. 1979 FXS Rebuild
  166. 74 electra glide brake question
  167. Paint color codes
  168. Shovel lounge-n-Café
  169. 1970 FLH Wing type Petcock
  170. Oil Blow By, Overfill or Other?
  171. Garage Find
  172. 1975 FLH throttle cable?
  173. 4 speed issues
  174. Rocker box question
  175. Rear Foot Peg 7/16" 14 Pitch
  176. 1980 FLT eng tick
  177. Dipstick question the one in the bike not on it
  178. Diaphragm clutch spring?
  179. Looking for Solo seat Recommendations on a 79' FLH 80
  180. Top End Questions - '75 FXE
  181. Lever start in place of starter solenoid.
  182. Speedster Bars
  183. Customizing Rear Brake Mount / Bracket
  184. Need to oil primary after oil change? ‘75 FXE
  185. Exaust gasket leakes?
  186. FXS Upper Triple Tree - Problems Ahead?
  187. help id shovelhead number
  188. Forward Controls
  189. 'O' and X-Ring Chains - Worth The $$???
  190. how do I unclog oil passage in front rocker box/
  191. 80 cubic inch with 74 jugs and haeds?
  192. How do you put a 72 FLH dash together?
  193. Shovel Chopper Build
  194. Bent frame?
  195. Starter Solenoid Issue
  196. Clutch/tranny bound up?
  197. how much oil primary 77 FXE with factory oiler after replacing primary gasket
  198. Primary oil required after gasket change in front oiler system
  199. carb puff on hot restart
  200. 82 wide glide bobber build
  201. 77 flh starter relay
  202. can i use76 sh fxe parts on a 80sh fxe?
  203. 77 FXE Rear Fork Bearing Upgrade....
  204. Hybrid Kicker
  205. they all do that
  206. Clutch Adjustment
  207. might try and save this 67 trike - thoughts
  208. Old Seat.... New Seat....
  209. 1980 fxs start problems
  210. 1978 FLH handle bar right buttons
  211. problem with my forks??
  212. Shovelhead dies when hot, I'm out of ideas
  213. 1970 FLH rear chain adjustment
  214. Help! Hard tail frame
  215. OEM Speedo?
  216. Shovelhead dragbike anyone?
  217. Inaccurate Speedo......
  218. 70 shovel, coil or fuel?
  219. Quick measurement needed on FLH
  220. 83 Fxsb starter gear bouncing around
  221. how to tell the difference between points and electronic ignition
  222. hydraulic untis - just swap them?
  223. Found a shovel!!!!
  224. Quality Gaskets
  225. Rockers braided oil lines
  226. 70 shovel, coil or fuel?
  227. 70 shovel, coil or fuel?
  228. Speed Drive Location?
  229. Adding 2 Fuel Gauges...Possible? How?
  230. 1982 FLT cast rear wheel orientation
  231. coil replacement
  232. Pushrod adjustment
  233. New Gas Caps?
  234. Speedometer cable interchange
  235. slap or thump at idle
  236. Great Day Wrenching....
  237. Brake Lights
  238. oil tank puffin - breather puffin - all a-Puffin
  239. Help with head gasket
  240. Advise the price WLA
  241. Rivera pro clutch
  242. '72 FLH front forks
  243. Custom 78' shovelhead
  244. 1976 Shovelhead restore guidance
  245. Improving Oil Flow After Pump/Valve Train Upgrade
  246. 1978 Electra glide oil tank
  247. impressions of the andrews "tall" 1st and 3rd
  248. New Bars......
  249. Clutch Pushrod adjustment
  250. Evo umbrella install?
